[fusion-commits] r1961 - in sandbox/jxlib-3.0: layers/MapServer lib templates/mapserver/standard templates/mapserver/standard/themes/crispin templates/mapserver/standard/themes/delicious widgets widgets/Legend
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Nov 5 14:09:53 EST 2009
Author: pagameba
Date: 2009-11-05 14:09:53 -0500 (Thu, 05 Nov 2009)
New Revision: 1961
   sandbox/jxlib-3.0/layers/MapServer/MapServer.js
   sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
   sandbox/jxlib-3.0/templates/mapserver/standard/ApplicationDefinition.xml
   sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css
   sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css
   sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css
   sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css
   sandbox/jxlib-3.0/widgets/Legend.js
   sandbox/jxlib-3.0/widgets/Legend/Legend.css
working on getting the legend working with jxlib 3.0
Modified: sandbox/jxlib-3.0/layers/MapServer/MapServer.js
--- sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2009-11-05 19:09:53 UTC (rev 1961)
@@ -815,6 +815,12 @@
     getMapTip: function(oMapTips){
+        if (!this.aLayers ||
+            !this.aLayers.length ||
+            !this.aLayers[0].scaleRanges) {
+            return;
         if(this.bMapTipFired == false){
             //console.log("MAPSERVER:getMapTip");
             var pos = this.mapWidget.pixToGeo(oMapTips.oCurrentPosition.x, oMapTips.oCurrentPosition.y);
Modified: sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
--- sandbox/jxlib-3.0/lib/jxlib.uncompressed.js	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/lib/jxlib.uncompressed.js	2009-11-05 19:09:53 UTC (rev 1961)
@@ -15226,7 +15226,7 @@
         if (el) {
             ref = document.id(reference);
             el.inject(ref,where);
-            this.fireEvent('addTo',this);
+            this.fireEvent('addTo',this);
         return this;
@@ -15254,7 +15254,7 @@
         if ($defined(container)){
             element = container.set('html',template);
         } else {
-            element = new Element('div',{html:template,styles:{border:'20px solid red'}});
+            element = new Element('div',{html:template});
         classes.each(function(klass){
             var el = element.getElement('.'+klass);
@@ -15396,7 +15396,7 @@
             } else {
                 document.id(item).addClass(this.options.selectClass);
                 this.selection.push(item);
-                this.fireEvent(this.options.eventToFire.select, item, this);
+                this.fireEvent(this.options.eventToFire.select, item);
         } else if (this.options.selectMode == 'single') {
             if (!this.selection.contains(item)) {
@@ -15408,7 +15408,7 @@
             } else {
                 this.unselect(item);
@@ -15524,44 +15524,78 @@
         this.container.store('jxList', this);
         var target = this;
+        var isEnabled = function(el) {
+            var item = el.retrieve('jxListTargetItem') || el;
+            return !item.hasClass('jxDisabled');
+        var isSelectable = function(el) {
+            return !item.hasClass('jxUnselectable');
         this.bound = {
             mousedown: function() {
-                this.addClass(target.options.pressClass);
-                target.fireEvent('mousedown', this, target);
+                if (isEnabled(this)) {
+                    this.addClass(target.options.pressClass);
+                    target.fireEvent('mousedown', this, target);
             mouseup: function() {
-                this.removeClass(target.options.pressClass);
-                target.fireEvent('mouseup', this, target);
+                    this.removeClass(target.options.pressClass);
+                    target.fireEvent('mouseup', this, target);
             mouseenter: function() {
-                this.addClass(target.options.hoverClass);
-                target.fireEvent('mouseenter', this, target);
+                    this.addClass(target.options.hoverClass);
+                    target.fireEvent('mouseenter', this, target);
             mouseleave: function() {
-                this.removeClass(target.options.hoverClass);
-                target.fireEvent('mouseleave', this, target);
+                    this.removeClass(target.options.hoverClass);
+                    target.fireEvent('mouseleave', this, target);
+            keydown: function(e) {
+                if (e.key == 'enter' && isEnabled(this)) {
+                    this.addClass('jxPressed');
+            keyup: function(e) {
+                    this.removeClass('jxPressed');
+            click: function () {
+                if (target.selection &&
+                    isEnabled(this) &&
+                    isSelectable(this)) {
+                    target.selection.select(this, target);
+            select: function(item) {
+                if (isEnabled(item)) {
+                    var itemTarget = item.retrieve('jxListTargetItem') || item;
+                    target.fireEvent('select', itemTarget);
+            unselect: function(item) {
+                    target.fireEvent('unselect', itemTarget);
         if (this.options.selection) {
             this.selection = this.options.selection;
+            this.options.select = true;
         } else if (this.options.select) {
             this.selection = new Jx.Selection(this.options);
             this.ownsSelection = true;
-        if (this.selection) {
-            this.bound.click = function () {
-                target.selection.select(this, target);
-            this.selection.addEvents({
-                select: function(item) {
-                    target.fireEvent('select', item);
-                unselect: function(item) {
         if ($defined(this.options.items)) {
             this.add(this.options.items);
@@ -15571,10 +15605,8 @@
         this.container.getChildren().each(function(item){
             this.remove(item);
         }, this);
+        this.setSelection(null);
         this.bound = null;
-        if (this.ownsSelection && this.selection) {
-            this.selection.destroy();
         this.container.eliminate('jxList');
@@ -15597,21 +15629,25 @@
         /* the element being wrapped */
         var el = document.id(item);
-        if (el) {
+        var target = el.retrieve('jxListTarget') || el;
+        if (target) {
+            target.store('jxListTargetItem', el);
             if (this.options.press && this.options.pressClass) {
-                el.addEvents({
+                target.addEvents({
                     mousedown: this.bound.mousedown,
-                    mouseup: this.bound.mouseup
+                    mouseup: this.bound.mouseup,
+                    keyup: this.bound.keyup,
+                    keydown: this.bound.keydown
             if (this.options.hover && this.options.hoverClass) {
-                el.addEvents({
                     mouseenter: this.bound.mouseenter,
                     mouseleave: this.bound.mouseleave
-                el.addEvents({
                     click: this.bound.click
@@ -15651,7 +15687,8 @@
         if (this.container.hasChild(item)) {
             this.unselect(item, true);
             document.id(item).dispose();
-            document.id(item).removeEvents(this.bound);
+            var target = item.retrieve('jxListTarget') || item;
+            target.removeEvents(this.bound);
             this.fireEvent('remove', item, this);
             return item;
@@ -15762,6 +15799,23 @@
             this.remove(item);
         }, this);
+    setSelection: function(selection) {
+        if (this.selection) {
+            this.selection.removeEvents(this.bound);
+            if (this.ownsSelection) {
+                this.selection.destroy();
+                this.ownsSelection = false;
+        this.selection = selection;
+            this.selection.addEvents({
+                select: this.bound.select,
+                unselect: this.bound.unselect
 });// $Id: $
@@ -19062,7 +19116,7 @@
         this.selectedSwatch.setStyles(styles);
-// $Id: menu.js 524 2009-09-18 05:40:16Z jonlb at comcast.net $
+// $Id: menu.js 582 2009-10-30 22:03:58Z pagameba $
  * Class: Jx.Menu
@@ -19786,7 +19840,7 @@
         this.setActiveButton(button);
         button.clicked();
-});// $Id: menu.item.js 524 2009-09-18 05:40:16Z jonlb at comcast.net $
+});// $Id: menu.item.js 582 2009-10-30 22:03:58Z pagameba $
  * Class: Jx.Menu.Item
@@ -24584,8 +24638,7 @@
         //update bar width
         //TODO: animate this
-        this.fill.get('tween', {property: 'width', onComplete: (function () {
+        this.text.get('tween', {property:'width', onComplete: function() {
             var obj = {};
             if (this.options.progressText.contains('{progress}')) {
