[fusion-commits] r1845 - in trunk/widgets: . FeatureInfo FeatureInfo/classes
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Apr 30 17:22:49 EDT 2009
Author: pagameba
Date: 2009-04-30 17:22:49 -0400 (Thu, 30 Apr 2009)
New Revision: 1845
Added:
   trunk/widgets/FeatureInfo.js
   trunk/widgets/FeatureInfo/
   trunk/widgets/FeatureInfo/classes/
   trunk/widgets/FeatureInfo/classes/feature.php
   trunk/widgets/FeatureInfo/classes/featureinfo.php
   trunk/widgets/FeatureInfo/classes/property.php
   trunk/widgets/FeatureInfo/featureinfocontroller.php
   trunk/widgets/FeatureInfo/featureinfomain.php
re #248, adding new Feature Info widget that displays the total area of selected features for now, but could be extended to compute other values in the future.
Added: trunk/widgets/FeatureInfo/classes/feature.php
--- trunk/widgets/FeatureInfo/classes/feature.php	                        (rev 0)
+++ trunk/widgets/FeatureInfo/classes/feature.php	2009-04-30 21:22:49 UTC (rev 1845)
@@ -0,0 +1,36 @@
+<?php
+//  Copyright (C) 2004-2006  Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+class Feature
+	public $displayValue = '';
+	public $centerX = '';
+	public $centerY = '';
+	public $idList = null;
+	function __construct($displayValue, $centerPoint, $idList)
+		$this->displayValue = $displayValue;
+		$this->centerX = $centerPoint->GetCoordinate()->GetX();
+		$this->centerY = $centerPoint->GetCoordinate()->GetY();
+		$this->idList = $idList;
\ No newline at end of file
Property changes on: trunk/widgets/FeatureInfo/classes/feature.php
___________________________________________________________________
Added: trunk/widgets/FeatureInfo/classes/featureinfo.php
--- trunk/widgets/FeatureInfo/classes/featureinfo.php	                        (rev 0)
+++ trunk/widgets/FeatureInfo/classes/featureinfo.php	2009-04-30 21:22:49 UTC (rev 1845)
@@ -0,0 +1,67 @@
+<?php
+require_once('property.php');
+require_once('feature.php');
+class FeatureInfo
+    private $args = null;
+    private $site = null;
+    function __construct($args)
+        $this->args = $args;
+        $this->site = new MgSiteConnection();
+        $this->site->Open(new MgUserInformation($args['SESSION']));
+    function GetMapLayerNames()
+        $layerNames = array();
+        $resourceService = $this->site->CreateService(MgServiceType::ResourceService);
+        $map = new MgMap();
+        $map->Open($resourceService, $this->args['MAPNAME']);
+        $layers = $map->GetLayers();
+        for ($i = 0; $i < $layers->GetCount(); $i++)
+            $layer = $layers->GetItem($i);
+            //TODO: Exclude Raster and Drawing Layers???
