[fusion-commits] r2272 - in trunk/templates/mapguide/standard/themes: crispin crispin/images delicious delicious/images
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Nov 5 14:23:10 EDT 2010
Author: madair
Date: 2010-11-05 11:23:10 -0700 (Fri, 05 Nov 2010)
New Revision: 2272
   trunk/templates/mapguide/standard/themes/crispin/ie6.css
   trunk/templates/mapguide/standard/themes/crispin/ie7.css
   trunk/templates/mapguide/standard/themes/crispin/images/button_combo.png
   trunk/templates/mapguide/standard/themes/crispin/images/icons.png
   trunk/templates/mapguide/standard/themes/crispin/images/panel_controls.png
   trunk/templates/mapguide/standard/themes/crispin/jxtheme.css
   trunk/templates/mapguide/standard/themes/crispin/jxtheme.uncompressed.css
   trunk/templates/mapguide/standard/themes/delicious/ie6.css
   trunk/templates/mapguide/standard/themes/delicious/ie7.css
   trunk/templates/mapguide/standard/themes/delicious/images/button_combo.png
   trunk/templates/mapguide/standard/themes/delicious/images/emblems.png
   trunk/templates/mapguide/standard/themes/delicious/images/icons.png
   trunk/templates/mapguide/standard/themes/delicious/images/panel_controls.png
   trunk/templates/mapguide/standard/themes/delicious/images/tab_bottom.png
   trunk/templates/mapguide/standard/themes/delicious/images/tab_close.png
   trunk/templates/mapguide/standard/themes/delicious/images/tab_left.png
   trunk/templates/mapguide/standard/themes/delicious/images/tab_right.png
   trunk/templates/mapguide/standard/themes/delicious/images/tab_top.png
   trunk/templates/mapguide/standard/themes/delicious/jxtheme.css
   trunk/templates/mapguide/standard/themes/delicious/jxtheme.uncompressed.css
re #311: update the Jx CSS files for Jx3.0
Modified: trunk/templates/mapguide/standard/themes/crispin/ie6.css
--- trunk/templates/mapguide/standard/themes/crispin/ie6.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/crispin/ie6.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -1,6 +1,6 @@
  * @project         Jx
- * @revision        $Id: ie6.css 321 2009-04-06 18:23:39Z fred.warnock $
+ * @revision        $Id: ie6.css 935 2010-05-28 17:36:13Z fred.warnock $
  * @author          Fred Warnock (fwarnock at dmsolutions.ca)
  * @copyright       (c) 2006 DM Solutions Group Inc.
@@ -18,9 +18,11 @@
  * Please note that IE8 changed how filters are written.
 .jxChromeDrag {filter: Alpha(opacity=50);}
-.jxDialogModal {filter: Alpha(opacity=20);}
 .jxDisabled {filter:Alpha(opacity=40);}
 .jxDisabled * {filter:Alpha(opacity=40);}
+.jxMask {filter:Alpha(opacity=50);}
+.jxModalMask {filter: Alpha(opacity=20);}
+.jxSpinner {filter: alpha(opacity=50);}
 iframe.jxIframeShim {filter:Alpha(opacity:0);}
 /* List items do not render properly under several conditions.
@@ -52,6 +54,7 @@
   outline: expression(hideFocus='true');
+ul.jxToolbar .jxButton:active span.jxButtonContent,
 .jxButton:active span.jxButtonContent {
   background-position: right -96px;
@@ -62,6 +65,7 @@
   background-position: left -144px;
+ul.jxToolbar .jxButtonActive:active span.jxButtonContent,
 .jxButtonActive:active span.jxButtonContent {
   background-position: right -144px;
@@ -72,6 +76,7 @@
   background-position: left -120px;
+ul.jxToolbar .jxButtonPressed:active span.jxButtonContent,
 .jxButtonPressed:active span.jxButtonContent {
   background-position: right -120px;
Modified: trunk/templates/mapguide/standard/themes/crispin/ie7.css
--- trunk/templates/mapguide/standard/themes/crispin/ie7.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/crispin/ie7.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -1,6 +1,6 @@
  * @project         Jx
- * @revision        $Id: ie7.css 321 2009-04-06 18:23:39Z fred.warnock $
+ * @revision        $Id: ie7.css 978 2010-09-08 18:37:27Z pagameba $
@@ -18,9 +18,11 @@
 /* tree item focus style */
@@ -33,6 +35,14 @@
+.jxTree,
+.jxTreeRoot,
+.jxTreeNest,
+li.jxTreeContainer {
+ /* zoom needed to fix alignment/sizing issues in IE 7 */
+ zoom: 1;
 /* IE versions 7 and below do not recognize the focus pseudo-class, but instead
  * use the active pseudo-class.  Other browsers use the active-pseudo-class
  * while something is being pressed so IE specific definitions are needed. */
@@ -43,6 +53,7 @@
@@ -53,6 +64,7 @@
@@ -63,6 +75,7 @@
Modified: trunk/templates/mapguide/standard/themes/crispin/images/button_combo.png
(Binary files differ)
Modified: trunk/templates/mapguide/standard/themes/crispin/images/icons.png
Modified: trunk/templates/mapguide/standard/themes/crispin/images/panel_controls.png
Modified: trunk/templates/mapguide/standard/themes/crispin/jxtheme.css
--- trunk/templates/mapguide/standard/themes/crispin/jxtheme.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/crispin/jxtheme.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -21,4 +21,4 @@
  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
  * DEALINGS IN THE SOFTWARE.
- */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;displ
 ay:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{b
 ackground-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButt
 onPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisab
 led .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxDiscloser span.jxButtonContent{padding-right:0;}.jxDiscloser span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{
 position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxTo
 olbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transpa
 rent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;emp
 ty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px soli
 d #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDi
 sabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMove
 able,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-posi
 tion:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,
 .jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileF
 ake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:2px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:-5px;height:35px;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;border-radius:10px;-moz-border-radius:10px;-webkit-border-radius:10px;-khtml-border-radius:10px;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInp
 utLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldError .jxInputText,.jxFieldError .jxInputPassword,.jxFieldError .jxInputTexta
 rea,.jxFieldError .jxInputSelect{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldSuccess .jxInputText,.jxFieldSuccess .jxInputPassword,.jxFieldSuccess .jxInputTextarea,.jxFieldSuccess .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldError .jxInputText:focus,.jxFieldError .jxInputPassword:focus,.jxFieldError .jxInputTextarea:focus,.jxFieldError .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldSuccess .jxInputText:focus,.jxFieldSuccess .jxInputPassword:focus,.jxFieldSuccess .jxInputTextarea:focus,.jxFieldSuccess .jxInputSelect:focus{border-color:#264409;}.jxFieldError .jxInputLabel,.jxFieldError .jxInputTag{color:#8a1f11;}.jxFieldSuccess .jxInputLabel,.jxFieldSuccess .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInl
 ine .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jx
 InputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .
 jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padd
 ing:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-
 position:0 0;background-repeat:repeat-y;text-align:center;font-weight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-po
 sition:right top;}.jxGridColumnSortedAsc span{background-position:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-po
 sition:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-us
 er-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabl
 ed a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jx
 MenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemToggleSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemToggleSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxNoticeListContainer{border:none;padding:0;margin:0;font-size:0;line-height:0;z-index:500;}.jxNoticeList{position:relative;}.jxNoticeItemContainer{position:relative;overflow:hidden;}.jxNoticeItemContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxHasChrome .jxNoticeItem{margin:6px 6px 8px 7px;}.jxNotice
 Item{position:relative;border:2px solid #ccc;margin:0;padding:0;background-color:#f8f8f8;background-image:url(images/notice.png);background-repeat:repeat-x;background-position:left bottom;}.jxNoticeIcon{position:absolute;top:0;left:0;margin:6px;width:16px;height:16px;background-image:url(images/icons.png);background-repeat:no-repeat;background-position:0 0;}.jxNotice{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:18px;color:#666;margin:0;border:none;padding:6px 26px 6px 10px;}.jxNoticeError .jxNoticeItem{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;background-image:url(images/notice_error.png);}.jxNoticeWarning .jxNoticeItem{background-color:#FFF6BF;color:#514721;border-color:#FFD324;background-image:url(images/notice_warning.png);}.jxNoticeSuccess .jxNoticeItem{background-color:#E6EFC2;color:#264409;border-color:#C6D880;background-image:url(images/notice_success.png);}.jxNoticeError .jxNotice{color:#8a1f11;pa
 dding-left:28px;}.jxNoticeWarning .jxNotice{color:#514721;padding-left:28px;}.jxNoticeSuccess .jxNotice{color:#264409;padding-left:28px;}.jxNoticeInfo .jxNotice{padding-left:28px;}.jxNoticeError .jxNoticeIcon{background-position:0 -32px;}.jxNoticeWarning .jxNoticeIcon{background-position:0 -16px;}.jxNoticeSuccess .jxNoticeIcon{background-position:0 -48px;}.jxNoticeInfo .jxNoticeIcon{background-position:0 -64px;}.jxNoticeClose{position:absolute;top:0;right:0;margin:6px;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-alig
 n:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16p
 x;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled
 .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-c
 ontainer .jxProgressBar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%
 ;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}span.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:-moz-inline-box;display:inline-block;position:relative;cursor:pointe
 r;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:-moz-inline-box;display:inline-block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{display:-moz-inline-box;display:inline-block;position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:-moz-inline-box;display:inline-block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled
 a.jxTabClose{cursor:default;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:5px;right:5px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -96
 px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxDis
 abled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jx
 Disabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{vertical-align:middle;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{vertical-align:middle;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:5px;left:5px;}.jxBarLeft .jxTabClose span.jxTabContent,.
 jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight
 a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLe
 ft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive
 :focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:
 repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;margi
 n:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left
 top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.
 jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTree
 BranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploadF
 ileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
\ No newline at end of file
+ */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;displ
 sabled *{-ms-filter:"Alpha(opacity=40)";}.jxMask{opacity:.5;-ms-filter:"Alpha(opacity=50)";background-color:#fff;}.jxModalMask{background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxEventMask{background-image:url(images/a_pixel.png);}.jxSpinner{position:absolute;opacity:.5;-ms-filter:"Alpha(opacity=50)";z-index:999;background:#fff;}.jxSpinnerMessage{text-align:center;font-weight:bold;}.jxSpinnerSmall .jxSpinnerMessage{margin:0;padding:0;font-size:11px;line-height:24px;}.jxSpinnerLarge .jxSpinnerImage{background:url(images/spinner_24.gif) no-repeat;width:24px;height:24px;margin:0 auto;}.jxSpinnerSmall .jxSpinnerImage{background:url(images/spinner_16.gif) no-repeat;width:16px;height:16px;margin-right:4px;display:inline-block;vertical-align:middle;}.jxConfirmQuestion,.jxPrompt{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;visibility:hidden;}.jx
 DialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3
 px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogMaximize img{background-position:0 -80px;}.jxDialogMaximized .jxDialogMaximize img{background-position:0 -96px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDial
 ogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:2px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0
 ;z-index:2;margin-top:-5px;height:35px;}.jxForm{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;border:1px solid #ccc;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputWrapper{display:inline-block;white-space:normal;position:relative;}.jxInputText,.jxInputPassword,.jxInputTextarea,.jxInputCombo,.jxInputColor{margin:0 4px;padding:4px;border:1px solid #bbb;width:232px;font-family:Arial,Helvetica,sans-serif;font
 -size:12px;line-height:16px;color:#000;}.jxInputCombo,.jxInputColor{padding:4px 20px 4px 20px;width:200px;}.jxInputIconHidden .jxInputCombo{padding-left:4px;width:216px;}.jxInputIcon{position:absolute;width:16px;height:16px;left:0;top:0;margin:4px 4px 4px 8px;}.jxInputContainerColor .jxInputIcon{border:1px solid #bbb;width:15px;height:15px;}.jxInputIconHidden .jxInputIcon{display:none;}.jxInputRevealer{position:absolute;width:16px;height:16px;right:0;top:0;margin:4px 8px 4px 4px;font-size:0;line-height:0;}img.jxInputRevealerIcon{background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}.jxInputRevealer .jxButtonContainer,.jxInputRevealer .jxButton{padding:0;margin:0;border:0;background-color:transparent;background-image:none;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:A
 rial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus,.jxInputCombo:focus,.jxInputColor:focus{border:1px solid #000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldError .jxInputText,.jxFieldError .jxInputPassword,.jxFieldError .jxInputTextarea,.jxFieldError .jxInputSelect,.jxFieldError .jxInputCombo,.jxFieldError .jxInputColor{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldSuccess .jxInputText,.jxFieldSuccess .jxInputPassword,.jxFieldSuccess .jxInputTextarea,.jxFieldSuccess .jxInputSelect,.jxFieldSuccess .jxInputCombo,.jxFieldSuccess .jxInputColor{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldErro
 r .jxInputText:focus,.jxFieldError .jxInputPassword:focus,.jxFieldError .jxInputTextarea:focus,.jxFieldError .jxInputSelect:focus,.jxFieldError .jxInputCombo:focus,.jxFieldError .jxInputColor:focus{border-color:#8a1f11;}.jxFieldSuccess .jxInputText:focus,.jxFieldSuccess .jxInputPassword:focus,.jxFieldSuccess .jxInputTextarea:focus,.jxFieldSuccess .jxInputSelect:focus,.jxFieldSuccess .jxInputCombo:focus,.jxFieldSuccess .jxInputColor:focus{border-color:#264409;}.jxFieldError .jxInputLabel,.jxFieldError .jxInputTag{color:#8a1f11;}.jxFieldSuccess .jxInputLabel,.jxFieldSuccess .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}
 .jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .
 jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;white-space:nowrap;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormI
 nlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridCellContent .jxInputContainer,.jxGridCellContent .jxInputRadio,.jxGridCellContent .jxInputCheck{display:inline;position:relative;border:none;margin:0;padding:0;font-size:0;line-height:0;color:#000;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{width:100%;position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding:0 3px;overflow:hidd
 en;vertical-align:middle;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;line-height:16px;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead .jxGridCellContent{padding:0 3px;text-align:center;font-weight:bold;color:#333;height:100%;}.jxGridRowHead .jxGridCellContent{text-align:center;font-weight:bold;color:#333;}.jxGridColHead{height:100%;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;cursor:default;padding:0;white-space:nowrap;overflow:hidden;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;cursor:default;o
 verflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td,.jxGridRowSelected th{background-color:#f7f7f7;}td.jxGridCellSelected,th.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td,.jxGridRowPrelight th{background-color:#e5f1ff;}td.jxGridCellPrelight,th.jxGridCellPrelight{background-color:#cce3ff;}.jxGridHeader .jxColSortable img{vertical-align:top;width:16px;height:16px;background-image:url('images/emblems.png');background-repeat:no-repeat;background-position:right top;}.jxGridHeader .jxColSortable .jxGridCe
 llContent{margin-right:-16px;}.jxGridHeader .jxGridColumnSortedAsc img{background-position:right -162px;}.jxGridHeader .jxGridColumnSortedDesc img{background-position:right -18px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxColSortable .jxGridColumnResize{right:8px;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxGridEditorPopup{min-width:130px;margin:3px;font-size:10px;box-shadow:2px 2px 5px #888;-moz-box-shadow:2px 2px 5px #888;-webkit-box-shadow:2px 2px 5px #888;background-color:#ddd;border:1px solid #999;position:absolute;}.jxGridEditorPopupInnerWrapper{position:relative;height:100%;width:100%;}.jxListView{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;
 padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padd
 ing:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a
 .jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButton
 SubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemToggleSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemToggleSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background
 -repeat:repeat-x;background-position:left center;}.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxNoticeListContainer{border:none;padding:0;margin:0;font-size:0;line-height:0;z-index:500;}.jxNoticeList{position:relative;}.jxNoticeItemContainer{position:relative;overflow:hidden;}.jxNoticeItemContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxHasChrome .jxNoticeItem{margin:6px 6px 8px 7px;}.jxNoticeItem{position:relative;border:2px solid #ccc;margin:0;padding:0;background-color:#f8f8f8;background-image:url(images/notice.png);background-repeat:repeat-x;background-position:left bottom;}.jxNoticeIcon{position:absolute;top:0;left:0;margin:6px;width:16px;height:16px;background-image:url(images/icons.png);background-repeat:no-repeat;background-position:0 0;}.jxNotice{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:18px;color:#666;margin:0;border:none;padding:6px 26px 6px 10px;
 }.jxNoticeError .jxNoticeItem{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;background-image:url(images/notice_error.png);}.jxNoticeWarning .jxNoticeItem{background-color:#FFF6BF;color:#514721;border-color:#FFD324;background-image:url(images/notice_warning.png);}.jxNoticeSuccess .jxNoticeItem{background-color:#E6EFC2;color:#264409;border-color:#C6D880;background-image:url(images/notice_success.png);}.jxNoticeInformation .jxNoticeItem{background-color:#F8F8F8;color:#666;border-color:#CCC;background-image:url(images/notice.png);}.jxNoticeError .jxNotice{color:#8a1f11;padding-left:28px;}.jxNoticeWarning .jxNotice{color:#514721;padding-left:28px;}.jxNoticeSuccess .jxNotice{color:#264409;padding-left:28px;}.jxNoticeInformation .jxNotice{color:#666;padding-left:28px;}.jxNoticeError .jxNoticeIcon{background-position:0 -32px;}.jxNoticeWarning .jxNoticeIcon{background-position:0 -16px;}.jxNoticeSuccess .jxNoticeIcon{background-position:0 -48px;}.jxNoticeInformation .jxN
 oticeIcon{background-position:0 -64px;}.jxNoticeClose{position:absolute;top:0;right:0;margin:6px;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-si
 ze:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelCo
 ntrols .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}.jxProgressBar-container{position:relative;display:block;width:100%;}.jxProgressBar-message{position:relative;display:block;color:black;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:20px;}.jxProgressBar{position:relative;display:block;width:100%;height:20px;border:none;margin:0;padding:0;}.jxProgressBar-outline{position:absolute;displa
 y:block;top:0;left:0;z-index:10;height:20px;border-left:1px solid #cbc8c8;border-right:1px solid #cbc8c8;background-image:url(images/progressbar.png);background-position:0 -140px;width:100%;}.jxProgressBar-fill{position:absolute;display:block;top:0;left:0;z-index:20;height:20px;border:none;background-image:url(images/progressbar.png);background-position:0 0;}.jxProgressStarting .jxProgressBar-fill{border:none;}.jxProgressWorking .jxProgressBar-fill{border-left:1px solid #49afe8;}.jxProgressFinished .jxProgressBar-fill{border-left:1px solid #49afe8;border-right:1px solid #49afe8;}.jxProgressBar-text{position:absolute;display:block;overflow:visible;top:0;left:1px;width:auto;height:20px;z-index:30;border:none;margin:0;padding:0 0 0 4px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:20px;white-space:nowrap;}.jxHasVerticalScrollbar,.jxHasHorizontalScrollbar{position:relative;overflow:hidden;}.jxScrollbarChildWrapper{overflow:hidden;}.jxHasVerticalScrollbar{padd
 ing-right:25px;}.jxHasVerticalScrollbar .jxScrollbarContainer{position:absolute;right:0;top:0;width:20px;height:100%;border:none;border-left:1px solid black;}.jxHasVerticalScrollbar .jxScrollLeft,.jxHasVerticalScrollbar .jxScrollRight{width:20px;height:20px;display:block;background-color:blue;}.jxHasVerticalScrollbar .jxSliderContainer{height:100%;width:20px;border:none;}.jxHasHorizontalScrollbar{padding-bottom:25px;}.jxHasHorizontalScrollbar .jxScrollbarContainer{position:absolute;bottom:0;left:0;height:20px;width:100%;border:none;border-top:1px solid black;}.jxHasHorizontalScrollbar .jxScrollLeft,.jxHasHorizontalScrollbar .jxScrollRight{width:20px;height:20px;display:block;background-color:blue;}.jxHasHorizontalScrollbar .jxScrollLeft{float:left;}.jxHasHorizontalScrollbar .jxScrollRight{float:right;}.jxHasHorizontalScrollbar .jxSlider{float:left;}.jxHasHorizontalScrollbar .jxSliderContainer{height:20px;width:100%;border:none;}.jxHasVerticalScrollbar .jxSliderKnob,.jxHasHor
 izontalScrollbar .jxSliderKnob{width:20px;height:20px;background-color:black;cursor:pointer;}.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBef
 ore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxBarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}span.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:-moz-inline-box;display:inline-block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:-moz-inline-box;display:inline-block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{display:-moz-inline-box
 ;display:inline-block;position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:-moz-inline-box;display:inline-block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxTabBarTop .jxBarWrapper,.jxTabBarBottom .jxBarWrapper{padding-left:2px;}.jxBarTop span.jxTabContainer,.jxBarBottom span.jxTabContainer{margin-right:-1px;padding:2px 0;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent,.jxTabBarTop .jxBarControls a.jxButton,.jxTabBarTop .jxBarControls span.jxButtonContent{background-
 image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent,.jxTabBarBottom .jxBarControls a.jxButton,.jxTabBarBottom .jxBarControls span.jxButtonContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:5px;right:5px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:r
 ight -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTo
 p .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBo
 ttom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{vertical-align:middle;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{vertical-align:middle;height:16px;padding:0 4px 0 4px;}.jxTabBarLeft .jxBarWrapper,.jxTabBarRight .jxBarWrapper{padding-top:2px;}.jxBarLeft span.jxTabContainer,.jxBarRight span.jxTabContainer{margin-bottom:-1px;padding:0 2px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxB
 arRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:5px;left:5px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,
 .jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .j
 xDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus
  span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/
 toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{float:left;height:28px;overflow:hidden;z-index:0;}.jxBarTop .jxBarScroller .jxBarWrapper,.jxBarBottom .jxBarScroller .jxBarWrapper{float:left;height:28px;overflow:hidden;width:10000%;}.jxBarTop .jxBarControls .jxButtonContainer,.jxBarBottom .jxBarControls .jxButtonContainer{z-index:1;padding:2px 0;margin-left:-1px;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(i
 mages/emblems.png);background-position:0 -96px;}.jxBarControls{float:right;position:relative;font-size:0;line-height:0;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;clear:none;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;white-space:nowrap;padding:0;margin:0;border:none;}li.jxToolItem .jxInputWrapper{white-space:nowrap;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar
 ,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxToolbarAlignLeft ul{float:left;}.jxToolbarAlignRight ul{float:right;}.jxToolbarAlignCenter{text-align:center;}.jxToolbarAlignCenter ul{float:none;}.jxToolbarAlignCenter ul li{float:none;display:inline;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overfl
 ow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{bac
 kground-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}
 .jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}img.jxTreeImage.jxBusy{background-image:url(images/spinner_16.gif);background-position:left top;}.jxFileUploadPanel{padding:5px;}.jxUploadQueue li{display:block;position:relative;overflow:hidden;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue li span.jxUploadFileName{font-size:12px;line-height:16px;padding-left:2px;}.jxUploadQueue li span.jxUploadFileDelete,.jxUploadQueue li span.jxUploadFileProgress,.jxUploadQueue li span.jxUploadFileComplete,.jxUploadQueue li span.jxUploadFileError{position:absolute;top:2px;right:2px;width:16px;height:16px;background-repeat:no-repeat;cursor:pointer;}.jxUploadQueue li span.jxUploadFileDelete{background-image:url('images/icons.png');background-position:0 -128px;}.jxUploadQueue li span.jxUploadFileProgress{background-image:url('images/spinner_16.gif');ba
 ckground-position:top left;}.jxUploadQueue li span.jxUploadFileComplete{background-image:url('images/icons.png');background-position:0 -48px;}.jxUploadQueue li span.jxUploadFileError{background-image:url('images/icons.png');background-position:0 -32px;}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/icons.png") no-repeat 0 -32px;color:black;width:100px;}
Modified: trunk/templates/mapguide/standard/themes/crispin/jxtheme.uncompressed.css
--- trunk/templates/mapguide/standard/themes/crispin/jxtheme.uncompressed.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/crispin/jxtheme.uncompressed.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -669,7 +669,7 @@
     height: 16px;
  * @project         Jx
- * @revision        $Id: common.css 267 2009-03-31 20:49:16Z fred.warnock $
+ * @revision        $Id: common.css 736 2010-03-05 16:04:56Z pagameba $
  * @author          Fred Warnock (fwarnock at dmsolutions.ca)
  * @copyright       (c) 2006 DM Solutions Group Inc.
@@ -678,19 +678,98 @@
 /* COMMON STYLES */
-.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}
-.jxDisabled{opacity:0.4;-ms-filter: "Alpha(opacity=40)";}
-.jxDisabled * {-ms-filter: "Alpha(opacity=40)";}
-iframe.jxIframeShim{position:absolute;top:0px;left:0px;width:100%;height:100%;opacity:0;-ms-filter: "Alpha(opacity=0)";z-index:-1;}/**
- * Confirm dialog classes
+.jxClearer {
+  display: block;
+  position: relative;
+  float: none;
+  clear: both;
+  font-size: 0;
+  line-height: 0;
+  width: 0;
+  height: 0;
+  margin: 0;
+  padding: 0;
+.jxDisabled {
+  opacity: 0.4;
+  -ms-filter: "Alpha(opacity=40)";
+.jxDisabled * {
+/*  MASK STYLES  */
+.jxMask {
+  opacity: 0.5;
+  -ms-filter: "Alpha(opacity=50)";
+  background-color: #fff;
+.jxModalMask {
+  background-color: #000;
+  opacity: 0.2;
+  -ms-filter: "Alpha(opacity=20)";
+.jxEventMask {
+  background-image: url(images/a_pixel.png);
+.jxSpinner {