                 obj.progress = progress;
@@ -24595,6 +24648,9 @@
             var t = this.options.progressText.substitute(obj);
             this.text.set('text', t);
+        }.bind(this)}).start(newWidth);
+        this.fill.get('tween', {property: 'width', onComplete: (function () {
             if (total === progress) {
                 this.complete = true;
@@ -24908,6 +24964,7 @@
     Extends: Jx.Widget,
     options: {
+        enabled: true,
         template: '<li class="jxListItemContainer jxListItem"></li>'
@@ -24920,8 +24977,13 @@
         this.parent();
         this.elements = this.processTemplate(this.options.template, this.classes);
         this.domObj = this.elements.get('jxListItemContainer');
-        this.domContent = this.elements.get('jxListItem')
+        this.domContent = this.elements.get('jxListItem');
+        this.domObj.store('jxListTarget', this.domContent);
         this.loadContent(this.domContent);
+    enable: function(state) {
 });// $Id: $
@@ -24970,7 +25032,7 @@
-        this.list = new Jx.List(this.domObj, this.listOptions, this.selection);
+        this.list = new Jx.List(this.domObj, this.options.listOptions, this.selection);
@@ -27708,7 +27770,7 @@
-// $Id: context.js 524 2009-09-18 05:40:16Z jonlb at comcast.net $
+// $Id: context.js 582 2009-10-30 22:03:58Z pagameba $
  * Class: Jx.Menu.Context
@@ -27784,7 +27846,7 @@
         e.stop();
-});// $Id: menu.separator.js 524 2009-09-18 05:40:16Z jonlb at comcast.net $
+});// $Id: menu.separator.js 582 2009-10-30 22:03:58Z pagameba $
  * Class: Jx.Menu.Separator
@@ -27803,7 +27865,7 @@
 Jx.Menu.Separator = new Class({
     Family: 'Jx.Menu.Separator',
-    Extends: Jx.Object,
+    Extends: Jx.Widget,
      * Property: domObj
      * {HTMLElement} the HTML element that the separator is contained
@@ -27848,7 +27910,7 @@
      * Show the menu item
     show: $empty
-});// $Id: submenu.js 524 2009-09-18 05:40:16Z jonlb at comcast.net $
+});// $Id: submenu.js 582 2009-10-30 22:03:58Z pagameba $
  * Class: Jx.Menu.SubMenu
@@ -28560,10 +28622,6 @@
          * {String} the label to display for the TreeItem
         label: '',
-        /* Option: data
-         * {Object} any arbitrary data to be associated with the TreeItem
-        data: null,
         /* Option: contextMenu
          * {<Jx.ContextMenu>} the context menu to trigger if there
          * is a right click on the node
@@ -28574,6 +28632,7 @@
          * TreeItem is not enabled, it cannot be clicked.
         enabled: true,
+        selectable: true,
         /* Option: image
          * {String} URL to an image to use as the icon next to the
          * label of this TreeItem
@@ -28600,9 +28659,17 @@
         this.domObj = this.elements.get('jxTreeContainer');
         this.domObj.store('jxTreeItem', this);
         var domA = this.elements.get('jxTreeItem');
+        domA.store('jxTreeItem', this);
         var domImg = this.elements.get('jxTreeIcon');
         var domLabel = this.elements.get('jxTreeLabel');
+        /* the target for jxPressed, jxSelected, jxHover classes */
+        this.domObj.store('jxListTarget', domA);
+        if (!this.options.selectable) {
+            this.domObj.addClass('jxUnselectable');
         if (this.domObj) {
             if (this.options.id) {
                 this.domObj.id = this.options.id;
@@ -28626,45 +28693,11 @@
         if (domA) {
-            var hasFocus;
-            var mouseDown;
             domA.addEvents({
                 click: this.click.bind(this),
                 dblclick: this.dblclick.bind(this),
                 drag: function(e) { e.stop(); },
                 contextmenu: function(e) { e.stop(); },
-                mousedown: (function(e) {
-                   domA.addClass('jxTreeItemPressed');
-                   hasFocus = true;
-                   mouseDown = true;
-                   domA.focus();
-                   if (e.rightClick && this.options.contextMenu) {
-                       this.options.contextMenu.show(e);
-                }).bind(this),
-                mouseup: function(e) {
-                    domA.removeClass('jxTreeItemPressed');
-                    mouseDown = false;
-                mouseleave: function(e) {
-                mouseenter: function(e) {
-                    if (hasFocus && mouseDown) {
-                keydown: function(e) {
-                    if (e.key == 'enter') {
-                keyup: function(e) {
-                blur: function() { hasFocus = false; }
             domA.appendChild(domImg);
             if (typeof Drag != 'undefined') {
@@ -28673,6 +28706,10 @@
+        if ($defined(this.options.enabled)) {
+            this.enable(this.options.enabled, true);
      * Method: finalize
@@ -28708,32 +28745,77 @@
     click: function() {
-        this.fireEvent('click', this);
-        this.select();
+        if (this.options.enabled) {
+            this.fireEvent('click', this);
     dblclick: function() {
-        this.fireEvent('dblclick', this);
-        this.select();
+            this.fireEvent('dblclick', this);
      * Method: select
      * Select a tree node.
     select: function() {
-            console.log('select: '+this.options.label);
+        if (this.selection && this.options.enabled) {
             this.selection.select(document.id(this));
-     * Method: getName
+     * Method: getLabel
      * Get the label associated with a TreeItem
      * Returns:
      * {String} the name
-    getName : function() { return this.options.label; },
+    getLabel: function() {
+        return this.options.label;
+     * Method: setLabel
+     * set the label of a tree item
+    setLabel: function(label) {
+        this.options.label = label;
+        var el = this.elements.get('jxTreeLabel');
+        if (el) {
+            el.set('html',label);
+    setImage: function(url, imageClass) {
+        var el = this.elements.get('jxTreeIcon')
+        if (el && $defined(url)) {
+            this.options.image = url;
+            el.setStyle('backgroundImage', 'url('+this.options.image+')');
+        if (el && $defined(imageClass)) {
+            el.removeClass(this.options.imageClass);
+            this.options.imageClass = imageClass;
+            el.addClass(imageClass);
+    enable: function(state, force) {
+        if (this.options.enabled != state || force) {
+            this.options.enabled = state;
+                this.domObj.removeClass('jxDisabled');
+                this.fireEvent('enabled', this);
+            } else {
+                this.domObj.addClass('jxDisabled');
+                this.fireEvent('disabled', this);
+                    this.selection.unselect(document.id(this));
      * Method: propertyChanged
      * A property of an object has changed, synchronize the state of the
      * TreeItem with the state of the object
@@ -28753,7 +28835,7 @@
-// $Id: treefolder.js 581 2009-10-29 20:59:48Z pagameba $
+// $Id: treefolder.js 582 2009-10-30 22:03:58Z pagameba $
  * Class: Jx.TreeFolder
@@ -28790,9 +28872,9 @@
         open: false,
         /* folders will share a selection with the tree they are in */
         select: false,
-        template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><a class="jxTreeItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><ul class="jxTree"></ul></li>'
+        template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><a class="jxTreeItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><ul class="jxTreeFolder"></ul></li>'
-    classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','jxTree'],
+    classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','jxTreeFolder'],
      * APIMethod: render
      * Create a new instance of Jx.TreeFolder
@@ -28800,14 +28882,19 @@
     render : function() {
         this.parent();
         this.domObj.store('jxTreeFolder', this);
+        this.bound = {
+            toggle: this.toggle.bind(this)
         this.addEvents({
-            click: this.toggle.bind(this),
-            dblclick: this.toggle.bind(this)
+            click: this.bound.toggle,
+            dblclick: this.bound.toggle
         var node = this.elements.get('jxTreeImage');
         if (node) {
-            document.id(node).addEvent('click', this.toggle.bind(this));
+            document.id(node).addEvent('click', this.bound.toggle);
         this.tree = new Jx.Tree({
@@ -28820,7 +28907,7 @@
                 this.update();
                 this.fireEvent('remove', item);
             }.bind(this)
-        }, this.elements.get('jxTree'));
+        }, this.elements.get('jxTreeFolder'));
         if (this.options.open) {
             this.expand();
         } else {
@@ -28845,6 +28932,18 @@
         return this;
+     * APIMethod: items
+     * return an array of tree item instances contained in this tree.
