[fusion-commits] r2123 - in sandbox/jxlib-3.0: . layers layers/Generic layers/MapGuide layers/MapGuide/php layers/MapServer lib text widgets widgets/BufferPanel widgets/Theme widgets/Theme/classes
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Mar 31 15:07:52 EDT 2010
Author: madair
Date: 2010-03-31 15:07:52 -0400 (Wed, 31 Mar 2010)
New Revision: 2123
   sandbox/jxlib-3.0/
   sandbox/jxlib-3.0/BUILDING.TXT
   sandbox/jxlib-3.0/COPYING.TXT
   sandbox/jxlib-3.0/build.xml
   sandbox/jxlib-3.0/layers/Generic/Generic.js
   sandbox/jxlib-3.0/layers/Layers.js
   sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js
   sandbox/jxlib-3.0/layers/MapGuide/php/GetSelectionProperties.php
   sandbox/jxlib-3.0/layers/MapGuide/php/SaveSelection.php
   sandbox/jxlib-3.0/layers/MapServer/MapServer.js
   sandbox/jxlib-3.0/lib/ApplicationDefinition.js
   sandbox/jxlib-3.0/lib/Map.js
   sandbox/jxlib-3.0/lib/fusion.js
   sandbox/jxlib-3.0/text/fr
   sandbox/jxlib-3.0/widgets/BufferPanel/BufferPanel.templ
   sandbox/jxlib-3.0/widgets/MapMenu.js
   sandbox/jxlib-3.0/widgets/Measure.js
   sandbox/jxlib-3.0/widgets/OverviewMap.js
   sandbox/jxlib-3.0/widgets/SelectAttribute.js
   sandbox/jxlib-3.0/widgets/TaskPane.js
   sandbox/jxlib-3.0/widgets/Theme/classes/theme.php
   sandbox/jxlib-3.0/widgets/Theme/thememain.php
merge of Fusion trunk rev 2053-2114; except for Legend.js which will need some work to resolve conflicts;  this allows the MapMenu widget to switch between maps in different projections
Property changes on: sandbox/jxlib-3.0
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk:1958-2051
   + /trunk:1958-2051,2053-2117
Modified: sandbox/jxlib-3.0/BUILDING.TXT
--- sandbox/jxlib-3.0/BUILDING.TXT	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/BUILDING.TXT	2010-03-31 19:07:52 UTC (rev 2123)
@@ -16,10 +16,8 @@
 For some tasks, external executable files are used and must be available for
 execution on the PATH environment variable.
-This script requires an HTDOCS environment variable be set to point to the
-document root directory of your web server.
+Targets available include:
-targets available include:
 prepare - creates a "build" subdirectory with all files required to be put on
           the web server
 deploy  - places a copy of the build directory in the web server HTDOCS directory
@@ -42,11 +40,14 @@
 Properties that can be set (and their defaults) include:
-<property name="sfName"  value="${build.home}/lib/fusionSF"/>
-<property name="cssOutput"  value="${sfName}"/>
-<property name="cssFiles"  value=""/>
-<property name="appDef"  value=""/>
+  <property name="YUIcompressor"  value="${basedir}/utils/yuicompressor-2.3.6.jar"/>
+  <property name="sfName"  value="fusionSF"/>
+  <property name="buildOutput"  value="${build.home}/lib/${sfName}"/>
+  <property name="cssOutput"  value="${build.home}/lib/${sfName}"/>
+  <property name="cssFiles"  value=""/>
+  <property name="PHP" value="/usr/local/php5cgi/bin/php"/>
 These properties can be assigned a value when ant is invoked by using the
 -D command line option, e.g.:
Modified: sandbox/jxlib-3.0/COPYING.TXT
--- sandbox/jxlib-3.0/COPYING.TXT	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/COPYING.TXT	2010-03-31 19:07:52 UTC (rev 2123)
@@ -1,14 +1,9 @@
 Fusion License
-Scriptaculous and prototype are third party libraries included in the jx
-directory and are distributed under their own licenses.  Please see
-MIT-LICENSE in the Scriptaculous directory for more information.
+Mootools is a third party library included in the jx distribution and is
+distributed under an MIT-style license.  Please see the jxlib.uncompressed.js
+file for more information.
-ExplorerCanvas is Copyright 2006 Google Inc. and is distributed under
-the Apache License Version 2.0, January 2004.
-JavaScript Scalebar for MapServer (widgets/scalebar/) is Copyright (c) 2005 Tim Schaub of CommEn Space (http://www.commenspace.org) and is distributed under the LGPL license.
 This license applies to all files obtained with the fusion source that are not
 explicitly covered by a separate license.
Modified: sandbox/jxlib-3.0/build.xml
--- sandbox/jxlib-3.0/build.xml	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/build.xml	2010-03-31 19:07:52 UTC (rev 2123)
@@ -74,7 +74,7 @@
   <property environment="env"/>
   <property name="app.name" value="fusion"/>
   <property name="app.path" value="/${app.name}"/>
-  <property name="app.version" value="1.1.x"/>
+  <property name="app.version" value="2.0.x"/>
   <property name="build.home" value="${basedir}/build"/>
   <property name="deploy.home" value="${basedir}/../${app.name}"/>
   <property name="dist.home" value="${basedir}/dist"/>
@@ -155,8 +155,7 @@
         <arg value="-i ./"/>
         <arg value="-o html ./docs"/>
         <arg value="-p ./docs/NaturalDocs"/>
-        <arg value="-xi ./scriptaculous"/>
-        <arg value="-xi ./lib"/>
+         <arg value="-xi ./lib"/>
         <arg value="-r"/>
         <arg line="/c perl C:\Progra~1\NaturalDocs\NaturalDocs -i ./lib -i ./widgets -o html ./docs/NaturalDocs -p ./docs/NaturalDocs -r"/>
@@ -213,6 +212,7 @@
         <filelist dir="${build.home}/lib"
                   files=" SingleFile.js
                           fusion.js
+                          proj4js-compressed.js
                           OpenLayers/OpenLayers.js
                           Error.js
Modified: sandbox/jxlib-3.0/layers/Generic/Generic.js
--- sandbox/jxlib-3.0/layers/Generic/Generic.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/layers/Generic/Generic.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -166,12 +166,22 @@
         if (!this.oLayerOL) {
-            if (!this.mapTag.layerOptions.maxExtent) {
-                this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892);
             if (typeof this.mapTag.layerOptions.sphericalMercator == 'undefined') {
                 this.mapTag.layerOptions.sphericalMercator = true;
+            if (this.mapTag.layerOptions.sphericalMercator) {
+              if (!this.mapTag.layerOptions.maxExtent) {
+                  this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892);
+              this.mapTag.layerOptions.units = "m";
+              this.mapTag.layerOptions.projection = "EPSG:3785";
+            } else {
+                  this.mapTag.layerOptions.maxExtent = new OpenLayers.Bounds(-180,-90,180,90);
+              this.mapTag.layerOptions.units = "dd";
+              this.mapTag.layerOptions.projection = "EPSG:4326";
             if (typeof this.mapTag.layerOptions.numZoomLevels == 'undefined') {
                 this.mapTag.layerOptions.numZoomLevels = 20;
@@ -180,6 +190,7 @@
             this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
         this.oLayerOL.events.register("loadstart", this, this.loadStart);
         this.oLayerOL.events.register("loadend", this, this.loadEnd);
         this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
Modified: sandbox/jxlib-3.0/layers/Layers.js
--- sandbox/jxlib-3.0/layers/Layers.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/layers/Layers.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -76,17 +76,6 @@
         this.sMapResourceId = mapTag.resourceId ? mapTag.resourceId : '';
         this.mapInfo = mapTag.mapInfo;
         this.layerType = mapTag.type;
-        //projection info from the extension
-        if (mapTag.extension.ProjectionCode) {
-          this.projCode = mapTag.extension.ProjectionCode[0];
-        if (mapTag.extension.ProjectionDef) {
-          var projDef = mapTag.extension.ProjectionDef[0];
-          this.projCode = "APP-DEF-PROJ";
-          Proj4js.defs[this.projCode] = projDef;
@@ -111,7 +100,7 @@
     getMetadata: function(key) {
-        if (typeof this.metadata[key] != 'undefined') {
+        if (this.metadata && typeof this.metadata[key] != 'undefined') {
             return this.metadata[key];
         } else {
             return '';
Modified: sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js
--- sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/layers/MapGuide/MapGuide.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -85,7 +85,7 @@
             this.nTolerance = 2; //pixels, default pixel tolernace for a point click; TBD make this configurable
         rootOpts = {
           displayInLegend: this.bDisplayInLegend,
           expandInLegend: this.bExpandInLegend,
@@ -300,12 +300,12 @@
             //set projection units and code if supplied
+            if (o.epsg != 0) {
+              this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
             //TODO: consider passing the metersPerUnit value into the framework
             //to allow for scaling that doesn't match any of the pre-canned units
-            this.units = Fusion.getClosestUnits(o.metersPerUnit);
-            if (this.projCode) {
-              this.mapWidget.setProjection(this.projCode);
+            this.mapTag.layerOptions.units = Fusion.getClosestUnits(o.metersPerUnit);
             //add in scales array if supplied