+  position: absolute;
+  opacity: 0.5;
+  z-index: 999;
+  background: #fff;
+/* .jxSpinnerContent { } */
+.jxSpinnerMessage {
+  text-align: center;
+  font-weight: bold;
+.jxSpinnerSmall .jxSpinnerMessage {
+  margin: 0px;
+  padding: 0px;
+  font-size: 11px;
+  line-height: 24px;
+.jxSpinnerLarge .jxSpinnerImage {
+  background: url(images/spinner_24.gif) no-repeat;
+  width: 24px;
+  height: 24px;
+  margin: 0 auto;
+.jxSpinnerSmall .jxSpinnerImage {
+  background: url(images/spinner_16.gif) no-repeat;
+  width: 16px;
+  height: 16px;
+  margin-right: 4px;
+  display: inline-block;
+  vertical-align: middle;
+/*iframe.jxIframeShim { }*/
+ * Confirm and Prompt dialog classes
-.jxConfirmQuestion {
+.jxConfirmQuestion, .jxPrompt {
     text-align: center;
     padding: 10px;
     margin-top: 10px;
  * @project         Jx
- * @revision        $Id: dialog.css 302 2009-04-02 18:42:56Z fred.warnock $
+ * @revision        $Id: dialog.css 732 2010-03-05 14:38:36Z pagameba $
@@ -708,6 +787,9 @@
   display: block;
   z-index: 1000;
   overflow: hidden;
+  /* initial state is hidden */
+  visibility: hidden;
 .jxDialogContentContainer {
@@ -717,20 +799,6 @@
   background-color: #f0f0f0;
-.jxDialogModal {
-  /* Base setup */
-  position: absolute;
-  display: block;
-  top: 0px;
-  left: 0px;
-  width: 100%;
-  height: 100%;
-  background-color: #000;
-  opacity: .2;
-  -ms-filter: "Alpha(opacity=20)";
 .jxDialogContent {
   /* Base setup */
   display: block;
@@ -851,6 +919,14 @@
   background-position: 0px -16px;
+.jxDialogMaximize img {
+  background-position: 0px -80px;
+.jxDialogMaximized .jxDialogMaximize img {
+  background-position: 0px -96px;
 .jxDialogLoading img {
   border: 0px;
   /* the margin needs to make up the difference between it's width/height
@@ -871,15 +947,6 @@
-.jxDialogControls span.jxButtonContent,
-.jxDialogControls .jxButton:hover span.jxButtonContent,
-.jxDialogControls .jxButton:active span.jxButtonContent,
-.jxDialogControls .jxButtonActive span.jxButtonContent,
-.jxDialogControls .jxButtonActive:hover span.jxButtonContent,
-.jxDialogControls .jxButtonActive:active span.jxButtonContent,
-.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,
-.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,
-.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,
 .jxDialogControls .jxButton:active ,
@@ -897,16 +964,6 @@
-.jxDialogControls .jxButtonMenu span.jxButtonContent,
-.jxDialogControls .jxButtonFlyout span.jxButtonContent {
-  background-image: none;
-.jxDialogControls .jxButtonMenu span.jxButtonContent span,
-.jxDialogControls .jxButtonFlyout span.jxButtonContent span {
-  padding-right: 0px;
 /* JX TOOLBAR STYLES OVERIDES */
@@ -984,7 +1041,7 @@
     height: 35px;
  * @project         Jx
- * @revision        $Id: form.css 615 2009-11-19 22:01:38Z fred.warnock $
+ * @revision        $Id: form.css 827 2010-04-01 14:22:49Z fred.warnock $
@@ -1013,7 +1070,6 @@
 .jxForm {
   display: block;
   position: relative;
-  overflow: hidden; /* ensures that floated elements are contained */
   font-family: Arial, Helvetica, sans-serif;
   font-size: 12px;
   line-height: 16px;
@@ -1023,12 +1079,7 @@
 .jxFieldset {
   display: block;
   position: relative;
   border: 1px solid #ccc;
-  border-radius: 10px;
-  -moz-border-radius: 10px;
-  -webkit-border-radius: 10px;
-  -khtml-border-radius: 10px;
   margin: 10px;
   padding: 5px;
@@ -1072,19 +1123,86 @@
   vertical-align: bottom;
+.jxInputWrapper {
+  white-space: normal;
 .jxInputText,
 .jxInputPassword,
-.jxInputTextarea {
+.jxInputTextarea,
+.jxInputCombo,
+.jxInputColor {
   margin: 0px 4px;
   padding: 4px;
   border: 1px solid #bbb;
+  /* overall width is 250px, margins+padding+border is 18px */
+  width: 232px;
   font-size: 12px;
   line-height: 16px;
   color: #000;
+.jxInputCombo,
+.jxInputColor {
+  padding: 4px 20px 4px 20px;
+  /* overall width is 250px, margins+padding+border is 50px */
+  width: 200px;
+.jxInputIconHidden .jxInputCombo {
+  /* overall width is 250px, margins+padding+border is 34px */
+  padding-left: 4px;
+  width: 216px;
+.jxInputIcon {
+  width: 16px;
+  height: 16px;
+  left: 0px;
+  top: 0px;
+  margin: 4px 4px 4px 8px;
+.jxInputContainerColor .jxInputIcon {
+  border: 1px solid #bbb;
+  width: 15px;
+  height: 15px;
+.jxInputIconHidden .jxInputIcon {
+  display: none;
+.jxInputRevealer {
+  width: 16px;
+  height: 16px;
+  right: 0px;
+  top: 0px;
+  margin: 4px 8px 4px 4px;
+  font-size: 0px;
+  line-height: 0px;
+img.jxInputRevealerIcon {
+  background-image: url(images/emblems.png);
+  background-position: right -16px;
+  background-repeat: no-repeat;
+.jxInputRevealer .jxButtonContainer,
+.jxInputRevealer .jxButton {
+  padding: 0px;
+  margin: 0px;
+  border: 0px;
+  background-color: transparent;
+  background-image: none;
 .jxInputSelect {
   margin: 0px 4px;
   padding: 3px 4px 3px 1px;
@@ -1095,13 +1213,6 @@
   color: #000;
-.jxInputText:focus,
-.jxInputPassword:focus,
-.jxInputTextarea:focus,
-.jxInputSelect:focus {
-  border: 1px solid #000;
 .jxInputRadio,
 .jxInputCheck {
   margin: 5px;
@@ -1111,6 +1222,15 @@
   color: #000;
+.jxInputText:focus,
+.jxInputPassword:focus,
+.jxInputTextarea:focus,
+.jxInputSelect:focus,
+.jxInputCombo:focus,
+.jxInputColor:focus {
+  border: 1px solid #000;
 .jxInputContainer .jxButtonContainer {
   padding: 0px;
   margin: 0px 4px;
@@ -1145,7 +1265,9 @@
-.jxFieldError .jxInputSelect {
+.jxFieldError .jxInputSelect,
+.jxFieldError .jxInputCombo,
+.jxFieldError .jxInputColor {
   background-color: #FBE3E4;
   color: #8a1f11;
   border-color: #FBC2C4;
@@ -1154,7 +1276,9 @@
-.jxFieldSuccess .jxInputSelect {
+.jxFieldSuccess .jxInputSelect,
+.jxFieldSuccess .jxInputCombo,
+.jxFieldSuccess .jxInputColor {
   background-color: #E6EFC2;
   color: #264409;
   border-color: #C6D880;
@@ -1163,14 +1287,18 @@
 .jxFieldError .jxInputText:focus,
-.jxFieldError .jxInputSelect:focus {
+.jxFieldError .jxInputSelect:focus,
+.jxFieldError .jxInputCombo:focus,
+.jxFieldError .jxInputColor:focus {
   border-color: #8a1f11;
-.jxFieldSuccess .jxInputSelect:focus {
+.jxFieldSuccess .jxInputSelect:focus,
+.jxFieldSuccess .jxInputCombo:focus,
+.jxFieldSuccess .jxInputColor:focus {
   border-color: #264409;
@@ -1308,6 +1436,7 @@
 form.jxForm span.jxFormInlineblock {
   display: block;
+  white-space: nowrap;
 /* Inline-Block Label */
@@ -1339,9 +1468,22 @@
   width: auto;
+/** Jx.Grid Overrides **/
+.jxGridCellContent .jxInputContainer,
+.jxGridCellContent .jxInputRadio,
+.jxGridCellContent .jxInputCheck {
+  display: inline;
+  border: none;
+  margin: 0px;
+  padding: 0px;
+  font-size: 0px;
+  line-height: 0px;
+  color: #000;
  * @project         Jx
- * @revision        $Id: grid.css 572 2009-10-29 05:53:36Z jonlb at comcast.net $
+ * @revision        $Id: grid.css 796 2010-03-26 19:56:43Z pagameba $
@@ -1362,21 +1504,15 @@
 .jxGridTable {
+    width: 100%;
     position: relative;
     table-layout: fixed;
     border-collapse: collapse;
     border-style: none;
     cursor: default;
-    font-family: Arial, Verdana, sans-serif;
-    font-size: 11px;
-    font-weight: normal;
-.jxGridHeader {
-    width: 100%;
 .jxGridTableBody {
     position: relative;
@@ -1384,33 +1520,8 @@
     border-style: none;
    /* width: 100%;*/
     cursor: default;
-    font-size: 11px;
-.jxGridColHeadHide {
-    height: 0px;
-    line-height: 0px;
-    font-size: 0px;
-    background-color: #fff;
-    white-space: normal;
-.jxGridColHeadHide p, .jxGridRowHeadHide p {
-    font-size: 0px;
-    line-height: 0px;
-    height: 0px;
-    margin: 0px;
-    padding: 0px;
-.jxGridRowHeadHide {
-    width: 0px;
 .jxGridCell {
     border-top: 0px solid #d8d8d8;
     border-right: 1px solid #d8d8d8;
@@ -1424,9 +1535,15 @@
     display: -moz-inline-box;
     overflow: hidden;
-    padding-left: 3px;
-    padding-right: 3px;
+    padding: 0px 3px;
     overflow: hidden;
+    font-family: Arial, Verdana, sans-serif;
+    font-size: 11px;
+    font-weight: normal;
+    line-height: 16px;
     /* can change this to normal */
     cursor: cell;
@@ -1434,9 +1551,24 @@
     text-overflow: ellipsis;
+.jxGridColHead .jxGridCellContent {
+    padding: 0px 3px;
+    color: #333;
+    height: 100%;
+.jxGridRowHead .jxGridCellContent {
+  color: #333;
 /* Normal Styles */
 .jxGridColHead {
+    height: 100%;
     border-bottom: 1px solid #d8d8d8;
@@ -1447,12 +1579,11 @@
     background-repeat: repeat-x;
     text-align: center;
-    font-weight: bold;
-    color: #333;
     cursor: default;
+    padding: 0px;
+    overflow: hidden;
 .jxGridRowHead {
@@ -1466,8 +1597,6 @@
     background-repeat: repeat-y;
     text-align: center;
-    color: #333;
     cursor: default;
     overflow: hidden;
@@ -1500,11 +1629,13 @@
     background-color: #f7f7f7;
-.jxGridRowSelected td {
+.jxGridRowSelected td,
+.jxGridRowSelected th {
-td.jxGridCellSelected {
+td.jxGridCellSelected,
+th.jxGridCellSelected {
     background-color: #ebebeb;
@@ -1524,36 +1655,35 @@
     background-color: #e5f1ff;
-.jxGridRowPrelight td {
+.jxGridRowPrelight td,
+.jxGridRowPrelight th {
-td.jxGridCellPrelight {
+td.jxGridCellPrelight,
+th.jxGridCellPrelight {
   background-color: #cce3ff;
-/* Sort styles */
-.jxColSortable {
-    padding-right: 20px;
-.jxGridCell.jxColSortable {
-    padding-right: 0;
-.jxColSortable span {
+.jxGridHeader .jxColSortable img {
+    vertical-align: top;
+    width: 16px;
+    height: 16px;
     background-image: url('images/emblems.png');
     background-position: right top;
+.jxGridHeader .jxColSortable .jxGridCellContent {
+  margin-right: -16px; /* recenter the column heading text */
-.jxGridColumnSortedAsc span {
-    background-position: right -160px;
+.jxGridHeader .jxGridColumnSortedAsc img {
+    background-position: right -162px;
-.jxGridColumnSortedDesc span {
-    background-position: right -16px;
+.jxGridHeader .jxGridColumnSortedDesc img {
+    background-position: right -18px;
@@ -1572,13 +1702,46 @@
     cursor: col-resize;
+.jxColSortable .jxGridColumnResize {
+  right: 8px;
 .jxGridRowResize {
     left: 0px;
     bottom: 0px;
     height: 4px;
     width: 100%;
     cursor: row-resize;
+/* Editor Styles */
+.jxGridEditorPopup {
+  min-width: 130px;
+  margin: 3px;
+  font-size: 10px;
+  box-shadow: 2px 2px 5px #888; /* i really like the boxshadow */
+  -moz-box-shadow : 2px 2px 5px #888;
+  -webkit-box-shadow : 2px 2px 5px #888;
+  border-radius: 5px;
+  -moz-border-radius: 5px;
+  -webkit-border-radius: 5px;
+  background-color: #dddddd;
+  border: 1px solid #999999;
+.jxGridEditorPopupInnerWrapper {
+  height: 100%;
+  width: 100%;
 }.jxListView {
+  position:relative;
+  display: block;
+  list-style: none;
+  margin: 0px;
+  padding: 0px;
 .jxListView .jxListItemContainer {
@@ -1944,19 +2107,20 @@
     padding: 6px 26px 6px 10px;
-.jxNoticeError .jxNoticeItem {   background-color: #FBE3E4; color: #8a1f11; border-color: #FBC2C4; background-image: url(images/notice_error.png);}
+.jxNoticeError .jxNoticeItem { background-color: #FBE3E4; color: #8a1f11; border-color: #FBC2C4; background-image: url(images/notice_error.png);}
 .jxNoticeWarning .jxNoticeItem { background-color: #FFF6BF; color: #514721; border-color: #FFD324; background-image: url(images/notice_warning.png);}
 .jxNoticeSuccess .jxNoticeItem { background-color: #E6EFC2; color: #264409; border-color: #C6D880; background-image: url(images/notice_success.png);}
+.jxNoticeInformation .jxNoticeItem { background-color: #F8F8F8; color: #666666; border-color: #CCCCCC; background-image: url(images/notice.png);}
-.jxNoticeError .jxNotice {   color: #8a1f11; padding-left: 28px; }
+.jxNoticeError .jxNotice { color: #8a1f11; padding-left: 28px; }
 .jxNoticeWarning .jxNotice { color: #514721; padding-left: 28px; }
 .jxNoticeSuccess .jxNotice { color: #264409; padding-left: 28px; }
-.jxNoticeInfo .jxNotice { padding-left: 28px; }
+.jxNoticeInformation .jxNotice { color: #666666; padding-left: 28px; }
-.jxNoticeError .jxNoticeIcon {   background-position: 0px -32px; }
+.jxNoticeError .jxNoticeIcon { background-position: 0px -32px; }
 .jxNoticeWarning .jxNoticeIcon { background-position: 0px -16px; }
 .jxNoticeSuccess .jxNoticeIcon { background-position: 0px -48px; }
-.jxNoticeInfo .jxNoticeIcon {    background-position: 0px -64px; }
+.jxNoticeInformation .jxNoticeIcon { background-position: 0px -64px; }
 .jxNoticeClose {
     position: absolute;
@@ -1970,7 +2134,7 @@
  * @project         Jx
- * @revision        $Id: panel.css 302 2009-04-02 18:42:56Z fred.warnock $
+ * @revision        $Id: panel.css 716 2010-03-02 16:07:19Z fred.warnock $
@@ -2132,15 +2296,6 @@
-.jxPanelControls span.jxButtonContent,
-.jxPanelControls .jxButton:hover span.jxButtonContent,
-.jxPanelControls .jxButton:active span.jxButtonContent,
-.jxPanelControls .jxButtonActive span.jxButtonContent,
-.jxPanelControls .jxButtonActive:hover span.jxButtonContent,
-.jxPanelControls .jxButtonActive:active span.jxButtonContent,
-.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,
-.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,
-.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,
 .jxPanelControls .jxButton:active ,
@@ -2157,16 +2312,7 @@
-.jxPanelControls .jxButtonMenu span.jxButtonContent,
-.jxPanelControls .jxButtonFlyout span.jxButtonContent {