+     * Does not descend into folders but does return a reference to the
+     * folders
+    items: function() {
+        return this.tree.items();
+    empty: function() {
+        this.tree.empty();
      * Method: update
      * Update the CSS of the TreeFolder's DOM element in case it has changed
      * position.
@@ -28874,10 +28973,12 @@
         this.tree.update(shouldDescend, isLast);
     toggle: function() {
-        if (this.options.open) {
-            this.collapse();
-        } else {
-            this.expand();
+            if (this.options.open) {
+                this.collapse();
+            } else {
+                this.expand();
@@ -28907,8 +29008,11 @@
         } else {
             return this.tree.findChild(path);
+        this.tree.setSelection(selection);
-});// $Id: tree.js 581 2009-10-29 20:59:48Z pagameba $
+});// $Id: tree.js 582 2009-10-30 22:03:58Z pagameba $
  * Class: Jx.Tree
@@ -28958,12 +29062,23 @@
+        this.bound = {
+                this.fireEvent('select', item.retrieve('jxTreeItem'));
+            }.bind(this),
+                this.fireEvent('unselect', item.retrieve('jxTreeItem'));
+            }.bind(this)
         if (this.selection && this.ownsSelection) {
-            this.selection.addEvent('select', function(item) {
-                this.fireEvent('select', item.retrieve('jxTreeItem'));
-            }.bind(this));
         if ($defined(this.options.container) &&
             document.id(this.options.container)) {
             this.domObj = this.options.container;
@@ -28990,6 +29105,7 @@
             disclose: function(what) { this.fireEvent('disclose', what).bind(this); }
         item.setSelection(this.selection);
+        item.owner = this;
         this.list.add(item, position);
         return this;
@@ -28997,11 +29113,14 @@
         item.removeEvents('add');
         item.removeEvents('remove');
         item.removeEvents('disclose');
+        item.owner = null;
         this.list.remove(item);
         item.setSelection(null);
         return this;
     replace: function(item, withItem) {
+        withItem.owner = this;
         this.list.replace(item, withItem);
         withItem.setSelection(this.selection);
@@ -29049,6 +29168,32 @@
+     * folders
+        return this.list.items().map(function(item) {
+            return item.retrieve('jxTreeItem');
+     * APIMethod:
+     * recursively empty this tree and any folders in it
+        this.list.items().each(function(item){
+            if (item.retrieve('jxTreeFolder')) {
+                item.retrieve('jxTreeFolder').empty();
+            if (item.retrieve('jxTreeItem')) {
+                this.remove(item.retrieve('jxTreeItem'));
      * Method: findChild
      * Get a reference to a child node by recursively searching the tree
@@ -29068,7 +29213,7 @@
         var result = false;
         this.list.items().some(function(item) {
             var treeItem = item.retrieve('jxTreeItem');
-            if (treeItem && treeItem.getName() == name) {
+            if (treeItem && treeItem.getLabel() == name) {
                 if (path.length > 0) {
                     var folder = item.retrieve('jxTreeFolder');
                     if (folder) {
@@ -29081,6 +29226,15 @@
             return result;
         return result;
+        if (this.selection && this.ownsSelection) {
+        this.list.setSelection(selection);
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/ApplicationDefinition.xml
--- sandbox/jxlib-3.0/templates/mapserver/standard/ApplicationDefinition.xml	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/ApplicationDefinition.xml	2009-11-05 19:09:53 UTC (rev 1961)
@@ -1011,6 +1011,10 @@
       <Name>Legend</Name>
       <Type>Legend</Type>
       <StatusText/>
+      <Extension>
+        <ShowRootFolder>false</ShowRootFolder>
+        <ShowMapFolder>true</ShowMapFolder>
+      </Extension>
     </Widget>
 <!-- SELECTION -->
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.css	2009-11-05 19:09:53 UTC (rev 1961)
@@ -21,4 +21,4 @@
  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
  * DEALINGS IN THE SOFTWARE.
- */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:2px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:-5px;height:35px;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;border-radius:10px;-moz-border-radius:10px;-webkit-border-radius:10px;-khtml-border-radius:10px;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed{margin:0;border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxListView .jxSelected{margin:0;border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 15px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 14px;background-position:left -72px;}a.jxTreeItem:hover{border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;margin:0 0 0 14px;background-color:#CDE5FF;background-position:left -24px;}a.jxTreeItemPressed,a.jxTreeItemPressed:hover{border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;margin:0 0 0 14px;background-color:#CDE5FF;background-position:left -48px;}.jxDisabled a.jxTreeItem,.jxDisabled a.jxTreeItem{cursor:default;}.jxDisabled a.jxTreeItem:focus,.jxDisabled a.jxTreeItemPressed,.jxDisabled a.jxTreeItemPressed:hover,.jxDisabled a.jxTreeItem:hover{background-position:left top;border:none;margin:0 1px 0 15px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:1px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}.jxTreeItemSelected{background-color:#AFD4FA;font-weight:bold;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
\ No newline at end of file
+ */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:2px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:-5px;height:35px;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;border-radius:10px;-moz-border-radius:10px;-webkit-border-radius:10px;-khtml-border-radius:10px;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTreeFolder,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTreeFolder li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/crispin/jxtheme.uncompressed.css	2009-11-05 19:09:53 UTC (rev 1961)
@@ -1622,8 +1622,8 @@
 .jxListView .jxHover {
     margin: 0px;
-    border-left: 1px solid #C5E0FF;
-    border-right: 1px solid #C5E0FF;
+    border-left: 1px solid #CDDFFD;
+    border-right: 1px solid #CDDFFD;
     background-image: url(images/listitem.png);
     background-repeat: repeat-x;
     background-color: #CDE5FF;
@@ -1640,28 +1640,19 @@
     background-position: left -72px;
-.jxListView .jxPressed {
+.jxListView .jxPressed,
+.jxListView .jxSelected {
   margin: 0px;
+  border-left: 1px solid #8AABFB;
+  border-right: 1px solid #8AABFB;
   background-position: left -48px;
-.jxListView .jxSelected {
-    margin: 0px;
-    background-color: #CDE5FF;
-    background-image: url(images/listitem.png);
-    background-repeat: repeat-x;
-    background-position: left -48px;
  * @project         Jx
- * @revision        $Id: menu.css 321 2009-04-06 18:23:39Z fred.warnock $
+ * @revision        $Id: menu.css 582 2009-10-30 22:03:58Z pagameba $
  * @author          Fred Warnock (fwarnock at dmsolutions.ca)
  * @copyright       (c) 2006 DM Solutions Group Inc.
