[fusion-commits] r2045 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Jan 28 14:13:22 EST 2010
Author: madair
Date: 2010-01-28 14:13:21 -0500 (Thu, 28 Jan 2010)
New Revision: 2045
   sandbox/jxlib-3.0/widgets/Select.js
   sandbox/jxlib-3.0/widgets/SelectAttribute.js
   sandbox/jxlib-3.0/widgets/SelectPolygon.js
   sandbox/jxlib-3.0/widgets/SelectRadius.js
selection widgets look for active layer; adjust drawing of Select by attribute
Modified: sandbox/jxlib-3.0/widgets/Select.js
--- sandbox/jxlib-3.0/widgets/Select.js	2010-01-26 20:35:43 UTC (rev 2044)
+++ sandbox/jxlib-3.0/widgets/Select.js	2010-01-28 19:13:21 UTC (rev 2045)
@@ -35,7 +35,7 @@
     isExclusive: true,
     uiClass: Jx.Button,
     selectionType: 'INTERSECTS',
-    nTolerance : 3,     //default pixel tolerance for a point click
+    nTolerance: 3,     //default pixel tolerance for a point click
     bActiveOnly: false, //only select feature(s) on the active layer?
     maxFeatures: 0,     //default of 0 selects all features (i.e. no maximum)
     pointClickSingleSelect: true, //default of true causes a point click always to select only a single feature
Modified: sandbox/jxlib-3.0/widgets/SelectAttribute.js
--- sandbox/jxlib-3.0/widgets/SelectAttribute.js	2010-01-26 20:35:43 UTC (rev 2044)
+++ sandbox/jxlib-3.0/widgets/SelectAttribute.js	2010-01-28 19:13:21 UTC (rev 2045)
@@ -34,6 +34,7 @@
 Fusion.Widget.SelectAttribute = OpenLayers.Class(Fusion.Widget, {
     isExclusive: true,
     uiClass: Jx.Button,
+    drawn: false,
     initializeWidget: function(widgetTag) {
         var json = widgetTag.extension;
@@ -42,7 +43,6 @@
           this.container = $(json.Container[0]);
         this.workArea = document.createElement('div');
-        this.workArea.style.display = 'none';
         this.container.appendChild(this.workArea);
         //eventually there will be multiple rows for AND/OR ops on attributes
@@ -51,6 +51,7 @@
         this.workArea.appendChild(this.attrRow);
         this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.listLayers, this));
+        this.getMap().registerForEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, OpenLayers.Function.bind(this.setActiveLayer, this));
@@ -89,6 +90,15 @@
+    setActiveLayer: function(event, layer) {
+      for (var i=0; i<this.layerList.options.length; ++i) {
+        if (this.layerList.options[i].value == layer.layerName) {
+          this.layerList.selectedIndex = i;
+          break;
     setAttributes: function(xhr) {
       if (xhr.status < 400) {
           eval('this.attrs='+xhr.responseText);
@@ -103,6 +113,13 @@
       for (var i=0; i<attrs.length; ++i) {
           this.propsList.add(new Option(attrs[i],props[i]),null);
+      var map = this.getMap();
+      for (var i=0; i<map.aMaps[0].aLayers.length; ++i) {
+        if (map.aMaps[0].aLayers[i].layerName == layer) {
+          map.setActiveLayer(map.aMaps[0].aLayers[i]);
+          break;
@@ -111,32 +128,34 @@
      * as a widget in the map
     activate: function() {
-        this.workArea.style.display = 'block';
-        this.attrRow.innerHTML = "";
+        this.container.style.display = 'block';
-        this.propsList = document.createElement('select');
-        this.propsList.className = 'propsSelector';
-        this.attrRow.appendChild(this.propsList);
-        this.operatorList = document.createElement('select');
-        this.operatorList.className = 'operatorSelector';
-        this.operatorList.add(new Option("=","eq",true),null);
-        this.operatorList.add(new Option("like","like"),null);