-.jxPanelControls .jxButtonMenu span.jxButtonContent span,
-.jxPanelControls .jxButtonFlyout span.jxButtonContent span {
@@ -2205,48 +2351,170 @@
  * progress bar classes
 .jxProgressBar-container {
+    display: block;
     width: 100%;
-    display: block;
-    clear: both;
 .jxProgressBar-message {
+    display: block;
     color: black;
+    font-family: Arial, Helvetica, sans-serif;
+    font-size: 12px;
+    line-height: 20px;
-.jxProgressBar-container .jxProgressBar {
+.jxProgressBar {
+    display: block;
     width: 100%;
-    clear: both;
-    border-top: none;
+    height: 20px;
+    border: none;
+    margin: 0px;
+    padding: 0px;
-.jxProgressBar-container .jxProgressBar .jxProgressBar-outline {
-    border: 1px solid #336600;
+.jxProgressBar-outline {
     position: absolute;
+    display: block;
     top: 0px;
     left: 0px;
     z-index: 10;
+    height: 20px;
+    border-left: 1px solid #cbc8c8;
+    border-right: 1px solid #cbc8c8;
+    background-image: url(images/progressbar.png);
+    background-position: 0px -140px;
+    width: 100%;
-.jxProgressBar-container .jxProgressBar .jxProgressBar-fill {
-    background-color: #99cc66;
+.jxProgressBar-fill {
     position: absolute;
-    top: 1px;
-    left: 1px;
+    display: block;
+    top: 0px;
+    left: 0px;
     z-index: 20;
+    height: 20px;
+    border: none;
+    background-position: 0px 0px;
-.jxProgressBar-container .jxProgressBar .jxProgressBar-text {
-    color: #336600;
-    margin: 0px;
-    padding: 2px;
+.jxProgressStarting .jxProgressBar-fill {
+    border: none;
+.jxProgressWorking .jxProgressBar-fill {
+    border-left: 1px solid #49afe8;
+.jxProgressFinished .jxProgressBar-fill {
+    border-right: 1px solid #49afe8;
+.jxProgressBar-text {
     position: absolute;
-    top: 1px;
+    display: block;
+    overflow: visible;
+    top: 0px;
     left: 1px;
     width: auto;
+    height: 20px;
     z-index: 30;
     border: none;
+    margin: 0px;
+    padding: 0px 0px 0px 4px;
+    font-size: 12px;
+.jxHasVerticalScrollbar,
+.jxHasHorizontalScrollbar {
+    overflow: hidden;
+.jxScrollbarChildWrapper {
+    overflow: hidden;
+.jxHasVerticalScrollbar {
+    padding-right: 25px;
+.jxHasVerticalScrollbar .jxScrollbarContainer {
+    right: 0;
+    top: 0;
+    width: 20px;
+    height: 100%;
+    border: none;
+    border-left: 1px solid black;
+.jxHasVerticalScrollbar .jxScrollLeft,
+.jxHasVerticalScrollbar .jxScrollRight {
+    width: 20px;
+    height: 20px;
+    display: block;
+    background-color: blue;
+.jxHasVerticalScrollbar .jxSliderContainer {
+    height: 100%;
+    width: 20px;
+    border: none;
+    padding-bottom: 25px;
+.jxHasHorizontalScrollbar .jxScrollbarContainer {
+    bottom: 0;
+    left: 0;
+    height: 20px;
+    width: 100%;
+    border: none;
+    border-top: 1px solid black;
+.jxHasHorizontalScrollbar .jxScrollLeft,
+.jxHasHorizontalScrollbar .jxScrollRight {
+    width: 20px;
+    height: 20px;
+    display: block;
+.jxHasHorizontalScrollbar .jxScrollLeft {
+    float: left;
+    float: right;
+.jxHasHorizontalScrollbar .jxSlider {
+    float: left;
+.jxHasHorizontalScrollbar .jxSliderContainer {
+    height: 20px;
+    width: 100%;
+    border: none;
+.jxHasVerticalScrollbar .jxSliderKnob,
+.jxHasHorizontalScrollbar .jxSliderKnob {
+    width: 20px;
+    height: 20px;
+    background-color: black;
+    cursor: pointer;
  * Slider classes
@@ -2357,7 +2625,7 @@
   background-color: #aaa;
  * @project         Jx
- * @revision        $Id: tab.css 615 2009-11-19 22:01:38Z fred.warnock $
+ * @revision        $Id: tab.css 875 2010-04-24 06:10:53Z fred.warnock $
@@ -2375,8 +2643,7 @@
      the position need to be explicitly set, as well as the width and height. */
   /* Base setup */
   position: relative;
-  display: -moz-inline-box;
-  display: inline-block;
+  display: block;
   overflow: hidden;
   width: 200px;
@@ -2386,7 +2653,7 @@
-.jxTabSetContainer  .jxToolbarContainer {
+.jxTabSetContainer  .jxBarContainer {
   /* Base setup */
   z-index: auto;
@@ -2512,18 +2779,29 @@
 /* HORIZONTALTAB BAR - TOP and BOTTOM TABS */
-.jxBarTop div.jxTabContainer,
-.jxBarBottom div.jxTabContainer {
+.jxTabBarTop .jxBarWrapper,
+.jxTabBarBottom .jxBarWrapper {
+  padding-left: 2px;
+.jxBarTop span.jxTabContainer,
+.jxBarBottom span.jxTabContainer {
   /* Base setup */
+  margin-right: -1px;
+  padding: 2px 0px;
 .jxBarTop a.jxTab,
-.jxBarTop span.jxTabContent {
+.jxBarTop span.jxTabContent,
+.jxTabBarTop .jxBarControls a.jxButton,
+.jxTabBarTop .jxBarControls span.jxButtonContent{
   background-image: url(images/tab_top.png);
-.jxBarBottom span.jxTabContent {
+.jxBarBottom span.jxTabContent,
+.jxTabBarBottom .jxBarControls a.jxButton,
+.jxTabBarBottom .jxBarControls span.jxButtonContent {
   background-image: url(images/tab_bottom.png);
@@ -2683,11 +2961,19 @@
 /* VERTICAL TAB BAR - LEFT and RIGHT */
+.jxTabBarLeft .jxBarWrapper,
+.jxTabBarRight .jxBarWrapper {
+  padding-top: 2px;
 .jxBarRight span.jxTabContainer {
   /* Base setup */
+  margin-bottom: -1px;
+  padding: 0px 2px;
 .jxBarLeft a.jxTab,
 .jxBarLeft span.jxTabContent {
   background-image: url(images/tab_left.png);
@@ -2836,7 +3122,7 @@
  * @project         Jx
- * @revision        $Id: toolbar.css 289 2009-04-01 18:09:24Z pagameba $
+ * @revision        $Id: toolbar.css 912 2010-05-21 21:33:08Z pagameba $
@@ -2909,26 +3195,29 @@
   background-position: left 0px;
 .jxBarBottom .jxBarScroller {
-  /* much bigger than its container */
-  width: 10000%;
+  float: left;
+  height: 28px;
   overflow: hidden;
+  z-index: 0;
-.jxBarTop .jxBarScrollLeft,
-.jxBarBottom .jxBarScrollLeft {
-  top: 0px;
-  left: 0px;
+.jxBarTop .jxBarScroller .jxBarWrapper,
+.jxBarBottom .jxBarScroller .jxBarWrapper {
+  float: left;
+  height: 28px;
+  overflow: hidden;
+  width: 10000%;
-.jxBarTop .jxBarScrollRight,
-.jxBarBottom .jxBarScrollRight {
-  top: 0px;
-  right: 0px;
+.jxBarTop .jxBarControls .jxButtonContainer,
+.jxBarBottom .jxBarControls .jxButtonContainer {
+  /* float: right; */
+  z-index: 1;
+  padding: 2px 0px;
+  margin-left: -1px;
@@ -2943,6 +3232,13 @@
+.jxBarControls {
+    float: right;
+    font-size: 0px;
+    line-height: 0px;
 /* The jx toolbar and tabbar are both built out of a UL
    The margins/padding are flattened out, and the list markers are hidden
    UL's are floated left so multiple toolbars can be in the samae row.
@@ -2963,6 +3259,7 @@
   display: block;
   position: relative;
   float: left;
+  clear: none;
   list-style-type: none;
   margin: 0px;  /* margins don't seem to work properly in IE */
@@ -2985,12 +3282,17 @@
   float: left;
   font-size: 0px;
   line-height: 0px;
   padding: 0px;
   border: none;
+/* inputs in toolbars wrap in IE */
+li.jxToolItem .jxInputWrapper {
 /* Seperator height should match that of button images
    and the margins+padding+border should add up to the same total too. */
@@ -3038,7 +3340,28 @@
   clear: both;
+/* Aligning options */
+.jxToolbarAlignLeft ul {
+    float: left;
+.jxToolbarAlignRight ul {
+    float: right;
+.jxToolbarAlignCenter {
+.jxToolbarAlignCenter ul {
+    float: none;
+.jxToolbarAlignCenter ul li {
+    float: none;
+    display: inline;
  * Tooltip classes
 .jxTooltip {
@@ -3052,7 +3375,7 @@
  * @project         Jx
- * @revision        $Id: tree.css 602 2009-11-10 19:41:36Z pagameba $
+ * @revision        $Id: tree.css 755 2010-03-15 03:09:37Z jonlb at comcast.net $
@@ -3252,25 +3575,32 @@
+img.jxTreeImage.jxBusy {
+	background-image: url(images/spinner_16.gif);
+    background-position: left top;
 /* FileUploadPanel */
 .jxFileUploadPanel {
     padding: 5px;
 .jxFileUploadPanel .jxInputContainer {
-    width: 300px;
+    /*width: 300px;*/
 .jxUploadQueue {
-    width: 100%;
-    margin-top: 10px;
+    /*width: 100%;*/
+    /*margin-top: 10px;*/
-.jxUploadQueue div {
+.jxUploadQueue li {
+    display: block;
     position: relative;
-    width: 95%;
-    clear: both;
-    border-top: 1px solid black;
+    overflow: hidden;
+    /*width: 95%;*/
+    /*clear: both;*/
+    /*border-top: 1px solid black;*/
     padding: 2px;
@@ -3278,43 +3608,51 @@
     display: block;
-.jxUploadQueue div span.jxUploadFileName {
-    float: left;
-    font-size: 16px;
+.jxUploadQueue li span.jxUploadFileName {
+    /*float: left;*/
+    font-size: 12px;
-.jxUploadQueue div span.jxUploadFileDelete,
-.jxUploadQueue div span.jxUploadFileProgress,
-.jxUploadQueue div span.jxUploadFileComplete,
-.jxUploadQueue div span.jxUploadFileError {
-    float: right;
+.jxUploadQueue li span.jxUploadFileDelete,
+.jxUploadQueue li span.jxUploadFileProgress,
+.jxUploadQueue li span.jxUploadFileComplete,
+.jxUploadQueue li span.jxUploadFileError {
+    /*float: right;*/
+    top: 2px;
+    right: 2px;
     width: 16px;
     height: 16px;
-    background-position: top left;
     cursor: pointer;
-.jxUploadQueue div span.jxUploadFileDelete {
-    background-image: url('images/delete.gif');
+.jxUploadQueue li span.jxUploadFileDelete {
+    background-image: url('images/icons.png');
+    background-position: 0px -128px;
-.jxUploadQueue div span.jxUploadFileProgress {
-    background-image: url('images/loading.gif');
+.jxUploadQueue li span.jxUploadFileProgress {
+    background-image: url('images/spinner_16.gif');
+    background-position: top left;
-.jxUploadQueue div span.jxUploadFileComplete {
-    background-image: url('images/green_tick.png');
+.jxUploadQueue li span.jxUploadFileComplete {
+    background-position: 0px -48px;
-    background-image: url('images/error.png');
+    background-position: 0px -32px;
 .jxUploadFileErrorTip {
   padding: 4px 4px 4px 20px;
   border: 2px solid #ddd;
-  background: url("images/error.png") no-repeat left top;
+  background: url("images/icons.png") no-repeat 0px -32px;
   color: black;
   width: 100px;
Modified: trunk/templates/mapguide/standard/themes/delicious/ie6.css
--- trunk/templates/mapguide/standard/themes/delicious/ie6.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/delicious/ie6.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -1,6 +1,6 @@
  * @project         Jx
- * @revision        $Id: ie6.css 321 2009-04-06 18:23:39Z fred.warnock $
+ * @revision        $Id: ie6.css 935 2010-05-28 17:36:13Z fred.warnock $
@@ -18,9 +18,12 @@
  * Please note that IE8 changed how filters are written.
 .jxChromeDrag {filter: Alpha(opacity=50);}
-.jxDialogModal {filter: Alpha(opacity=20);}
 .jxDisabled {filter:Alpha(opacity=40);}
 .jxDisabled * {filter:Alpha(opacity=40);}
+.jxMask {filter:Alpha(opacity=50);}
+.jxModalMask {filter: Alpha(opacity=20);}
+.jxSpinner {filter: alpha(opacity=50);}
 iframe.jxIframeShim {filter:Alpha(opacity:0);}
 /* List items do not render properly under several conditions.
@@ -52,6 +55,7 @@
   outline: expression(hideFocus='true');
+ul.jxToolbar .jxButton:active span.jxButtonContent,
 .jxButton:active span.jxButtonContent {
   background-position: right -96px;
@@ -62,6 +66,7 @@
   background-position: left -144px;
+ul.jxToolbar .jxButtonActive:active span.jxButtonContent,
 .jxButtonActive:active span.jxButtonContent {
   background-position: right -144px;
@@ -72,6 +77,7 @@
   background-position: left -120px;
+ul.jxToolbar .jxButtonPressed:active span.jxButtonContent,
 .jxButtonPressed:active span.jxButtonContent {
   background-position: right -120px;
Modified: trunk/templates/mapguide/standard/themes/delicious/ie7.css
--- trunk/templates/mapguide/standard/themes/delicious/ie7.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/delicious/ie7.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -1,6 +1,6 @@
  * @project         Jx
- * @revision        $Id: ie7.css 321 2009-04-06 18:23:39Z fred.warnock $
+ * @revision        $Id: ie7.css 979 2010-09-08 19:34:36Z pagameba $
@@ -18,9 +18,11 @@
 /* tree item focus style */
@@ -33,6 +35,14 @@
+.jxTree,
+.jxTreeRoot,
+.jxTreeNest,
+li.jxTreeContainer {
+ /* zoom needed to fix alignment/sizing issues in IE 7 */
+ zoom: 1;
 /* IE versions 7 and below do not recognize the focus pseudo-class, but instead
  * use the active pseudo-class.  Other browsers use the active-pseudo-class
  * while something is being pressed so IE specific definitions are needed. */
@@ -43,6 +53,7 @@
@@ -53,6 +64,7 @@
@@ -63,6 +75,7 @@
Modified: trunk/templates/mapguide/standard/themes/delicious/images/button_combo.png
(Binary files differ)
Modified: trunk/templates/mapguide/standard/themes/delicious/images/emblems.png
Modified: trunk/templates/mapguide/standard/themes/delicious/images/icons.png
Modified: trunk/templates/mapguide/standard/themes/delicious/images/panel_controls.png
Modified: trunk/templates/mapguide/standard/themes/delicious/images/tab_bottom.png
Modified: trunk/templates/mapguide/standard/themes/delicious/images/tab_close.png
Modified: trunk/templates/mapguide/standard/themes/delicious/images/tab_left.png
Modified: trunk/templates/mapguide/standard/themes/delicious/images/tab_right.png
Modified: trunk/templates/mapguide/standard/themes/delicious/images/tab_top.png
Modified: trunk/templates/mapguide/standard/themes/delicious/jxtheme.css
--- trunk/templates/mapguide/standard/themes/delicious/jxtheme.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/delicious/jxtheme.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -21,4 +21,4 @@
  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
  * DEALINGS IN THE SOFTWARE.
