[fusion-commits] r1806 - in trunk: common/php layers layers/MapGuide/php layers/MapServer/php templates/mapserver/standard widgets widgets/SelectWithin
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Mar 4 15:38:54 EST 2009
Author: pdeschamps
Date: 2009-03-04 15:38:53 -0500 (Wed, 04 Mar 2009)
New Revision: 1806
   trunk/common/php/Xml2JSON.php
   trunk/layers/Layers.js
   trunk/layers/MapGuide/php/CreateSession.php
   trunk/layers/MapGuide/php/GetSelectionProperties.php
   trunk/layers/MapGuide/php/LoadMap.php
   trunk/layers/MapGuide/php/Measure.php
   trunk/layers/MapGuide/php/Query.php
   trunk/layers/MapGuide/php/SaveSelection.php
   trunk/layers/MapGuide/php/Selection.php
   trunk/layers/MapGuide/php/SetLayers.php
   trunk/layers/MapServer/php/CreateSession.php
   trunk/layers/MapServer/php/LoadMap.php
   trunk/layers/MapServer/php/LoadScaleRanges.php
   trunk/layers/MapServer/php/Maptip.php
   trunk/layers/MapServer/php/Measure.php
   trunk/layers/MapServer/php/Query.php
   trunk/layers/MapServer/php/Selection.php
   trunk/layers/MapServer/php/SetLayers.php
   trunk/templates/mapserver/standard/ApplicationDefinition.xml
   trunk/templates/mapserver/standard/index.html
   trunk/widgets/Legend.js
   trunk/widgets/ScalebarDual.js
   trunk/widgets/SelectWithin/SelectWithin.php
closes #32: added application/json to content-type
Modified: trunk/common/php/Xml2JSON.php
--- trunk/common/php/Xml2JSON.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/common/php/Xml2JSON.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -35,7 +35,7 @@
     if (!isset($REQUEST_VARS['xml'])) {
         die('xml not set');
-    header('Content-type: text/plain');
+    header('Content-type: application/json');
     header('X-JSON: true');
     $xml = rawurldecode ($REQUEST_VARS['xml']);
     $xml = trim($xml);
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/Layers.js	2009-03-04 20:38:53 UTC (rev 1806)
@@ -317,6 +317,7 @@
         this.initiallyVisible = o.visible;
         this.actuallyVisible = o.actuallyVisible;
         this.registerEventID(Fusion.Event.GROUP_PROPERTY_CHANGED);
+        this.groupParent = o.groupParent;
     show: function(noDraw) {
@@ -524,7 +525,7 @@
     set: function(property, value) {
         this[property] = value;
         this.triggerEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, this);
Modified: trunk/layers/MapGuide/php/CreateSession.php
--- trunk/layers/MapGuide/php/CreateSession.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/CreateSession.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -37,7 +37,7 @@
     $sessionId =  $site->CreateSession();
     $user->SetMgSessionId($sessionId);
-    header('Content-type: text/x-json');
     $result = null;
     $result->sessionId = $sessionId;
Modified: trunk/layers/MapGuide/php/GetSelectionProperties.php
--- trunk/layers/MapGuide/php/GetSelectionProperties.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/GetSelectionProperties.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -57,7 +57,7 @@
         $properties->layers = array();
         //process
         $layers = $selection->GetLayers();
         $nLayers = $layers->GetCount();
Modified: trunk/layers/MapGuide/php/LoadMap.php
--- trunk/layers/MapGuide/php/LoadMap.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/LoadMap.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -85,8 +85,8 @@
-    //header('Content-type: text/x-json');
-    //header('X-JSON: true');
+    header('X-JSON: true');
     $mapObj->sessionId = $sessionID;
     $mapObj->mapId = $mapid;
Modified: trunk/layers/MapGuide/php/Measure.php
--- trunk/layers/MapGuide/php/Measure.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/Measure.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -57,7 +57,7 @@
         $distance = $srsMap->MeasureEuclideanDistance($x1, $y1, $x2, $y2);
     $distance = $srsMap->ConvertCoordinateSystemUnitsToMeters($distance);
     echo "{distance:$distance}";
     exit;
Modified: trunk/layers/MapGuide/php/Query.php