-        this.operatorList.add(new Option(">","gt"),null);
-        this.operatorList.add(new Option("<","lt"),null);
-        this.operatorList.add(new Option("<=","le"),null);
-        this.operatorList.add(new Option(">=","ge"),null);
-        this.operatorList.add(new Option("!=","ne"),null);
-        this.attrRow.appendChild(this.operatorList);
-        this.attrValue = document.createElement('input');
-        this.attrValue.className = 'propsValue';
-        this.attrRow.appendChild(this.attrValue);
-        new Jx.Button({
-            label: 'Query',
-            onClick: OpenLayers.Function.bind(this.execute, this)
-        }).addTo(this.attrRow);
+        if (!this.drawn) {
+          this.drawn = true;
+          this.propsList = document.createElement('select');
+          this.propsList.className = 'propsSelector';
+          this.attrRow.appendChild(this.propsList);
+          this.operatorList = document.createElement('select');
+          this.operatorList.className = 'operatorSelector';
+          this.operatorList.add(new Option("=","eq",true),null);
+          this.operatorList.add(new Option("like","like"),null);
+          this.operatorList.add(new Option(">","gt"),null);
+          this.operatorList.add(new Option("<","lt"),null);
+          this.operatorList.add(new Option("<=","le"),null);
+          this.operatorList.add(new Option(">=","ge"),null);
+          this.operatorList.add(new Option("!=","ne"),null);
+          this.attrRow.appendChild(this.operatorList);
+          this.attrValue = document.createElement('input');
+          this.attrValue.className = 'propsValue';
+          this.attrRow.appendChild(this.attrValue);
+          new Jx.Button({
+              label: 'Query',
+              onClick: OpenLayers.Function.bind(this.execute, this)
+          }).addTo(this.attrRow);
@@ -145,7 +164,8 @@
     deactivate: function() {
+        this.container.style.display = 'none';
+        //this.workArea.style.display = 'none';
Modified: sandbox/jxlib-3.0/widgets/SelectPolygon.js
--- sandbox/jxlib-3.0/widgets/SelectPolygon.js	2010-01-26 20:35:43 UTC (rev 2044)
+++ sandbox/jxlib-3.0/widgets/SelectPolygon.js	2010-01-28 19:13:21 UTC (rev 2045)
@@ -33,6 +33,7 @@
 Fusion.Widget.SelectPolygon = OpenLayers.Class(Fusion.Widget, {
     isExclusive: true,
     uiClass: Jx.Button,
+    bActiveOnly: false, //only select feature(s) on the active layer?
     nTolerance: 3, //default pixel tolernace for a point click
@@ -45,6 +46,11 @@
         if (json.Tolerance && (parseInt(json.Tolerance[0]) > 0)) {
             nTolerance = parseInt(json.Tolerance[0]);
+        this.bActiveOnly = (json.QueryActiveLayer &&
+                           (json.QueryActiveLayer[0] == 'true' ||
+                            json.QueryActiveLayer[0] == '1')) ? true : false;
         this.bComputeMetadata = (json.ComputeMetadata &&
                            (json.ComputeMetadata[0] == 'true' ||
                             json.ComputeMetadata[0] == '1')) ? true : false;
Modified: sandbox/jxlib-3.0/widgets/SelectRadius.js
--- sandbox/jxlib-3.0/widgets/SelectRadius.js	2010-01-26 20:35:43 UTC (rev 2044)
+++ sandbox/jxlib-3.0/widgets/SelectRadius.js	2010-01-28 19:13:21 UTC (rev 2045)
@@ -35,6 +35,7 @@
     isExclusive: true,
     uiClass: Jx.Button,
     defaultRadius: 20, //this is now in pixels
@@ -53,6 +54,9 @@
         var container = json.RadiusTooltipContainer ? json.RadiusTooltipContainer[0] : '';
         if (container != '') {
More information about the fusion-commits mailing list