             if (o.FiniteDisplayScales && o.FiniteDisplayScales.length>0) {
@@ -568,14 +568,13 @@
       var layerOptions = {
-        units: this.units,
         maxResolution: 'auto',
         useOverlay: this.selectionAsOverlay,
         useAsyncOverlay: this.useAsyncOverlay,
         ratio: this.ratio
       if ((behavior & 1) == 0 && !/WebKit/.test(navigator.userAgent)) {
-        //layerOptions.transitionEffect = 'resize';
+        layerOptions.transitionEffect = 'resize';
Modified: sandbox/jxlib-3.0/layers/MapGuide/php/GetSelectionProperties.php
--- sandbox/jxlib-3.0/layers/MapGuide/php/GetSelectionProperties.php	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/layers/MapGuide/php/GetSelectionProperties.php	2010-03-31 19:07:52 UTC (rev 2123)
@@ -179,7 +179,7 @@
     } catch(MgException $e) {
-        echo "/* SetSelection Exception: " . $e->GetDetails()."*/";
+        echo "ERROR: " . $e->GetDetails() . "\n";
 function GetParameters($params)
Modified: sandbox/jxlib-3.0/layers/MapGuide/php/SaveSelection.php
--- sandbox/jxlib-3.0/layers/MapGuide/php/SaveSelection.php	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/layers/MapGuide/php/SaveSelection.php	2010-03-31 19:07:52 UTC (rev 2123)
@@ -93,7 +93,7 @@
Modified: sandbox/jxlib-3.0/layers/MapServer/MapServer.js
--- sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/layers/MapServer/MapServer.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -254,16 +254,12 @@
             if (o.projString.length > 0) {
               var epsg = o.projString.indexOf("init=");
               if (epsg >= 0) {
-                this.projCode = o.projString.substring(epsg+5).toUpperCase();
+                this.mapTag.layerOptions.projection = o.projString.substring(epsg+5).toUpperCase();
               } else {
-                this.projCode = o.mapName.toUpperCase();
-                Proj4js.defs[this.projCode] = o.projString;
+                this.mapTag.layerOptions.projection = o.mapName.toUpperCase();
+                Proj4js.defs[this.mapTag.layerOptions.projection] = o.projString;
-            this.mapWidget.setMetersPerUnit(o.metersPerUnit);
             this.mapTag.layerOptions.maxExtent = OpenLayers.Bounds.fromArray(o.extent);
@@ -293,12 +289,11 @@
       				singleTile: true,
       				ratio: this.ratio,
       				minScale: maxScale,	//OL interpretation of min/max scale is reversed from Fusion
       				maxScale: minScale
@@ -330,7 +325,6 @@
             if (this.bIsMapWidgetLayer) {
               this.mapWidget.addMap(this);
-              this.mapWidget.oMapOL.units = this.oLayerOL.units;
             this.bMapLoaded = true;
@@ -842,6 +836,14 @@
         Fusion.ajaxRequest(s, params);
+    getMetadata: function(key) {
+            return this.metadata[key];
+        } else {
+            return '';
     getGroupInfoUrl: function(groupName) {
       return null;
Modified: sandbox/jxlib-3.0/lib/ApplicationDefinition.js
--- sandbox/jxlib-3.0/lib/ApplicationDefinition.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/lib/ApplicationDefinition.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -486,6 +486,7 @@
     type: null,
     singleTile: false,
     extension: null,
     initialize: function(jsonNode) {
         /* TODO: type can be any supported OpenLayers type */
         this.type = jsonNode.Type[0];
@@ -522,6 +523,22 @@
             this.layerParams[key] = tagParams[0][key][0];
+        //projection info from the extension
+        //this.layerOptions.projection = "EPSG:4326";  //default to WGS84 lat long
+        if (this.extension.ProjectionCode) {
+          this.layerOptions.projection = this.extension.ProjectionCode[0];
+        if (this.extension.ProjectionDef) {
+          var projDef = this.extension.ProjectionDef[0];
+          if (!this.layerOptions.projection) {
+            this.layerOptions.projection = "APP-DEF-PROJ";
+          Proj4js.defs[this.layerOptions.projection] = projDef;
+          this.layerOptions.projection = "EPSG:4326";
         switch (this.type) {
           case 'MapGuide':
@@ -530,7 +547,19 @@
                   Fusion.require('layers/' + this.type + '/' + this.type + '.js');
             break;
+          case "Google":
+          case "Yahoo":
+          case "VirtualEarth":
+              this.layerOptions.isBaseLayer = true;
+              this.layerOptions.sphericalMercator = true;
+              this.layerOptions.displayProjection = "EPSG:4326";
+              //no break here continue below to set EPSG:3785 as projCode
           default:
+            if (this.layerOptions.sphericalMercator) {
+              this.layerOptions.projection = "EPSG:3785";  //commercial map layer projection spherical mercator
+            } else {
+              this.layerOptions.projection = "EPSG:4326";  //WGS84 lat long
             if ( !Fusion.Layers.Generic ) {
               Fusion.require('layers/Generic/Generic.js');
Modified: sandbox/jxlib-3.0/lib/Map.js
--- sandbox/jxlib-3.0/lib/Map.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/lib/Map.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -27,6 +27,7 @@
  * Class: Fusion.Widget.Map
  * generic class for map widgets. Provides common utility classes.
+ * This class provides a wrapper around the OpenLayers Map object.
 Fusion.Event.MAP_EXTENTS_CHANGED = Fusion.Event.lastEventId++;
@@ -45,6 +46,7 @@
 Fusion.Event.MAP_SCALE_RANGE_LOADED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_MAP_GROUP_LOADED = Fusion.Event.lastEventId++;
 Fusion.Constant.LAYER_POINT_TYPE = 0;
 Fusion.Constant.LAYER_LINE_TYPE = 1;
 Fusion.Constant.LAYER_POLYGON_TYPE = 2;
@@ -53,37 +55,69 @@
 Fusion.Constant.LAYER_DWF_TYPE = 5;
 Fusion.Widget.Map = OpenLayers.Class(Fusion.Lib.EventMgr, {
+    /** The DOM object that holds the map */
     _oDomObj: null,
+    /** The id of DOM object */
     _sDomObj: '',
+    /** The internal name used for the map, usually assigned by the server */
     _sMapname: '',
-    _nWidth: -1,
-    _nHeight: -1,
+    /** conversion factor to convert from map units to meters */
     _fMetersperunit: -1,
+    /** scale denominator value */
     _fScale: -1,
+    /** Dots per inch setting for the server */
     _nDpi: 96,
+    /** The current bounds of the map, this is updated on every map draw */
     _oCurrentExtents: null,
+    /** The maximum extent of the map */
     maxExtent: new OpenLayers.Bounds(),
+    /** counter of worker threads for the ActivityIndicator widget  */
     _nWorkers: 0,
+    /** The context menu object for right click */
     oContextMenu: null,
+    /** flag to disable the map context menu, set this in the Map extension  */
     bSupressContextMenu: false,
+    /** an array to hold all the individual map layer objects */
     aMaps: null,
+    /** flag to indicate if all the map layers are loaded */
     mapsLoaded: false,
+    /** the root of the layer structure for the Legend */
     layerRoot: null,
+    /** flag to indicate if the map is tiled or not, set in the Map extension */
     singleTile: true,
+    /** flag to indicate if fractional zoom is supported, ie. allow any scale
+    *   value rather than a fixed set of scales
     fractionalZoom: true,
     maxScale: null, //set this to a large number in AppDef to zoom out beyond maxExtent, e.g. 1 billion
      * construct a new view Fusion.Widget.Map class.
-    initialize : function(widgetTag, mapGroup, widgetSet) {
+    initialize: function(widgetTag, mapGroup, widgetSet) {
         this.widgetTag = widgetTag;
         var name = widgetTag.name;
         this.aMaps = [];
         this.buttonSet = new Jx.ButtonSet();
         this.widgetSet = widgetSet;
-        this._nCellSize = -1;
         this._sDomObj = name;
         this._oDomObj = $(this._sDomObj);
         this.layerRoot = new Fusion.Layers.Group({
@@ -102,6 +136,7 @@
           this.fractionalZoom = widgetTag.extension.FractionalZoom[0]=='false'?false:true;
+        //if there is a scales array specified, use that set and turn off fraczoom
         var scalesArray = null;
         if (widgetTag.extension.Scales) {
           scalesArray = widgetTag.extension.Scales[0].split(',');
@@ -114,11 +149,13 @@
           this.maxScale = parseInt(widgetTag.extension.MaxExtent[0]);
+        //set the maxExtent
         var maxExtent = null;
         if (widgetTag.extension.MaxExtent) {
           maxExtent = OpenLayers.Bounds.fromString(widgetTag.extension.MaxExtent[0]);
+        //create the OpenLayers Map object
         OpenLayers.DOTS_PER_INCH = this._nDpi;
         if (!this.oMapOL) {
             var options = {
@@ -137,6 +174,7 @@
             this.oMapOL = new OpenLayers.Map(this._sDomObj, options );
+        //Fusion specific modifications to the OL map window style
         this.oMapOL.viewPortDiv.style.position = 'absolute';  //not the top level container so set it to absolute
         this.oMapOL.viewPortDiv.style.zIndex = 0;   //must explicitly set the z-index for FF3
@@ -192,11 +230,29 @@
         this.loadMapGroup(mapGroup);
+     * Function: mapLoaded
+     * Callback for when all maps have been loaded
+     * Parameter: none.
