[fusion-commits] r1875 - trunk/widgets/Search
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Jul 22 10:05:29 EDT 2009
Author: pagameba
Date: 2009-07-22 10:05:29 -0400 (Wed, 22 Jul 2009)
New Revision: 1875
   trunk/widgets/Search/Search.php
re #229, close feature readers.
Modified: trunk/widgets/Search/Search.php
--- trunk/widgets/Search/Search.php	2009-07-22 14:03:20 UTC (rev 1874)
+++ trunk/widgets/Search/Search.php	2009-07-22 14:05:29 UTC (rev 1875)
@@ -1,310 +1,311 @@
-<?php
- * Search
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-    // Start output buffering
-    ob_start();
-    $fusionMGpath = '../../layers/MapGuide/php/';
-    include $fusionMGpath . 'Common.php';
-    //$logHandle = fopen("debug.log","at");
-    class SearchError extends Exception
-        public function __construct($message, $title) {
-            parent::__construct($message, 0);
-            $this->title = $title;
-        public $title;
-    $locale = GetDefaultLocale();
-    $userInput = "";
-    $target = "";
-    $popup = 0;
-    $layerName = "";
-    $mapName = "";
-    $sessionId = "";
-    $filter = "";
-    $resNames = array();
-    $resProps = array();
-    $matchLimit = "";
-    GetRequestParameters();
-    SetLocalizedFilesPath(GetLocalizationPath());
-    $searchError = GetLocalizedString("SEARCHERROR", $locale);
-    try
-        $featureSrvc = $siteConnection->CreateService(MgServiceType::FeatureService);
-        //Create a temporary map runtime object, locate the layer
-        $map = new MgMap();
-        $map->Open($resourceService, $mapName);
-        $layers = $map->GetLayers();
-        $layer = null;
-        //fwrite($logHandle,"found layers:".$layers->GetCount()."\n");
-        for($i = 0; $i < $layers->GetCount(); $i++)
-            $layer = $layers->GetItem($i);
-            //fwrite($logHandle,"found layer:".$layer->GetName()."\n");
-            if($layer->GetName() == $layerName)
-                break;
-        if($layer == null)
-            trigger_error(FormatMessage("SEARCHLAYERNOTFOUND", $locale, array($layerName)));
-        //unescape strings
-        if(ini_get("magic_quotes_sybase") == "1")
-            $matchLabel = str_replace("''", "'", $matchLabel);
-            $filter = str_replace("''", "'", $filter);
-        else if(get_magic_quotes_gpc() == "1")
-            //Unescape single quotes
-            $filter = str_replace("\\'", "'", $filter);
-            //Unescape double quotes
-            $filter = str_replace('\\"', '"', $filter);
-            //remove additional backslash
-            $filter = str_replace("\\", "", $filter);
-        //fwrite($logHandle,"filter before:".$filter."\n");
-        //substitute the input tag with the actual user input to make up the filter
-        $filter = str_replace('$USER_VARIABLE', $userInput, $filter);
-        //fwrite($logHandle,"filter after:".$filter."\n");
-        //parse the match label string, which defines what columns to be displayed
-        $displayAll = (count($resProps) == 0);
-        //query the features
-        $opts = new MgFeatureQueryOptions();
-        $opts->SetFilter($filter);
-        $featureClassName = $layer->GetFeatureClassName();
-        $srcId = new MgResourceIdentifier($layer->GetFeatureSourceId());
-        $features = $featureSrvc->SelectFeatures($srcId, $featureClassName, $opts);
-        $hasResult = $features->ReadNext();
-        if($hasResult)
-          //fwrite($logHandle,"has result\n");
-            $colCount = $displayAll? $features->GetPropertyCount(): count($resProps);
-            //output the beginning of the document (head section and beginning of body section)
-            $templ = file_get_contents("./Search.templ");
-            $templ = Localize($templ, $locale, GetClientOS());
-            print sprintf($templ, $colCount, $target, $popup, $mapName);
-            $classDef = $features->GetClassDefinition();
-            $idProps = $classDef->GetIdentityProperties();
-            $idPropNames = array();
-            for($j = 0; $j < $idProps->GetCount(); $j++)
-                $idProp = $idProps->GetItem($j);
-                array_push($idPropNames, $idProp->GetName());
-            //table headings
-            echo "<tr class=\"SearchHeading\">";
-            if($displayAll)
-                for($i = 0; $i < $colCount; $i++)
-                    $resProps[$i] = $features->GetPropertyName($i);
-                    echo "<td class=\"SearchHeading\">&nbsp;" . $resProps[$i] . "</td>";
-            else
-                    echo "<td class=\"SearchHeading\">&nbsp;" . $resNames[$i] . "</td>";
-            echo "</tr>";
-            //output the results
-            $row = 0;
-            do
-                echo "<tr>";
-                    $propName = $resProps[$i];
-                    $propType = $features->GetPropertyType($resProps[$i]);