--- trunk/layers/MapGuide/php/Query.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/Query.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -350,7 +350,7 @@
     //print_r($properties);
     //echo "/* SelectionXML:".$selection->ToXML()."*/";
     $result = NULL;
Modified: trunk/layers/MapGuide/php/SaveSelection.php
--- trunk/layers/MapGuide/php/SaveSelection.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/SaveSelection.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -49,7 +49,7 @@
         //now return a data struture which is the same as Query.php
         //process
Modified: trunk/layers/MapGuide/php/Selection.php
--- trunk/layers/MapGuide/php/Selection.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/Selection.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -139,7 +139,7 @@
-header('Content-type: text/x-json');
+header('Content-type: application/json');
 echo var2json($result);
Modified: trunk/layers/MapGuide/php/SetLayers.php
--- trunk/layers/MapGuide/php/SetLayers.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapGuide/php/SetLayers.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -30,7 +30,7 @@
 echo "{";
Modified: trunk/layers/MapServer/php/CreateSession.php
--- trunk/layers/MapServer/php/CreateSession.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/CreateSession.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -36,7 +36,7 @@
 $sessionId = session_id();
 loadFusionConfig();
 $result = null;
Modified: trunk/layers/MapServer/php/LoadMap.php
--- trunk/layers/MapServer/php/LoadMap.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/LoadMap.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -139,8 +139,8 @@
 $mapObj = NULL;
 if ($oMap) {
     $mapObj->mapId = $mapId;
Modified: trunk/layers/MapServer/php/LoadScaleRanges.php
--- trunk/layers/MapServer/php/LoadScaleRanges.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/LoadScaleRanges.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -140,7 +140,7 @@
 echo var2json($scaleObj);
Modified: trunk/layers/MapServer/php/Maptip.php
--- trunk/layers/MapServer/php/Maptip.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/Maptip.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -63,8 +63,8 @@
 /* a spatial filter in the form on a WKT geometry */
 $spatialFilter = (isset($_REQUEST['spatialfilter']) && $_REQUEST['spatialfilter'] != '') ? urldecode($_REQUEST['spatialfilter']) : false;
-   // header('Content-type: text/x-json');
-   // header('X-JSON: true');
+header('X-JSON: true');
 if (!isset($mapName)) {
     die("{'error':'mapname not set'}");
Modified: trunk/layers/MapServer/php/Measure.php
--- trunk/layers/MapServer/php/Measure.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/Measure.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -58,7 +58,7 @@
         $distance = GetMetersPerUnit($oMap->units)*$distance;
     exit;
Modified: trunk/layers/MapServer/php/Query.php
--- trunk/layers/MapServer/php/Query.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/Query.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -122,7 +122,7 @@
 if ($bExtendSelection) {
 if ($result->hasSelection) {
     $oMap->savequery(getSessionSavePath()."query.qry");
Modified: trunk/layers/MapServer/php/Selection.php
--- trunk/layers/MapServer/php/Selection.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/Selection.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -176,7 +176,7 @@
Modified: trunk/layers/MapServer/php/SetLayers.php
--- trunk/layers/MapServer/php/SetLayers.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/layers/MapServer/php/SetLayers.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -32,7 +32,7 @@
 include ("Common.php");
 include ("Utilities.php");
 if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
Modified: trunk/templates/mapserver/standard/ApplicationDefinition.xml
--- trunk/templates/mapserver/standard/ApplicationDefinition.xml	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/templates/mapserver/standard/ApplicationDefinition.xml	2009-03-04 20:38:53 UTC (rev 1806)