+     * Return: none
     mapLoaded: function() {
       this.setViewOptions(this.getUnits());
       this.loadScaleRanges(OpenLayers.Function.bind(this.scaleRangesLoaded, this));
+     * Function: setMenu
+     * Attaches a context menu as defined in the AppDef to the map
+     * Return: none
     setMenu: function() {
         if (this.widgetTag.extension.MenuContainer) {
             var contextMenu = new Jx.Menu.Context();
@@ -208,6 +264,15 @@
+     * Function: loadMapGroup
+     * Controls the creation of Layers based on the MapGroup object passed in
+     * Parameter: {Object} mapGroup - a representation of the MapGroup object
+     * Return: none
     loadMapGroup: function(mapGroup) {
         //clear any existing selection
         this.mapsLoaded = false;
@@ -220,7 +285,10 @@
             this.aMaps[i].oLayerOL.destroy();
+        this._fMetersperunit = -1;
+        this.oMapOL.center = null;
+        this.maxExtent = new OpenLayers.Bounds();
         this.aMaps = [];
         this.layerRoot.clear();
@@ -237,9 +305,20 @@
           this.aMaps[i].registerForEvent(Fusion.Event.LAYER_LOADED, OpenLayers.Function.bind(this.layerLoaded,this));
-		this.triggerEvent(Fusion.Event.MAP_MAP_GROUP_LOADED);
+        this.triggerEvent(Fusion.Event.MAP_MAP_GROUP_LOADED);
+     * Function: layerLoaded
+     * Called after each layer is loaded in the OL viewport.  Nothing happens
+     * here until the last layer is laoded, then it sets the OL baselayer and
+     * zooms to the initial extent.
+     * Parameter: none
+     * Return: none
     layerLoaded: function() {
       for (var i=0; i<this.aMaps.length; ++i) {
         if (!this.aMaps[i].isMapLoaded()) {
@@ -271,10 +350,14 @@
-     * Method: wheelChange
+     * Function: wheelChange
+     * handles mouse wheel events by accummulating the events and setting a timer
+     * to do the actual zoom in/out
      * Parameters:
-     * evt - {Event}
+     * evt - {Event} the mouse wheel event object
+     * deltaZ - {Integer} the number of ticks wheeled
     wheelChange: function(evt, deltaZ) {
         if (this.wheelTimer) {
@@ -287,6 +370,17 @@
         this.wheelTimer = setTimeout(OpenLayers.Function.bind(function(){this.doWheelChange(evt, deltaZ);}, this), 200);
+     * Function: doWheelChange
+     * Carries out the actual map zoom based on the wheel movement
+     * Parameters:
+     * Return: none
     doWheelChange: function(evt, deltaZ) {
         this.wheelTimer = null;
         if (this.cumulativeDelta == 0) {
@@ -333,19 +427,43 @@
-     * returns the dom element
+     * Function: getDomObj
+     * returns the dom element for this widget
+     * Parameters: none
+     * Return: none
     getDomObj: function() {
         return this._oDomObj;
+     * Function: getMapName
+     * returns the name of the baselayer map
+     * Return: {String} the name of the baselayer map
     getMapName: function() {
         //TODO: what is the mapname in the case of multiple map layer objects?
         //just return baselayer mapname for now
         return this.aMaps[0].getMapName();
+     * Function: getMapTitle
+     * returns the Title of the baselayer map.  This is a human-readable title
+     * Return: {String} the Title of the baselayer map
     getMapTitle: function() {
         //TODO: what is the map title in the case of multiple map layer objects?
         //just return baselayer mapTitle for now
@@ -358,31 +476,61 @@
         return this.aMaps[0].getMetadata(key);
+     * Function: getSessionID
+     * returns the server session ID
+     * Return: {String} the session ID
     getSessionID: function() {
         //just return baselayer session ID for now
         return this.aMaps[0].getSessionID();
+     * Function: getDomId
+     * returns the ID of dom element for this widget
+     * Return: {String} the id of the DOM element
     getDomId: function() {
         return this._sDomObj;
+     * Function: setMapOptions
+     * sets options on the OpenLayers map object, a wrapper for the OL function
+     * Parameters: {Object} options - has of option key/value pairs
+     * Return: none
     setMapOptions: function(options) {
         this.oMapOL.setOptions(options);
+     * Function: addMap
+     * adds a map/Layer to the map and registers some event handlers on the map
+     * Parameters: {Object} map - the map object to tbe added (really a layer object)
+     * Return: none
     addMap: function(map) {
         if (map.mapTag.layerOptions.maxExtent) {
-          this.projection = map.projection;
-          this.units = map.units;
           this.maxExtent.extend(map.mapTag.layerOptions.maxExtent);
-          this.oMapOL.setOptions({
-                  maxExtent: this.maxExtent,
-                  units: map.units,
-                  projection: this.projection
+          this.oMapOL.setOptions({maxExtent: this.maxExtent});
         //if bRestrictExtent is null, use the default OL behaviour with somewhat restricted map navigation
@@ -396,19 +544,44 @@
         this.oMapOL.addLayer(map.oLayerOL);
-        map.registerForEvent(Fusion.Event.MAP_LOADED,
-                OpenLayers.Function.bind(this.mapLoadHandler, this));
+        if (map.oLayerOL.isBaseLayer) {
+          this.projection = map.projection;
+          this.units = map.units;
+                  units: map.units,
+                  projection: this.projection
         map.registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
                 OpenLayers.Function.bind(this.selectionHandler, this));
         map.registerForEvent(Fusion.Event.MAP_SELECTION_ON,
+     * Function: getAllMaps
+     * returns the array of map objects
+     * Return: {Array} the array of map Objects
     getAllMaps: function() {
         return this.aMaps;
-    //this uses setTimeout so this method can be called from an IFRAME
+     * Function: reloadMap
+     * Called to reload all the map objects.
+     * this uses setTimeout so this method can be called from an IFRAME
+     * Return: none
     reloadMap: function() {
         var map = this.aMaps[i];
@@ -416,6 +589,17 @@
+     * Function: loadScaleRanges
+     * Loads the ScaleRange objects separate from the LoadMap sequence since
+     * this also generates sprites and is a relatively expensive operation.
+     * Parameters: {Function} userFunc - a user defined function to be called as a
+     *                                  callback
+     * Return: none
     loadScaleRanges: function() {
@@ -426,7 +610,9 @@
      * Function: query
-     * dispatch query requests to maps
+     * dispatch query requests to the maps
+     * Parameters: {object} options - query options to be passed to each map
     query: function(options) {
         this.lastQueryOptions = options;
@@ -437,25 +623,14 @@
-     * Function: mapLoadHandler
+     * Function: selectionHandler
      * handle selection events from maps and republish for
      * widgets as appropriate
-    mapLoadHandler: function() {
-        ++this.mapLoadCounter;
-        if (this.mapLoadCounter == this.aMaps.length) {
-            this._oInitialExtents = null;
-            this.fullExtents();
-            this.triggerEvent(Fusion.Event.MAP_LOADED);
-     * Function: selectionHandler
-     * handle selection events from maps and republish for
-     * widgets as appropriate
+     * Return: none
     selectionHandler: function() {
         if (this.hasSelection()) {
@@ -468,7 +643,9 @@
      * Function: hasSelection
-     * returns true if any map has a selection
+     * cehck to see if any of the maps have an active selection
+     * Returns: {Boolean} - true if any map has a selection
      hasSelection: function() {
          for (var i=0; i<this.aMaps.length; i++ ) {
@@ -495,7 +672,7 @@
       * Function: getSelection
-      * returns the current selection asynchronously in case we
+      * initiates a call to get the current selection asynchronously in case we
       * need to retrieve the details from the server
      getSelection: function(callback, layers, startcount) {
@@ -523,7 +700,11 @@
       * Function: setSelection
-      * sets a Selection XML back to the server
+      * sets a Selection XML back to the server for each of the maps
+      * Parameters:
+      * {String} selText - the selection string
+      * {Boolean} zoomTo - if set, will zoom to the selection on completion
       setSelection: function(selText, zoomTo) {
@@ -536,6 +717,10 @@
       * accumulate the selection results from each map and when all have
       * reported in, pass the results to the callback function
+      * Parameters:
+      * {Object} map - the map object that has the selection
+      * {Object} oSelection - the Fusion selection object
      accumulateSelection: function(map, oSelection) {
          this.oSelection[map._sMapname] = oSelection;
@@ -553,25 +738,33 @@
       * Function: setActiveLayer
       * sets the active layer for selection/manipulation
+      * Parameters:
+      * {Object} oLayer - the layer to be set as active
-    setActiveLayer: function( oLayer ) {
-        this.oActiveLayer = oLayer;
-        if (oLayer) {
-            this.oActiveMap = oLayer.map;
-        this.triggerEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, oLayer);
+      setActiveLayer: function( oLayer ) {
+          this.oActiveLayer = oLayer;
+          if (oLayer) {
+              this.oActiveMap = oLayer.map;
+          this.triggerEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, oLayer);
       * Function: getActiveLayer
       * returns the active layer for selection/manipulation
+      * Returns:
+      * {Object} the active layer
     getActiveLayer: function() {
         return this.oActiveLayer;
+     * Function: _addWorker
      * indicate that a new asynchronous process has started and make sure the
      * visual indicator is visible for the user.  This is intended to be used
      * internally by gMap but could be used by external tools if appropriate.
