[fusion-commits] r2186 - in trunk: layers/MapGuide lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Jun 24 14:01:01 EDT 2010
Author: madair
Date: 2010-06-24 18:01:01 +0000 (Thu, 24 Jun 2010)
New Revision: 2186
   trunk/layers/MapGuide/MapGuide.js
   trunk/lib/proj4js-compressed.js
   trunk/widgets/Measure.js
re #395: patch applied to trunk
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2010-06-24 17:57:04 UTC (rev 2185)
+++ trunk/layers/MapGuide/MapGuide.js	2010-06-24 18:01:01 UTC (rev 2186)
@@ -303,6 +303,16 @@
             //set projection units and code if supplied
             if (o.epsg != 0) {
               this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
+            } else {
+              if (o.wkt.length > 0) {
+                  var wkt = o.wkt;
+                  var wktContentRE = /(\w+)\[(.*)\]/;
+                  var wktContent = wkt.match(wktContentRE);
+                  var wktName = wktContent[2].split(",")[0];
+                  wktName = wktName.toUpperCase();
+                  this.mapTag.layerOptions.projection = wktName;
+                  Proj4js.defs[wktName] = "+proj=identity +"+wkt;
             //TODO: consider passing the metersPerUnit value into the framework
             //to allow for scaling that doesn't match any of the pre-canned units
Modified: trunk/lib/proj4js-compressed.js
--- trunk/lib/proj4js-compressed.js	2010-06-24 17:57:04 UTC (rev 2185)
+++ trunk/lib/proj4js-compressed.js	2010-06-24 18:01:01 UTC (rev 2186)
@@ -43,7 +43,7 @@
 if(!this.a){var ellipse=Proj4js.Ellipsoid[this.ellps]?Proj4js.Ellipsoid[this.ellps]:Proj4js.Ellipsoid['WGS84'];Proj4js.extend(this,ellipse);}
 if(this.rf&&!this.b)this.b=(1.0-1.0/this.rf)*this.a;if(Math.abs(this.a-this.b)<Proj4js.common.EPSLN){this.sphere=true;this.b=this.a;}
 this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=(this.a2-this.b2)/this.a2;this.e=Math.sqrt(this.es);if(this.R_A){this.a*=1.-this.es*(Proj4js.common.SIXTH+this.es*(Proj4js.common.RA4+this.es*Proj4js.common.RA6));this.a2=this.a*this.a;this.b2=this.b*this.b;this.es=0.;}
-this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",'EPSG:3785':"+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"};Proj4js.defs['GOOGLE']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:900913']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:102113']=Proj4js.defs['EPSG:3785'];Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.283185307179586477,FORTPI:0.78539816339744833,R2
 D:57.29577951308232088,D2R:0.01745329251994329577,SEC_TO_RAD:4.84813681109535993589914102357e-6,EPSLN:1.0e-10,MAX_ITER:20,COS_67P5:0.38268343236508977,AD_C:1.0026000,PJD_UNKNOWN:0,PJD_3PARAM:1,PJD_7PARAM:2,PJD_GRIDSHIFT:3,PJD_WGS84:4,PJD_NODATUM:5,SRS_WGS84_SEMIMAJOR:6378137.0,SIXTH:.1666666666666666667,RA4:.04722222222222222222,RA6:.02215608465608465608,RV4:.06944444444444444444,RV6:.04243827160493827160,msfnz:function(eccent,sinphi,cosphi){var con=eccent*sinphi;return cosphi/(Math.sqrt(1.0-con*con));},tsfnz:function(eccent,phi,sinphi){var con=eccent*sinphi;var com=.5*eccent;con=Math.pow(((1.0-con)/(1.0+con)),com);return(Math.tan(.5*(this.HALF_PI-phi))/con);},phi2z:function(eccent,ts){var eccnth=.5*eccent;var con,dphi;var phi=this.HALF_PI-2*Math.atan(ts);for(i=0;i<=15;i++){con=eccent*Math.sin(phi);dphi=this.HALF_PI-2*Math.atan(ts*(Math.pow(((1.0-con)/(1.0+con)),eccnth)))-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001)return phi;}
+this.ep2=(this.a2-this.b2)/this.b2;if(!this.k0)this.k0=1.0;this.datum=new Proj4js.datum(this);}});Proj4js.Proj.longlat={init:function(){},forward:function(pt){return pt;},inverse:function(pt){return pt;}};Proj4js.Proj.identity=Proj4js.Proj.longlat;Proj4js.defs={'WGS84':"+title=long/lat:WGS84 +proj=longlat +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4326':"+title=long/lat:WGS84 +proj=longlat +a=6378137.0 +b=6356752.31424518 +ellps=WGS84 +datum=WGS84 +units=degrees",'EPSG:4269':"+title=long/lat:NAD83 +proj=longlat +a=6378137.0 +b=6356752.31414036 +ellps=GRS80 +datum=NAD83 +units=degrees",'EPSG:3785':"+title= Google Mercator +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"};Proj4js.defs['GOOGLE']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:900913']=Proj4js.defs['EPSG:3785'];Proj4js.defs['EPSG:102113']=Proj4js.defs['EPSG:3785'];Proj4js.common={PI:3.141592653589793238,HALF_PI:1.570796326794896619,TWO_PI:6.28318