@@ -14,7 +14,7 @@
         <Type>MapServer</Type>
         <SingleTile>true</SingleTile>
         <Extension>
-            <MapFile>/ms4w/apps/gmap/htdocs/gmap_groups.map</MapFile>
+            <MapFile>/home/pdeschamps/fgs/apps/gmap-orig/htdocs/gmap_groups.map</MapFile>
         </Extension>
       </Map>
     </MapGroup>
@@ -23,7 +23,7 @@
         <Extension>
-            <MapFile>/ms4w/apps/gmap/htdocs/gmap75.map</MapFile>
+            <MapFile>/home/pdeschamps/fgs/apps/gmap-orig/htdocs/gmap75.map</MapFile>
         </Extension>
       </Map>
     </MapGroup>
@@ -49,7 +49,7 @@
         <Extension>
-            <MapFile>/ms4w/apps/gmap/htdocs/gmapLonLat.map</MapFile>
             <Options>
               <isBaseLayer>false</isBaseLayer>
               <singleTile>true</singleTile>
@@ -1193,7 +1193,13 @@
             <TextField>AREA_KMSQ</TextField>
             <CustomURL>http://localhost/showParkArea.php?parkId=[PARK_ID]&amp;areakmsq=[AREA_KMSQ]</CustomURL>
         </Maptip>
         <Maptip>
+            <Layer>Precipitation</Layer>
+            <Label>Station ID</Label>
+            <TextField>STATN_ID</TextField>
+        </Maptip>
+        <Maptip>
             <Layer>park</Layer>
             <Label>Year Established</Label>
             <TextField>YEAR_EST</TextField>
Modified: trunk/templates/mapserver/standard/index.html
--- trunk/templates/mapserver/standard/index.html	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/templates/mapserver/standard/index.html	2009-03-04 20:38:53 UTC (rev 1806)
@@ -97,7 +97,8 @@
     <div id="SelectionPanel"></div>
     <div id="OverviewMap"></div>
 </div>
-<div id="Map"><div id="Navigator"></div></div>
+<div id="Map"><div id="Navigator"></div>
+<div id="Maptip"></div></div>
 <div id="Statusbar"></div>
 <div id="TaskPane"></div>
 <div id="PoweredBy" class="statusBarItem">
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/widgets/Legend.js	2009-03-04 20:38:53 UTC (rev 1806)
@@ -59,7 +59,7 @@
      * Constant: defaultRootFolderIcon
      * {String} The default image for the root folder
     defaultRootFolderIcon: 'images/icons/legend-map.png',
@@ -74,7 +74,7 @@
     defaultGroupInfoIcon: 'images/icons/tree_group_info.png',
-    initializeWidget: function(widgetTag) {
+    initializeWidget: function(widgetTag) {
         // TODO: maybe it's a good idea to do a function like Fusion.Widget.BindRenderer.. for limit the code
         // duplication if we plan to apply this pattern to others widgets
         Fusion.addWidgetStyleSheet(widgetTag.location + 'Legend/Legend.css');
@@ -85,7 +85,7 @@
         if (json.LegendRenderer)
             var renderer = eval(json.LegendRenderer[0]);
-            if (renderer && renderer.prototype.CLASS_NAME
+            if (renderer && renderer.prototype.CLASS_NAME
                 && renderer.prototype.CLASS_NAME == "Fusion.Widget.Legend.LegendRenderer") {
                 this.renderer = new renderer(this, widgetTag);
             } else if (typeof renderer == "function") {
@@ -102,13 +102,13 @@
         if (this.renderer.mapReloaded)
-            this.getMap().registerForEvent(Fusion.Event.MAP_RELOADED,
+            this.getMap().registerForEvent(Fusion.Event.MAP_RELOADED,
                                            OpenLayers.Function.bind(this.renderer.mapReloaded, this.renderer));
         if (this.renderer.mapLoading)
-            this.getMap().registerForEvent(Fusion.Event.MAP_LOADING,
+            this.getMap().registerForEvent(Fusion.Event.MAP_LOADING,
                                            OpenLayers.Function.bind(this.renderer.mapLoading,this.renderer));
         if (this.renderer.mapLoaded)
-            this.getMap().registerForEvent(Fusion.Event.MAP_LOADED,
+            this.getMap().registerForEvent(Fusion.Event.MAP_LOADED,
                                            OpenLayers.Function.bind(this.renderer.mapLoaded, this.renderer));
@@ -187,15 +187,15 @@
 /* Class: Fusion.Widget.Legend.LegendRendererDefault
  * This class provide a default legend as a collapsable tree.