@@ -583,6 +776,8 @@
+     * Function: _removeWorker
      * indicate that an asynchronous process has completed and hide the
      * visual indicator if no remaining processes are active.  This is
      * intended to be used internally by gMap but could be used by
@@ -597,19 +792,57 @@
         this.triggerEvent(Fusion.Event.MAP_BUSY_CHANGED, this);
+     * Function: mapExtentsChanged
+     * OpenLayers event handler for whenever the map changes either zoom level
+     * of the center has changed.  This in turn triggers the Fusion event.
+     * Return: none
     mapExtentsChanged: function() {
         this._oCurrentExtents = this.oMapOL.getExtent();
         this.triggerEvent(Fusion.Event.MAP_EXTENTS_CHANGED);
+     * Function: isBusy
+     * check to see if there are any outstanding requests to the server
+     * Return: {Boolean} true if there are active requests
     isBusy: function() {
         return this._nWorkers > 0;
+     * Function: sizeChanged
+     * callback for when the browser window size changes, simply calls resize
+     * on the map viewport layout object
+     * Return: none
     sizeChanged: function() {
         this.resize();
+     * Function: resize
+     * handles the resizing of the maps and triggers a Fusion event
+     * Return: none
     resize: function() {
       if (!this.mapsLoaded) {
         return;
@@ -617,29 +850,57 @@
       //console.log('Fusion.Widget.Map.resize');
         this.oMapOL.updateSize();
         var d = $(this.getDomObj()).getContentBoxSize();
-        this._nWidth = d.width;
-        this._nHeight = d.height;
         if (this._oCurrentExtents) {
           this.setExtents(this._oCurrentExtents);
         this.triggerEvent(Fusion.Event.MAP_RESIZED, this);
+     * Function: redraw
+     * redraws the map using current extents and zoom level.  A dummy parameter
+     * is added to the map request to ensure the map request is not cached.
+     * Return: none
     redraw: function() {
-	    if(this.aMaps[i].oLayerOL.params){
+        if(this.aMaps[i].oLayerOL.params){
             this.aMaps[i].oLayerOL.params.ts = (new Date()).getTime();
             //mergeNewParams calls redraw on the layer, which will get called below anyway
             //this.aMaps[i].oLayerOL.mergeNewParams({ts : (new Date()).getTime()});
       this.oMapOL.setCenter(this.oMapOL.getCenter(), this.oMapOL.getZoom(), false, true);
+     * Function: setBackgroundColor
+     * sets the background color for the map
+     * Parameters: {String} color - the CSS color value to set as background
+     * Return: none
     setBackgroundColor: function(color) {
         this._oDomObj.style.backgroundColor = color;
+     * Function: setExtents
+     * handle selection events from maps and republish for
+     * widgets as appropriate
+     * Parameters: {Object} oExtents - an OpenLayers.Bounds object or an array
+     *                            of 4 values that will be converted to Bounds
+     * Return: none
     setExtents: function(oExtents) {
         if (!oExtents) {
             Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
@@ -660,10 +921,14 @@
+     * Function: setInitialExtents
      * determine the initialExtents of the map from (in order of precedence):
      * 1. a URL query parameter called 'extent'
      * 2. an <InitialView> specified in the MapGroup in AppDef
      * 3. the maxExtent as specified by the LoadMap call (default)
+     * Returns: {Object} an OpenLayers.Bounds object which is the initial extent
     setInitialExtents: function() {
       var initialExtents;
@@ -692,7 +957,12 @@
-     * sets the extent by examining all mapgroup map extents
+     * Function: getMapGroupExtent
+     * gets the intitial extents from all maps with or without including the
+     * extent of any Generic/commercial layers
+     * Return: {Object} an OpenLayers.Bounds object which is the initial extent
     getMapGroupExtent: function(includeGenericLayers) {
       var initialExtent;
@@ -706,6 +976,8 @@
+     * Function: fullExtents
      * sets the extent of the map to the max as returned by loadMap
     fullExtents: function() {
@@ -713,10 +985,34 @@
       this.setExtents(extents);
+     * Function: isMapLoaded
+     * returns if the map has finished loading (based on setting the
+     * _oCurrentExtent value)
+     * Returns {Boolean} true if the map is loaded and extent has been set
     isMapLoaded: function() {
         return (this._oCurrentExtents) ? true : false;
+     * Function: zoom
+     * sets the map zoom and extent.
+     * Parameters:
+     *   fX {Float} - new x coordinate value in map units
+     *   fY {Float} - new y coordinate value in map units
+     *   nFactor {Float} - zoom factor; positive values zoom in, negative out
+     *                  - if set to 0 or 1, the map is just recentered
+     *                  - if the map has fractional zoom enabled, the map resolution
+     *                  will be modified by this factor
+     *                  - with fixed scales, zoom up or down one level, depending on the sign
+     * Returns: none
     zoom: function(fX, fY, nFactor) {
         //do this differntly with OL code??
         if (nFactor == 1 || nFactor == 0) {
@@ -753,15 +1049,63 @@
+     * Function: zoom
+     * Parameters:
+     * Returns: none
     zoomToScale: function(fScale) {
         var center = this.getCurrentCenter();
         var extent = this.getExtentFromPoint(center.x, center.y, fScale);
         this.setExtents(extent);
-    queryRect : function(fMinX, fMinY, fMaxX, fMaxY) { },
+     * Function: zoom
+     * Parameters:
+     * Returns: none
+    queryRect: function(fMinX, fMinY, fMaxX, fMaxY) { },
-    queryPoint : function(fX, fY) { },
+     * Function: zoom
+     * Parameters:
+     * Returns: none
+    queryPoint: function(fX, fY) { },
@@ -773,7 +1117,7 @@
      * @return an object with geographic coordinates in x and y properties of the
      *         object.
-    pixToGeo : function( pX, pY ) {
+    pixToGeo: function( pX, pY ) {
         var lonLat = this.oMapOL.getLonLatFromPixel( new OpenLayers.Pixel(pX,pY) );
         if (lonLat != null) {
           return {x:lonLat.lon, y:lonLat.lat};
@@ -791,7 +1135,7 @@
      * @return an object with pixel coordinates in x and y properties of the
      *         object.
-    geoToPix : function( gX, gY ) {
+    geoToPix: function( gX, gY ) {
         if (!(this._oCurrentExtents)) {
             return null;
@@ -807,7 +1151,7 @@
      * @return geographic measure
-    pixToGeoMeasure : function(nPixels) {
+    pixToGeoMeasure: function(nPixels) {
         var resolution = this.oMapOL.getResolution();
         return (nPixels*resolution);
@@ -818,12 +1162,10 @@
      * @param projCode projection code
-    setProjection: function(projCode) {
-        if (!Proj4js.defs[projCode]) {
-          Fusion.reportError( new Fusion.Error(Fusion.Error.WARNING,
-            'Projection definition not found for:'+projCode));
+    setProjection: function(projCode, units) {
+        this.projection = projCode;
         this.oMapOL.projection = projCode;
+        this.oMapOL.units = units;
Modified: sandbox/jxlib-3.0/lib/fusion.js
--- sandbox/jxlib-3.0/lib/fusion.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/lib/fusion.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -98,7 +98,7 @@
         Lib: {},
-         * Class: Fusion.Maps
+         * Class: Fusion.Layers
          * A set of classes that implement layer functionality for various server
          * technologies.
@@ -112,21 +112,40 @@
         Constant: {},
+         * Pointer to the Application Definition, parsed into all the Fusion
+         * objects: MapGroups, WidgetSets
         applicationDefinition: null,
-         * URL to the configuration file to use for this application.  The
-         * configuration file must be located on the same domain as the
-         * application template.
+         * URL of a proxy script if the map server is on a different domain/port
+         * that the application template to get around the same-origin policy
-        sConfigFileURL : "",
-        sWebAgentURL : "",
-        sWebTierURL : "",
-        sRedirectScript : "",
-        bForceRedirect : false,
-        sScriptLang : "",
-        locale : 'en',
+        sRedirectScript: "",
+         * A flag to force XHR calls through the proxy, defaults to false
+        bForceRedirect: false,
+         * the script programming language for server-side programming.
+         * Typically set to 'php' but other server languages may be used.
+        sScriptLang: "php",
+         * the locale setting for the browser and for localization of Fusion.
