[fusion-commits] r1549 - in branches/fusion-1.1: MapGuide lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Sep 24 14:29:07 EDT 2008
Author: madair
Date: 2008-09-24 14:29:07 -0400 (Wed, 24 Sep 2008)
New Revision: 1549
   branches/fusion-1.1/MapGuide/MapGuide.js
   branches/fusion-1.1/lib/Map.js
re #132
Modified: branches/fusion-1.1/MapGuide/MapGuide.js
--- branches/fusion-1.1/MapGuide/MapGuide.js	2008-09-23 21:40:33 UTC (rev 1548)
+++ branches/fusion-1.1/MapGuide/MapGuide.js	2008-09-24 18:29:07 UTC (rev 1549)
@@ -481,9 +481,12 @@
         isBaseLayer : bIsBaseLayer,
         maxExtent : this._oMaxExtent,
         maxResolution : 'auto',
-        ratio : this.ratio,
-        transitionEffect : 'resize'
+        ratio : this.ratio
+//        transitionEffect : 'resize'
+      if (!/WebKit/.test(navigator.userAgent)) {
+        layerOptions.transitionEffect = 'resize';
       //add in scales array if supplied
       if (this.scales && this.scales.length>0) {
Modified: branches/fusion-1.1/lib/Map.js
--- branches/fusion-1.1/lib/Map.js	2008-09-23 21:40:33 UTC (rev 1548)
+++ branches/fusion-1.1/lib/Map.js	2008-09-24 18:29:07 UTC (rev 1549)
@@ -159,6 +159,7 @@
         this.oMapOL.events.register('moveend', this, this.mapExtentsChanged);
         this._oDomObj.oncontextmenu = function() {return false;};
+        this._oDomObj.onselectstart = function() {return false;};
         OpenLayers.Event.observe(this._oDomObj, 'contextmenu',
                             OpenLayers.Function.bind(this.onContextMenu, this));
@@ -853,6 +854,9 @@
      stopObserveEvent : function(sEventName, fnCB)
+       //debugger;  //shows error in IE and Safari: OpenLayers.Event is
+                    //overriden by prototype Event for some reason.  Uncomment
+                    //the debugger line and step into next function to see it
          OpenLayers.Event.stopObserving(this._oDomObj, sEventName, fnCB, false);
More information about the fusion-commits mailing list