-                    $val = "";
-                    if (!$features->IsNull($propName))
-                        switch($propType)
-                            case MgPropertyType::Boolean:
-                                $val = $features->GetBoolean($propName)? "true": "false";
-                                break;
-                            case MgPropertyType::Single:
-                                $val = $features->GetSingle($propName);
-                                break;
-                            case MgPropertyType::Double:
-                                $val = $features->GetDouble($propName);
-                                break;
-                            case MgPropertyType::Int16:
-                                $val = $features->GetInt16($propName);
-                                break;
-                            case MgPropertyType::Int32:
-                                $val = $features->GetInt32($propName);
-                                break;
-                            case MgPropertyType::Int64:
-                                $val = $features->GetInt64($propName);
-                                break;
-                            case MgPropertyType::String:
-                                $val = $features->GetString($propName);
-                                break;
-                            case MgPropertyType::DateTime:
-                                $val = $features->GetDateTime($propName)->ToString();
-                                break;
-                    // Generate XML to selection this feature
-                    $sel = new MgSelection($map);
-                    $idProps = new MgPropertyCollection();
-                    foreach ($idPropNames as $id)
-                        $idPropType = $features->GetPropertyType($id);
-                        switch($idPropType)
-                                $idProps->Add(new MgInt32Property($id, $features->GetInt32($id)));
-                                break;
-                                $idProps->Add(new MgStringProperty($id, $features->GetString($id)));
-                                break;
-                                $idProps->Add(new MgInt64Property($id, $features->GetInt64($id)));
-                                break;
-                                $idProps->Add(new MgDoubleProperty($id, $features->GetDouble($id)));
-                                break;
-                                $idProps->Add(new MgSingleProperty($id, $features->GetSingle($id)));
-                                break;
-                                $idProps->Add(new MgDateTimeProperty($id, $features->GetDateTime($id)));
-                                break;
-                            default:
-                                throw new SearchError(FormatMessage("SEARCHTYYPENOTSUP", $locale, array($idPropType)), $searchError);
-                    $sel->AddFeatureIds($layer, $featureClassName, $idProps);
-                    $selText = EscapeForHtml($sel->ToXml(), true);
-                    echo sprintf("<td class=\"%s\" id=\"%d:%d\" onmousemove=\"SelectRow(%d)\" onclick=\"CellClicked('%s')\">&nbsp;%s</td>\n", !($row%2)? "Search" : "Search2", $row, $i, $row, $selText, $val);
-                echo "</tr>";
-                if (++ $row == $matchLimit)
-                    break;
-            } while($features->ReadNext());
-        else
-            throw new SearchError(GetLocalizedString("SEARCHNOMATCHES", $locale), GetLocalizedString("SEARCHREPORT", $locale));
-    catch(MgException $ae)
-        if($features)
-            // Close the feature reader
-            $features->Close();
-        OnError($searchError, $ae->GetDetails());
-    catch(SearchError $e)
-        if($features)
-        OnError($e->title, $e->getMessage());
-    //terminate the html document
-    echo "</table></body></html>";
-    // Set content length header
-    header("Content-Length:".ob_get_length());
-    // Flush output buffer
-    ob_end_flush();
-function OnError($title, $msg)
-    global $target, $popup;
-    $templ = file_get_contents("./ErrorPage.templ");
-    print sprintf($templ, $popup, $title, $msg);
-function GetParameters($params)
-    global $userInput, $target, $layerName, $popup, $locale;
-    global $mapName, $sessionId, $filter, $resNames, $resProps, $matchLimit;
-    if(isset($params['locale']))
-        $locale = $params['locale'];
-    $userInput = $params['userinput'];
-    $target = $params['target'];
-    $popup = $params['popup'];
-    $layerName = $params['layer'];
-    $mapName = $params['mapname'];
-    $sessionId = $params['session'];
-    $filter = $params['filter'];
-    $matchLimit = $params['limit'];
-    $colCount = $params['cols'];
-    if($colCount > 0)
-            array_push($resNames, $params['CN' . $i]);