@@ -2983,7 +2974,7 @@
-.jxTree,
+.jxTreeFolder,
 .jxTreeRoot {
   /* relative positioning is required for IE to fix the peek-a-boo bug */
   position:relative;
@@ -3020,7 +3011,7 @@
   -khtml-user-select: none;
-.jxTree li.jxTreeContainer {
+.jxTreeFolder li.jxTreeContainer {
   margin-left: 16px;
@@ -3036,7 +3027,7 @@
   background-position: left top;
   border: none;
-  margin: 0px 1px 0px 15px;
+  margin: 0px 1px 0px 17px;
   padding: 0px 0px 0px 20px;
   z-index: 0;
   font-family: Arial, Helvetica, sans-serif;
@@ -3052,40 +3043,41 @@
 a.jxTreeItem:focus {
   border-left: 1px dotted #75ADFF;
   border-right: 1px dotted #75ADFF;
-  margin: 0px 0px 0px 14px;
+  margin: 0px 0px 0px 16px;
-a.jxTreeItem:hover {
+a.jxTreeItem:hover,
+li.jxTreeContainer a.jxHover {
   /*border: 1px solid #C5E0FF;*/
   background-position: left -24px;
-a.jxTreeItemPressed,
-a.jxTreeItemPressed:hover {
+li.jxTreeContainer a.jxSelected,
+li.jxTreeContainer a.jxSelected:hover,
+li.jxTreeContainer a.jxPressed,
+li.jxTreeContainer a.jxPressed:hover {
-.jxDisabled a.jxTreeItem,
-.jxDisabled a.jxTreeItem {
+li.jxDisabled a.jxTreeItem {
   cursor: default;
-.jxDisabled a.jxTreeItem:focus,
-.jxDisabled a.jxTreeItemPressed,
-.jxDisabled a.jxTreeItemPressed:hover,
-.jxDisabled a.jxTreeItem:hover {
+li.jxDisabled a.jxTreeItem:focus,
+li.jxDisabled a.jxTreeItem:hover {
+  background-color: transparent;
   border: none;
 .jxTreeNest {
@@ -3113,7 +3105,7 @@
 img.jxTreeIcon {
   height: 16px;
-  top: 1px;
+  top: 2px;
   left: 1px;
@@ -3158,10 +3150,6 @@
   background-position: left -120px; /* last node image */
-.jxTreeItemSelected {
-  background-color: #AFD4FA;
-  font-weight:bold;
 a.jxTreeItem,
 img.jxTreeImage,
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.css	2009-11-05 19:09:53 UTC (rev 1961)
@@ -21,4 +21,4 @@
  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
  * DEALINGS IN THE SOFTWARE.
- */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}@CHARSET "ISO-8859-1";.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:6px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:3px;height:35px;width:100%;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed{margin:0;border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxListView .jxSelected{margin:0;border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}@CHARSET "ISO-8859-1";.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}@CHARSET "ISO-8859-1";.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}@CHARSET "ISO-8859-1";.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 15px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 14px;background-position:left -72px;}a.jxTreeItem:hover{border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;margin:0 0 0 14px;background-color:#CDE5FF;background-position:left -24px;}a.jxTreeItemPressed,a.jxTreeItemPressed:hover{border-left:1px solid #C5E0FF;border-right:1px solid #C5E0FF;margin:0 0 0 14px;background-color:#CDE5FF;background-position:left -48px;}.jxDisabled a.jxTreeItem,.jxDisabled a.jxTreeItem{cursor:default;}.jxDisabled a.jxTreeItem:focus,.jxDisabled a.jxTreeItemPressed,.jxDisabled a.jxTreeItemPressed:hover,.jxDisabled a.jxTreeItem:hover{background-position:left top;border:none;margin:0 1px 0 15px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:1px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}.jxTreeItemSelected{background-color:#AFD4FA;font-weight:bold;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
\ No newline at end of file
+ */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{background-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButtonPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxButtonMenu span.jxButtonContent,.jxButtonMulti span.jxButtonContent,.jxButtonFlyout span.jxButtonContent,.jxButtonCombo span.jxButtonContent,.jxButtonEditCombo span.jxButtonContent{padding-right:0;}.jxButtonMenu span.jxButtonContent span,.jxButtonFlyout span.jxButtonContent span,.jxButtonMulti span.jxButtonContent span,.jxButtonCombo span.jxButtonContent span,.jxButtonEditCombo span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxToolbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transparent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;empty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px solid #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDisabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}@CHARSET "ISO-8859-1";.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:6px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:3px;height:35px;width:100%;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldInvalid .jxInputText,.jxFieldInvalid .jxInputPassword,.jxFieldInvalid .jxInputTextarea,.jxFieldInvalid .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldValidated .jxInputText,.jxFieldValidated .jxInputPassword,.jxFieldValidated .jxInputTextarea,.jxFieldValidated .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldInvalid .jxInputText:focus,.jxFieldInvalid .jxInputPassword:focus,.jxFieldInvalid .jxInputTextarea:focus,.jxFieldInvalid .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldValidated .jxInputText:focus,.jxFieldValidated .jxInputPassword:focus,.jxFieldValidated .jxInputTextarea:focus,.jxFieldValidated .jxInputSelect:focus{border-color:#264409;}.jxFieldInvalid .jxInputLabel,.jxFieldInvalid .jxInputTag{color:#8a1f11;}.jxFieldValidated .jxInputLabel,.jxFieldValidated .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}@CHARSET "ISO-8859-1";.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}@CHARSET "ISO-8859-1";.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}@CHARSET "ISO-8859-1";.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}div.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxTabClose img{width:16px;height:16px;background-image:url(images/tab_close.png);}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxBarTop div.jxTabContainer,.jxBarBottom div.jxTabContainer{float:left;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:3px;right:3px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{float:left;padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{float:left;padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{float:left;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{float:left;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:3px;left:3px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTreeFolder,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTreeFolder li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
Modified: sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css
--- sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/templates/mapserver/standard/themes/delicious/jxtheme.uncompressed.css	2009-11-05 19:09:53 UTC (rev 1961)
@@ -1622,8 +1622,8 @@
 .jxListView .jxHover {
     margin: 0px;
-    border-left: 1px solid #C5E0FF;
-    border-right: 1px solid #C5E0FF;
+    border-left: 1px solid #CDDFFD;
+    border-right: 1px solid #CDDFFD;
     background-image: url(images/listitem.png);
     background-repeat: repeat-x;
     background-color: #CDE5FF;
@@ -1640,28 +1640,19 @@
     background-position: left -72px;
-.jxListView .jxPressed {
+.jxListView .jxPressed,
+.jxListView .jxSelected {
   margin: 0px;
+  border-left: 1px solid #8AABFB;
+  border-right: 1px solid #8AABFB;
   background-position: left -48px;
-.jxListView .jxSelected {
-    margin: 0px;
-    background-color: #CDE5FF;
-    background-image: url(images/listitem.png);
-    background-repeat: repeat-x;
-    background-position: left -48px;
  * @project         Jx
- * @revision        $Id: menu.css 321 2009-04-06 18:23:39Z fred.warnock $
+ * @revision        $Id: menu.css 582 2009-10-30 22:03:58Z pagameba $
  * @author          Fred Warnock (fwarnock at dmsolutions.ca)
  * @copyright       (c) 2006 DM Solutions Group Inc.
