[fusion-commits] r2196 - in branches/fusion-2.0: layers/MapGuide
templates/mapguide/standard
svn_fusion at osgeo.org
Thu Jul 29 13:55:37 EDT 2010
Author: madair
Date: 2010-07-29 17:55:37 +0000 (Thu, 29 Jul 2010)
New Revision: 2196
branches/fusion-2.0/layers/MapGuide/MapGuide.js
branches/fusion-2.0/templates/mapguide/standard/ApplicationDefinition.xml
re #395: reverting to the old way of setting projection code in AppDef for the 2.0 release; parsing of WKT will be handled in 2.2 release
Modified: branches/fusion-2.0/layers/MapGuide/MapGuide.js
--- branches/fusion-2.0/layers/MapGuide/MapGuide.js 2010-07-29 09:23:22 UTC (rev 2195)
+++ branches/fusion-2.0/layers/MapGuide/MapGuide.js 2010-07-29 17:55:37 UTC (rev 2196)
@@ -303,16 +303,6 @@
//set projection units and code if supplied
if (o.epsg != 0) {
this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
- } else {
- if (o.wkt.length > 0) {
- var wkt = o.wkt;
- var wktContentRE = /(\w+)\[(.*)\]/;
- var wktContent = wkt.match(wktContentRE);
- var wktName = wktContent[2].split(",")[0];
- wktName = wktName.toUpperCase();
- this.mapTag.layerOptions.projection = wktName;
- Proj4js.defs[wktName] = "+proj=identity +"+wkt;
//TODO: consider passing the metersPerUnit value into the framework
//to allow for scaling that doesn't match any of the pre-canned units
Modified: branches/fusion-2.0/templates/mapguide/standard/ApplicationDefinition.xml
--- branches/fusion-2.0/templates/mapguide/standard/ApplicationDefinition.xml 2010-07-29 09:23:22 UTC (rev 2195)
+++ branches/fusion-2.0/templates/mapguide/standard/ApplicationDefinition.xml 2010-07-29 17:55:37 UTC (rev 2196)
@@ -15,6 +15,7 @@
<SingleTile>true</SingleTile>
<Extension>
<ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</ResourceId>
+ <ProjectionCode>EPSG:4326</ProjectionCode>
<ImageFormat>PNG8</ImageFormat>
<SelectionAsOverlay>true</SelectionAsOverlay>
<SelectionFormat>PNG</SelectionFormat>
@@ -44,6 +45,7 @@
<Extension>
<SelectionColor>0xFF0000FF</SelectionColor>
@@ -56,6 +58,7 @@
<SingleTile>false</SingleTile>
<Extension>
<ResourceId>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</ResourceId>
</Extension>
</Map>
</MapGroup>
More information about the fusion-commits