-            array_push($resProps, $params['CP' . $i]);
-function GetRequestParameters()
-    if($_SERVER['REQUEST_METHOD'] == "POST")
-        GetParameters($_POST);
-    else
-        GetParameters($_GET);
+<?php
+ * Search
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+    // Start output buffering
+    ob_start();
+    $fusionMGpath = '../../layers/MapGuide/php/';
+    include $fusionMGpath . 'Common.php';
+    //$logHandle = fopen("debug.log","at");
+    class SearchError extends Exception
+        public function __construct($message, $title) {
+            parent::__construct($message, 0);
+            $this->title = $title;
+        public $title;
+    $locale = GetDefaultLocale();
+    $userInput = "";
+    $target = "";
+    $popup = 0;
+    $layerName = "";
+    $mapName = "";
+    $sessionId = "";
+    $filter = "";
+    $resNames = array();
+    $resProps = array();
+    $matchLimit = "";
+    GetRequestParameters();
+    SetLocalizedFilesPath(GetLocalizationPath());
+    $searchError = GetLocalizedString("SEARCHERROR", $locale);
+    try
+        $featureSrvc = $siteConnection->CreateService(MgServiceType::FeatureService);
+        //Create a temporary map runtime object, locate the layer
+        $map = new MgMap();
+        $map->Open($resourceService, $mapName);
+        $layers = $map->GetLayers();
+        $layer = null;
+        //fwrite($logHandle,"found layers:".$layers->GetCount()."\n");
+        for($i = 0; $i < $layers->GetCount(); $i++)
+            $layer = $layers->GetItem($i);
+            //fwrite($logHandle,"found layer:".$layer->GetName()."\n");
+            if($layer->GetName() == $layerName)
+                break;
+        if($layer == null)
+            trigger_error(FormatMessage("SEARCHLAYERNOTFOUND", $locale, array($layerName)));
+        //unescape strings
+        if(ini_get("magic_quotes_sybase") == "1")
+            $matchLabel = str_replace("''", "'", $matchLabel);
+            $filter = str_replace("''", "'", $filter);
+        else if(get_magic_quotes_gpc() == "1")
+            //Unescape single quotes
+            $filter = str_replace("\\'", "'", $filter);
+            //Unescape double quotes
+            $filter = str_replace('\\"', '"', $filter);
+            //remove additional backslash
+            $filter = str_replace("\\", "", $filter);
+        //fwrite($logHandle,"filter before:".$filter."\n");
+        //substitute the input tag with the actual user input to make up the filter
+        $filter = str_replace('$USER_VARIABLE', $userInput, $filter);
+        //fwrite($logHandle,"filter after:".$filter."\n");
+        //parse the match label string, which defines what columns to be displayed
+        $displayAll = (count($resProps) == 0);
+        //query the features
+        $opts = new MgFeatureQueryOptions();
+        $opts->SetFilter($filter);
+        $featureClassName = $layer->GetFeatureClassName();
+        $srcId = new MgResourceIdentifier($layer->GetFeatureSourceId());
+        $features = $featureSrvc->SelectFeatures($srcId, $featureClassName, $opts);
+        $hasResult = $features->ReadNext();
+        if($hasResult)
+          //fwrite($logHandle,"has result\n");
+            $colCount = $displayAll? $features->GetPropertyCount(): count($resProps);
+            //output the beginning of the document (head section and beginning of body section)
+            $templ = file_get_contents("./Search.templ");
+            $templ = Localize($templ, $locale, GetClientOS());
+            print sprintf($templ, $colCount, $target, $popup, $mapName);
+            $classDef = $features->GetClassDefinition();
+            $idProps = $classDef->GetIdentityProperties();
+            $idPropNames = array();
+            for($j = 0; $j < $idProps->GetCount(); $j++)
+                $idProp = $idProps->GetItem($j);
+                array_push($idPropNames, $idProp->GetName());
+            //table headings
+            echo "<tr class=\"SearchHeading\">";
+            if($displayAll)
+                for($i = 0; $i < $colCount; $i++)
+                    $resProps[$i] = $features->GetPropertyName($i);
+                    echo "<td class=\"SearchHeading\">&nbsp;" . $resProps[$i] . "</td>";
+            else
+                    echo "<td class=\"SearchHeading\">&nbsp;" . $resNames[$i] . "</td>";
+            echo "</tr>";
+            //output the results
+            $row = 0;
+            do
+                echo "<tr>";
+                    $propName = $resProps[$i];
+                    $propType = $features->GetPropertyType($resProps[$i]);
+                    $val = "";
+                    if (!$features->IsNull($propName))
+                        switch($propType)
+                            case MgPropertyType::Boolean:
+                                $val = $features->GetBoolean($propName)? "true": "false";
