[fusion-commits] r2015 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Dec 11 03:20:53 EST 2009
Author: liuar
Date: 2009-12-11 03:20:51 -0500 (Fri, 11 Dec 2009)
New Revision: 2015
   trunk/widgets/BasemapSwitcher.js
Fixed Ticket http://trac.osgeo.org/fusion/ticket/350
External Providers widget doesn't work
[Analysis]
MAP_MAP_GROUP_LOADED event was triggered before basemapSwitcher could register it.
[Resolution]
Invoke setDefaultBasemap in basemapSwitcher itself, after setUiObject called.
Modified: trunk/widgets/BasemapSwitcher.js
--- trunk/widgets/BasemapSwitcher.js	2009-12-11 02:47:28 UTC (rev 2014)
+++ trunk/widgets/BasemapSwitcher.js	2009-12-11 08:20:51 UTC (rev 2015)
@@ -22,11 +22,11 @@
 Fusion.Widget.BasemapSwitcher = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Menu,
     options: {},
     baseMaps: {},
     defaultBasemap: null,
     menuItems: {},
@@ -34,30 +34,30 @@
     initializeWidget: function(widgetTag) {
         this.getMap().registerForEvent(Fusion.Event.MAP_MAP_GROUP_LOADED, OpenLayers.Function.bind(this.setDefaultBasemap, this));
-	refreshSettings: function(){
-		this.baseMaps = {};
-		this.defaultBasemap = null;
-		this.menuItems = {};
-		this.options = {
-			'G_NORMAL_MAP': null,
-			'G_SATELLITE_MAP': null,
-			'G_HYBRID_MAP': null,
-			'YAHOO_MAP_REG': null,
-			'YAHOO_MAP_SAT': null,
-			'YAHOO_MAP_HYB': null,
-			'Road': null,
-			'Aerial': null,
-			'Hybrid': null,
-			'None': null
-	generateOptions: function(){
-		// Clear previous settings
-		this.refreshSettings();
-		var maps = this.getMap().aMaps;
+    refreshSettings: function() {
+        this.baseMaps = {};
+        this.defaultBasemap = null;
+        this.menuItems = {};
+        this.options = {
+            'G_NORMAL_MAP': null,
+            'G_SATELLITE_MAP': null,
+            'G_HYBRID_MAP': null,
+            'YAHOO_MAP_REG': null,
+            'YAHOO_MAP_SAT': null,
+            'YAHOO_MAP_HYB': null,
+            'Road': null,
+            'Aerial': null,
+            'Hybrid': null,
+            'None': null
+    generateOptions: function() {
+        // Clear previous settings
+        this.refreshSettings();
+        var maps = this.getMap().aMaps;
         for (var i = 0, len = maps.length; i < len; i++) {
             var map = maps[i];
             switch (map.layerType) {
@@ -200,13 +200,14 @@
                     break;
-		if (!this.defaultBasemap) {
-			this.defaultBasemap = "None";
+        if (!this.defaultBasemap) {
+            this.defaultBasemap = "None";
     setUiObject: function(uiObj) {
         Fusion.Widget.prototype.setUiObject.apply(this, [uiObj]);
+        this.setDefaultBasemap();
     setBasemap: function(baseMap) {
@@ -224,12 +225,12 @@
     setDefaultBasemap: function() {
-		this.generateOptions();
-		//re-generate the menu
-		this.uiObj.initialize();
-		//set up the root menu
-		var buttonSet = new Jx.ButtonSet();
+        this.generateOptions();
+        //re-generate the menu
+        this.uiObj.initialize();
+        //set up the root menu
+        var buttonSet = new Jx.ButtonSet();
         for (var key in this.options) {
             if (this.options[key]) {
                 var menuItem = new Jx.Menu.Item({
@@ -237,14 +238,12 @@
                     toggle: true,
                     onDown: OpenLayers.Function.bind(this.setBasemap, this, key)
-				buttonSet.add(menuItem);
+                buttonSet.add(menuItem);
                 this.uiObj.add(menuItem);
                 this.menuItems[key] = menuItem;
         this.menuItems[this.defaultBasemap].setActive(true);
         this.setBasemap(this.defaultBasemap);
More information about the fusion-commits mailing list