- */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;displ
 ay:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:4px 4px 4px 0;border:none;background-image:url(images/button.png);background-position:right -24px;background-repeat:no-repeat;}ul.jxToolbar span.jxButtonContent{background-position:right top;}ul.jxToolbar .jxButtonActive,.jxButtonActive{background-position:left -72px;}ul.jxToolbar .jxButtonActive span.jxButtonContent,.jxButtonActive span.jxButtonContent{background-position:right -72px;}ul.jxToolbar .jxButton:focus,.jxButton:focus{background-position:left -96px;}ul.jxToolbar .jxButton:focus span.jxButtonContent,.jxButton:focus span.jxButtonContent{background-position:right -96px;}ul.jxToolbar .jxButtonActive:focus,.jxButtonActive:focus{background-position:left -144px;}ul.jxToolbar .jxButtonActive:focus span.jxButtonContent,.jxButtonActive:focus span.jxButtonContent{background-position:right -144px;}ul.jxToolbar .jxButton:hover,ul.jxToolbar .jxButtonActive:hover,.jxButton:hover,.jxButtonActive:hover{b
 ackground-position:left -48px;}ul.jxToolbar .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxButtonActive:hover span.jxButtonContent,.jxButton:hover span.jxButtonContent,.jxButtonActive:hover span.jxButtonContent{background-position:right -48px;}ul.jxToolbar .jxButtonPressed,ul.jxToolbar .jxButtonPressed:focus,.jxButtonPressed,.jxButtonPressed:focus{background-position:left -120px;}ul.jxToolbar .jxButtonPressed span.jxButtonContent,ul.jxToolbar .jxButtonPressed:focus span.jxButtonContent,.jxButtonPressed span.jxButtonContent,.jxButtonPressed:focus span.jxButtonContent{background-position:right -120px;}.jxDisabled .jxButton,.jxDisabled span.jxButtonContent span{cursor:default;}ul.jxToolbar .jxDisabled .jxButton:focus,ul.jxToolbar .jxDisabled .jxButton:active,ul.jxToolbar .jxDisabled .jxButton:hover,ul.jxToolbar .jxDisabled .jxButtonPressed{background-position:left top;}.jxDisabled .jxButton:focus,.jxDisabled .jxButton:active,.jxDisabled .jxButton:hover,.jxDisabled .jxButt
 onPressed{background-position:left -24px;}ul.jxToolbar .jxDisabled .jxButton:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:active span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButton:hover span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right top;}.jxDisabled .jxButton:focus span.jxButtonContent,.jxDisabled .jxButton:active span.jxButtonContent,.jxDisabled .jxButton:hover span.jxButtonContent,.jxDisabled .jxButtonPressed span.jxButtonContent{background-position:right -24px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus,ul.jxToolbar .jxDisabled .jxButtonActive:active,ul.jxToolbar .jxDisabled .jxButtonActive:hover,.jxDisabled .jxButtonActive:focus,.jxDisabled .jxButtonActive:active,.jxDisabled .jxButtonActive:hover{background-position:left -72px;}ul.jxToolbar .jxDisabled .jxButtonActive:focus span.jxButtonContent,ul.jxToolbar .jxDisabled .jxButtonActive:active span.jxButtonContent,ul.jxToolbar .jxDisab
 led .jxButtonActive:hover span.jxButtonContent,.jxDisabled .jxButtonActive:focus span.jxButtonContent,.jxDisabled .jxButtonActive:active span.jxButtonContent,.jxDisabled .jxButtonActive:hover span.jxButtonContent{background-position:right -72px;}img.jxButtonIcon{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxButtonContent span{display:-moz-inline-box;display:inline-block;position:relative;vertical-align:middle;cursor:pointer;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;height:16px;white-space:nowrap;}span.jxButtonContent span.jxButtonLabel{margin:0;padding:0 4px 0 4px;color:#000;font-size:11px;}.jxDiscloser span.jxButtonContent{padding-right:0;}.jxDiscloser span.jxButtonContent span{padding-right:16px;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose{
 position:absolute;display:-moz-inline-box;display:inline-block;padding:4px 0;font-size:0;line-height:0;right:2px;top:2px;background-image:url(images/button_multi_disclose.png);background-position:right 0;background-repeat:no-repeat;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxButtonDisclose img{width:16px;height:16px;margin:0;padding:0;border:0;background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}a.jxButtonDisclose:focus,a.jxButtonDisclose:active{background-position:right -96px;}a.jxButtonDisclose:hover{background-position:right -48px;}a.jxButtonDisclosePressed{background-position:right -120px;}.jxDisabled a.jxButtonDisclose,.jxDisabled a.jxButtonDisclose:focus,.jxDisabled a.jxButtonDisclose:active,.jxDisabled a.jxButtonDisclose:hover,.jxDisabled a.jxButtonDisclosePressed{cursor:default;background-position:right 0;}ul.jxToolbar .jxButtonHover{background-position:left -24px!important;}ul.jxTo
 olbar .jxButtonHover span.jxButtonContent{background-position:right -24px!important;}.jxFlyout .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxFlyout{position:absolute;display:block;z-index:100;margin:0;padding:0;}.jxFlyoutContent{position:relative;display:block;overflow:auto;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}.jxButtonMulti,.jxButtonMulti span.jxButtonContent{background-image:url(images/button_multi.png);}.jxButtonEditCombo,.jxButtonEditCombo span.jxButtonContent{background-image:url(images/button_combo.png);}.jxButtonMulti span.jxButtonContent span{padding-right:21px;}.jxButtonEditCombo span.jxButtonContent span{font-size:0;}.jxButtonComboDefault span.jxButtonContent span,.jxButtonComboDefault input{font-style:italic;color:#999;}.jxButtonEditCombo input{float:left;line-height:16px;height:16px;padding:0 4px;margin:0;border:none;font-size:11px;font-family:Arial,Helvetica,sans-serif;background-color:transpa
 rent;}.jxChrome{position:absolute;display:block;font-size:0;line-height:0;z-index:-1;width:100%;height:100%;top:0;left:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxChromeDrag{opacity:.5;-ms-filter:"Alpha(opacity=50)";}.jxChromeTL{position:absolute;overflow:hidden;left:0;top:0;width:50%;height:50%;}.jxChromeTR{position:absolute;overflow:hidden;left:50%;top:0;width:50%;height:50%;}.jxChromeBL{position:absolute;overflow:hidden;left:0;top:50%;width:50%;height:50%;}.jxChromeBR{position:absolute;overflow:hidden;left:50%;top:50%;width:50%;height:50%;}.jxChromeTL img{position:absolute;top:0;left:0;width:1000px;height:600px;}.jxChromeTR img{position:absolute;top:0;right:0;width:1000px;height:600px;}.jxChromeBL img{position:absolute;bottom:0;left:0;width:1000px;height:600px;}.jxChromeBR img{position:absolute;bottom:0;right:0;width:1000px;height:600px;}.jxColorBar{position:relative;overflow:hidden;}table.jxColorGrid{position:relative;border-collapse:collapse;emp
 ty-cells:show;clear:both;padding:0;margin:0;}.jxColorGrid tr{padding:0;margin:0;}.jxColorGrid td{border:1px solid #000;padding:0;margin:0;}.jxColorGrid td.emptyCell{border:0 solid #000;}.jxColorGrid td.emptyCell span{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;padding:1px;margin:0;}.jxColorGrid a.colorSwatch{display:block;width:7px;height:7px;line-height:0;font-size:0;border:0 solid #000;margin:0;padding:1px;}.jxColorGrid a.borderWhite:hover{border:1px solid #fff;padding:0;}.jxColorGrid a.borderBlack:hover{border:1px solid #000;padding:0;}input.jxHexInput{width:55px;vertical-align:middle;}input.jxAlphaInput{width:30px;vertical-align:middle;}div.jxColorPreview{float:left;position:relative;width:20px;height:20px;border:1px solid #000;margin:2px;vertical-align:middle;background-image:url('images/grid.png');overflow:hidden;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch{display:block;float:left;width:14px;height:14px;border:1px soli
 d #000;background-image:url('images/grid.png');background-position:0 0;background-repeat:repeat;padding-right:0!important;}.jxButtonFlyout span.jxButtonContent span.jxButtonSwatch span{display:block;width:14px;height:14px;position:absolute;padding-right:0;background:none;}div.jxColorPreview img{position:absolute;z-index:0;}div.jxColorPreview div{width:20px;height:10px;position:absolute;display:block;left:0;z-index:1;font-size:10px;line-height:0;}div.jxColorPreview div.jxColorSelected{top:0;}div.jxColorPreview div.jxColorHover{bottom:0;}label.jxColorLabel,label.jxAlphaLabel{width:auto;font-family:Arial,sans-serif;font-size:11px;line-height:24px;padding:2px;vertical-align:middle;}a.jxColorClose{position:absolute;top:0;right:0;width:16px;height:16px;}a.jxColorClose img{width:16px;height:16px;}.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}.jxDisabled{opacity:.4;-ms-filter:"Alpha(opacity=40)";}.jxDi
 sabled *{-ms-filter:"Alpha(opacity=40)";}iframe.jxIframeShim{position:absolute;top:0;left:0;width:100%;height:100%;opacity:0;-ms-filter:"Alpha(opacity=0)";z-index:-1;}@CHARSET "ISO-8859-1";.jxConfirmQuestion{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;}.jxDialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogModal{position:absolute;display:block;top:0;left:0;width:100%;height:100%;background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bot
 tom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollap
 se img{background-position:0 -16px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls span.jxButtonContent,.jxDialogControls .jxButton:hover span.jxButtonContent,.jxDialogControls .jxButton:active span.jxButtonContent,.jxDialogControls .jxButtonActive span.jxButtonContent,.jxDialogControls .jxButtonActive:hover span.jxButtonContent,.jxDialogControls .jxButtonActive:active span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDialogControls .jxDisabled .jxButton,.jxDialogControls .jxDis
 abled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent,.jxDialogControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxDialogControls .jxButtonMenu span.jxButtonContent span,.jxDialogControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{wi
 dth:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:6px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0;z-index:2;margin-top:3px;height:35px;width:100%;}.jxForm{display:block;position:relative;overflow:hidden;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;overflow:hidden;border:1px solid #ccc;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.
 jxInputText,.jxInputPassword,.jxInputTextarea{margin:0 4px;padding:4px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus{border:1px solid #000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldError .jxInputText,.jxFieldError .jxInputPassword,.jxFieldError .jxInputTextarea,.jxFieldError .jxInputSelect{background-color:#FBE3E4;color:
 #8a1f11;border-color:#FBC2C4;}.jxFieldSuccess .jxInputText,.jxFieldSuccess .jxInputPassword,.jxFieldSuccess .jxInputTextarea,.jxFieldSuccess .jxInputSelect{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldError .jxInputText:focus,.jxFieldError .jxInputPassword:focus,.jxFieldError .jxInputTextarea:focus,.jxFieldError .jxInputSelect:focus{border-color:#8a1f11;}.jxFieldSuccess .jxInputText:focus,.jxFieldSuccess .jxInputPassword:focus,.jxFieldSuccess .jxInputTextarea:focus,.jxFieldSuccess .jxInputSelect:focus{border-color:#264409;}.jxFieldError .jxInputLabel,.jxFieldError .jxInputTag{color:#8a1f11;}.jxFieldSuccess .jxInputLabel,.jxFieldSuccess .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxIn
 putTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}.jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInput
 ContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;wid
 th:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormInlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridHeader{width:100%;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;}.jxGridColHeadHide{height:0;line-height:0;font-size:0;background-color:#fff;white-space:normal;}.jxGridColHeadHide p,.jxGridRowHeadHide p{font-size:0;line-height:0;height:0;margin:0;padding:0;}.jxGridRowHeadHide{width:0;white-space:normal;}.jxGridCel
 l{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding-left:3px;padding-right:3px;overflow:hidden;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;font-weight:bold;color:#333;cursor:default;padding-left:3px;padding-right:3px;white-space:nowrap;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;font-w
 eight:bold;color:#333;cursor:default;overflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td{background-color:#f7f7f7;}td.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td{background-color:#e5f1ff;}td.jxGridCellPrelight{background-color:#cce3ff;}.jxColSortable{padding-right:20px;}.jxGridCell.jxColSortable{padding-right:0;}.jxColSortable span{background-image:url('images/emblems.png');padding-right:20px;background-repeat:no-repeat;background-position:right top;}.jxGridColumnSortedAsc span{background-positio
 n:right -160px;}.jxGridColumnSortedDesc span{background-position:right -16px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px do
 tted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;ove
 rflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a.jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisable
 d a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButtonSubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.j
 xMenuItemIcon,.jxMenuItemToggleSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemToggleSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background-repeat:repeat-x;background-position:left center;}@CHARSET "ISO-8859-1";.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxNoticeListContainer{border:none;padding:0;margin:0;font-size:0;line-height:0;z-index:500;}.jxNoticeList{position:relative;}.jxNoticeItemContainer{position:relative;overflow:hidden;}.jxNoticeItemContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxHasChrome .jxNoticeItem{margin:6px 6px 8px 7px;}.jxNoticeItem{position:relative;border:2px solid #c
 cc;margin:0;padding:0;background-color:#f8f8f8;background-image:url(images/notice.png);background-repeat:repeat-x;background-position:left bottom;}.jxNoticeIcon{position:absolute;top:0;left:0;margin:6px;width:16px;height:16px;background-image:url(images/icons.png);background-repeat:no-repeat;background-position:0 0;}.jxNotice{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:18px;color:#666;margin:0;border:none;padding:6px 26px 6px 10px;}.jxNoticeError .jxNoticeItem{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;background-image:url(images/notice_error.png);}.jxNoticeWarning .jxNoticeItem{background-color:#FFF6BF;color:#514721;border-color:#FFD324;background-image:url(images/notice_warning.png);}.jxNoticeSuccess .jxNoticeItem{background-color:#E6EFC2;color:#264409;border-color:#C6D880;background-image:url(images/notice_success.png);}.jxNoticeError .jxNotice{color:#8a1f11;padding-left:28px;}.jxNoticeWarning .jxNotic
 e{color:#514721;padding-left:28px;}.jxNoticeSuccess .jxNotice{color:#264409;padding-left:28px;}.jxNoticeInfo .jxNotice{padding-left:28px;}.jxNoticeError .jxNoticeIcon{background-position:0 -32px;}.jxNoticeWarning .jxNoticeIcon{background-position:0 -16px;}.jxNoticeSuccess .jxNoticeIcon{background-position:0 -48px;}.jxNoticeInfo .jxNoticeIcon{background-position:0 -64px;}.jxNoticeClose{position:absolute;top:0;right:0;margin:6px;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select
 :none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-positio
 n:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls span.jxButtonContent,.jxPanelControls .jxButton:hover span.jxButtonContent,.jxPanelControls .jxButton:active span.jxButtonContent,.jxPanelControls .jxButtonActive span.jxButtonContent,.jxPanelControls .jxButtonActive:hover span.jxButtonContent,.jxPanelControls .jxButtonActive:active span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonActive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabl
 ed .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent,.jxPanelControls .jxButtonFlyout span.jxButtonContent{background-image:none;}.jxPanelControls .jxButtonMenu span.jxButtonContent span,.jxPanelControls .jxButtonFlyout span.jxButtonContent span{padding-right:0;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}@CHARSET "ISO-8859-1";.jxProgressBar-container{width:100%;display:block;clear:both;}.jxProgressBar-message{color:black;}.jxProgressBar-container .jxProgressBar{width:100%;clear:both;border-top:none;}.jxProgressBar-container .jxProgress
 Bar .jxProgressBar-outline{border:1px solid #360;position:absolute;top:0;left:0;z-index:10;}.jxProgressBar-container .jxProgressBar .jxProgressBar-fill{background-color:#9c6;position:absolute;top:1px;left:1px;z-index:20;}.jxProgressBar-container .jxProgressBar .jxProgressBar-text{color:#360;margin:0;padding:2px;position:absolute;top:1px;left:1px;width:auto;z-index:30;border:none;}@CHARSET "ISO-8859-1";.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:10
 0%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag{background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxToolbarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}span.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:-moz-inline-box;display:inline-block;position:relative;cursor:poin
 ter;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:-moz-inline-box;display:inline-block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-repeat;}img.jxTabIcon{display:-moz-inline-box;display:inline-block;position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:-moz-inline-box;display:inline-block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisable
 d a.jxTabClose{cursor:default;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:5px;right:5px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:focus span.jxTabContent{background-position:right -
 96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabContent{background-position:right -120px;}.jxBarTop .jxD
 isabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBottom .jxDisabled a.jxTabActive:focus,.jxBarBottom .
 jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{vertical-align:middle;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{vertical-align:middle;height:16px;padding:0 4px 0 4px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(images/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:5px;left:5px;}.jxBarLeft .jxTabClose span.jxTabContent
 ,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBarLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRigh
 t a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLeft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBar
 Left .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActi
 ve:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:auto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repea
 t:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{position:absolute;width:10000%;overflow:hidden;}.jxBarTop .jxBarScrollLeft,.jxBarBottom .jxBarScrollLeft{position:absolute;top:0;left:0;}.jxBarTop .jxBarScrollRight,.jxBarBottom .jxBarScrollRight{position:absolute;top:0;right:0;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollRight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;padding:0;mar
 gin:0;border:none;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolbar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:lef
 t top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer
 a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeItem:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTr
 eeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}.jxFileUploadPanel{padding:5px;}.jxFileUploadPanel .jxInputContainer{width:300px;}.jxUploadQueue{width:100%;margin-top:10px;}.jxUploadQueue div{position:relative;width:95%;clear:both;border-top:1px solid black;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue div span.jxUploadFileName{float:left;font-size:16px;}.jxUploadQueue div span.jxUploadFileDelete,.jxUploadQueue div span.jxUploadFileProgress,.jxUploadQueue div span.jxUploa
 dFileComplete,.jxUploadQueue div span.jxUploadFileError{float:right;width:16px;height:16px;background-repeat:no-repeat;background-position:top left;cursor:pointer;}.jxUploadQueue div span.jxUploadFileDelete{background-image:url('images/delete.gif');}.jxUploadQueue div span.jxUploadFileProgress{background-image:url('images/loading.gif');}.jxUploadQueue div span.jxUploadFileComplete{background-image:url('images/green_tick.png');}.jxUploadQueue div span.jxUploadFileError{background-image:url('images/error.png');}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/error.png") no-repeat left top;color:black;width:100px;}
\ No newline at end of file
+ */body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}table{border-collapse:collapse;border-spacing:0;}fieldset,img{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul{list-style:none;}caption,th{text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}.jxButtonContainer{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:2px;border:none;}.jxButton{display:-moz-inline-box;display:inline-block;position:relative;font-size:0;line-height:0;margin:0;padding:0 0 0 4px;border:none;background-image:url(images/button.png);background-position:left -24px;background-repeat:no-repeat;text-decoration:none;outline:none;}a.jxButton{cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;}ul.jxToolbar .jxButton{background-position:left top;}span.jxButtonContent{display:-moz-inline-box;displ
 sabled *{-ms-filter:"Alpha(opacity=40)";}.jxMask{opacity:.5;-ms-filter:"Alpha(opacity=50)";background-color:#fff;}.jxModalMask{background-color:#000;opacity:.2;-ms-filter:"Alpha(opacity=20)";}.jxEventMask{background-image:url(images/a_pixel.png);}.jxSpinner{position:absolute;opacity:.5;-ms-filter:"Alpha(opacity=50)";z-index:999;background:#fff;}.jxSpinnerMessage{text-align:center;font-weight:bold;}.jxSpinnerSmall .jxSpinnerMessage{margin:0;padding:0;font-size:11px;line-height:24px;}.jxSpinnerLarge .jxSpinnerImage{background:url(images/spinner_24.gif) no-repeat;width:24px;height:24px;margin:0 auto;}.jxSpinnerSmall .jxSpinnerImage{background:url(images/spinner_16.gif) no-repeat;width:16px;height:16px;margin-right:4px;display:inline-block;vertical-align:middle;}.jxConfirmQuestion,.jxPrompt{text-align:center;padding:10px;margin-top:10px;}.jxDialog .jxChrome{background-image:url(images/dialog_chrome.png);}.jxDialog{display:block;z-index:1000;overflow:hidden;visibility:hidden;}.jx
 DialogContentContainer{z-index:1;margin:0 11px 13px 12px;border:1px solid #b7b7b7;background-color:#f0f0f0;}.jxDialogContent{display:block;position:relative;overflow:auto;padding:0;z-index:1;}.jxDialogTitle{display:block;position:relative;background-image:url(images/a_pixel.png);text-align:center;height:24px;line-height:24px;z-index:1;margin:6px 6px 0 7px;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxDialogMin .jxDialogTitle{margin-bottom:8px;}.jxDialogMoveable,.jxDialogMoveable .jxDialogLabel{cursor:move;}.jxDialogIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxDialogLabel{font-family:Arial,Helvetica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;cursor:default;}.jxDialogResize{position:absolute;bottom:7px;right:6px;width:16px;height:16px;z-index:2;border:0;cursor:se-resize;background-image:url(images/dialog_resize.png);}.jxDialogControls{position:absolute;top:3
 px;right:2px;height:16px;width:80px;}.jxDialogControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxDialogClose img{background-position:0 -32px;}.jxDialogMenu img{background-position:0 -48px;}.jxDialogHelp img{background-position:0 -64px;}.jxDialogCollapse img{background-position:0 -16px;}.jxDialogMin .jxDialogCollapse img{background-position:0 0;}.jxDialogMax .jxDialogCollapse img{background-position:0 -16px;}.jxDialogMaximize img{background-position:0 -80px;}.jxDialogMaximized .jxDialogMaximize img{background-position:0 -96px;}.jxDialogLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxDialogControls .jxButtonContainer,.jxDialogControls .jxButton,.jxDialogControls .jxButton:hover,.jxDialogControls .jxButton:active,.jxDialogControls .jxButtonActive,.jxDialogControls .jxButtonActive:hover,.jxDialogControls .jxButtonActive:active,.jxDial
 ogControls .jxDisabled .jxButton,.jxDialogControls .jxDisabled .jxButton:hover,.jxDialogControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxDialogControls .jxBarContainer{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxDialogControls .jxBarScroller{left:auto;right:0;}.jxDialogControls ul.jxToolbar{float:right;}.jxDialogControls ul.jxToolbar,.jxDialogControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}div.jxFileInputs{position:relative;}div.jxFileFake{position:absolute;top:0;left:0;z-index:1;}div.jxFileFake span{float:left;display:block;}div.jxFileFake .jxInputContainer{width:150px;}div.jxFileFake .jxInputText{width:135px;}div.jxFileFake .jxButtonContainer{margin-top:2px;float:left;}.jxInputFile{position:relative;text-align:right;-moz-opacity:0;filter:alpha(opacity:0);opacity:0
 ;z-index:2;margin-top:-5px;height:35px;}.jxForm{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxFieldset{display:block;position:relative;border:1px solid #ccc;margin:10px;padding:5px;}.jxFieldsetLegend,.jxFieldset legend{position:relative;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:14px;line-height:26px;color:#000;}.jxInputContainer{display:block;position:relative;padding:0;margin:2px;border:none;}.jxInputLabel,.jxInputTag{display:-moz-inline-box;display:inline-block;margin:0;padding:0;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:26px;color:#000;}.jxInputLabel{vertical-align:top;}.jxInputTag{vertical-align:bottom;}.jxInputWrapper{display:inline-block;white-space:normal;position:relative;}.jxInputText,.jxInputPassword,.jxInputTextarea,.jxInputCombo,.jxInputColor{margin:0 4px;padding:4px;border:1px solid #bbb;width:232px;font-family:Arial,Helvetica,sans-serif;font
 -size:12px;line-height:16px;color:#000;}.jxInputCombo,.jxInputColor{padding:4px 20px 4px 20px;width:200px;}.jxInputIconHidden .jxInputCombo{padding-left:4px;width:216px;}.jxInputIcon{position:absolute;width:16px;height:16px;left:0;top:0;margin:4px 4px 4px 8px;}.jxInputContainerColor .jxInputIcon{border:1px solid #bbb;width:15px;height:15px;}.jxInputIconHidden .jxInputIcon{display:none;}.jxInputRevealer{position:absolute;width:16px;height:16px;right:0;top:0;margin:4px 8px 4px 4px;font-size:0;line-height:0;}img.jxInputRevealerIcon{background-image:url(images/emblems.png);background-position:right -16px;background-repeat:no-repeat;}.jxInputRevealer .jxButtonContainer,.jxInputRevealer .jxButton{padding:0;margin:0;border:0;background-color:transparent;background-image:none;}.jxInputSelect{margin:0 4px;padding:3px 4px 3px 1px;border:1px solid #bbb;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputRadio,.jxInputCheck{margin:5px;font-family:A
 rial,Helvetica,sans-serif;font-size:12px;line-height:16px;color:#000;}.jxInputText:focus,.jxInputPassword:focus,.jxInputTextarea:focus,.jxInputSelect:focus,.jxInputCombo:focus,.jxInputColor:focus{border:1px solid #000;}.jxInputContainer .jxButtonContainer{padding:0;margin:0 4px;}.jxInputGroup{border:none;padding:0;margin:2px;}.jxInputGroup legend{font-size:0;line-height:0;padding:0;margin:0;border:none;}.jxInputGroup .jxFieldsetLegend{font-size:12px;}.jxInputGroup .jxInputLabel{width:auto;}.jxFieldError .jxInputText,.jxFieldError .jxInputPassword,.jxFieldError .jxInputTextarea,.jxFieldError .jxInputSelect,.jxFieldError .jxInputCombo,.jxFieldError .jxInputColor{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;}.jxFieldSuccess .jxInputText,.jxFieldSuccess .jxInputPassword,.jxFieldSuccess .jxInputTextarea,.jxFieldSuccess .jxInputSelect,.jxFieldSuccess .jxInputCombo,.jxFieldSuccess .jxInputColor{background-color:#E6EFC2;color:#264409;border-color:#C6D880;}.jxFieldErro
 r .jxInputText:focus,.jxFieldError .jxInputPassword:focus,.jxFieldError .jxInputTextarea:focus,.jxFieldError .jxInputSelect:focus,.jxFieldError .jxInputCombo:focus,.jxFieldError .jxInputColor:focus{border-color:#8a1f11;}.jxFieldSuccess .jxInputText:focus,.jxFieldSuccess .jxInputPassword:focus,.jxFieldSuccess .jxInputTextarea:focus,.jxFieldSuccess .jxInputSelect:focus,.jxFieldSuccess .jxInputCombo:focus,.jxFieldSuccess .jxInputColor:focus{border-color:#264409;}.jxFieldError .jxInputLabel,.jxFieldError .jxInputTag{color:#8a1f11;}.jxFieldSuccess .jxInputLabel,.jxFieldSuccess .jxInputTag{color:#264409;}.jxFormInline .jxInputContainer,form .jxFormInline .jxInputContainer,form .jxFieldset span.jxFormInline,form.jxForm span.jxFormInline{display:inline;}.jxFormInline .jxInputLabel,form .jxFormInline .jxInputLabel,form span.jxFormInline .jxInputLabel{display:inline;width:auto;}.jxFormInline .jxInputTag,form .jxFormInline .jxInputTag,form span.jxFormInline .jxInputTag{display:inline;}
 .jxFormInline .jxInputGroup,form .jxFormInline .jxInputGroup{padding-left:0;}.jxFormInline .jxInputGroup .jxFieldsetLegend,form .jxFormInline .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormInline .jxInputGroup .jxInputLabel,form .jxFormInline .jxInputGroup .jxInputLabel{display:inline;width:auto;}.jxFormBlock .jxInputContainer,form .jxFormBlock .jxInputContainer,form .jxFieldset span.jxFormBlock,form.jxform span.jxFormBlock{display:block;}.jxFormBlock .jxInputLabel,form .jxFormBlock .jxInputLabel,form span.jxFormBlock .jxInputLabel{display:block;width:auto;margin-left:4px;}.jxFormBlock .jxInputContainerCheck .jxInputLabel,.jxFormBlock .jxInputContainerRadio .jxInputLabel,form .jxFormBlock .jxInputContainerCheck .jxInputLabel,form .jxFormBlock .jxInputContainerRadio .jxInputLabel,form span.jxFormBlock .jxInputContainerCheck .jxInputLabel,form span.jxFormBlock .jxInputContainerRadio .jxInputLabel{display:-moz-inline-box;display:inline-block;}.jxFormBlock .
