[fusion-commits] r2009 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Sun Dec 6 21:06:14 EST 2009
Author: liuar
Date: 2009-12-06 21:06:12 -0500 (Sun, 06 Dec 2009)
New Revision: 2009
   trunk/widgets/Redline.js
Fixed Ticket 344 http://trac.osgeo.org/fusion/ticket/344
Object drawn by Redline with consumer map didn't display until Zoom map.
Modified: trunk/widgets/Redline.js
--- trunk/widgets/Redline.js	2009-12-04 18:00:25 UTC (rev 2008)
+++ trunk/widgets/Redline.js	2009-12-07 02:06:12 UTC (rev 2009)
@@ -218,9 +218,23 @@
     featureAdded: function(evt) {
-        this.triggerEvent(Fusion.Event.REDLINE_FEATURE_ADDED, evt.feature);
+        this.triggerEvent(Fusion.Event.REDLINE_FEATURE_ADDED, evt.feature);
+		this.moveLayerToTop(evt.feature.layer);
+	// move the redline layer to the top and redraw it
+	moveLayerToTop: function(layer) {
+		var map = layer.map;
+		var baseIndex = map.getLayerIndex(layer);
+		if(baseIndex != layer.map.layers.length-2)
+			// except for the current temp drawing layer, the redline layer is not on the top of the map.
+			map.setLayerIndex(layer,layer.map.layers.length-2)
+		layer.redraw();
     // change active layer
     activateLayer: function(layerIndex) {
         this.activeLayer = this.vectorLayers[layerIndex];
More information about the fusion-commits mailing list