+         * This is the same as the locale setting in OpenLayers and is used as
+         * the file name for localization files in the /text subdirectory
+        locale: 'en',
+         * the hash of strings used for localization of Fusion.  Strings are
+         * indexed by a key which is used in calls to OpenLayers.i18n()
         Strings: {},    //locale specific strings
         /** URL to the directory from which fusion.js was loaded */
@@ -134,18 +153,25 @@
          * configuration object that holds the server configuration as
-         * loaded from fusion/config.xml
+         * loaded from fusion/config.json
         configuration: null,
-        /* broker instance for communicating with the mapagent */
+        * broker instance for communicating with the mapagent, typically only
+        * used with MapGuide
         oBroker: null,
         /** An array of scripts that are queued to be loaded */
-        aScripts : [],
+        aScripts: [],
         /** An array of scripts that are currently being loaded */
         aLoadingScripts: [],
-        /** The current state during initialization of the application */
+        * The current state during initialization of the application.  Valid
+        * states are enumerated below
         loadState: null,
         /** API loading has not begun */
@@ -157,7 +183,11 @@
         /** Loading is complete */
         LOAD_COMPLETE: 3,
-        /** unit related stuff */
+        * unit related stuff - the following values are the keys into the
+        * unit related arrays below: aUnitPerMeter, aMeterPerUnit, aUnitNames
+        * and aUnitAbbr
         UNKNOWN: 0,
         INCHES: 1,
         FEET: 2,
@@ -172,6 +202,9 @@
         DECIMALDEGREES: 11,
         DMS: 12,
         PIXELS: 13,
+        * conversion factors to go from the specified units to meters
         aUnitPerMeter: [1.0, /* 0 - UNKNOWN */
                         39.37, /* 1 - INCHES */
                         3.2808, /* 2 - FEET */
@@ -187,6 +220,9 @@
                         0.000009044, /* 12 - DMS */
                         1.0 /* 13 - PIXELS */
+        * conversion factors to go from meters to the specified units
         aMeterPerUnit: [1.0, /* 0 - UNKNOWN */
                         0.0254, /* 1 - INCHES */
                         0.3048, /* 2 - FEET */
@@ -201,9 +237,17 @@
                         111061.75033, /* 11 - DECIMALDEGREES */
                         111061.75033, /* 12 - DMS */
                         1.0 /* 13 - PIXELS */],
+        * the units names spelled out fully
         aUnitNames: ['Unknown','Inches', 'Feet', 'Yards', 'Miles', 'Nautical Miles',
                      'Millimeters', 'Centimeters', 'Meters', 'Kilometers',
                      'Degrees', 'Decimal Degrees', 'Degrees Minutes Seconds', 'Pixels'],
+        * unit names abbreviations
         aUnitAbbr: ['unk', 'in', 'ft', 'yd', 'mi', 'nm',
                     'mm', 'cm', 'm', 'km',
                     '&deg;', '&deg;', '&deg;', 'px'],
@@ -211,24 +255,28 @@
          * Function: initialize
-         * Initialize the Fusion application.
+         * Initialize the Fusion application.  This method must be called from
+         * the template's onload method once all script files have been loaded.
+         * Applications can register for the event Fusion.Event.FUSION_INITIALIZED
+         * to carry out further application initialization when all the Fusion
+         * objects have been created and are available.
          * @param {Object} options
          * Optional paramters that can be passed to initialize are:
-         * {String} applicationDefinition - a URL or resource ID
+         * {String} applicationDefinitionURL - a URL or resource ID
          *          for an ApplicationDefinition file
          * {String} sessionId - a session id to start the application
          *          with.  Normally, applications are started without
          *          a session id and create one.  However, sometimes
          *          it is desirable to use an existing session.
-        initialize : function(options) {
+        initialize: function(options) {
             options = options || {};
             var sessionIdParam = this.getQueryParam('Session');
-			// Override the pre-created sessionId by user specified sessionId(if exist)
-			this.sessionId = sessionIdParam || options.sessionId || this.sessionId;
+            // Override the pre-created sessionId by user specified sessionId(if exist)
+            this.sessionId = sessionIdParam || options.sessionId || this.sessionId;
             if (options.applicationDefinitionURL) {
                 this.applicationDefinitionURL = options.applicationDefinitionURL;
@@ -249,15 +297,12 @@
             this.initializeLocale();
-            this.sWebagentURL = "";
-            this.sScriptLang = "";
-			 * if the application has been loaded from the same host as
-			 * fusion is installed in, then technically we don't need to
-			 * use the redirect script because we conform to the
-			 * Same Origin Policy for XmlHttpRequest to work.
+             * if the application has been loaded from the same host as
+             * fusion is installed in, then technically we don't need to
+             * use the redirect script because we conform to the
+             * Same Origin Policy for XmlHttpRequest to work.
             var test = window.location.protocol+'//'+window.location.host;
             var configUrl = 'config.json';
             //if (this.fusionURL.indexOf(test,0) == 0) {
@@ -268,9 +313,6 @@
                 configUrl += '&method=get';
-            /*script language*/
-            this.sScriptLang = 'php';
             if (Fusion.configuration) {
                 //config.json loaded via single file build
                 this.serverSet();
@@ -284,6 +326,19 @@
+         * Function: initializeLocale
+         * Initialize the Strings hash with the requested locale.  This method
+         * simply extends the OpenLayers strings hash with strings specific
+         * to Fusion.  Add strings to the files in fusion/text/[locale].json.
+         * This method can be called before Fusion.initialize() if localized
+         * strings are required in the template initialization.
+         * @param {String} locale - the locale value e.g. 'en-CA' or simply 'en'
+         *                        for English
         initializeLocale: function(locale) {
           OpenLayers.Lang.setCode(locale ? locale : window._FusionLocale);
           this.locale = OpenLayers.Lang.code;
@@ -333,6 +388,7 @@
                     break;
          * Function: loadQueuedScripts
@@ -379,7 +435,7 @@
          * The url of the script.
-        queueScript : function(url) {
+        queueScript: function(url) {
             if(!document.getElementById(url) && !this.aScripts[url]) {
                 var script = document.createElement('script');
                 script.defer = false;
@@ -393,6 +449,7 @@
                 this.aScripts.push(script);
          * Function: scriptFailed
@@ -438,11 +495,12 @@
          * Function: checkLoadingScripts
-         * check if scripts have loaded.  In IE, scripts don't seem to fire the onload
-         * event.  Safari also seems to have some problems.
+         * check if scripts have loaded.  In IE, scripts don't seem to fire the
+         * onload event.  Safari also seems to have some problems.
         checkLoadingScripts: function() {
             var agt=navigator.userAgent.toLowerCase();
@@ -461,13 +519,15 @@
          * Function: loadConfig
-         * asynchronously load the application definition through the broker and config
-         * manager.
+         * asynchronously load the application definition.  For MapGuide, also
+         * set up the broker object.  Once the AppDef is loaded/created advance
+         * the laod state.
-        loadConfig : function() {
+        loadConfig: function() {
             var mapAgentUrl = this.getConfigurationItem('mapguide', 'mapAgentUrl');
             if (mapAgentUrl) {
                 this.oBroker = new Fusion.Lib.MGBroker();
@@ -495,7 +555,7 @@
          * Parameter {Object} r
          * an XMLHttpRequest object
-        getConfigCB : function(r) {
+        getConfigCB: function(r) {
             if (r.responseText) {
                 eval("this.configuration="+r.responseText);
                 this.serverSet();
@@ -514,11 +574,11 @@
-        serverSet : function() {
+        serverSet: function() {
             var s = this.configuration.mapguide.webTierUrl;
             /* if it is set, use it ... otherwise assume fusion is installed in
-                      * the default location and compute the web tier url from that
+             * the default location and compute the web tier url from that
             if (s) {
                 var nLength = s.length;
                 var slastChar =  s.charAt((nLength-1));
@@ -570,8 +630,8 @@
          * Parameter: {Object} options
-         * optional parameters to send with the request, passed directly to
-         * Prototype's Ajax.Request function
+         * optional parameters to send with the request, passed directly to the
+         * OpenLayers Ajax.Request function
         ajaxRequest: function(scriptURL, options) {
             //console.log('options.parameters='+options.parameters);
@@ -613,22 +673,18 @@
-         * Function: convertXML
+         * Function: getXmlAsJson
-         * Optionally convert XML to JSON using a server-side script
+         * Convert XML to JSON using a server-side script
          * for requests that aren't available in JSON.
-         * Parameter: {XmlHttpRequest} r
+         * Parameter: {String} url - the URL of the XML object to be converted;
+         *      this can be any URL and is not prepended with the Fusion URL
-         * the XmlHttpRequest object
+         * Parameter: {Function} callback - a callback function to be called if
+         *      the request is successful
-         * Parameter: json
          * boolean indicator if the content is JSON or not.
-         * Parameter: callback
-         * callback method to be executed on success and will be passed a parsed json object
         getXmlAsJson: function(url, callback) {
             var options = {
@@ -639,6 +695,25 @@
             var temp = new OpenLayers.Ajax.Request(url, options);
+         * Function: xml2json
+         * Callback method to convert the XNR response into an actual json object
+         * and triggers the call to the callback method
+         * Parameter: callback
+         * callback method to be executed on success and will be passed a parsed json object
+         * Parameter: {XmlHttpRequest} r
+         * the XmlHttpRequest object
+         * Parameter: json
+         * boolean indicator if the content is JSON or not (set by OpenLayers)
         xml2json: function(callback, r, json) {
           if (json) {
             var o;
@@ -676,7 +751,7 @@
          * Returns: {Object} a map object or null if not found.
-        getMapByName : function(name) {
+        getMapByName: function(name) {
             var map = null;
             if (this.applicationDefinition) {
                 map = this.applicationDefinition.getMapByName(name);
@@ -687,7 +762,7 @@
          * Function: getMapById
-         * return a map widget that is associated with the given dom element
+         * return a map widget that is associated with the given DOM element
          * by id.
          * Parameter: {String} id
@@ -696,7 +771,7 @@
-        getMapById : function(id) {
+        getMapById: function(id) {
             var map = null;
                 map = this.applicationDefinition.getMapById(id);
@@ -707,7 +782,8 @@
          * Function: getMapByIndice
-         * return the map widget at the given index
+         * return the map widget at the given index if there are more than one
+         * map elements specified in the AppDef
          * Parameter: {String} indice
@@ -715,7 +791,7 @@
-        getMapByIndice : function(indice) {
+        getMapByIndice: function(indice) {
             var map = null;
                 map = this.applicationDefinition.getMapByIndice(indice);
@@ -770,6 +846,13 @@
             return widgets;
+         * Function getSearchDefinitions
+         * returns the SearchDefinition objects as defined in the AppDef.