@@ -2976,7 +2967,7 @@
  * @project         Jx
- * @revision        $Id: tree.css 536 2009-09-28 19:02:46Z pagameba $
+ * @revision        $Id: tree.css 535 2009-09-28 18:47:18Z fred.warnock $
@@ -2991,7 +2982,7 @@
-.jxTree,
+.jxTreeFolder,
 .jxTreeRoot {
   /* relative positioning is required for IE to fix the peek-a-boo bug */
   position:relative;
@@ -3028,7 +3019,7 @@
   -khtml-user-select: none;
-.jxTree li.jxTreeContainer {
+.jxTreeFolder li.jxTreeContainer {
   margin-left: 16px;
@@ -3044,7 +3035,7 @@
   background-position: left top;
   border: none;
-  margin: 0px 1px 0px 15px;
+  margin: 0px 1px 0px 17px;
   padding: 0px 0px 0px 20px;
   z-index: 0;
   font-family: Arial, Helvetica, sans-serif;
@@ -3060,40 +3051,41 @@
 a.jxTreeItem:focus {
   border-left: 1px dotted #75ADFF;
   border-right: 1px dotted #75ADFF;
-  margin: 0px 0px 0px 14px;
+  margin: 0px 0px 0px 16px;
-a.jxTreeItem:hover {
+a.jxTreeItem:hover,
+li.jxTreeContainer a.jxHover {
   /*border: 1px solid #C5E0FF;*/
   background-position: left -24px;
-a.jxTreeItemPressed,
-a.jxTreeItemPressed:hover {
+li.jxTreeContainer a.jxSelected,
+li.jxTreeContainer a.jxSelected:hover,
+li.jxTreeContainer a.jxPressed,
+li.jxTreeContainer a.jxPressed:hover {
-.jxDisabled a.jxTreeItem,
-.jxDisabled a.jxTreeItem {
+li.jxDisabled a.jxTreeItem {
   cursor: default;
-.jxDisabled a.jxTreeItem:focus,
-.jxDisabled a.jxTreeItemPressed,
-.jxDisabled a.jxTreeItemPressed:hover,
-.jxDisabled a.jxTreeItem:hover {
+li.jxDisabled a.jxTreeItem:focus,
+li.jxDisabled a.jxTreeItem:hover {
+  background-color: transparent;
   border: none;
 .jxTreeNest {
@@ -3121,7 +3113,7 @@
 img.jxTreeIcon {
   height: 16px;
-  top: 1px;
+  top: 2px;
   left: 1px;
@@ -3166,10 +3158,6 @@
   background-position: left -120px; /* last node image */
-.jxTreeItemSelected {
-  background-color: #AFD4FA;
-  font-weight:bold;
 a.jxTreeItem,
 img.jxTreeImage,
Modified: sandbox/jxlib-3.0/widgets/Legend/Legend.css
--- sandbox/jxlib-3.0/widgets/Legend/Legend.css	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/widgets/Legend/Legend.css	2009-11-05 19:09:53 UTC (rev 1961)
@@ -1,48 +1,64 @@
-.fusionLegendItemCheckbox span,
-.fusionLegendFolder span,
-.fusionLegendItem span,
-.fusionLegendItemCheckbox input,
-.fusionLegendFolder input,
-.fusionLegendItemCheckbox .jxTreeIcon,
-.fusionLegendFolder .jxTreeIcon,
-.fusionLegendItem .jxTreeIcon {
-  position: relative;
-  vertical-align: middle;
+/* The tree item a tag */
+.jxTreeContainer a.fusionCheckboxItem  {
+    padding-left: 36px;
-.jxTree a.fusionLegendItem,
-.jxTreeRoot a.fusionLegendItem,
-.jxTree a.fusionLegendFolder,
-.jxTreeRoot a.fusionLegendFolder,
-.jxTree a.fusionLegendItemCheckbox,
-.jxTreeRoot a.fusionLegendItemCheckbox,
-.jxTree a.fusionLegendFolder:hover,
-.jxTreeRoot a.fusionLegendFolder:hover,
-.jxTree a.fusionLegendItemCheckbox:hover,
-.jxTreeRoot a.fusionLegendItemCheckbox:hover {
-    padding: 0px;
+a.fusionCheckboxItem img.jxTreeIcon {
+    left: 16px;
-.jxTreeBranchOpen .fusionLegendItemCheckbox .jxTreeIcon,
-.jxTreeBranchLastOpen .fusionLegendItemCheckbox .jxTreeIcon {
+li.jxUnselectable a.jxTreeItem {
+  cursor: default;
+.fusionLegendTreeRoot li.jxUnselectable a.jxPressed,
+.fusionLegendTreeRoot li.jxUnselectable a.jxTreeItem:focus,
+.fusionLegendTreeRoot li.jxUnselectable a.jxTreeItem:hover {
+  border: none;
-.jxTreeBranchClosed .fusionLegendItemCheckbox .jxTreeIcon,
-.jxTreeBranchLastClosed .fusionLegendItemCheckbox .jxTreeIcon {
-  background-position: left top;
+/* The checkbox */
+.fusionLegendCheckboxContainer {
+    position: absolute;
+    left: 16px;
+    top: 0px;
+    height: 20px;
+    width: 16px;
+    z-index: 2;
+    line-height: 20px;
+    font-size: 11px;
-span.fusionLegendLabel {
-  padding-left: 4px;
+.fusionLegendCheckbox {
+    vertical-align: middle;
-.jxTree li,
-.jxTreeRoot li {
-    zoom: 1;
+/* Group Info Icon */
+.fusionShowGroupInfo .fusionGroupInfo {
+    display: block;
-.jxTreeIcon {
-    top: auto !important;
-    left: auto !important;
+.fusionGroupInfo {
+    display: none;
+.fusionGroupInfoIcon {
+/* Layer Information Icon */
+.fusionShowLayerInfo .fusionLayerInfo {
+    display: block;
+.fusionLayerInfo {
+    display: none;
+.fusionLayerInfoIcon {
Modified: sandbox/jxlib-3.0/widgets/Legend.js
--- sandbox/jxlib-3.0/widgets/Legend.js	2009-11-03 21:07:12 UTC (rev 1960)
+++ sandbox/jxlib-3.0/widgets/Legend.js	2009-11-05 19:09:53 UTC (rev 1961)
@@ -238,8 +238,23 @@
         //not used?
