[fusion-commits] r2005 - in trunk: layers/MapServer/php widgets
svn_fusion at osgeo.org
Wed Dec 2 13:37:45 EST 2009
Author: pdeschamps
Date: 2009-12-02 13:37:44 -0500 (Wed, 02 Dec 2009)
New Revision: 2005
trunk/layers/MapServer/php/SetLayers.php
trunk/widgets/LayerManager.js
Layer reversal issue
Modified: trunk/layers/MapServer/php/SetLayers.php
--- trunk/layers/MapServer/php/SetLayers.php 2009-12-02 18:36:10 UTC (rev 2004)
+++ trunk/layers/MapServer/php/SetLayers.php 2009-12-02 18:37:44 UTC (rev 2005)
@@ -65,7 +65,7 @@
echo "*/";
} else {
- echo "/* reordering layers */";
$res = $oMap->setlayersdrawingorder($layers);
@@ -73,7 +73,7 @@
$oMap->save($_SESSION['maps'][$mapName]);
$oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
$newLayers = $oMap->getlayersdrawingorder();
- echo "{success: true, layerindex: [".implode(",",$newLayers)."]}";
+ echo "{success: true, layerindex: [".implode(",",$layers)."]}";
} else {
echo "{success: false, layerindex: [".$_REQUEST['layerindex']."]}";
Modified: trunk/widgets/LayerManager.js
--- trunk/widgets/LayerManager.js 2009-12-02 18:36:10 UTC (rev 2004)
+++ trunk/widgets/LayerManager.js 2009-12-02 18:37:44 UTC (rev 2005)
@@ -54,8 +54,8 @@
currentNode: null,
bIsDrawn: false,
map: null,
- bLayerChanged:false,
initializeWidget: function(widgetTag) {
+ //console.log("initializeWidget");
var json = widgetTag.extension;
this.delIconSrc = json.DeleteIcon ? json.DeleteIcon[0] : 'images/icons/select-delete.png';
@@ -71,22 +71,18 @@
mapLoaded: function() {
this.draw();
- this.bLayerChanged = true;
layerChanged: function() {
- this.draw();
this.updateSessionMapFile();
- mapReLoaded: function(){
- this.bLayerChanged = false;
+ mapReLoaded: function(){
this.draw();
* remove the dom objects representing the legend layers and groups
clear: function(node) {
+ //console.log("clear");
while (node.childNodes.length > 0) {
this.clear(node.childNodes[0]);
node.destroy(node.childNodes[0]);
@@ -99,6 +95,7 @@
* @param r Object the reponse xhr object
draw: function(r) {
+ //console.log("draw");
if (this.mapList) {
this.clear(this.mapList);
this.mapList.destroy();
@@ -113,7 +110,6 @@
//this processes the OL layers
var map = this.getMap();
for (var i=0; i<map.aMaps.length; ++i) {
var mapBlock = document.createElement('li');
mapBlock.className = 'jxLmanMap';
@@ -139,19 +135,15 @@
processMapBlock: function(blockDom, map) {
+ //console.log("processMapBlock");
var mapBlockList = document.createElement('ul');
mapBlockList.className = 'jxLmanSet';
mapBlockList.id = 'fusionLayerManager_'+map.getMapName();
blockDom.appendChild(mapBlockList);
map.layerPrefix = 'layer_'; //TODO make this unique for each block
- mapBlockList.bLayerChanged = this.bLayerChanged;
//this process all layers within an OL layer
var processArray = map.aLayers;
- if (map.bLayersReversed && this.bLayerChanged === false ) {
- processArray.reverse();
for (var i=0; i<processArray.length; ++i) {
var blockItem = document.createElement('li');
blockItem.className = 'jxLmanLayer';
@@ -235,6 +227,7 @@
updateLayer: function(map, ul) {
+ //console.log("updateLayer");
//reorder the layers in the client as well as the session
var aLayerIndex = [];
var aIds = [];
@@ -242,9 +235,6 @@
for (var i=0; i<nLayers; ++i) {
aIds[i] = this.childNodes[i].id.split('_');
var index = parseInt(aIds[i].pop());
- if (map.bLayersReversed && ul.bLayerChanged === false) {
- index = nLayers - (index+1);
aLayerIndex.push(index);
this.childNodes[i].id = '';
@@ -257,9 +247,6 @@
node.childNodes[1].checked = node.layer.isVisible()
- aLayerIndex.reverse();
map.reorderLayers(aLayerIndex);
@@ -268,6 +255,7 @@
deleteLayer: function(layer, ev) {
+ // console.log("deleteLayer");
var targetLI = (new Event(ev)).target.parentNode;
var ul = targetLI.parentNode;
$(targetLI).dispose();
@@ -284,6 +272,7 @@
updateSessionMapFile: function(){
+ // console.log("updateSessionMapFile");
// get map
var aMaps = map.getAllMaps();
More information about the fusion-commits