+         * Returns: {Array} an array of searchDefinitions, which may be empty
         getSearchDefinitions: function() {
                 return this.applicationDefinition.searchDefinitions;
@@ -778,6 +861,13 @@
+         * Function getSearchCategories
+         * returns the SearchCategory objects as defined in the AppDef.
+         * Returns: {Array} an array of searchCategories, which may be empty
         getSearchCategories: function() {
                 return this.applicationDefinition.searchCategories;
@@ -786,12 +876,21 @@
+         * Function getApplicationDefinitionURL
+         * returns the URL of the Application Definition
+         * Returns: {String} a URL
         getApplicationDefinitionURL: function() { return this.applicationDefinitionURL; },
          * Function: getApplicationURL
          * returns the applicaiton's absolute URL minus the filename.html part
         getApplicationURL: function() {
           var path = window.location.pathname;
@@ -802,8 +901,26 @@
           return window.location.protocol + "//" + window.location.host + path;
+         * Function: getFusionURL
+         * returns the application's absolute URL minus the filename.html part
         getFusionURL: function() {return this.fusionURL;},
+         * Function: getConfigurationItem
+         * returns individual elements out of the Fusion config.json file
+         * Parameter: {String} arch - the server architecture (mapguide or mapserver)
+         * Parameter: {String} key - the config item to be returned
+         * Returns: {String} a the value for the key of null if not found
         getConfigurationItem: function(arch, key) {
             if (this.configuration[arch] && (this.configuration[arch][key]!='undefined')) {
                 return this.configuration[arch][key];
@@ -811,16 +928,73 @@
             return null;
+         * Function: getScriptLanguage
+         * Accessor to return the server-side script language
+         * Returns: {String} the script language e.g. 'php'
         getScriptLanguage: function() { return this.configuration.general.scriptLanguage; },
+         * Function: getRedirectScript
+         * Accessor to return the URL of the redirect script
         getRedirectScript: function() { return this.sRedirectScript; },
+         * Function: getBroker
+         * Accessor to return the broker object (for MapGuide only).  The broker
+         * is used to prepare various queries to the MapGuide server.
+         * Returns: {Object} the broker object
         getBroker: function() { return this.oBroker; },
+         * Function: require
+         * Marks a JavaScript file as required which puts it into the queue for
+         * loading during Fusion initialization.  Widget code is included
+         * through this mecahnism
+         * Parameter: {String} url - the URL of the JS file to be loaded
+         * Returns: none
         require: function(url) { this.queueScript(url); },
+         * Function: reportError
+         * Triggers the Fusion.Event.FUSION_ERROR and passes along the error
+         * object to the callback functions registered for this event.  Widgets
+         * call Fusion.reportError(o) to inform the system of errors.
+         * Applications will typically register an event listener for the error
+         * event and do something to report the error to the user.
+         * By default, errors are not reported since there is no listener
+         * Parameter: {Object} o - the error object which is typically a string
+         * Returns: none
         reportError: function(o) { this.triggerEvent(Fusion.Event.FUSION_ERROR, o); },
+         * Function: unitFromName
+         * returns index into the units array for the given unit name or
+         * abbreviation
+         * Parameter: {String} unit - the units name to look up
+         * Returns: {Integer} index into the units array
         unitFromName: function(unit) {
             switch(unit.toLowerCase()) {
                 case 'unknown':
@@ -879,6 +1053,16 @@
+         * Given a unit, this method returns if the units system is one of:
+         * imperial, metric, degrees or device units
+         * Parameter: {Integer} unit - the units array index
+         * Returns: {String} the units system
         unitSystem: function(unit) {
             switch(unit) {
@@ -904,12 +1088,31 @@
+         * Function: unitName
+         * Given a unit, this method returns the units name
+         * Returns: {String} the units name
         unitName: function(unit) {
             if (unit >= Fusion.UNKNOWN && unit <= Fusion.PIXELS) {
               return (Fusion.aUnitNames[unit]);
             return 'Unknown';
+         * Function: unitAbbr
+         * Given a unit, this method returns the units abbreviation
+         * Returns: {String} the units abbreviation
         unitAbbr: function(unit) {
               return (Fusion.aUnitAbbr[unit]);
@@ -917,6 +1120,17 @@
             return 'Unk';
+         * Function: toMeter
+         * Converts a length value from native units into meters.  This is the
+         * identity transform if the input units are meters
+         * Parameter: {Float} value - the value to be converted
+         * Returns: {Float} the value in meters
         toMeter: function(unit, value) {
             if (unit == Fusion.UNKNOWN) {
                 return value;
@@ -926,6 +1140,18 @@
             return false;
+         * Function: fromMeter
+         * Converts a length value from meters into native units.  This is the
+         * identity transform if the native units are meters
+         * Returns: {Float} the value in native units
         fromMeter: function(unit, value) {
                 return value;
@@ -935,6 +1161,18 @@
             return false;
+         * Function: convert
+         * Converts a length value from one unit system into another.
+         * Parameter: {Integer} unitsIn - the units array index of the input
+         * Parameter: {Integer} unitsOut - the units array index of the output
+         * Returns: {Float} the value in output units
         convert: function(unitsIn, unitsOut, value) {
             if (unitsIn >= Fusion.UNKNOWN && unitsIn < Fusion.PIXELS &&
                 unitsOut >= Fusion.UNKNOWN && unitsOut < Fusion.PIXELS) {
@@ -944,11 +1182,15 @@
-         * initializes the meters per unit values when a new map is loaded.  Some systems make different
-         * assumptions for the conversion of degrees to meters so this makes sure both Fusion and
-         * OpenLayers are using the same value.
+         * Function: initUnits
-         * @param metersPerUnit the value returned by LoadMap.php for meters per unit
+         * initializes the meters per unit values when a new map is loaded.
+         * Some systems make different assumptions for the conversion of degrees
+         * to meters so this makes sure both Fusion and OpenLayers are using
+         * the same value.
+         * Parameter: {Float} metersPerUnit - the value returned by LoadMap.php
+         *                                    for meters per unit
         initUnits: function(metersPerUnit) {
             var eps = 1000;
@@ -967,11 +1209,13 @@
-         * find the OpenLayers units identifier given the Fusion metersPerUnit value
+        * Function: getClosestUnits
+        * find the OpenLayers units identifier given the Fusion metersPerUnit value
+        * @param metersPerUnit the value returned by LoadMap.php for meters per unit
         getClosestUnits: function(metersPerUnit) {
             var units = "degrees";
             var minDiff = 100000000;
@@ -986,6 +1230,16 @@
             return units;
+         * Function: addWidgetStyleSheet
+         * Dynamically load a CSS stylesheet.  The url will be prepended with
+         * the Fusion URL.
+         * Parameter: {String} url - the URL of the CSS file to be loaded
+         * Returns: none
         addWidgetStyleSheet: function(url) {
             var lnk = document.createElement('link');
             var hd = document.getElementsByTagName('HEAD')[0];
@@ -995,6 +1249,15 @@
             lnk.href = Fusion.getFusionURL()+url;
+         * Function: parseQueryString
+         * An initialization time function to parse the application URL parameters
+         * and stores them in an array.  They can be retrieved using
+         * Fusion.getQueryParam(key).
+         * Returns: {Array} an array of the query params from when the page was loaded
         parseQueryString: function() {
             this.queryParams = [];
             var s=window.location.search;
@@ -1009,6 +1272,15 @@
             return this.queryParams;
+         * Function: getQueryParam
+         * Returns the query parameter value for a given parameter name
+         * Parameter: {String} p - the parameter to lookup
+         * Returns: parameter value or the empty string '' if not found
         getQueryParam: function(p) {
             if (!this.queryParams) {
                 this.parseQueryString();
@@ -1029,7 +1301,7 @@
          * Function: _getScriptLocation
-         * Return the path to this script.
+         * Return the path to this script for bootstrapping Fusion.