         //this.layerInfoURL = json.LayerInfoURL ? json.LayerInfoURL[0] : '';
         this.selectedLayer = null;
+        this.selection = new Jx.Selection({
+            onSelect: function(item) {
+                var treeItem = item.retrieve('jxTreeItem');
+                var data = treeItem.options.data
+                if (data instanceof Fusion.Layers.Group) {
+                    this.getMap().setActiveLayer(null);
+                } else {
+                    this.getMap().setActiveLayer(data);
+            }.bind(this)
-        this.oTree = new Jx.Tree({parent:this.oLegend.domObj});
+        this.oTree = new Jx.Tree({
+            template: '<ul class="jxTreeRoot fusionLegendTreeRoot"></ul>',
+            selection:this.selection
+        }).addTo(this.oLegend.domObj);
         this.hideInvisibleLayers = (json.HideInvisibleLayers && json.HideInvisibleLayers[0]) == 'true' ? true : false;
         //don't show the root folder by default
@@ -255,13 +270,11 @@
             var opt = {
                 label: OpenLayers.i18n('defaultMapTitle'),
                 open: true,
-                draw: this.renderFolder,
                 contextMenu: this.getContextMenu(),
-                'class':'fusionLegendFolder'
             this.oRoot = new Jx.TreeFolder(opt);
-            this.oTree.append(this.oRoot);
-            this.oRoot.options.contextMenu.add(
+            this.oTree.add(this.oRoot);
+            this.oRoot.options.contextMenu.add([
                 new Jx.Menu.Item({
                     label: OpenLayers.i18n('collapse'),
                     onClick: OpenLayers.Function.bind(this.collapseBranch, this, this.oRoot)
@@ -269,7 +282,7 @@
                 new Jx.Menu.Item({
                     label: OpenLayers.i18n('expand'),
                     onClick: OpenLayers.Function.bind(this.expandBranch, this, this.oRoot)
@@ -277,7 +290,7 @@
     getContextMenu: function() {
-        return new Jx.Menu.Context(this.name).add(
+        return new Jx.Menu.Context(this.name).add([
             new Jx.Menu.Item({
                 label: OpenLayers.i18n('refresh'),
                 onClick: OpenLayers.Function.bind(this.update, this)
@@ -289,29 +302,27 @@
             new Jx.Menu.Item({
                 label: OpenLayers.i18n('expandAll'),
                 onClick: OpenLayers.Function.bind(this.expandAll, this)
     expandAll: function(folder) {
-        for (var i=0; i<this.oTree.nodes.length; i++) {
-            var item = this.oTree.nodes[i];
+        this.oTree.items().each(function(item){
             if (item instanceof Jx.TreeFolder) {
-              this.recurseTree('expand', item);
+                this.recurseTree('expand', item);
+        },this);
         if (this.showRootFolder) {
           this.oRoot.expand();
     collapseAll: function(folder) {
-              this.recurseTree('collapse', item);
+                this.recurseTree('collapse', item);
+        },this);
           this.oRoot.collapse();
@@ -332,13 +343,12 @@
      * @param the folder to operate on
     recurseTree: function(op, folder) {
-        for (var i=0; i<folder.nodes.length; i++) {
-            var item = folder.nodes[i];
+        folder.items().each(function(item){
                 this.recurseTree(op, item);
                 item[op]();
+        },this);
     scaleRangesLoaded: function() {
@@ -381,7 +391,7 @@
         this.clear();
-            this.oRoot.itemLabelobj.innerHTML = this.getMap().getMapTitle();
+            this.oRoot.setLabel(this.getMap().getMapTitle());
         var startGroup = this.layerRoot;
         if (!this.showMapFolder) {
@@ -409,48 +419,34 @@
             var opt = {
                 label: group.legendLabel,
                 open: group.expandInLegend,
+                checked: group.visible
-            group.legend.treeItem = new Jx.TreeFolder(opt);
-            group.legend.treeItem.domObj.store('data', group);
-            group.legend.treeItem.options.contextMenu.add(
+            var treeItem = new Fusion.Widget.Legend.TreeFolder(opt);
+            treeItem.options.data = group;
+            group.legend.treeItem = treeItem;
+            treeItem.options.contextMenu.add(
                 new Jx.Menu.Item({
-                    onClick: OpenLayers.Function.bind(this.collapseBranch, this, group.legend.treeItem)
+                    onClick: OpenLayers.Function.bind(this.collapseBranch, this, treeItem)
                 new Jx.Menu.Item({
-                    onClick: OpenLayers.Function.bind(this.expandBranch, this, group.legend.treeItem)
+                    onClick: OpenLayers.Function.bind(this.expandBranch, this, treeItem)
-            folder.append(group.legend.treeItem);
-            group.legend.treeItem.checkBox.checked = group.visible?true:false;
-            OpenLayers.Event.observe(group.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, group));
+            folder.add(treeItem);
             var groupInfo = group.oMap.getGroupInfoUrl(group.groupName);
             if (groupInfo) {
-                var a = document.createElement('a');
-                a.href = groupInfo;
-                if (groupInfo.indexOf('javascript:') < 0) {
-                  a.target = '_blank';
-                var img = document.createElement('img');
-                Jx.addToImgQueue({element:img, src: this.imgGroupInfoIcon});
-                img.border = 0;
-                a.appendChild(img);
-                group.legend.treeItem.domObj.insertBefore(a, group.legend.treeItem.domObj.childNodes[4]);
+                treeItem.setGroupInfo(groupInfo, this.imgGroupInfoIcon);
-            if (this.oSelectionListener) {
-                group.legend.treeItem.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
             for (var i=0; i<group.groups.length; i++) {
-                this.processMapGroup(group.groups[i], group.legend.treeItem);
+                this.processMapGroup(group.groups[i], treeItem);
             for (var i=0; i<group.layers.length; i++) {
-                this.processMapLayer(group.layers[i], group.legend.treeItem);
+                this.processMapLayer(group.layers[i], treeItem);
@@ -464,7 +460,7 @@
     layerPropertyChanged: function(eventID, layer) {
-        layer.legend.treeItem.checkBox.checked = layer.isVisible();
+        layer.legend.treeItem.check(layer.isVisible());
     update: function() {
@@ -491,26 +487,9 @@
      * remove the dom objects representing the legend layers and groups
     clear: function() {
-        while (this.oRoot.nodes.length > 0) {
-            this.oRoot.remove(this.oRoot.nodes[0]);
+        this.oRoot.empty();
-    selectionChanged: function(o) {
-        if (this.currentNode) {
-          //console.log(this.currentNode);
-            $(this.currentNode.domObj.childNodes[1]).removeClass('jxTreeItemSelected');
-        this.currentNode = o;
-        $(this.currentNode.domObj.childNodes[1]).addClass('jxTreeItemSelected');
-        var data = o.domObj.retrieve('data');
-        if (data instanceof Fusion.Layers.Group) {
-            this.getMap().setActiveLayer(null);
-        } else {
-            this.getMap().setActiveLayer(data);
     updateGroupLayers: function(group, fScale) {
             this.updateGroupLayers(group.groups[i], fScale);
@@ -520,100 +499,90 @@
     updateLayer: function(layer, fScale) {
-        var checkbox = layer.oMap.bSingleTile ? this.bIncludeVisToggle : false;
+        /* no need to do anything if we are hiding the layer */
         if (!layer.displayInLegend || !layer.legend) {
             return;
+        /* check the layer's current scale range against the previous one
+         * if the range hasn't changed, don't do anything
         var range = layer.getScaleRange(fScale);
         if (range == layer.legend.currentRange && layer.legend.treeItem) {
             return;
