[fusion-commits] r2174 - sandbox/jxlib-3.0/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon May 31 11:31:39 EDT 2010
Author: madair
Date: 2010-05-31 11:31:39 -0400 (Mon, 31 May 2010)
New Revision: 2174
   sandbox/jxlib-3.0/widgets/SelectAttribute.js
fix cross-browser errors in creating the select drop downs #iloveIE
Modified: sandbox/jxlib-3.0/widgets/SelectAttribute.js
--- sandbox/jxlib-3.0/widgets/SelectAttribute.js	2010-05-28 17:45:04 UTC (rev 2173)
+++ sandbox/jxlib-3.0/widgets/SelectAttribute.js	2010-05-31 15:31:39 UTC (rev 2174)
@@ -69,11 +69,11 @@
         //this.layerList.empty();
         this.layerList.innerHTML = '';
         var map = this.getMap().aMaps[0];
-        this.layerList.add(new Option('--select--',''),0);
+        this.layerList.options[this.layerList.options.length] = new Option('--select--','');
         for (var i=0; i<map.aLayers.length; ++i) {
             var layer = map.aLayers[i];
             if (layer.selectable) {
-              this.layerList.add(new Option(layer.legendLabel,layer.layerName),0);
+              this.layerList.options[this.layerList.options.length] = new Option(layer.legendLabel,layer.layerName);
         this.layerList.onchange = OpenLayers.Function.bind(this.activateLayer, this);
@@ -108,7 +108,7 @@
         var attrs = this.attrs[layer].propertyvalues;
         var props = this.attrs[layer].propertynames;
         for (var i=0; i<attrs.length; ++i) {
-            this.propsList.add(new Option(attrs[i],props[i]),i);
+            this.propsList.options[this.propsList.options.length] = new Option(attrs[i],props[i]);
@@ -142,13 +142,13 @@
           this.operatorList = document.createElement('select');
           this.operatorList.className = 'operatorSelector';
-          this.operatorList.add(new Option("=","eq",true),0);
-          this.operatorList.add(new Option("like","like"),0);
-          this.operatorList.add(new Option(">","gt"),0);
-          this.operatorList.add(new Option("<","lt"),0);
-          this.operatorList.add(new Option("<=","le"),0);
-          this.operatorList.add(new Option(">=","ge"),0);
-          this.operatorList.add(new Option("!=","ne"),0);
+          this.operatorList.options[this.operatorList.options.length] = new Option("=","eq",true);
+          this.operatorList.options[this.operatorList.options.length] = new Option("like","like");
+          this.operatorList.options[this.operatorList.options.length] = new Option(">","gt");
+          this.operatorList.options[this.operatorList.options.length] = new Option("<","lt");
+          this.operatorList.options[this.operatorList.options.length] = new Option("<=","le");
+          this.operatorList.options[this.operatorList.options.length] = new Option(">=","ge");
+          this.operatorList.options[this.operatorList.options.length] = new Option("!=","ne");
           this.attrRow.appendChild(this.operatorList);
           this.attrValue = document.createElement('input');
More information about the fusion-commits mailing list