+            if((substr($layer->GetName(), 0, 1) != "_") && (substr(strtoupper($layer->GetFeatureSourceId()), 0, 7) != "SESSION"))
+                $layerNames[$layer->GetName()] = $layer->GetLegendLabel();
+        asort($layerNames);
+        return $layerNames;
+    function SelectFeatures() {
Property changes on: trunk/widgets/FeatureInfo/classes/featureinfo.php
Added: trunk/widgets/FeatureInfo/classes/property.php
--- trunk/widgets/FeatureInfo/classes/property.php	                        (rev 0)
+++ trunk/widgets/FeatureInfo/classes/property.php	2009-04-30 21:22:49 UTC (rev 1845)
@@ -0,0 +1,32 @@
+<?php
+class Property
+	public $name = '';
+	public $isString = false;
+	function __construct($name, $isString)
+		$this->name = $name;
+		$this->isString = $isString;
Property changes on: trunk/widgets/FeatureInfo/classes/property.php
Added: trunk/widgets/FeatureInfo/featureinfocontroller.php
--- trunk/widgets/FeatureInfo/featureinfocontroller.php	                        (rev 0)
+++ trunk/widgets/FeatureInfo/featureinfocontroller.php	2009-04-30 21:22:49 UTC (rev 1845)
@@ -0,0 +1,105 @@
+<?php
+    $fusionMGpath = '../../layers/MapGuide/php/';
+    require_once $fusionMGpath . 'Common.php';
+    require_once $fusionMGpath . 'Utilities.php';
+    require_once $fusionMGpath . 'JSON.php';
+    require_once 'classes/featureinfo.php';
+    $args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
+    try {
+        $responseType = 'text/plain';
+        $response = '';
+        $site = new MgSiteConnection();
+        $site->Open(new MgUserInformation($args['SESSION']));
+        $resourceService = $site->CreateService(MgServiceType::ResourceService);
+        $featureService =
+            $site->CreateService(MgServiceType::FeatureService);
+        $layerName = $args['LAYERNAME'];
+        $mapName = $args['MAPNAME'];
+        $map = new MgMap($site);
+        $map->Open($mapName);
+        $layer = $map->GetLayers()->GetItem($layerName);
+        $className = $layer->GetFeatureClassName();
+        $selection = new MgSelection($map);
+        $selection->Open($resourceService, $mapName);
+        $properties = NULL;
+        if ($selection->Contains($layer, $className)) {
+            $featureReader = $selection->GetSelectedFeatures($layer, $className, new MgStringCollection());
+            /* Get the map SRS - we use this to convert distances */
+            $srsFactory = new MgCoordinateSystemFactory();
+            //safely get an SRS ... (in Utilities)
+            $srsDefMap = GetMapSRS($map);
+            $srsMap = $srsFactory->Create($srsDefMap);
+            $featureResId = new MgResourceIdentifier($layer->GetFeatureSourceId());
+              $spatialContext = $featureService->GetSpatialContexts($featureResId, true);
+              $srsLayerWkt = false;
+              if($spatialContext != null && $spatialContext->ReadNext() != null) {
+                  $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
+                  /* skip this layer if the srs is empty */
+              if ($srsLayerWkt == null) {
+                  $srsLayerWkt = $srsDefMap;
+              /* create a coordinate system from the layer's SRS wkt */
+              $srsLayer = $srsFactory->Create($srsLayerWkt);
+              // exclude layer if:
+              //  the map is non-arbitrary and the layer is arbitrary or vice-versa
+              //     or
+              //  layer and map are both arbitrary but have different units
+              $bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
+              $bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
+              $bNeedsTransform = false;
+              if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
+                  ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
+                      $bComputedProperties = false;
+              } else {
+                  $srsTarget = null;
+                  $srsXform = null;
+                  $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
+              $properties = BuildSelectionArray($featureReader, $layerName, $properties, true, $srsLayer, $bNeedsTransform, $layer);
+        $response = json_encode($properties);
+    } catch (MgException $e) {
