[fusion-commits] r1764 - in trunk/widgets: . Search
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Feb 3 13:59:39 EST 2009
Author: madair
Date: 2009-02-03 13:59:39 -0500 (Tue, 03 Feb 2009)
New Revision: 1764
   trunk/widgets/Search.js
   trunk/widgets/Search/SearchPrompt.php
   trunk/widgets/Search/SearchPrompt.templ
closes #207: pass in parameters explicitly to the SearchPrompt.php and make Search.js a ui class object
Modified: trunk/widgets/Search/SearchPrompt.php
--- trunk/widgets/Search/SearchPrompt.php	2009-02-02 20:10:06 UTC (rev 1763)
+++ trunk/widgets/Search/SearchPrompt.php	2009-02-03 18:59:39 UTC (rev 1764)
@@ -39,21 +39,31 @@
     SetLocalizedFilesPath(GetLocalizationPath());
     $templ = Localize($templ, $locale, GetClientOS());
     $vpath = GetSurroundVirtualPath();
-    print sprintf($templ, $popup, $widgetName, $vpath."Search.php", $mapName, $sessionId);
+    print sprintf($templ, $popup, $properties, $propNames, $title, $prompt, $target, $filter, $layer, $limit, $vpath."Search.php", $mapName, $sessionId);
 function GetParameters($params)
     global $popup, $locale;
-    global $mapName, $sessionId, $widgetName;
+    global $mapName, $sessionId;
+    global $title, $prompt, $target, $filter, $layer, $limit;
+    global $propNames, $properties;
-    if(isset($params['locale']))
+    if(isset($params['locale'])) {
         $locale = $params['locale'];
     $popup = $params['popup'];
-    $widgetName = $params['widgetname'];
     $mapName = $params['mapname'];
     $sessionId = $params['session'];
+    $propNames = $params['propNames'];
+    $properties = $params['properties'];
+    $title = $params['title'];
+    $prompt = $params['prompt'];
+    $target = $params['target'];
+    $filter = $params['filter'];
+    $layer = $params['layer'];
+    $limit = $params['limit'];
 function GetRequestParameters()
Modified: trunk/widgets/Search/SearchPrompt.templ
--- trunk/widgets/Search/SearchPrompt.templ	2009-02-02 20:10:06 UTC (rev 1763)
+++ trunk/widgets/Search/SearchPrompt.templ	2009-02-03 18:59:39 UTC (rev 1764)
@@ -38,25 +38,37 @@
 var msie = agent.indexOf("msie") != -1;
 var popup = %s;
-var widgetId = '%s';
-var resultColumns;
+var propsIn = "%s";
+var properties = [];
+var namesIn = "%s";
+var names = [];
+var title = "%s";
+var prompt = "%s";
+var target = "%s";
+var filter = "%s";
+var layer = "%s";
+var limit = "%s";
 function InitDocument()
     if(!msie) document.getElementById("lf").innerHTML = "<br>";
     if(!popup) document.onmousedown = OnMouseDown;
-    var widget = GetParent().Fusion.getWidgetById(widgetId);
-    resultColumns = widget.resultColumns;
+    if (propsIn != "") {
+      properties = propsIn.split(',');
+    if (namesIn != "") {
+      names = namesIn.split(',');
+    document.getElementById('title').innerHTML = title;  //TODO use a better property than this
+    document.getElementById('prompt').innerHTML = prompt;  //TODO use a better property than this
+    document.getElementById('target').value = target;  //TODO use a better property than this
+    document.getElementById('filter').value = filter;  //TODO use a better property than this
+    document.getElementById('layer').value = layer;  //TODO use a better property than this
+    document.getElementById('limit').value = limit;  //TODO use a better property than this
+    document.getElementById('popup').value = popup?"true":"false";  //TODO use a better property than this
-    document.getElementById('title').innerHTML = widget.title;  //TODO use a better property than this
-    document.getElementById('prompt').innerHTML = widget.prompt;  //TODO use a better property than this
-    document.getElementById('target').value = widget.sTarget;  //TODO use a better property than this
-    document.getElementById('filter').value = widget.filter;  //TODO use a better property than this
-    document.getElementById('layer').value = widget.layer;  //TODO use a better property than this
-    document.getElementById('limit').value = widget.limit;  //TODO use a better property than this
-    document.getElementById('popup').value = popup;  //TODO use a better property than this
     var field = document.getElementById("Fld")
     field.focus();
@@ -76,11 +88,11 @@
 function SetMatchLabel()
-    var colDef = "<input type=\"hidden\" name=\"cols\" value=\"" + resultColumns.length + "\">";
-    for(var i = 0; i < resultColumns.length; i++)
+    var colDef = "<input type=\"hidden\" name=\"cols\" value=\"" + properties.length + "\">";
+    for(var i = 0; i < properties.length; i++)
-        colDef += "<input type=\"hidden\" name=\"CN" + i + "\" value=\"" + resultColumns[i].Name + "\">";
-        colDef += "<input type=\"hidden\" name=\"CP" + i + "\" value=\"" + resultColumns[i].Property + "\">";
+        colDef += "<input type=\"hidden\" name=\"CN" + i + "\" value=\"" + names[i] + "\">";
+        colDef += "<input type=\"hidden\" name=\"CP" + i + "\" value=\"" + properties[i] + "\">";
     document.getElementById("MatchLabel").innerHTML = colDef;
Modified: trunk/widgets/Search.js
--- trunk/widgets/Search.js	2009-02-02 20:10:06 UTC (rev 1763)
+++ trunk/widgets/Search.js	2009-02-03 18:59:39 UTC (rev 1764)
@@ -34,6 +34,7 @@
 Fusion.Widget.Search = OpenLayers.Class(Fusion.Widget, {
+    uiClass: Jx.Button,
     sFeatures : 'menubar=no,location=no,status=no,scrollbars=yes',
     initializeWidget: function(widgetTag) {
@@ -66,7 +67,20 @@
         } else {
           params.push('popup=true');
-        params.push('widgetname='+this.id);
+        params.push('title='+this.title);
+        params.push('prompt='+this.prompt);
+        params.push('target='+this.sTarget);
+        params.push('filter='+this.filter);
+        params.push('layer='+this.layer);
+        params.push('limit='+this.limit);
+        var names = [];
+        var props = [];
+        for (var i=0; i<this.resultColumns.length; ++i) {
+          names.push(this.resultColumns[i].Name);
+          props.push(this.resultColumns[i].Property);
+        params.push('properties='+props.join(","));
+        params.push('propNames='+names.join(","));
         if (url.indexOf('?') < 0) {
             url += '?';
More information about the fusion-commits mailing list