 jxInputGroup,form .jxFormBlock .jxInputGroup{padding-left:0;}.jxFormBlock .jxInputGroup .jxFieldsetLegend,form .jxFormBlock .jxInputGroup .jxFieldsetLegend{position:relative;left:auto;}.jxFormBlock .jxInputGroup .jxInputLabel,form .jxFormBlock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxFormInlineblock .jxInputContainer,form .jxFormInlineblock .jxInputContainer,form .jxFieldset span.jxFormInlineblock,form.jxForm span.jxFormInlineblock{display:block;white-space:nowrap;}.jxFormInlineblock .jxInputLabel,form .jxFormInlineblock .jxInputLabel,form span.jxFormInlineblock .jxInputLabel{display:-moz-inline-box;display:inline-block;width:200px;}.jxFormInlineblock .jxInputGroup,form .jxFormInlineblock .jxInputGroup{padding-left:200px;}.jxFormInlineblock .jxInputGroup .jxFieldsetLegend,form .jxFormInlineblock .jxInputGroup .jxFieldsetLegend{position:absolute;left:-200px;width:200px;}.jxFormInlineblock .jxInputGroup .jxInputLabel,form .jxFormI
 nlineblock .jxInputGroup .jxInputLabel{display:-moz-inline-box;display:inline-block;width:auto;}.jxGridCellContent .jxInputContainer,.jxGridCellContent .jxInputRadio,.jxGridCellContent .jxInputCheck{display:inline;position:relative;border:none;margin:0;padding:0;font-size:0;line-height:0;color:#000;}.jxGridContainer{position:absolute;top:0;left:0;border-left:0 solid #d8d8d8;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;overflow:hidden;}.jxGridTable{width:100%;position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;}.jxGridTableBody{position:relative;table-layout:fixed;border-collapse:collapse;border-style:none;cursor:default;}.jxGridCell{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;overflow:hidden;}.jxGridCellContent{position:relative;display:-moz-inline-box;display:inline-block;overflow:hidden;padding:0 3px;overflow:hidd
 en;vertical-align:middle;font-family:Arial,Verdana,sans-serif;font-size:11px;font-weight:normal;line-height:16px;white-space:nowrap;cursor:cell;text-overflow:ellipsis;}.jxGridColHead .jxGridCellContent{padding:0 3px;text-align:center;font-weight:bold;color:#333;height:100%;}.jxGridRowHead .jxGridCellContent{text-align:center;font-weight:bold;color:#333;}.jxGridColHead{height:100%;border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_col.png');background-position:0 0;background-repeat:repeat-x;text-align:center;cursor:default;padding:0;white-space:nowrap;overflow:hidden;}.jxGridRowHead{border-top:0 solid #d8d8d8;border-right:1px solid #d8d8d8;border-bottom:1px solid #d8d8d8;border-left:0 solid #d8d8d8;background-color:#f2f2f2;background-image:url('images/table_row.png');background-position:0 0;background-repeat:repeat-y;text-align:center;cursor:default;o
 verflow:hidden;white-space:nowrap;}.jxGridRowAll{background-color:#fff;}.jxGridColumnHeaderSelected{background-color:#e1e1e1;background-position:0 -200px;}.jxGridRowHeaderSelected{background-color:#e1e1e1;background-position:-400px 0;}.jxGridColumnSelected{background-color:#f7f7f7;}.jxGridRowSelected td,.jxGridRowSelected th{background-color:#f7f7f7;}td.jxGridCellSelected,th.jxGridCellSelected{background-color:#ebebeb;}.jxGridColumnHeaderPrelight{background-color:#cee5ff;background-position:0 -300px;}.jxGridRowHeaderPrelight{background-color:#cee5ff;background-position:-600px 0;}.jxGridColumnPrelight{background-color:#e5f1ff;}.jxGridRowPrelight td,.jxGridRowPrelight th{background-color:#e5f1ff;}td.jxGridCellPrelight,th.jxGridCellPrelight{background-color:#cce3ff;}.jxGridHeader .jxColSortable img{vertical-align:top;width:16px;height:16px;background-image:url('images/emblems.png');background-repeat:no-repeat;background-position:right top;}.jxGridHeader .jxColSortable .jxGridCe
 llContent{margin-right:-16px;}.jxGridHeader .jxGridColumnSortedAsc img{background-position:right -162px;}.jxGridHeader .jxGridColumnSortedDesc img{background-position:right -18px;}.jxGridColumnResize,.jxGridRowResize{display:block;position:absolute;background-image:url(images/a_pixel.png);z-index:1;}.jxGridColumnResize{right:0;top:0;height:100%;width:4px;cursor:col-resize;}.jxColSortable .jxGridColumnResize{right:8px;}.jxGridRowResize{left:0;bottom:0;height:4px;width:100%;cursor:row-resize;}.jxGridEditorPopup{min-width:130px;margin:3px;font-size:10px;box-shadow:2px 2px 5px #888;-moz-box-shadow:2px 2px 5px #888;-webkit-box-shadow:2px 2px 5px #888;background-color:#ddd;border:1px solid #999;position:absolute;}.jxGridEditorPopupInnerWrapper{position:relative;height:100%;width:100%;}.jxListView{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxListView .jxListItemContainer{position:relative;display:block;outline:none;overflow:hidden;border:none;margin:0 1px;
 padding:0;}.jxListItem{position:relative;display:block;cursor:pointer;outline:none;overflow:hidden;border:none;margin:0 1px;padding:0;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}.jxListView .jxHover{margin:0;border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;background-image:url(images/listitem.png);background-repeat:repeat-x;background-color:#CDE5FF;background-position:left -24px;}.jxListItem:focus{margin:0;border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -72px;}.jxListView .jxPressed,.jxListView .jxSelected{margin:0;border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;background-color:#CDE5FF;background-image:url(images/listitem.png);background-repeat:repeat-x;background-position:left -48px;}.jxMenuContainer .jxChrome{background-image:url(images/flyout_chrome.png);padd
 ing:5px 5px 7px 6px;}.jxButtonMenu span.jxMenuItemSpan{padding-right:16px;}.jxMenuContainer{position:absolute;top:0;left:-10000px;display:none;z-index:2000;padding:0;}ul.jxMenu{display:block;position:relative;list-style-type:none;padding:1px;margin:6px 6px 8px 7px;background-color:#fff;border:1px solid #999;}li.jxMenuItemContainer{display:block;position:relative;font-size:0;line-height:0;margin:0;padding:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}a.jxMenuItem{display:block;position:relative;overflow:hidden;text-decoration:none;cursor:pointer;outline:none;border:1px solid #fff;background-image:url(images/menuitem.png);background-repeat:no-repeat;background-position:left top;font-family:Arial,Helvetica,sans-serif;font-size:11px;text-decoration:none;margin:0;padding:0;color:#000;}a.jxMenuItemActive{background-position:left -98px;}a.jxMenuItem:focus{background-position:left -74px;}a.jxMenuItem:focus span.jxMenuItemContent{border-right:1px dotted #75ADFF;}a
 .jxMenuItemActive:focus{background-position:left -170px;}a.jxMenuItem:hover{background-color:#CDE5FF;background-position:left -26px;}a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #C5E0FF;}a.jxMenuItemActive:hover{background-position:left -122px;}a.jxMenuItemPressed,a.jxMenuItemPressed:hover{background-color:#CDE5FF;background-position:left -50px;}.jxDisabled a.jxMenuItem,.jxDisabled span.jxMenuItemContent span{cursor:default;}.jxDisabled a.jxMenuItem:focus,.jxDisabled a.jxMenuItemPressed,.jxDisabled a.jxMenuItemPressed:hover,.jxDisabled a.jxMenuItem:hover{background-color:#fff;background-position:left top;border-right:1px solid #fff;}.jxDisabled a.jxMenuItem:hover span.jxMenuItemContent{border-right:1px solid #fff;}span.jxMenuItemContent{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:0;line-height:0;white-space:nowrap;padding:0 20px 0 0;margin:0;border-right:1px solid #fff;}.jxButtonSubMenu span.jxMenuItemContent,.jxButton
 SubMenu:hover span.jxMenuItemContent{background-image:url(images/emblems.png);background-position:right -30px;background-repeat:no-repeat;}img.jxMenuItemIcon{position:absolute;top:2px;left:2px;width:16px;height:16px;background-position:left center;background-repeat:no-repeat;}span.jxMenuItemContent span{display:block;position:relative;cursor:pointer;margin:0;padding:2px 0 2px 22px;font-size:16px;line-height:16px;color:#000;}span.jxMenuItemContent span.jxMenuItemLabel{color:#000;font-size:11px;}.jxMenuItemToggle img.jxMenuItemIcon,.jxMenuItemToggleSet img.jxMenuItemIcon{background-image:url(images/emblems.png);background-position:2px 0;background-repeat:no-repeat;}.jxMenuItemToggle a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -48px;}.jxMenuItemToggleSet a.jxMenuItemActive img.jxMenuItemIcon{background-position:2px -64px;}ul.jxMenu span.jxMenuSeparator{display:block;font-size:10px;line-height:10px;background-image:url(images/toolbar_separator_v.png);background
 -repeat:repeat-x;background-position:left center;}@CHARSET "ISO-8859-1";.jxMessage{text-align:center;padding:10px;margin-top:10px;}.jxNoticeListContainer{border:none;padding:0;margin:0;font-size:0;line-height:0;z-index:500;}.jxNoticeList{position:relative;}.jxNoticeItemContainer{position:relative;overflow:hidden;}.jxNoticeItemContainer .jxChrome{background-image:url(images/flyout_chrome.png);padding:5px 5px 7px 6px;}.jxHasChrome .jxNoticeItem{margin:6px 6px 8px 7px;}.jxNoticeItem{position:relative;border:2px solid #ccc;margin:0;padding:0;background-color:#f8f8f8;background-image:url(images/notice.png);background-repeat:repeat-x;background-position:left bottom;}.jxNoticeIcon{position:absolute;top:0;left:0;margin:6px;width:16px;height:16px;background-image:url(images/icons.png);background-repeat:no-repeat;background-position:0 0;}.jxNotice{display:block;position:relative;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:18px;color:#666;margin:0;border:none;padd
 ing:6px 26px 6px 10px;}.jxNoticeError .jxNoticeItem{background-color:#FBE3E4;color:#8a1f11;border-color:#FBC2C4;background-image:url(images/notice_error.png);}.jxNoticeWarning .jxNoticeItem{background-color:#FFF6BF;color:#514721;border-color:#FFD324;background-image:url(images/notice_warning.png);}.jxNoticeSuccess .jxNoticeItem{background-color:#E6EFC2;color:#264409;border-color:#C6D880;background-image:url(images/notice_success.png);}.jxNoticeInformation .jxNoticeItem{background-color:#F8F8F8;color:#666;border-color:#CCC;background-image:url(images/notice.png);}.jxNoticeError .jxNotice{color:#8a1f11;padding-left:28px;}.jxNoticeWarning .jxNotice{color:#514721;padding-left:28px;}.jxNoticeSuccess .jxNotice{color:#264409;padding-left:28px;}.jxNoticeInformation .jxNotice{color:#666;padding-left:28px;}.jxNoticeError .jxNoticeIcon{background-position:0 -32px;}.jxNoticeWarning .jxNoticeIcon{background-position:0 -16px;}.jxNoticeSuccess .jxNoticeIcon{background-position:0 -48px;}.jx
 NoticeInformation .jxNoticeIcon{background-position:0 -64px;}.jxNoticeClose{position:absolute;top:0;right:0;margin:6px;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxPanel{display:block;position:relative;}.jxPanelContentContainer{overflow:hidden;background-color:#f0f0f0;}.jxPanelContent{position:relative;display:block;overflow:auto;background-color:#fff;margin:0;padding:0;}.jxPanelTitle{display:block;position:relative;background-image:url(images/panelbar.png);background-repeat:repeat-x;background-position:left top;height:22px;margin:0;padding:0;text-align:center;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxPanelBar{position:absolute;line-height:1px;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxPanelIcon{position:absolute;left:2px;top:3px;width:16px;height:16px;border:none;padding:0;margin:0;}.jxPanelLabel{padding-left:25px;font-family:Arial,Helvet
 ica,sans-serif;font-size:11px;font-weight:bold;line-height:21px;color:#000;white-space:nowrap;}.jxPanelControls{position:absolute;top:3px;right:2px;height:16px;width:80px;overflow:hidden;}.jxPanelControls img{background-image:url('images/panel_controls.png');background-repeat:no-repeat;border:0;margin:0;width:16px;height:16px;}.jxPanelClose img{background-position:0 -32px;}.jxPanelMenu img{background-position:0 -48px;}.jxPanelHelp img{background-position:0 -64px;}.jxPanelCollapse img{background-position:0 -16px;}.jxPanelMin .jxPanelCollapse img{background-position:0 0;}.jxPanelMax .jxPanelCollapse img{background-position:0 -16px;}.jxPanelMaximize img{background-position:0 0;}.jxPanelLoading img{border:0;margin:0;width:16px;height:16px;visibility:hidden;position:absolute;top:1px;left:2px;}.jxPanelControls .jxButtonContainer,.jxPanelControls .jxButton,.jxPanelControls .jxButton:hover,.jxPanelControls .jxButton:active,.jxPanelControls .jxButtonActive,.jxPanelControls .jxButtonA
 ctive:hover,.jxPanelControls .jxButtonActive:active,.jxPanelControls .jxDisabled .jxButton,.jxPanelControls .jxDisabled .jxButton:hover,.jxPanelControls .jxDisabled .jxButton:active{padding:0;margin:0;border:none;background-color:transparent;background-image:none;}.jxPanelControls div.jxBarTop{position:absolute;right:0;background-image:none;background-color:transparent;margin:0;padding:0;border:none;height:16px;}.jxPanelControls .jxBarScroller{left:auto;right:0;}.jxPanelControls ul.jxToolbar{float:right;}.jxPanelControls ul.jxToolbar,.jxPanelControls li.jxToolItem{background-image:none;background-color:transparent;margin:0;padding:0;border:none;}.jxProgressBar-container{position:relative;display:block;width:100%;}.jxProgressBar-message{position:relative;display:block;color:black;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:20px;}.jxProgressBar{position:relative;display:block;width:100%;height:20px;border:none;margin:0;padding:0;}.jxProgressBar-outline{po
 sition:absolute;display:block;top:0;left:0;z-index:10;height:20px;border-left:1px solid #cbc8c8;border-right:1px solid #cbc8c8;background-image:url(images/progressbar.png);background-position:0 -140px;width:100%;}.jxProgressBar-fill{position:absolute;display:block;top:0;left:0;z-index:20;height:20px;border:none;background-image:url(images/progressbar.png);background-position:0 0;}.jxProgressStarting .jxProgressBar-fill{border:none;}.jxProgressWorking .jxProgressBar-fill{border-left:1px solid #49afe8;}.jxProgressFinished .jxProgressBar-fill{border-left:1px solid #49afe8;border-right:1px solid #49afe8;}.jxProgressBar-text{position:absolute;display:block;overflow:visible;top:0;left:1px;width:auto;height:20px;z-index:30;border:none;margin:0;padding:0 0 0 4px;font-family:Arial,Helvetica,sans-serif;font-size:12px;line-height:20px;white-space:nowrap;}.jxHasVerticalScrollbar,.jxHasHorizontalScrollbar{position:relative;overflow:hidden;}.jxScrollbarChildWrapper{overflow:hidden;}.jxHas
 VerticalScrollbar{padding-right:25px;}.jxHasVerticalScrollbar .jxScrollbarContainer{position:absolute;right:0;top:0;width:20px;height:100%;border:none;border-left:1px solid black;}.jxHasVerticalScrollbar .jxScrollLeft,.jxHasVerticalScrollbar .jxScrollRight{width:20px;height:20px;display:block;background-color:blue;}.jxHasVerticalScrollbar .jxSliderContainer{height:100%;width:20px;border:none;}.jxHasHorizontalScrollbar{padding-bottom:25px;}.jxHasHorizontalScrollbar .jxScrollbarContainer{position:absolute;bottom:0;left:0;height:20px;width:100%;border:none;border-top:1px solid black;}.jxHasHorizontalScrollbar .jxScrollLeft,.jxHasHorizontalScrollbar .jxScrollRight{width:20px;height:20px;display:block;background-color:blue;}.jxHasHorizontalScrollbar .jxScrollLeft{float:left;}.jxHasHorizontalScrollbar .jxScrollRight{float:right;}.jxHasHorizontalScrollbar .jxSlider{float:left;}.jxHasHorizontalScrollbar .jxSliderContainer{height:20px;width:100%;border:none;}.jxHasVerticalScrollbar .