+        echo "ERROR: " . $e->GetMessage() . "\n";
+        echo $e->GetDetails() . "\n";
+        echo $e->GetStackTrace() . "\n";
+    header('Content-Type: ' . $responseType);
+    echo trim($response);
Property changes on: trunk/widgets/FeatureInfo/featureinfocontroller.php
Added: trunk/widgets/FeatureInfo/featureinfomain.php
--- trunk/widgets/FeatureInfo/featureinfomain.php	                        (rev 0)
+++ trunk/widgets/FeatureInfo/featureinfomain.php	2009-04-30 21:22:49 UTC (rev 1845)
@@ -0,0 +1,298 @@
+<?php
+    require_once $fusionMGpath . '/JSON.php';
+    $errorMsg = null;
+    $errorDetail = null;
+    try
+        $featureInfo = new FeatureInfo($args);
+        $layerNames = $featureInfo->GetMapLayerNames();
+    catch (MgException $mge)
+        $errorMsg = $mge->GetMessage();
+        $errorDetail = $mge->GetDetails();
+        echo $errorMsg;
+        echo $errorDetail;
+    catch (Exception $e)
+        $errorMsg = $e->GetMessage();
+        echo $errorMsg;
+<html>
+<head>
+    <title>Feature Information</title>
+    <link rel="stylesheet" href="../../common/mgsamples.css" type="text/css">
+    <script language="javascript" src="../../common/browserdetect.js"></script>
+    <script language="javascript" src="../../common/json.js"></script>
+    <script language="javascript" src="../../layers/MapGuide/MapGuideViewerApi.js"></script>
+    <script language="javascript">
+        var READY_STATE_UNINITIALIZED   = 0;
+        var READY_STATE_LOADING         = 1;
+        var READY_STATE_LOADED          = 2;
+        var READY_STATE_INTERACTIVE     = 3;
+        var READY_STATE_COMPLETE        = 4;
+        var NOT_BUSY_IMAGE = "../../common/images/loader_inactive.gif";
+        var BUSY_IMAGE = "../../common/images/loader_pulse.gif";
+        var session = '<?= $args['SESSION'] ?>';
+        var mapName = '<?= $args['MAPNAME'] ?>';
+        var properties = null;
+        var results;
+        var reqHandler;
+        function OnLayerChange() {
+            var map = GetFusionMapWidget();
+            map.clearSelection();
+            var layerSelect = document.getElementById('layerSelect');
+            var layer = map.layerRoot.findLayerByAttribute('layerName', layerSelect.value);
+            map.setActiveLayer(layer);
+        function ActiveLayerChange(evt, layer) {
+            for (var i=0; i<layerSelect.options.length; i++) {
+                if (layerSelect.options[i].value == layer.layerName) {
+                    layerSelect.options[i].selected = true;
+        function OnDigitizePoint() {
+            DigitizePoint(OnPointDigitized);
+        function OnPointDigitized(point) {
+            var tolerance = GetFusionMapWidget().pixToGeoMeasure(3);
+            var min = {x:point.X-tolerance,y:point.Y-tolerance};
+            var max = {x:point.X+tolerance,y:point.Y+tolerance};
+            var geom = 'POLYGON(('+ min.x + ' ' +  min.y + ', ' +  max.x + ' ' +  min.y + ', ' + max.x + ' ' +  max.y + ', ' + min.x + ' ' +  max.y + ', ' + min.x + ' ' +  min.y + '))';
+            SetSpatialFilter(geom);
+        function OnDigitizeRectangle() {
+            DigitizeRectangle(OnRectangleDigitized);
+        function OnRectangleDigitized(rectangle) {
+          var min = rectangle.Point1;
+          var max = rectangle.Point2;
+          var geom = 'POLYGON(('+ min.X + ' ' +  min.Y + ', ' +  max.X + ' ' +  min.Y + ', ' + max.X + ' ' +  max.Y + ', ' + min.X + ' ' +  max.Y + ', ' + min.X + ' ' +  min.Y + '))';
+        function OnDigitizePolygon() {
+            DigitizePolygon(OnPolyonDigitized);
+        function OnPolyonDigitized(polygon) {
+            var points = [];
+            for (var i = 0; i < polygon.Count; i++) {
+                points.push(polygon.Point(i).X+' '+polygon.Point(i).Y);
+            var geomText = 'POLYGON(('+points.join(',')+'))';
+            SetSpatialFilter(geomText);
+        function SetSpatialFilter(geomText) {
+            ClearDigitization();
+            var options = {};
+            options.selectionType = 'INTERSECTS';
+            options.maxFeatures = 0;
+            options.geometry = geomText;
+            var layerSelect = document.getElementById("layerSelect");
+            options.layers = layerSelect.value;