+        /* remember the range we are now representing for the next update */
         layer.legend.currentRange = range;
-        if (range != null) {
+        /* if layer is in range and has at least one style */
+        if (range != null && range.styles && range.styles.length > 0) {
+            /* if it has more than one style, we represent it as a folder
+             * with classes as items in it
             if (range.styles.length > 1) {
                 //tree item needs to be a folder
                 if (!layer.legend.treeItem) {
                     layer.legend.treeItem = this.createFolderItem(layer);
-                    OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
-                    layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
-                } else if (layer.legend.treeItem instanceof Jx.TreeItem) {
+                    layer.parentGroup.legend.treeItem.add(layer.legend.treeItem);
+                } else if (layer.legend.treeItem instanceof Fusion.Widget.Legend.TreeItem) {
                     this.clearTreeItem(layer);
                 } else {
-                    while(layer.legend.treeItem.nodes.length > 0) {
-                        layer.legend.treeItem.remove(layer.legend.treeItem.nodes[0]);
+                    layer.legend.treeItem.empty();
                 for (var i=0; i<range.styles.length; i++) {
                     var item = this.createTreeItem(layer,
                                                range.styles[i], fScale, false);
-                    layer.legend.treeItem.append(item);
+                    layer.legend.treeItem.add(item);
+            /* if there is only one style, we represent it as a tree item */
             } else {
                 var style = range.styles[0];
-                if (style && !style.legendLabel) {
-                  style.legendLabel = layer.legendLabel;
+                if (!style.legendLabel) {
+                    style.legendLabel = layer.legendLabel;
-                    layer.legend.treeItem = this.createTreeItem(layer, style, fScale, checkbox);
-                    if (checkbox) {
-                } else if (layer.legend.treeItem instanceof Jx.TreeFolder) {
+                    layer.legend.treeItem = this.createTreeItem(layer, style, fScale, true);
+                } else if (layer.legend.treeItem instanceof Fusion.Widget.Legend.TreeFolder) {
-                    if (checkbox) {
                 } else {
                     if (range.styles.length > 0) {
-                        layer.legend.treeItem.domImg.style.backgroundImage = 'url('+layer.oMap.getLegendImageURL(fScale, layer, range.styles[0])+')' ;
-                        $(layer.legend.treeItem.domObj).removeClass('jxDisabled');
+                        var url = layer.oMap.getLegendImageURL(fScale, layer, range.styles[0]);
+                        layer.legend.treeItem.setImage(url);
+                        layer.legend.treeItem.enable(true);
                     } else {
-                        $(layer.legend.treeItem.domObj).addClass('jxDisabled');
+                        layer.legend.treeItem.enable(false);
-            if (checkbox) {
-              layer.legend.treeItem.checkBox.checked = layer.visible?true:false;
-              if (layer.layerTypes[0] == 4 || range.styles.length > 0) {
-                layer.legend.treeItem.checkBox.disabled = false;
-              } else {
-                layer.legend.treeItem.checkBox.disabled = true;
         } else {
+            /* the layer is to be displayed but is not visible in the map
+             * at the current map scale so disable it and display as a tree
+             * item or hide it altogether if necessary;
             if (this.hideInvisibleLayers) {
                 if (layer.legend.treeItem) {
                     layer.parentGroup.legend.treeItem.remove(layer.legend.treeItem);
                     layer.legend.treeItem = null;
             } else {
-              var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel}, null, checkbox);
-                if (checkbox) {
-                  OpenLayers.Event.observe(newTreeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
+              var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel}, null, true);
-                    if (checkbox) layer.legend.treeItem.checkBox.disabled = true;
                     layer.parentGroup.legend.treeItem.replace(newTreeItem, layer.legend.treeItem);
                     layer.legend.treeItem.finalize();
                 } else {
-                    layer.parentGroup.legend.treeItem.append(newTreeItem);
+                    layer.parentGroup.legend.treeItem.add(newTreeItem);
                 layer.legend.treeItem = newTreeItem;
-            layer.legend.treeItem.domObj.store('data', layer);
+            layer.legend.treeItem.options.data = layer;
+            layer.legend.treeItem.check(layer.visible);
@@ -621,14 +590,13 @@
         var opt = {
             label: layer.legendLabel == '' ? '&nbsp;' : layer.legendLabel,
             isOpen: layer.expandInLegend,
-            'class':'fusionLegendItemCheckbox',
-            // image overrides
             image: this.imgLayerThemeIcon
-        var folder = new Jx.TreeFolder(opt);
-        folder.options.contextMenu.add(
+        var folder = new Fusion.Widget.Legend.TreeFolder(opt);
+        var img = folder.elements.get('jxTreeIcon');
+        img.style.backgroundPosition = '0px 0px';
+        folder.options.contextMenu.add([
             new Jx.Menu.Item({
                 onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
@@ -636,38 +604,22 @@
             new Jx.Menu.Item({
                 onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
         var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
         if (layerInfo) {
-            a.href = layerInfo;
-            if (layerInfo.indexOf('javascript:') < 0) {
-            Jx.addToImgQueue({element:img, src:this.imgLayerInfoIcon});
-            img.border = 0;
-            folder.domObj.insertBefore(a, folder.domObj.childNodes[4]);
+            folder.setLayerInfo(layerInfo, this.imgLayerInfoIcon);
-        folder.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
         return folder;
-    createTreeItem: function(layer, style, scale, bCheckBox) {
+    createTreeItem: function(layer, style, scale, checkbox) {
         var opt = {};
         opt.statusIsDefault = layer.statusDefault;
+        opt.label = style.legendLabel == '' ? '&nbsp;' : style.legendLabel;
-        if (bCheckBox ) {
-            opt.label = layer.legendLabel == '' ? '&nbsp;' : layer.legendLabel;
-            opt.draw = this.renderItemCheckBox;
-        } else {
-            opt.label = style.legendLabel == '' ? '&nbsp;' : style.legendLabel;
-            opt.draw = this.renderItem;
         if (!style) {
             opt.image = this.imgDisabledLayerIcon;
             opt.enabled = false;
@@ -686,174 +638,177 @@
                 opt.image = layer.oMap.getLegendImageURL(scale, layer, style, defaultIcon);
-        opt.contextMenu = this.getContextMenu();
-        var item = new Jx.TreeItem(opt);
-        if (style && style.iconX >= 0 && style.iconY >= 0) {
-            item.domImg;
-            item.domImg.style.backgroundImage = 'url('+opt.image+')';
-            item.domImg.src = Jx.aPixel.src;
-            item.domImg.style.backgroundPosition = (-1*style.iconX) + 'px ' + (-1*style.iconY) + 'px';
-            if (style.iconOpt.width) {
-                item.domImg.style.width = style.iconOpt.width + 'px';
-            if (style.iconOpt.height) {
-                item.domImg.style.height = style.iconOpt.height + 'px';
-        if (bCheckBox) {
-            //item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
+        var item;
+        if (checkbox) {
+            opt.contextMenu = this.getContextMenu();
