[fusion-commits] r1610 - branches/fusion-1.1
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Oct 27 10:42:56 EDT 2008
Author: madair
Date: 2008-10-27 10:42:56 -0400 (Mon, 27 Oct 2008)
New Revision: 1610
   branches/fusion-1.1/config_dist.json
re #42: reset to default settings
Modified: branches/fusion-1.1/config_dist.json
--- branches/fusion-1.1/config_dist.json	2008-10-27 14:22:33 UTC (rev 1609)
+++ branches/fusion-1.1/config_dist.json	2008-10-27 14:42:56 UTC (rev 1610)
@@ -9,7 +9,7 @@
 	    /* A directory on this system that fusion can use for
 	       temporary files. */
-	    "temporaryDirectory": "/tmp"
+	    "temporaryDirectory": "/ms4w/tmp"
     /* The MapGuide section is required if you are installing
        fusion for MapGuide. */
@@ -27,11 +27,11 @@
 	    "cgi": "/cgi-bin/mapserv",
 	    /* The file system path to where mapserver should put
 	        web-accessible temporary images. */
-	    "imagePath": "/tmp/ms_tmp",
+	    "imagePath": "/ms4w/tmp/ms_tmp",
 	    /* The URL to the image path configured above. */
-	    "imageUrl": "http://localhost/tmp/ms_tmp",
+	    "imageUrl": "http://localhost/ms_tmp",
 	        web-accessible temporary legend images. */
-	    "legendIconCacheDir":"/tmp/ms_tmp"
+	    "legendIconCacheDir":"/ms4w/tmp/ms_tmp"
\ No newline at end of file
More information about the fusion-commits mailing list