+                                break;
+                            case MgPropertyType::Single:
+                                $val = $features->GetSingle($propName);
+                                break;
+                            case MgPropertyType::Double:
+                                $val = $features->GetDouble($propName);
+                                break;
+                            case MgPropertyType::Int16:
+                                $val = $features->GetInt16($propName);
+                                break;
+                            case MgPropertyType::Int32:
+                                $val = $features->GetInt32($propName);
+                                break;
+                            case MgPropertyType::Int64:
+                                $val = $features->GetInt64($propName);
+                                break;
+                            case MgPropertyType::String:
+                                $val = $features->GetString($propName);
+                                break;
+                            case MgPropertyType::DateTime:
+                                $val = $features->GetDateTime($propName)->ToString();
+                                break;
+                    // Generate XML to selection this feature
+                    $sel = new MgSelection($map);
+                    $idProps = new MgPropertyCollection();
+                    foreach ($idPropNames as $id)
+                        $idPropType = $features->GetPropertyType($id);
+                        switch($idPropType)
+                                $idProps->Add(new MgInt32Property($id, $features->GetInt32($id)));
+                                break;
+                                $idProps->Add(new MgStringProperty($id, $features->GetString($id)));
+                                break;
+                                $idProps->Add(new MgInt64Property($id, $features->GetInt64($id)));
+                                break;
+                                $idProps->Add(new MgDoubleProperty($id, $features->GetDouble($id)));
+                                break;
+                                $idProps->Add(new MgSingleProperty($id, $features->GetSingle($id)));
+                                break;
+                                $idProps->Add(new MgDateTimeProperty($id, $features->GetDateTime($id)));
+                                break;
+                            default:
+                                throw new SearchError(FormatMessage("SEARCHTYYPENOTSUP", $locale, array($idPropType)), $searchError);
+                    $sel->AddFeatureIds($layer, $featureClassName, $idProps);
+                    $selText = EscapeForHtml($sel->ToXml(), true);
+                    echo sprintf("<td class=\"%s\" id=\"%d:%d\" onmousemove=\"SelectRow(%d)\" onclick=\"CellClicked('%s')\">&nbsp;%s</td>\n", !($row%2)? "Search" : "Search2", $row, $i, $row, $selText, $val);
+                echo "</tr>";
+                if (++ $row == $matchLimit)
+                    break;
+            } while($features->ReadNext());
+        else
+            throw new SearchError(GetLocalizedString("SEARCHNOMATCHES", $locale), GetLocalizedString("SEARCHREPORT", $locale));
+        $features->Close();
+    catch(MgException $ae)
+        if($features)
+            // Close the feature reader
+        OnError($searchError, $ae->GetDetails());
+    catch(SearchError $e)
+        if($features)
+        OnError($e->title, $e->getMessage());
+    //terminate the html document
+    echo "</table></body></html>";
+    // Set content length header
+    header("Content-Length:".ob_get_length());
+    // Flush output buffer
+    ob_end_flush();
+function OnError($title, $msg)
+    global $target, $popup;
+    $templ = file_get_contents("./ErrorPage.templ");
+    print sprintf($templ, $popup, $title, $msg);
+function GetParameters($params)
+    global $userInput, $target, $layerName, $popup, $locale;
+    global $mapName, $sessionId, $filter, $resNames, $resProps, $matchLimit;
+    if(isset($params['locale']))
+        $locale = $params['locale'];
+    $userInput = $params['userinput'];
+    $target = $params['target'];
+    $popup = $params['popup'];
+    $layerName = $params['layer'];
+    $mapName = $params['mapname'];
+    $sessionId = $params['session'];
+    $filter = $params['filter'];
+    $matchLimit = $params['limit'];
+    $colCount = $params['cols'];
+    if($colCount > 0)
+            array_push($resNames, $params['CN' . $i]);
+            array_push($resProps, $params['CP' . $i]);
+function GetRequestParameters()
+    if($_SERVER['REQUEST_METHOD'] == "POST")
+        GetParameters($_POST);
+    else
+        GetParameters($_GET);
More information about the fusion-commits mailing list
