[fusion-commits] r2053 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Feb 2 14:14:28 EST 2010
Author: madair
Date: 2010-02-02 14:14:26 -0500 (Tue, 02 Feb 2010)
New Revision: 2053
   sandbox/jxlib-3.0/widgets/MapMenu.js
use resourceId rather than MapResource for menu hierarchy
Modified: sandbox/jxlib-3.0/widgets/MapMenu.js
--- sandbox/jxlib-3.0/widgets/MapMenu.js	2010-02-02 16:49:01 UTC (rev 2052)
+++ sandbox/jxlib-3.0/widgets/MapMenu.js	2010-02-02 19:14:26 UTC (rev 2053)
@@ -108,7 +108,7 @@
             if (o.values) {
               for (var i=0; i<list.length; i++) {
                   var resource = list[i];
-                  var mapId = resource.sMapResource;
+                  var mapId = resource.sResourceId;
                   mapId = mapId.replace(this.rootFolder, '');
                   var folders = mapId.split('/');
                   var label = folders.pop();
@@ -118,7 +118,7 @@
                   // check for mapgroup data and if there is none,
                   // create a maptag that will be passed to the map
                   // widget constructor
-                  data = {maps:[{'resourceId': resource.sResourceId,
+                  data = {maps:[{'resourceId': resource.sMapResource,
                           'singleTile':true,
                           'type': this.arch,
                           'extension':{'MapFile': [resource.sPath]}
More information about the fusion-commits mailing list
