[fusion-commits] r1864 - trunk/layers/Generic
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Jul 8 13:29:45 EDT 2009
Author: zjames
Date: 2009-07-08 13:29:44 -0400 (Wed, 08 Jul 2009)
New Revision: 1864
   trunk/layers/Generic/Generic.js
re: #267 added yahoo and ve layer type support
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js	2009-05-21 20:21:44 UTC (rev 1863)
+++ trunk/layers/Generic/Generic.js	2009-07-08 17:29:44 UTC (rev 1864)
@@ -107,8 +107,48 @@
                 this.mapTag.layerOptions.type = G_NORMAL_MAP;
                 break;
-         case 'VirtualEarth':
+            break;
+         case 'VirtualEarth':
+             switch (this.mapTag.layerOptions.type) {   //VE layer types are enumerated values
+               case 'Aerial':              //defined in VEMapStyle from the VE api
+                 this.mapTag.layerOptions.type = VEMapStyle.Aerial;
+                 break;
+               case 'Shaded':
+                 this.mapTag.layerOptions.type = VEMapStyle.Shaded;
+                 break;
+               case 'Hybrid':
+                 this.mapTag.layerOptions.type = VEMapStyle.Hybrid;
+                 break;
+               default:
+                 this.mapTag.layerOptions.type = VEMapStyle.Road;
+                 break;
+             break;
          case 'Yahoo':
+            switch (this.mapTag.layerOptions.type) {   //Yahoo is similar to google
+              case 'YAHOO_MAP_SAT':              //defined by YMap, not a string
+                this.mapTag.layerOptions.type = YAHOO_MAP_SAT;
+                break;
+              case 'YAHOO_MAP_HYB':
+                this.mapTag.layerOptions.type = YAHOO_MAP_HYB;
+                break;
+              case 'YAHOO_MAP_REG':
+              default:
+                this.mapTag.layerOptions.type = YAHOO_MAP_REG;
+                break;
+            break;
+          default:
+            this.oLayerOL = new OpenLayers.Layer[this.layerType](
+                                  this.getMapName(),
+                                  this.sMapResourceId,
+                                  this.mapTag.layerParams,
+                                  this.mapTag.layerOptions );
+            break;
+        if (!this.oLayerOL) {
             if (!this.mapTag.layerOptions.maxExtent) {
                 this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892);
@@ -121,16 +161,8 @@
             this.oLayerOL = new OpenLayers.Layer[this.layerType](this.getMapName(), this.mapTag.layerOptions );
             this.mapWidget.fractionalZoom = false;        //fractionalZoom not permitted with Google layers
             this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
-           break;
-          default:
-            this.oLayerOL = new OpenLayers.Layer[this.layerType](
-                                  this.getMapName(),
-                                  this.sMapResourceId,
-                                  this.mapTag.layerParams,
-                                  this.mapTag.layerOptions );
-            break;
         this.oLayerOL.events.register("loadstart", this, this.loadStart);
         this.oLayerOL.events.register("loadend", this, this.loadEnd);
         this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
@@ -197,4 +229,3 @@
More information about the fusion-commits mailing list
