[fusion-commits] r1996 - sandbox/jxlib-3.0/lib
    svn_fusion at osgeo.org
    Fri Nov 27 11:22:18 EST 2009
Author: pagameba
Date: 2009-11-27 11:22:16 -0500 (Fri, 27 Nov 2009)
New Revision: 1996
   sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
updating jxlib.
Modified: sandbox/jxlib-3.0/lib/jxlib.uncompressed.js
--- sandbox/jxlib-3.0/lib/jxlib.uncompressed.js	2009-11-27 02:21:28 UTC (rev 1995)
+++ sandbox/jxlib-3.0/lib/jxlib.uncompressed.js	2009-11-27 16:22:16 UTC (rev 1996)
@@ -21366,7 +21366,7 @@
-// $Id: combo.js 626 2009-11-20 13:22:22Z pagameba $
+// $Id: combo.js 647 2009-11-26 16:23:24Z pagameba $
  * Class: Jx.Button.Combo
@@ -21456,7 +21456,7 @@
             this.add(this.options.items);
         var button = this;
-        this.addEvent('click', (function(e) {
+        this.addEvent('click', function(e) {
             if (this.list.count() === 0) {
                 return;
@@ -21482,11 +21482,11 @@
             this.contentContainer.setStyle('visibility','');
-            document.addEvent('mousedown', this.hideWatcher);
-            document.addEvent('keyup', this.keypressWatcher);
+            document.addEvent('mousedown', this.bound.mousedown);
+            document.addEvent('keyup', this.bound.keypress);
             this.fireEvent('show', this);
-        }).bindWithEvent(this.menu));
+        }.bindWithEvent(this.menu));
         this.menu.addEvents({
             'show': (function() {
@@ -25056,8 +25056,15 @@
          * Option: disabled
          * {True|False} defaults to false. Whether this field is disabled.
-        disabled : false
+        disabled : false,
+         * Option: defaultAction
+         * {Boolean} defaults to false, if true and this field is a button
+         * of some kind (Jx.Button, a button or an input of type submit) then
+         * if the user hits the enter key on any field in the form except a
+         * textarea, this field will be activated as if clicked
+        defaultAction: false
@@ -25251,6 +25258,19 @@
     enable : function () {
         this.field.erase("disabled");
         this.field.removeClass('jxFieldDisabled');
+     * APIMethod: addTo
+    addTo: function(what) {
+        if (what instanceof Jx.Fieldset || what instanceof Jx.Form) {
+            what.add(this);
+        } else {
+            this.parent(what);
+        return this;
@@ -25404,6 +25424,15 @@
+     * Property: defaultAction
+     * the default field to activate if the user hits the enter key in this
+     * form.  Set by specifying default: true as an option to a field.  Will
+     * only work if the default is a Jx button field or an input of a type
+     * that is a button
+    defaultAction: null,
      * Property: fields
@@ -25427,7 +25456,18 @@
             'method' : this.options.method,
             'action' : this.options.action,
             'class' : 'jxForm',
-            'name' : this.options.name
+            'name' : this.options.name,
+            events: {
+                keypress: function(e) {
+                    if (e.key == 'enter' &&
+                        e.target.tagName != "TEXTAREA" &&
+                        this.defaultAction &&
+                        this.defaultAction.click) {
+                        document.id(this.defaultAction).focus();
+                        this.defaultAction.click();
+                }.bind(this)
         if (this.options.fileUpload) {
@@ -25450,9 +25490,11 @@
     addField : function (field) {
         this.fields.set(field.id, field);
+        if (field.options.defaultAction) {
+            this.defaultAction = field;
      * Method: isValid
      * Determines if the form passes validation
@@ -31689,7 +31731,21 @@
             this.domObj.grab(field);
         return this;
+        if (what instanceof Jx.Form) {
+            this.form = what;
+        } else if (what instanceof Jx.Fieldset) {
+            this.form = what.form;
+        return this.parent(what);
 // $Id: $
@@ -32199,6 +32255,9 @@
         template: '<span class="jxInputContainer"><label class="jxInputLabel"></label><div class="jxInputButton"></div><span class="jxInputTag"></span></span>'
+    button: null,
      * Property: type
      * The type of this field
@@ -32207,14 +32266,17 @@
     processTemplate: function(template, classes, container) {
         var h = this.parent(template, classes, container);
-        var b = new Jx.Button(this.options.buttonOptions);
+        this.button = new Jx.Button(this.options.buttonOptions);
         var c = h.get('jxInputButton');
         if (c) {
-            b.domObj.replaces(c);
+            this.button.domObj.replaces(c);
         return h;
+    click: function() {
+        this.button.clicked();
 });// $Id: $
  * Class: Jx.Field.Password
More information about the fusion-commits