 5307179586477,FORTPI:0.78539816339744833,R2D:57.29577951308232088,D2R:0.01745329251994329577,SEC_TO_RAD:4.84813681109535993589914102357e-6,EPSLN:1.0e-10,MAX_ITER:20,COS_67P5:0.38268343236508977,AD_C:1.0026000,PJD_UNKNOWN:0,PJD_3PARAM:1,PJD_7PARAM:2,PJD_GRIDSHIFT:3,PJD_WGS84:4,PJD_NODATUM:5,SRS_WGS84_SEMIMAJOR:6378137.0,SIXTH:.1666666666666666667,RA4:.04722222222222222222,RA6:.02215608465608465608,RV4:.06944444444444444444,RV6:.04243827160493827160,msfnz:function(eccent,sinphi,cosphi){var con=eccent*sinphi;return cosphi/(Math.sqrt(1.0-con*con));},tsfnz:function(eccent,phi,sinphi){var con=eccent*sinphi;var com=.5*eccent;con=Math.pow(((1.0-con)/(1.0+con)),com);return(Math.tan(.5*(this.HALF_PI-phi))/con);},phi2z:function(eccent,ts){var eccnth=.5*eccent;var con,dphi;var phi=this.HALF_PI-2*Math.atan(ts);for(i=0;i<=15;i++){con=eccent*Math.sin(phi);dphi=this.HALF_PI-2*Math.atan(ts*(Math.pow(((1.0-con)/(1.0+con)),eccnth)))-phi;phi+=dphi;if(Math.abs(dphi)<=.0000000001)return phi;}
 alert("phi2z has NoConvergence");return(-9999);},qsfnz:function(eccent,sinphi){var con;if(eccent>1.0e-7){con=eccent*sinphi;return((1.0-eccent*eccent)*(sinphi/(1.0-con*con)-(.5/eccent)*Math.log((1.0-con)/(1.0+con))));}else{return(2.0*sinphi);}},asinz:function(x){if(Math.abs(x)>1.0){x=(x>1.0)?1.0:-1.0;}
 return Math.asin(x);},e0fn:function(x){return(1.0-0.25*x*(1.0+x/16.0*(3.0+1.25*x)));},e1fn:function(x){return(0.375*x*(1.0+0.25*x*(1.0+0.46875*x)));},e2fn:function(x){return(0.05859375*x*x*(1.0+0.75*x));},e3fn:function(x){return(x*x*x*(35.0/3072.0));},mlfn:function(e0,e1,e2,e3,phi){return(e0*phi-e1*Math.sin(2.0*phi)+e2*Math.sin(4.0*phi)-e3*Math.sin(6.0*phi));},srat:function(esinp,exp){return(Math.pow((1.0-esinp)/(1.0+esinp),exp));},sign:function(x){if(x<0.0)return(-1);else return(1);},adjust_lon:function(x){x=(Math.abs(x)<this.PI)?x:(x-(this.sign(x)*this.TWO_PI));return x;},adjust_lat:function(x){x=(Math.abs(x)<this.HALF_PI)?x:(x-(this.sign(x)*this.PI));return x;},latiso:function(eccent,phi,sinphi){if(Math.abs(phi)>this.HALF_PI)return+Number.NaN;if(phi==this.HALF_PI)return Number.POSITIVE_INFINITY;if(phi==-1.0*this.HALF_PI)return-1.0*Number.POSITIVE_INFINITY;var con=eccent*sinphi;return Math.log(Math.tan((this.HALF_PI+phi)/2.0))+eccent*Math.log((1.0-con)/(1.0+con))/2.0;},fL:
 function(x,L){return 2.0*Math.atan(x*Math.exp(L))-this.HALF_PI;},invlatiso:function(eccent,ts){var phi=this.fL(1.0,ts);var Iphi=0.0;var con=0.0;do{Iphi=phi;con=eccent*Math.sin(Iphi);phi=this.fL(Math.exp(eccent*Math.log((1.0+con)/(1.0-con))/2.0),ts)}while(Math.abs(phi-Iphi)>1.0e-12);return phi;},sinh:function(x)
 {var r=Math.exp(x);r=(r-1.0/r)/2.0;return r;},cosh:function(x)
Modified: trunk/widgets/Measure.js
--- trunk/widgets/Measure.js	2010-06-24 17:57:04 UTC (rev 2185)
+++ trunk/widgets/Measure.js	2010-06-24 18:01:01 UTC (rev 2186)
@@ -65,6 +65,9 @@
     /* Style for the polygon used for area draw */
     fillStyle: null,
+    /* set to false for local coordinate systems */
+    geodesic: true,
     /* Style for the polygon line used for area draw */
     areaStyle: null,
     segmentLabels: true,
@@ -318,7 +321,11 @@
             from = this.getMap().geoToPix(v[0].x,v[0].y);
             to = this.getMap().geoToPix(v[1].x,v[1].y);
             at = {x: (from.x + to.x) / 2, y: (from.y + to.y) / 2};
-            quantity = geom.getGeodesicLength(proj);
+            if (this.geodesic) {
+              quantity = geom.getGeodesicLength(proj);
+            } else {
+              quantity = geom.getLength();
             //calculate the length in pixels
             pixQuantity = Math.sqrt((to.x - from.x) * (to.x - from.x) + (to.y - from.y) * (to.y - from.y));
@@ -333,7 +340,11 @@
             var cg = geom.getCentroid();
             at = this.getMap().geoToPix(cg.x, cg.y);
-            quantity = geom.getGeodesicArea(proj);
+              quantity = geom.getGeodesicArea(proj);
+            } else {
+              quantity = geom.getArea();
             measureUnits = Fusion.METERS;
             if (measureUnits != this.units) {
More information about the fusion-commits mailing list