          * Returns:
          * {String} Path to this script
@@ -1074,10 +1346,12 @@
     var locale = navigator.language ?
                   navigator.language.substring(0,2):    //e.g. en-CA becomes just en
                   navigator.userLanguage.substring(0,2);//only use the prefix part for now,
-    var s = window.location.search.toLowerCase();
+    var s = window.location.search;
     var idx = s.indexOf('locale=');
     if (idx>0) {
-      locale = s.substring(idx+7,idx+9);
+      var temp = s.substring(idx+7);
+      var idx2 = temp.indexOf('&');
+      locale = temp.substring(0,idx2<0?temp.length:idx2);
     window._FusionLocale = locale;
@@ -1196,50 +1470,54 @@
         document.writeln('<script src="' + src + '"><\/script>');
-	var getXmlHttpRequest = function(){
+    var getXmlHttpRequest = function(){
         try { return new XMLHttpRequest(); }
-		catch (e) { try { return new ActiveXObject('Msxml2.XMLHTTP'); }
-		catch (e) { try { return new ActiveXObject('Microsoft.XMLHTTP'); }
-		catch (e) { return  null; }}}
-	 * Function: createSessionId
-	 * Pre-create a session to avoid the 401 Unauthorized dialog
-	var createSessionId = function(){
-		var xhr = getXmlHttpRequest();
-		xhr.open("GET", Fusion.fusionURL+"layers/MapGuide/php/CreateSession.php",false);
-		xhr.send(null);
-		var o;
-		eval('o='+xhr.responseText);
-		Fusion.sessionId = o.sessionId;
-	var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
-	if(appDefUrl && (
-	    appDefUrl.indexOf('Library') == 0 ||
-	    appDefUrl.indexOf('Session') == 0)){
-    	createSessionId();
-		var xhr = new getXmlHttpRequest();
-		var mapAgentUrl = getAgentUrl();
-		xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ Fusion.sessionId, false);
-		xhr.send(null);
-		var appDefXML = xhr.responseXML.documentElement;
-		if(appDefXML){
-			var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
-			var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
-			var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
+        catch (e) { try { return new ActiveXObject('Msxml2.XMLHTTP'); }
+        catch (e) { try { return new ActiveXObject('Microsoft.XMLHTTP'); }
+        catch (e) { return  null; }}}
-			addElement(googleElement);
-			addElement(yahooElement);
-			addElement(veElement);
+     * Function: createSessionId
+     * Pre-create a session to avoid the 401 Unauthorized dialog
+    var createSessionId = function(){
+        var xhr = getXmlHttpRequest();
+        xhr.open("GET", Fusion.fusionURL+"layers/MapGuide/php/CreateSession.php",false);
+        xhr.send(null);
+        var o;
+        eval('o='+xhr.responseText);
+        Fusion.sessionId = o.sessionId;
+    var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
+    if(appDefUrl && (
+        appDefUrl.indexOf('Library') == 0 ||
+        appDefUrl.indexOf('Session') == 0)){
+        var passedSessionId = Fusion.getQueryParam('Session');
+        if(passedSessionId == null || passedSessionId == "" ){
+            createSessionId();
+        }else{
+            Fusion.sessionId = passedSessionId;
+        var xhr = new getXmlHttpRequest();
+        var mapAgentUrl = getAgentUrl();
+        xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ Fusion.sessionId, false);
+        xhr.send(null);
+        var appDefXML = xhr.responseXML.documentElement;
+        if(appDefXML){
+            var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
+            var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
+            var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
+            addElement(googleElement);
+            addElement(yahooElement);
+            addElement(veElement);
Modified: sandbox/jxlib-3.0/text/fr
--- sandbox/jxlib-3.0/text/fr	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/text/fr	2010-03-31 19:07:52 UTC (rev 2123)
@@ -112,7 +112,9 @@
 COLORPICKERHEXFORMAT            = Hex format
 # MeasureUI
-MEASURETITLE            = Measure Distance
+MEASUREDISTANCETITLE    = Measure Distance
+MEASUREAREATITLE        = Measure Area
+MEASUREBOTHTITLE        = Measure Distance And Area
 MEASUREINFO             = Click a start and end point.
 RESUME                  = Resume
 STOP                    = Stop
@@ -123,6 +125,8 @@
 SEGMENT                 = Segment
 TOTAL                   = Total
 LENGTH                  = Length
+TOTALLENGTH             = Total Length
+TOTALAREA               = Total Area
 MEASUREERROR            = Measure Error
 # Measure
@@ -132,6 +136,97 @@
 MEASURETOTAL            = total
 MEASURELAYER            = Measure
+# FeatureInfoUI
+FEATUREINFOTITLE        = Feature Information
+FEATUREINFOSUBTITLE     = Select a Layer
+FEATUREINFOLAYER        = Layer:
+FEATUREINFOSELECTFEATURE= Select Features:
+FEATUREINFODIGITIZE     = Digitize:
+FEATUREINFOPOINT        = Point
+FEATUREINFORECTANGLE    = Rectangle
+FEATUREINFOPOLYGON      = Polygon
+FEATUREINFOTOTAL        = Total:
+FEATUREINFONOSELECTED   = no features selected.
+FEATUREINFOERROR        = Error
+FEATUREINFOFETCHINFO    = fetching feature info ...
+FEATUREINFOFEATURESEL   = features selected
+FEATUREINFOAREA         = Area:
+FEATUREINFOAREAUNDEFINE = areaIdx undefined
+FEATUREINFONOINFO       = no layer info
+FEATUREINFONOFEATUREIN  = no features in selected layer.
+# QueryUI
+QUERYTITLE              = Query Features
+QUERYSELECTLAYER        = Select a Layer
+QUERYLAYER              = Layer:
+QUERYPROPERTYFILTER     = Property Filter
+QUERYPROPERTY           = Property:
+QUERYOPERATOR           = Operator:
+QUERYVALUE              = Value:
+QUERYSPATIALFILTER      = Spatial Filter
+QUERYDIGITIZE           = Digitize:
+QUERYRECTANGLE          = Rectangle
+QUERYPOLYGON            = Polygon
+QUERYCLEAR              = Clear
+QUERYOUTPUT             = Output
+QUERYOUTPUTPROPERTY     = Output property:
+QUERYEXECUTE            = Execute
+QUERYMAXRESULT          = Max results:
+QUERYRESULTS            = Results
+QUERYSCALE              = Scale:
+QUERYZOOM               = Zoom
+QUERYSELECT             = Select
+QUERYERROR              = Error
+QUERYEQUALTO            = Equal to
+QUERYNOTEQUALTO         = Not equal to
+QUERYGREATTHAN          = Greater than
+QUERYGREATTHANEQUAL     = Greater than or equal to
+QUERYLESSTHAN           = Less than
+QUERYLESSTHANEQUAL      = Less than or equal to
+QUERYBEGIN              = Begins with
+QUERYCONTAINS           = Contains
+# Theme UI
+THEMETITLE              = Theme Layer
+THEMESELECTLAYER        = Select a Layer
+THEMELAYER              = Layer:
+THEMENAME               = Theme Name:
+THEMECONDITIONS         = Define Conditions
+THEMEPROPERTY           = Property:
+THEMEMIN                = Min:
+THEMEMAX                = Max:
+THEMEDISTRIBUTION       = Distribution:
+THEMERULE               = # of Rules:
+THEMESCALERANGE         = Scale Range
+THEMESTYLERAMP          = Style Ramp
+THEMEFILLTRANS          = Fill Transparency:
+THEMEFILLCOLOR          = Fill Color:
+THEMEFROM               = From:
+THEMETO                 = To:
+THEMEBORDERCOLOR        = Border Color:
+THEMEAPPLY              = Apply
+THEMEERROR              = Error
+THEMEINDIVIDUAL         = Individual
+THEMEEQUAL              = Equal
+THEMESTANDARD           = Standard Deviation
+THEMEQUANTILE           = Quantile
+THEMEJENKS              = Jenks (Natural Breaks)
+# Redline UI
+REDLINEOPTIONS          = Digitizing Options
+REDLINESELECTLAYER      = Select Layer:
+REDLINENEW              = New
+REDLINERENAME           = Rename
+REDLINEREMOVE           = Remove
+REDLINEDRAW             = Draw:
+REDLINEPOINT            = Point
+REDLINELINE             = Line
+REDLINERECTANGLE        = Rectangle
+REDLINEPOLYGON          = Polygon
+REDLINESAVE             = Save
+REDLINEUPLOAD           = Upload
+REDLINEFEATURES         = Features
 # HtmlViewerAbout
 HTMLABOUTTITLE          = About %s
 HTMLABOUTTITLEBAR       = MapGuide Viewer
Modified: sandbox/jxlib-3.0/widgets/BufferPanel/BufferPanel.templ
--- sandbox/jxlib-3.0/widgets/BufferPanel/BufferPanel.templ	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/BufferPanel/BufferPanel.templ	2010-03-31 19:07:52 UTC (rev 2123)
@@ -57,6 +57,7 @@
 var decimalSeparator = "__#DECIMALSEPARATOR#__";
 var agent = navigator.userAgent.toLowerCase();
 var msie = agent.indexOf("msie") != -1;
+var mapName;
 function InitDocument()
@@ -70,7 +71,7 @@
     var list = document.getElementById("layers");
     var listNames = document.getElementById("layerNames");
-    var mapName = document.getElementById('Frm').mapname.value;
+    mapName = document.getElementById('Frm').mapname.value;
     list.options.length = 0;
     var map = GetParent().Fusion.getMapByName(mapName);
     var layers = map.aMaps[0].getSelectedLayers();
@@ -219,6 +220,9 @@
 function OnCancel()
+    if(mapName == "undefined")
+        return;
     map.clearSelection();
     //mf.GotoHomePage();
Modified: sandbox/jxlib-3.0/widgets/MapMenu.js
--- sandbox/jxlib-3.0/widgets/MapMenu.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/MapMenu.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -216,6 +216,17 @@
     //change the map, preserving current extents
     switchMap: function(data) {
         var ce = this.getMap().getCurrentExtents();
+        var dest = null;
+        for (var i=0; i<data.maps.length; ++i) {
+          dest = new OpenLayers.Projection(data.maps[i].layerOptions.projection);