+            GetFusionMapWidget().query(options);
+        function SelectionOn() {
+            var reqParams = "SESSION=" + encodeURIComponent(session);
+            reqParams += "&MAPNAME=" + encodeURIComponent(mapName);
+            reqParams += "&LAYERNAME=" + encodeURIComponent(layerSelect.value);
+            if (msie)
+                reqHandler = new ActiveXObject("Microsoft.XMLHTTP");
+            else
+                reqHandler = new XMLHttpRequest();
+            reqHandler.onreadystatechange = OnReadyStateChange;
+            reqHandler.open("POST", "featureinfocontroller.php", true);
+            reqHandler.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
+            document.getElementById('totalFeatures').innerHTML = 'fetching feature info ...';
+            document.getElementById('totalArea').innerHTML = ''
+            document.getElementById("layerSelect").disabled = true;
+            document.getElementById("pointButton").disabled = true;
+            document.getElementById("rectButton").disabled = true;
+            document.getElementById("polyButtton").disabled = true;
+            document.getElementById("busyImg").src = BUSY_IMAGE;
+            reqHandler.send(reqParams);
+        function OnReadyStateChange()
+            var ready = reqHandler.readyState;
+            if (ready == READY_STATE_COMPLETE)
+                var results = reqHandler.responseText.parseJSON();
+                if (results) {
+                    var layerInfo = results[layerSelect.value];
+                    if (layerInfo) {
+                        var areaIdx;
+                        for (var i=0; i<layerInfo.metadatanames.length; i++) {
+                            if (layerInfo.metadatanames[i] == 'area') {
+                                areaIdx = i;
+                                break;
+                        if (typeof areaIdx != 'undefined') {
+                            var totalArea = 0;
+                            var n = layerInfo.numelements;
+                            for (var i=0; i<n; i++) {
+                                var metadata = layerInfo.metadata[i];
+                                totalArea += metadata[areaIdx];
+                            document.getElementById('totalFeatures').innerHTML = n + ' features selected';
+                            document.getElementById('totalArea').innerHTML = 'Area: ' + totalArea + ' m<sup>2</sup>';
+                        } else {
+                            document.getElementById('totalArea').innerHTML = 'areaIdx undefined';
+                    } else {
+                        document.getElementById('totalArea').innerHTML = 'no layer info';
+                } else {
+                  document.getElementById('totalFeatures').innerHTML = 'no features in selected layer.';
+                document.getElementById("layerSelect").disabled = false;
+                document.getElementById("pointButton").disabled = false;
+                document.getElementById("rectButton").disabled = false;
+                document.getElementById("polyButtton").disabled = false;
+                document.getElementById("busyImg").src = NOT_BUSY_IMAGE;
+                reqHandler = null;
+        function SelectionOff() {
+            document.getElementById('totalFeatures').innerHTML = 'no features selected.';
+            document.getElementById('totalArea').innerHTML = '';
+        function OnLoad() {
+            map.registerForEvent(Fusion.Event.MAP_SELECTION_ON, SelectionOn);
+            map.registerForEvent(Fusion.Event.MAP_SELECTION_OFF, SelectionOff);
+            map.registerForEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, ActiveLayerChange);
+            var layer = map.getActiveLayer();
+            if (layer) {
+                ActiveLayerChange(null, layer);
+            OnLayerChange();
+        function OnUnload() {
+          map.deregisterForEvent(Fusion.Event.MAP_SELECTION_ON, SelectionOn);
+          map.deregisterForEvent(Fusion.Event.MAP_SELECTION_OFF, SelectionOff);
+          map.deregisterForEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, ActiveLayerChange);
+    </script>
+</head>
