[fusion-commits] r1617 - in branches/fusion-1.1: MapGuide widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Oct 27 15:26:24 EDT 2008
Author: madair
Date: 2008-10-27 15:26:24 -0400 (Mon, 27 Oct 2008)
New Revision: 1617
   branches/fusion-1.1/MapGuide/MapGuide.js
   branches/fusion-1.1/widgets/Maptip.js
re #99: parse out href if maptip hyperlink contains an anchor tag
Modified: branches/fusion-1.1/MapGuide/MapGuide.js
--- branches/fusion-1.1/MapGuide/MapGuide.js	2008-10-27 18:07:36 UTC (rev 1616)
+++ branches/fusion-1.1/MapGuide/MapGuide.js	2008-10-27 19:26:24 UTC (rev 1617)
@@ -985,7 +985,17 @@
             eval('o='+xhr.responseText);
             var h = o['FeatureInformation']['Hyperlink'];
             if (h) {
-                window.open(h[0], "");
+              var linkURL;
+              if (h[0].indexOf('href=') > 0) {
+                //MGOS allows full anchor tag as the hyperlink, extract the href
+                var tempDiv = document.createElement('div');
+                tempDiv.innerHTML = h[0];
+                linkURL = tempDiv.firstChild.href;
+                tempDiv = null;
+              } else {
+                linkURL = h[0];
+              window.open(linkURL, "");
Modified: branches/fusion-1.1/widgets/Maptip.js
--- branches/fusion-1.1/widgets/Maptip.js	2008-10-27 18:07:36 UTC (rev 1616)
+++ branches/fusion-1.1/widgets/Maptip.js	2008-10-27 19:26:24 UTC (rev 1617)
@@ -200,13 +200,21 @@
             var h = tooltip['FeatureInformation']['Hyperlink'];
             if (h) {
+              var a, linkURL;
               var linkDiv = document.createElement('div');
-              var a = document.createElement('a');
-              a.innerHTML = h[0];
+              if (h[0].indexOf('href=') > 0) {   //MGOS allows complete anchor tags as the hyperlink
+                linkDiv.innerHTML = h[0];
+                a = linkDiv.firstChild;
+                linkURL = a.href;
+              } else {
+                a = document.createElement('a');
+                a.innerHTML = h[0];
+                linkURL = h[0];
+                linkDiv.appendChild(a);
               a.href = 'javascript:void(0)';
-              var openLink = OpenLayers.Function.bind(this.openLink, this, h[0]);
+              var openLink = OpenLayers.Function.bind(this.openLink, this, linkURL);
               a.onclick = OpenLayers.Function.bindAsEventListener(openLink, this);
-              linkDiv.appendChild(a);
               contentDiv.appendChild(linkDiv);
               empty = false;
@@ -265,7 +273,7 @@
         this.bOverTip = false;
-    openLink : function(url, evt) {
+    openLink: function(url, evt) {
         var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
         if ( taskPaneTarget ) {
             taskPaneTarget.setContent(url);
More information about the fusion-commits mailing list
