[fusion-commits] r1402 - trunk/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri May 9 13:32:39 EDT 2008
Author: madair
Date: 2008-05-09 13:32:39 -0400 (Fri, 09 May 2008)
New Revision: 1402
   trunk/lib/Map.js
re #2: only issue a warning if the metersPerUnit value differs from what was previously set
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2008-05-09 17:32:10 UTC (rev 1401)
+++ trunk/lib/Map.js	2008-05-09 17:32:39 UTC (rev 1402)
@@ -652,8 +652,10 @@
             Fusion.initUnits(metersPerUnit);
             this._fMetersperunit = metersPerUnit;
         } else {
-            Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
-                                'meters per unit value already set'));
+            if (metersPerUnit != this._fMetersperunit) {
+                Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
+                                    'meters per unit value already set'));
More information about the fusion-commits mailing list