+          if (data.maps[i].layerOptions.isBaseLayer) {
+            break;
+        if (!dest) {
+          dest = new OpenLayers.Projection("EPSG:4326");
+        ce = ce.transform(this.oMap.oMapOL.getProjectionObject(), dest);
         data.initialView = {minX:ce.left,
                             minY:ce.bottom,
                             maxX:ce.right,
Modified: sandbox/jxlib-3.0/widgets/Measure.js
--- sandbox/jxlib-3.0/widgets/Measure.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/Measure.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -306,6 +306,9 @@
             this.totalLength = quantity.toPrecision(this.distPrecision);
         } else {
+            if(geom.getArea() == 0)
+                return;
             var cg = geom.getCentroid();
             at = this.getMap().geoToPix(cg.x, cg.y);
             quantity = geom.getGeodesicArea(proj);
@@ -355,7 +358,8 @@
     onKeyPress: function(e) {
         var charCode = (e.charCode ) ? e.charCode : ((e.keyCode) ? e.keyCode : e.which);
         if (charCode == OpenLayers.Event.KEY_ESC) {
-            this.control.cancel();
+            this.deactivate();
+            this.activate();
@@ -581,6 +585,10 @@
           var tDist = outputDoc.getElementById('totalDistance');
           tDist.innerHTML = '';
+          var tArea = outputDoc.getElementById('totalArea');
+          if(tArea){
+              tArea.innerHTML = '';
Modified: sandbox/jxlib-3.0/widgets/OverviewMap.js
--- sandbox/jxlib-3.0/widgets/OverviewMap.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/OverviewMap.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -59,7 +59,7 @@
         } else {
           this.mapObject = new Fusion.Layers.Generic(this, mapTag, false);
-        this.mapObject.registerForEvent(Fusion.Event.LAYER_LOADED, OpenLayers.Function.bind(this.loadOverview, this));
+        //this.mapObject.registerForEvent(Fusion.Event.LAYER_LOADED, OpenLayers.Function.bind(this.loadOverview, this));
         //first set the size to the size of the DOM element if available
         if (this.domObj) {
@@ -73,28 +73,23 @@
         this.oMapOptions = {};  //TODO: allow setting some mapOptions in AppDef
-        //this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapWidgetLoaded, this));
+        this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapWidgetLoaded, this));
     mapWidgetLoaded: function()
         var mapWidget = this.getMap();
-        if (this.sMapGroupId && (mapWidget.projection == this.mapObject.projection) ) {
-          this.loadOverview([this.mapObject.oLayerOL]);
+        if (this.sMapGroupId) {// && (mapWidget.projection == this.mapObject.projection) ) {
+          this.loadOverview(this.mapObject.oLayerOL);
         } else {
           //just use the base map layer
-          var extent = this.oMap._oCurrentExtents;
-          this.loadOverview([this.getMap().oMapOL.baseLayer.clone()]);
+          //setTimeout(OpenLayers.Function.bind(this.loadOverview, this), 5000);
+          this.loadOverview();
-    keymapLoaded: function()
+    loadOverview: function(layer)
-        this.mapObject.oLayerOL.isBaseLayer = true;
-    loadOverview: function()
         if (this.control) {
           this.control.destroy();
@@ -102,22 +97,25 @@
         var size = $(this.domObj).getContentBoxSize();
         this.oSize = new OpenLayers.Size(size.width, size.height);
-        if (this.mapObject.oLayerOL.singleTile) {
+        if (!layer) {
+            layer = this.getMap().oMapOL.baseLayer.clone();
+        layer.isBaseLayer = true;
+        layer.ratio = 1.0;
+        if (layer.singleTile) {
           this.oMapOptions.numZoomLevels = 3;  //TODO: make this configurable?
-        this.mapObject.oLayerOL.ratio = 1.0;
-        var mapOpts = {
+        var options = {
           div: this.domObj,
           minRatio: this.nMinRatio,
           maxRatio: this.nMaxRatio,
           mapOptions: this.oMapOptions,
-          layers: [this.mapObject.oLayerOL]
+          layers: [layer]
-        this.control = new OpenLayers.Control.OverviewMap(mapOpts);
+        this.control = new OpenLayers.Control.OverviewMap(options);
         if (size.width == 0 || size.height == 0) {
           return;   //don't try to load if the container is not visible
         } else {
Modified: sandbox/jxlib-3.0/widgets/SelectAttribute.js
--- sandbox/jxlib-3.0/widgets/SelectAttribute.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/SelectAttribute.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -107,19 +107,21 @@
     setAttributeOptions: function(event) {
-      this.propsList.empty();
-      var layer = this.layerList[this.layerList.selectedIndex].value;
-      var attrs = this.attrs[layer].propertyvalues;
-      var props = this.attrs[layer].propertynames;
-      for (var i=0; i<attrs.length; ++i) {
-          this.propsList.add(new Option(attrs[i],props[i]),null);
-      var map = this.getMap();
-      for (var i=0; i<map.aMaps[0].aLayers.length; ++i) {
-        if (map.aMaps[0].aLayers[i].layerName == layer) {
-          map.setActiveLayer(map.aMaps[0].aLayers[i]);
-          break;
+      if (this.drawn) {
+        this.propsList.empty();
+        var layer = this.layerList[this.layerList.selectedIndex].value;
+        var attrs = this.attrs[layer].propertyvalues;
+        var props = this.attrs[layer].propertynames;
+        for (var i=0; i<attrs.length; ++i) {
+            this.propsList.add(new Option(attrs[i],props[i]),null);
+        var map = this.getMap();
+        for (var i=0; i<map.aMaps[0].aLayers.length; ++i) {
+          if (map.aMaps[0].aLayers[i].layerName == layer) {
+            map.setActiveLayer(map.aMaps[0].aLayers[i]);
+            break;
Modified: sandbox/jxlib-3.0/widgets/TaskPane.js
--- sandbox/jxlib-3.0/widgets/TaskPane.js	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/TaskPane.js	2010-03-31 19:07:52 UTC (rev 2123)
@@ -28,8 +28,9 @@
  * A utility widget that holds output from other widgets.
+Fusion.Event.TASK_PANE_LOADED = Fusion.Event.lastEventId++;
 Fusion.Widget.TaskPane = OpenLayers.Class(Fusion.Widget, {
     aExecutedTasks: null,   //array of URLs for tasks execcuted in the TaskPane
     nCurrentTask: -1,
@@ -125,6 +126,7 @@
         //is added to the DOM
         this.oTaskPane.domObj.resize();
+        Fusion.registerEventID(Fusion.Event.TASK_PANE_LOADED);
         Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, OpenLayers.Function.bind(this.setTaskMenu, this));
         this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.setInitialContent, this, initialTask));
@@ -160,6 +162,8 @@
     setContent: function(url) {
+        Fusion.triggerEvent(Fusion.Event.TASK_PANE_LOADED);
         if (this.nCurrentTask < this.aExecutedTasks.length-1) {
             //this.aExecutedTasks.splice(this.nCurrentTask, this.aExecutedTasks.length - this.nCurrentTask);
Modified: sandbox/jxlib-3.0/widgets/Theme/classes/theme.php
--- sandbox/jxlib-3.0/widgets/Theme/classes/theme.php	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/Theme/classes/theme.php	2010-03-31 19:07:52 UTC (rev 2123)
@@ -53,7 +53,10 @@
             if((substr($layer->GetName(), 0, 1) != "_") && (substr(strtoupper($layer->GetFeatureSourceId()), 0, 7) != "SESSION"))
                 $resId = new MgResourceIdentifier($layer->GetFeatureSourceId());
-                $schemaClass = explode(':', $layer->GetFeatureClassName());
+                $layerFeatureClassName = $layer->GetFeatureClassName();
+                if($layerFeatureClassName == "")
+                    continue;
+                $schemaClass = explode(':', $layerFeatureClassName);
                 $classDef = $featureService->GetClassDefinition($resId, $schemaClass[0], $schemaClass[1]);
                 $propDef = $classDef->GetProperties()->GetItem($layer->GetFeatureGeometryName());
@@ -233,9 +236,17 @@
         $doc = DOMDocument::loadXML($byteReader->ToString());
         $version = $doc->documentElement->getAttribute('version');
         $template = 'templates/arearuletemplate-'.$version.'.xml';
-        $nodeList = $doc->getElementsByTagName('VectorScaleRange');
+        $layerDefList = $doc->getElementsByTagName('VectorLayerDefinition');
+        $layerDef = $layerDefList->item(0);
+        $nodeList = $layerDef->getElementsByTagName('VectorScaleRange');
         $vectorScaleRangecElement = $nodeList->item($this->args['SCALERANGEINDEX']);
+        $listLength = $nodeList->length;
+        for($index = 0; $index < $listLength; $index++)
+            $layerDef->removeChild($nodeList->item(0));
+        $layerDef->appendChild($vectorScaleRangecElement);
         $areaTypeStyle = $vectorScaleRangecElement->getElementsByTagName('AreaTypeStyle')->item(0);
         // Remove any existing <AreaRule> elements.
Modified: sandbox/jxlib-3.0/widgets/Theme/thememain.php
--- sandbox/jxlib-3.0/widgets/Theme/thememain.php	2010-03-31 02:31:02 UTC (rev 2122)
+++ sandbox/jxlib-3.0/widgets/Theme/thememain.php	2010-03-31 19:07:52 UTC (rev 2123)
@@ -124,6 +124,11 @@
         function OnLayerChange()
             var layerSelect = document.getElementById("layerSelect");
+            if(layerSelect.value == ""){
+                return;
             var propertySelect = document.getElementById("propertySelect");
             var scaleSelect = document.getElementById("scaleSelect");
More information about the fusion-commits mailing list