+            item = new Fusion.Widget.Legend.TreeItem(opt);
             /* only need to add layer info if it has a check box too */
             if (layerInfo) {
+                item.setLayerInfo(layerInfo, this.imgLayerInfoIcon);
+        }  else {
+            opt.selectable = false;
+            item = new Jx.TreeItem(opt);
+        var iconX = 0;
+        var iconY = 0;
+        if (style && style.iconX >= 0 && style.iconY >= 0) {
+            /* calculate the size of the image that holds the icon
+             * only once and cache the values as it is an expensive operation
+             * We use the size to center the class/layer icon as a background
+             * image inside the image that holds it so that if the icon is
+             * not the same size it is represented in a reasonable way
+            var img = item.elements.get('jxTreeIcon');
+            if (!this.offsetsCalculated) {
+                var parent = img.parentNode;
+                var sibling = img.getPrevious();
+                var d = new Element('div', {'class':'fusionLegendTreeRoot'});
+                img.setStyle('visiblity','hidden');
+                img.inject(d);
+                var w = img.getStyle('width').toInt();
+                var h = img.getStyle('height').toInt();
+                if (!sibling) {
+                    img.inject(parent,'top');
+                } else {
+                    img.inject(sibling, 'after');
-                Jx.addToImgQueue({element:img, src: this.imgLayerInfoIcon});
-                img.border = 0;
-                item.domObj.insertBefore(a, item.domObj.childNodes[4]);
+                img.setStyle('visibility','visible');
+                this.iconWidth = (style.iconOpt.width - w)/2;
+                this.iconHeight = (style.iconOpt.height - h)/2;
+                this.offsetsCalculated = true;
+            iconX = -1 * (style.iconX + this.iconWidth);
+            iconY = -1 * (style.iconY + this.iconHeight);
-        item.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
+        img.style.backgroundPosition = iconX + 'px ' + iconY + 'px';
         return item;
     clearTreeItem: function(layer) {
         if (layer.legend.treeItem && layer.legend.treeItem.owner) {
-            layer.legend.treeItem.domObj.store('data', null);
             layer.legend.treeItem.owner.remove(layer.legend.treeItem);
-            layer.legend.treeItem.finalize();
+            layer.legend.treeItem.destroy();
+Fusion.Widget.Legend.TreeItem = new Class({
+    Extends: Jx.TreeItem,
+    options: {
+        template: '<li class="jxTreeContainer jxTreeLeaf"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><a class="fusionLayerInfo"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a></li>'
-    stateChanged: function(obj, event) {
-        if (obj.legend && obj.legend.treeItem.checkBox) {
-            if (obj.legend.treeItem.checkBox.checked) {
-                obj.show();
-            } else {
-                obj.hide();
+    classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','fusionLegendCheckboxInput','fusionLayerInfo','fusionLayerInfoIcon'],
+    render: function() {
+        this.parent();
+        this.checkbox = this.elements.get('fusionLegendCheckboxInput');
+        if (this.checkbox) {
+            if ($defined(this.options.checked)) {
+                this.check(this.options.checked);
+            this.checkbox.addEvent('change', function(e){
+                if (this.options.data) {
+                    if (e.target.checked && this.options.data.show) {
+                        this.options.data.show();
+                    } else if (!e.target.checked && this.options.data.hide) {
+                        this.options.data.hide();
+            }.bind(this));
+            this.addEvents({
+                enabled: function() {
+                    this.checkbox.disabled = false;
+                disabled: function() {
+                    this.checkbox.disabled = true;
-        OpenLayers.Event.stop(event, true);
-    renderFolder: function() {
-        var domA = new Element('a',{
-            'class':this.options['class'],
-            href:'javascript:void(0)',
-            events: {
-                click: this.selected.bindWithEvent(this),
-                dblclick: this.selected.bindWithEvent(this),
-                contextmenu: this.options.contextMenu.show.bindWithEvent(this.options.contextMenu)
-        this.checkBox = document.createElement('input');
-        this.checkBox.type = 'checkbox';
-        this.domImg = document.createElement('img');
-        this.domImg.className = 'jxTreeIcon ' + (this.options.imageClass ? this.options.imageClass : '');
-        this.domImg.src = Jx.aPixel.src;
-        if (this.options.image) {
-            this.domImg.style.backgroundImage = 'url('+this.options.image+')';
+    check: function(state) {
+            this.checkbox.set('checked', state);
+    isChecked: function() {
+        return this.checkbox && this.checkbox.checked;
+    setLayerInfo: function(url, icon) {
+        //change class to make fusionLayerInfo display block
+        this.domObj.addClass('showFusionLayerInfo');
+        if (this.elements.get('fusionLayerInfo')) {
+            this.elements.get('fusionLayerInfo').set('href', url);
+        if (this.elements.get('fusionLayerInfoIcon')) {
+            this.elements.get('fusionLayerInfoIcon').set('src', icon);
-        var domLabel = new Element('span',{
-            'class': 'fusionLegendLabel',
-            html: this.options.label
-        domA.appendChild(this.checkBox);
-        domA.appendChild(this.domImg);
-        domA.appendChild(domLabel);
-        this.itemLabelobj = domA;
-        return domA;
+Fusion.Widget.Legend.TreeFolder = new Class({
+    Extends: Jx.TreeFolder,
+    options: {
+        template: '<li class="jxTreeContainer jxTreeBranch"><img class="jxTreeImage" src="'+Jx.aPixel.src+'" alt="" title=""><span class="fusionLegendCheckboxContainer"><input type="checkbox" class="fusionLegendCheckboxInput"></span><a class="jxTreeItem fusionCheckboxItem" href="javascript:void(0);"><img class="jxTreeIcon" src="'+Jx.aPixel.src+'" alt="" title=""><span class="jxTreeLabel"></span></a><a class="fusionGroupInfo"><img class="fusionGroupInfoIcon" src="'+Jx.aPixel.src+'"></a><a class="fusionLayerInfo"><img class="fusionLayerInfoIcon" src="'+Jx.aPixel.src+'"></a><ul class="jxTreeFolder"></ul></li>'
+    classes: ['jxTreeContainer','jxTreeImage','jxTreeItem','jxTreeIcon','jxTreeLabel','jxTreeFolder','fusionLegendCheckboxInput','fusionGroupInfo','fusionGroupInfoIcon','fusionLayerInfo','fusionLayerInfoIcon'],
-    renderItem: function() {
-        var domA = new Element('a', {
-            'class': 'fusionLegendItem',
-            href: 'javascript:void(0)',
-            events: {
+        this.parent();
+            }.bind(this));
+            this.addEvents({
-        return domA;
-    renderItemCheckBox: function() {
-            'class': 'fusionLegendItemCheckbox',
-            'href':'javascript:void(0);',
-            events: {
-        /* layer is set to "status default" set checkbox to checked , disabled , read only*/
-        if(this.options.statusIsDefault){
-            this.checkBox.checked = true;
-            this.checkBox.disabled = true;
-            this.checkBox.readOnly = true;
+    setGroupInfo: function(url, icon) {
+        //change class to make fusionGroupInfo display block
+        this.domObj.addClass('showFusionGroupInfo');
+        if (this.elements.get('fusionGroupInfo')) {
+            this.elements.get('fusionGroupInfo').set('href', url);
+        if (this.elements.get('fusionGroupInfoIcon')) {
+            this.elements.get('fusionGroupInfoIcon').set('src', icon);
-        return domA;
\ No newline at end of file
More information about the fusion-commits mailing list