+<body onLoad="OnLoad();" onUnload="OnUnload();" marginwidth=5 marginheight=5 leftmargin=5 topmargin=5 bottommargin=5 rightmargin=5>
+<?php if ($errorMsg == null) { ?>
+<table class="RegText" border="0" cellspacing="0" width="100%">
+    <tr><td class="Title"><img id="busyImg" src="../../common/images/loader_inactive.gif" style="vertical-align:bottom">&nbsp;Feature Information<hr></td></tr>
+    <tr><td class="SubTitle">Select a Layer</td></tr>
+    <tr><td>Layer:</td></tr>
+    <tr>
+        <td class="RegText">
+            <select size="1" class="Ctrl" id="layerSelect" onChange="OnLayerChange()" style="width: 100%">
+                <?php
+                    $selected = 'selected';
+                    foreach($layerNames as $layerName => $layerLabel) {
+                <option value="<?= $layerName ?>" <?=$selected ?> ><?= $layerLabel ?></option>
+                <?php
+                        $selected = '';
+            </select>
+        </td>
+    </tr>
+    <tr><td class="Spacer"></td></tr>
+    <tr><td class="SubTitle">Select Features:</td></tr>
+    <tr><td>Digitize:</td></tr>
+    <tr>
+        <td align="center">
+            <input type="button" name="" value="Point" class="Ctrl" id="pointButton" onClick="OnDigitizePoint()" style="width: 30%">
+            <input type="button" name="" value="Rectangle" class="Ctrl" id="rectButton" onClick="OnDigitizeRectangle()" style="width: 30%">
+            <input type="button" name="" value="Polygon" class="Ctrl" id="polyButtton" onClick="OnDigitizePolygon()" style="width: 30%">
+        </td>
+    </tr>
+    <tr><td class="SubTitle">Total:</td></tr>
+    <tr><td id="totalFeatures">no features selected.</td></tr>
+    <tr><td id="totalArea"></td></tr>
+</table>
+<?php } else { ?>
+<table class="RegText" border="0" cellspacing="0" width="100%%">
+    <tr><td class="Title">Error<hr></td></tr>
+    <tr><td><?= $errorMsg ?></td></tr>
+    <tr><td><?= $errorDetail ?></td></tr>
+</table>
+<?php } ?>
+</body>
+</html>
Property changes on: trunk/widgets/FeatureInfo/featureinfomain.php
Added: trunk/widgets/FeatureInfo.js
--- trunk/widgets/FeatureInfo.js	                        (rev 0)
+++ trunk/widgets/FeatureInfo.js	2009-04-30 21:22:49 UTC (rev 1845)
@@ -0,0 +1,83 @@
+ * Fusion.Widget.FeatureInfo
+ * $Id: $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Fusion.Widget.FeatureInfo
+ * The FeatureInfo widget displays information about selected polygons.
+ * If the Target property points to TaskPane widget, the task will be listed in
+ * the menu list of the TaskPane and loaded there.
+ * Otherwise if the target is an existing IFrame in the page it will be loaded
+ * there, otherwise it will open a new window with that name.
+Fusion.Widget.FeatureInfo = OpenLayers.Class(Fusion.Widget, {
+    uiClass: Jx.Button,
+    sFeatures : 'menubar=no,location=no,resizable=no,status=no',
+    initializeWidget: function(widgetTag) {
+        var json = widgetTag.extension;
+        this.sTarget = json.Target ? json.Target[0] : "FeatureInfoWindow";
+        this.sBaseUrl = Fusion.getFusionURL() + 'widgets/FeatureInfo/featureinfomain.php';
+    activate: function() {
+        var url = this.sBaseUrl;
+        //add in other parameters to the url here
+        var map = this.getMap();
+        var mapLayers = map.getAllMaps();
+        var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
+        var pageElement = $(this.sTarget);
+        var params = [];
+        params.push('LOCALE='+Fusion.locale);
+        params.push('SESSION='+mapLayers[0].getSessionID());
+        params.push('MAPNAME='+mapLayers[0].getMapName());
+        if (taskPaneTarget || pageElement) {
+          params.push('POPUP=false');
+        } else {
+          params.push('POPUP=true');
+        if (url.indexOf('?') < 0) {
+            url += '?';
+        } else if (url.slice(-1) != '&') {
+            url += '&';
+        url += params.join('&');
+        if ( taskPaneTarget ) {
+            taskPaneTarget.setContent(url);
+        } else {
+            if ( pageElement ) {
+                pageElement.src = url;
+            } else {
+                window.open(url, this.sTarget, this.sWinFeatures);
Property changes on: trunk/widgets/FeatureInfo.js
More information about the fusion-commits mailing list
