[fusion-commits] r1849 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Sun May 17 16:00:19 EDT 2009
Author: pagameba
Date: 2009-05-17 16:00:19 -0400 (Sun, 17 May 2009)
New Revision: 1849
Added:
trunk/widgets/widgetinfo/theme.xml
re #250, add widget info file.
Added: trunk/widgets/widgetinfo/theme.xml
--- trunk/widgets/widgetinfo/theme.xml (rev 0)
+++ trunk/widgets/widgetinfo/theme.xml 2009-05-17 20:00:19 UTC (rev 1849)
@@ -0,0 +1,20 @@
+<WidgetInfo>
+ <Type>Theme</Type>
+ <Location></Location>
+ <LocalizedType>Theme</LocalizedType>
+ <Description>This widget will create a new themed layer based on an existing map layer. Either a popup window or the task pane will be used to gather user input, depending on the setting of the Target parameter</Description>
+ <Label>Theme</Label>
+ <Tooltip>Click to create a themed layer</Tooltip>
+ <ImageUrl>images/icons.png</ImageUrl>
+ <ImageClass>invoke-url</ImageClass>
+ <StandardUi>true</StandardUi>
+ <ContainableBy>Any</ContainableBy>
+ <Parameter>
+ <Name>Target</Name>
+ <Label>Target</Label>
+ <Type>target</Type>
+ <Description>The frame, window, or TaskPane in which to display any UI for the widget. If empty, a new window is used</Description>
+ <IsMandatory>true</IsMandatory>
+ <DefaultValue>TaskPane</DefaultValue>
+ </Parameter>
+</WidgetInfo>
Property changes on: trunk/widgets/widgetinfo/theme.xml
___________________________________________________________________
More information about the fusion-commits
