[fusion-commits] r1607 - in branches/fusion-1.1: . text/en text/fr
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Oct 27 10:04:31 EDT 2008
Author: madair
Date: 2008-10-27 10:04:31 -0400 (Mon, 27 Oct 2008)
New Revision: 1607
Added:
   branches/fusion-1.1/config_dist.json
Removed:
   branches/fusion-1.1/config.json
   branches/fusion-1.1/text/en/strings.json
   branches/fusion-1.1/text/fr/strings.json
re #42: renaming config.json and adding more info to config load error message
Deleted: branches/fusion-1.1/config.json
--- branches/fusion-1.1/config.json	2008-10-24 19:42:02 UTC (rev 1606)
+++ branches/fusion-1.1/config.json	2008-10-27 14:04:31 UTC (rev 1607)
@@ -1,37 +0,0 @@
-/* This is the fusion configuration file.  Adjust as necessary. */
-    /* The general section contains settings that are general to
-       fusion as a whole. */
-    "general": {
-	    /* PHP is the default and only script language supported.
-	       Don"t change this. */
-	    "scriptLanguage": "php",
-	    /* A directory on this system that fusion can use for
-	       temporary files. */
-	    "temporaryDirectory": "/tmp"
-    /* The MapGuide section is required if you are installing
-       fusion for MapGuide. */
-    "mapguide": {
-	    /* The WebTierURL is the url to mapguide, it should start
-	       with http and end with /mapguide.  If you have installed
-	       fusion inside the www directory of MapGuide, then you can
-	       leave this empty as it will be automatically calculated. */
-           "webTierUrl": ""
-    /* The MapServer section is required if you are installing fusion
-       for MapServer. */
-   "mapserver": {
-	    /* The URL of the mapserver CGI that you want to use.  */
-	    "cgi": "/cgi-bin/mapserv",
-	    /* The file system path to where mapserver should put
-	        web-accessible temporary images. */
-	    "imagePath": "/tmp/ms_tmp",
-	    /* The URL to the image path configured above. */
-	    "imageUrl": "http://localhost/tmp/ms_tmp",
-	        web-accessible temporary legend images. */
-	    "legendIconCacheDir":"/tmp/ms_tmp"
\ No newline at end of file
Copied: branches/fusion-1.1/config_dist.json (from rev 1575, branches/fusion-1.1/config.json)
--- branches/fusion-1.1/config_dist.json	                        (rev 0)
+++ branches/fusion-1.1/config_dist.json	2008-10-27 14:04:31 UTC (rev 1607)
@@ -0,0 +1,37 @@
+/* This is the fusion configuration file.  Adjust as necessary. */
+    /* The general section contains settings that are general to
+       fusion as a whole. */
+    "general": {
+	    /* PHP is the default and only script language supported.
+	       Don"t change this. */
+	    "scriptLanguage": "php",
+	    /* A directory on this system that fusion can use for
+	       temporary files. */
+	    "temporaryDirectory": "/tmp"
+    /* The MapGuide section is required if you are installing
+       fusion for MapGuide. */
+    "mapguide": {
+	    /* The WebTierURL is the url to mapguide, it should start
+	       with http and end with /mapguide.  If you have installed
+	       fusion inside the www directory of MapGuide, then you can
+	       leave this empty as it will be automatically calculated. */
+           "webTierUrl": ""
+    /* The MapServer section is required if you are installing fusion
+       for MapServer. */
+   "mapserver": {
+	    /* The URL of the mapserver CGI that you want to use.  */
+	    "cgi": "/cgi-bin/mapserv",
+	    /* The file system path to where mapserver should put
+	        web-accessible temporary images. */
+	    "imagePath": "/tmp/ms_tmp",
+	    /* The URL to the image path configured above. */
+	    "imageUrl": "http://localhost/tmp/ms_tmp",
+	        web-accessible temporary legend images. */
+	    "legendIconCacheDir":"/tmp/ms_tmp"
Property changes on: branches/fusion-1.1/config_dist.json
___________________________________________________________________
   + Author Date Id Revision
Modified: branches/fusion-1.1/text/en/strings.json
--- branches/fusion-1.1/text/en/strings.json	2008-10-24 19:42:02 UTC (rev 1606)
+++ branches/fusion-1.1/text/en/strings.json	2008-10-27 14:04:31 UTC (rev 1607)
@@ -1,7 +1,9 @@
 Fusion.Strings.en = {
 'scriptFailed': 'failed to load script: ${script}',
 'configParseError': 'Error parsing fusion configuration file, initialization aborted',
-'configLoadError': 'Error loading fusion configuration file, initialization aborted',
+'configLoadError': 'Error loading fusion configuration file, initialization aborted.' +
+                  'Make sure that you have copied config_dist.json to config.json ' +
+                  'and have configured the settings for your system',
 'ajaxError': 'Exception occurred in AJAX callback.\nMessage: ${exception}\nLocation: ${filename} (${line})\nResponse: ${response}',
 'importFailed': 'failed to import stylesheet: ${url}',
 'registerEventError': 'Error registering eventID, invalid (empty) eventID.',
Modified: branches/fusion-1.1/text/fr/strings.json
--- branches/fusion-1.1/text/fr/strings.json	2008-10-24 19:42:02 UTC (rev 1606)
+++ branches/fusion-1.1/text/fr/strings.json	2008-10-27 14:04:31 UTC (rev 1607)
@@ -1,7 +1,9 @@
 Fusion.Strings.fr = {
 'ajaxError': 'Exception occurred in AJAX callback.\n${exception}\nLocation: ${file} (${line}))',
More information about the fusion-commits mailing list