-Fusion.Widget.Legend.LegendRendererDefault = OpenLayers.Class(Fusion.Widget.Legend.LegendRenderer,
+Fusion.Widget.Legend.LegendRendererDefault = OpenLayers.Class(Fusion.Widget.Legend.LegendRenderer,
      * Property: showRootFolder
      * {Boolean} This controls whether the tree will have a single root node that
-     * contains the name of the map as its label.  By default, the root node does
+     * contains the name of the map as its label.  By default, the root node does
      * not appear.  Set to "true" or "1" to make the root node appear.
     showRootFolder: false,
@@ -231,7 +231,7 @@
         this.imgLayerDWFIcon = json.LayerDWFIcon ? json.LayerDWFIcon[0] : this.oLegend.defaultLayerDWFIcon;
         this.imgLayerRasterIcon = json.LayerRasterIcon ? json.LayerRasterIcon[0] : this.oLegend.defaultLayerRasterIcon;
         this.imgLayerThemeIcon = json.LayerThemeIcon ? json.LayerThemeIcon[0] : this.oLegend.defaultLayerThemeIcon;
-        this.imgDisabledLayerIcon = json.DisabledLayerIcon ? json.DisabledLayerIcon[0] : this.oLegend.defaultDisabledLayerIcon;
+        this.imgDisabledLayerIcon = json.DisabledLayerIcon ? json.DisabledLayerIcon[0] : this.oLegend.defaultDisabledLayerIcon;
         this.imgLayerInfoIcon = json.LayerInfoIcon ? json.LayerInfoIcon[0] : this.oLegend.defaultLayerInfoIcon;
         this.imgGroupInfoIcon = json.GroupInfoIcon ? json.GroupInfoIcon[0] : this.oLegend.defaultGroupInfoIcon;
@@ -425,7 +425,7 @@
                 label: group.legendLabel,
                 open: group.expandInLegend,
                 draw: this.renderFolder,
-                'class':'fusionLegendFolder'
+                'class':'fusionLegendFolder'
             group.legend.treeItem = new Jx.TreeFolder(opt);
             group.legend.treeItem.contextMenu = this.getContextMenu(group.legend.treeItem);
@@ -522,7 +522,7 @@
         for (var i=0; i<group.layers.length; i++) {
             this.updateLayer(group.layers[i], fScale);
     updateLayer: function(layer, fScale) {
@@ -564,7 +564,7 @@
                     layer.legend.treeItem = this.createTreeItem(layer, style, fScale, this.bIncludeVisToggle);
                     OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
-                    layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
+                    layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
                 } else if (layer.legend.treeItem instanceof Jx.TreeFolder) {
                     this.clearTreeItem(layer);
@@ -578,7 +578,7 @@
                     } else {
                         $(layer.legend.treeItem.domObj).addClass('jxDisabled');
             layer.legend.treeItem.checkBox.checked = layer.visible?true:false;
             if (layer.layerTypes[0] == 4 || range.styles.length > 0) {
Modified: trunk/widgets/ScalebarDual.js
--- trunk/widgets/ScalebarDual.js	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/widgets/ScalebarDual.js	2009-03-04 20:38:53 UTC (rev 1806)
@@ -34,8 +34,8 @@
         var json = widgetTag.extension;
         var maxWidth = json.MaxWidth ? parseInt(json.MaxWidth[0]) : 300;
-        var topInUnits = json.TopInUnits ? json.TopInUnits[0] : 'ft';
-        var topOutUnits = json.TopOutUnits ? json.TopOutUnits[0] : 'mi';
+        var topInUnits = json.TopInUnits ? json.TopInUnits[0] : 'in';
+        var topOutUnits = json.TopOutUnits ? json.TopOutUnits[0] : 'cm';
         var bottomInUnits = json.BottomInUnits ? json.BottomInUnits[0] : 'm';
         var bottomOutUnits = json.BottomOutUnits ? json.BottomOutUnits[0] : 'km';
         var options = {   //set these from widgetTag extension
Modified: trunk/widgets/SelectWithin/SelectWithin.php
--- trunk/widgets/SelectWithin/SelectWithin.php	2009-03-04 20:27:32 UTC (rev 1805)
+++ trunk/widgets/SelectWithin/SelectWithin.php	2009-03-04 20:38:53 UTC (rev 1806)
@@ -123,7 +123,7 @@
   } catch(MgException $e) {
More information about the fusion-commits mailing list