 jxSliderKnob,.jxHasHorizontalScrollbar .jxSliderKnob{width:20px;height:20px;background-color:black;cursor:pointer;}@CHARSET "ISO-8859-1";.jxSliderContainer{width:100%;height:10px;border:1px solid black;}.jxSliderKnob{width:10px;height:10px;background-color:black;cursor:pointer;}.jxSplitterMask{position:absolute;top:0;left:0;width:100%;height:100%;overflow:hidden;background-image:url(images/a_pixel.png);z-index:1;}.jxSplitBarHorizontal{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:5px;height:100%;cursor:col-resize;background-color:#f0f0f0;z-index:2;}.jxSplitBarVertical{display:block;position:absolute;font-size:0;line-height:0;margin:0;padding:0;border:none;width:100%;height:5px;cursor:row-resize;background-color:#f0f0f0;z-index:2;}.jxSplitContainer{display:block;position:relative;margin:0;padding:0;border:none;overflow:hidden;}.jxSplitArea{display:block;position:absolute;margin:0;padding:0;border:none;z-index:0;}.jxSplitBarDrag
 {background-color:#eee;}.jxSnapHorizontalBefore{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxSnapHorizontalAfter{width:5px;height:5px;position:absolute;top:0;left:0;background-color:#aaa;}.jxTabSetContainer{position:relative;display:block;overflow:hidden;width:200px;height:200px;margin:0;padding:0;background-color:#fff;}.jxTabSetContainer .jxBarContainer{z-index:auto;}.tabContent{display:none;position:relative;width:100%;height:100%;overflow:auto;}.tabContentActive{display:block;}span.jxTabContainer{display:block;position:relative;margin:0;padding:2px;border:none;}a.jxTab{display:-moz-inline-box;display:inline-block;position:relative;cursor:pointer;user-select:none;-moz-user-select:none;-khtml-user-select:none;margin:0;padding:0;border:none;background-repeat:no-repeat;text-decoration:none;outline:none;}span.jxTabContent{display:-moz-inline-box;display:inline-block;font-size:0;line-height:0;margin:0;padding:0;border:none;background-repeat:no-r
 epeat;}img.jxTabIcon{display:-moz-inline-box;display:inline-block;position:relative;width:16px;height:16px;background-position:center center;background-repeat:no-repeat;}span.jxTabLabel{display:-moz-inline-box;display:inline-block;position:relative;cursor:pointer;margin:0;padding:0;color:#000;font-family:Arial,Helvetica,sans-serif;font-size:11px;line-height:16px;}a.jxTabClose{display:block;position:absolute;cursor:pointer;outline:none;user-select:none;-moz-user-select:none;-khtml-user-select:none;width:16px;height:16px;background-image:url(images/tab_close.png);background-position:0 0;background-repeat:no-repeat;}.jxDisabled a.jxTab,.jxDisabled span.jxTabContent span,.jxDisabled a.jxTabClose{cursor:default;}.jxTabBarTop .jxBarWrapper,.jxTabBarBottom .jxBarWrapper{padding-left:2px;}.jxBarTop span.jxTabContainer,.jxBarBottom span.jxTabContainer{margin-right:-1px;padding:2px 0;}.jxBarTop a.jxTab,.jxBarTop span.jxTabContent,.jxTabBarTop .jxBarControls a.jxButton,.jxTabBarTop .jx
 BarControls span.jxButtonContent{background-image:url(images/tab_top.png);}.jxBarBottom a.jxTab,.jxBarBottom span.jxTabContent,.jxTabBarBottom .jxBarControls a.jxButton,.jxTabBarBottom .jxBarControls span.jxButtonContent{background-image:url(images/tab_bottom.png);}.jxBarTop a.jxTabClose,.jxBarBottom a.jxTabClose{top:5px;right:5px;}.jxBarTop .jxTabClose span.jxTabContent,.jxBarBottom .jxTabClose span.jxTabContent{padding-right:16px;}.jxBarTop a.jxTab,.jxBarBottom a.jxTab{padding-left:4px;background-position:left -24px;}.jxBarTop span.jxTabContent,.jxBarBottom span.jxTabContent{padding:4px 4px 4px 0;background-position:right -24px;}.jxBarTop a.jxTabActive,.jxBarBottom a.jxTabActive{background-position:left -72px;}.jxBarTop a.jxTabActive span.jxTabContent,.jxBarBottom a.jxTabActive span.jxTabContent{background-position:right -72px;}.jxBarTop a.jxTab:focus,.jxBarBottom a.jxTab:focus{background-position:left -96px;}.jxBarTop a.jxTab:focus span.jxTabContent,.jxBarBottom a.jxTab:f
 ocus span.jxTabContent{background-position:right -96px;}.jxBarTop a.jxTabActive:focus,.jxBarBottom a.jxTabActive:focus{background-position:left -144px;}.jxBarTop a.jxTabActive:focus span.jxTabContent,.jxBarBottom a.jxTabActive:focus span.jxTabContent{background-position:right -144px;}.jxBarTop a.jxTab:hover,.jxBarTop a.jxTabActive:hover,.jxBarBottom a.jxTab:hover,.jxBarBottom a.jxTabActive:hover{background-position:left -48px;}.jxBarTop a.jxTab:hover span.jxTabContent,.jxBarTop a.jxTabActive:hover span.jxTabContent,.jxBarBottom a.jxTab:hover span.jxTabContent,.jxBarBottom a.jxTabActive:hover span.jxTabContent{background-position:right -48px;}.jxBarTop a.jxTabPressed,.jxBarTop a.jxTabPressed:focus,.jxBarBottom a.jxTabPressed,.jxBarBottom a.jxTabPressed:focus{background-position:left -120px;}.jxBarTop a.jxTabPressed span.jxTabContent,.jxBarTop a.jxTabPressed:focus span.jxTabContent,.jxBarBottom a.jxTabPressed span.jxTabContent,.jxBarBottom a.jxTabPressed:focus span.jxTabConten
 t{background-position:right -120px;}.jxBarTop .jxDisabled a.jxTab:focus,.jxBarTop .jxDisabled a.jxTab:active,.jxBarTop .jxDisabled a.jxTab:hover,.jxBarTop .jxDisabled a.jxTabPressed,.jxBarBottom .jxDisabled a.jxTab:focus,.jxBarBottom .jxDisabled a.jxTab:active,.jxBarBottom .jxDisabled a.jxTab:hover,.jxBarBottom .jxDisabled a.jxTabPressed{background-position:left -24px;}.jxBarTop .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarTop .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabPressed span.jxTabContent{background-position:right -24px;}.jxBarTop .jxDisabled a.jxTabActive:focus,.jxBarTop .jxDisabled a.jxTabActive:active,.jxBarTop .jxDisabled a.jxTabActive:hover,.jxBarBot
 tom .jxDisabled a.jxTabActive:focus,.jxBarBottom .jxDisabled a.jxTabActive:active,.jxBarBottom .jxDisabled a.jxTabActive:hover{background-position:left -72px;}.jxBarTop .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarTop .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarBottom .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:right -72px;}.jxBarTop img.jxTabIcon,.jxBarBottom img.jxTabIcon{vertical-align:middle;}.jxBarTop span.jxTabLabel,.jxBarBottom span.jxTabLabel{vertical-align:middle;height:16px;padding:0 4px 0 4px;}.jxTabBarLeft .jxBarWrapper,.jxTabBarRight .jxBarWrapper{padding-top:2px;}.jxBarLeft span.jxTabContainer,.jxBarRight span.jxTabContainer{margin-bottom:-1px;padding:0 2px;}.jxBarLeft a.jxTab,.jxBarLeft span.jxTabContent{background-image:url(im
 ages/tab_left.png);}.jxBarRight a.jxTab,.jxBarRight span.jxTabContent{background-image:url(images/tab_right.png);}.jxBarLeft a.jxTabClose,.jxBarRight a.jxTabClose{top:5px;left:5px;}.jxBarLeft .jxTabClose span.jxTabContent,.jxBarRight .jxTabClose span.jxTabContent{padding-top:16px;}.jxBarLeft a.jxTab,.jxBarRight a.jxTab{padding-top:4px;background-position:-24px top;}.jxBarLeft span.jxTabContent,.jxBarRight span.jxTabContent{padding:0 4px 4px 4px;background-position:-24px bottom;}.jxBarLeft a.jxTabActive,.jxBarRight a.jxTabActive{background-position:-72px top;}.jxBarLeft a.jxTabActive span.jxTabContent,.jxBarRight a.jxTabActive span.jxTabContent{background-position:-72px bottom;}.jxBarLeft a.jxTab:focus,.jxBarRight a.jxTab:focus{background-position:-96px top;}.jxBarLeft a.jxTab:focus span.jxTabContent,.jxBarRight a.jxTab:focus span.jxTabContent{background-position:-96px bottom;}.jxBarLeft a.jxTabActive:focus,.jxBarRight a.jxTabActive:focus{background-position:-144px top;}.jxBa
 rLeft a.jxTabActive:focus span.jxTabContent,.jxBarRight a.jxTabActive:focus span.jxTabContent{background-position:-144px bottom;}.jxBarLeft a.jxTab:hover,.jxBarLeft a.jxTabActive:hover,.jxBarRight a.jxTab:hover,.jxBarRight a.jxTabActive:hover{background-position:-48px top;}.jxBarLeft a.jxTab:hover span.jxTabContent,.jxBarLeft a.jxTabActive:hover span.jxTabContent,.jxBarRight a.jxTab:hover span.jxTabContent,.jxBarRight a.jxTabActive:hover span.jxTabContent{background-position:-48px bottom;}.jxBarLeft a.jxTabPressed,.jxBarLeft a.jxTabPressed:focus,.jxBarRight a.jxTabPressed,.jxBarRight a.jxTabPressed:focus{background-position:-120px top;}.jxBarLeft a.jxTabPressed span.jxTabContent,.jxBarLeft a.jxTabPressed:focus span.jxTabContent,.jxBarRight a.jxTabPressed span.jxTabContent,.jxBarRight a.jxTabPressed:focus span.jxTabContent{background-position:-120px bottom;}.jxBarLeft .jxDisabled a.jxTab:focus,.jxBarLeft .jxDisabled a.jxTab:active,.jxBarLeft .jxDisabled a.jxTab:hover,.jxBarLe
 ft .jxDisabled a.jxTabPressed,.jxBarRight .jxDisabled a.jxTab:focus,.jxBarRight .jxDisabled a.jxTab:active,.jxBarRight .jxDisabled a.jxTab:hover,.jxBarRight .jxDisabled a.jxTabPressed{background-position:-24px top;}.jxBarLeft .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabPressed span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTab:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabPressed span.jxTabContent{background-position:-24px bottom;}.jxBarLeft .jxDisabled a.jxTabActive:focus,.jxBarLeft .jxDisabled a.jxTabActive:active,.jxBarLeft .jxDisabled a.jxTabActive:hover,.jxBarRight .jxDisabled a.jxTabActive:focus,.jxBarRight .jxDisabled a.jxTabActive:active,.jxBarRight .jxDisabled a.jxTabActive:hover{background-position:-72px top
 ;}.jxBarLeft .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarLeft .jxDisabled a.jxTabActive:hover span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:focus span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:active span.jxTabContent,.jxBarRight .jxDisabled a.jxTabActive:hover span.jxTabContent{background-position:-72px bottom;}.jxBarLeft span.jxTabLabel,.jxBarRight span.jxTabLabel{padding:4px 0 4px 0;}.jxBarContainer{display:block;position:relative;z-index:1;overflow:hidden;margin:0;padding:0;border:0;background-color:#f0f0f0;}.jxBarTop,.jxBarBottom{width:100%;height:28px;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;overflow:hidden;}.jxTabBox .jxTabBarTop{background-image:url(images/tabbar.png);background-position:0 bottom;}.jxTabBox .jxTabBarBottom{background-image:url(images/tabbar_bottom.png);background-position:0 top;}.jxBarLeft,.jxBarRight{width:a
 uto;height:100%;background-image:url(images/toolbar.png);background-repeat:repeat-x;background-position:0 0;float:left;overflow:hidden;}.jxTabBox .jxTabBarLeft{background-image:url(images/tabbar_left.png);background-repeat:repeat-y;background-position:right 0;}.jxTabBox .jxTabBarRight{background-image:url(images/tabbar_right.png);background-repeat:repeat-y;background-position:left 0;}.jxBarTop .jxBarScroller,.jxBarBottom .jxBarScroller{float:left;height:28px;overflow:hidden;z-index:0;}.jxBarTop .jxBarScroller .jxBarWrapper,.jxBarBottom .jxBarScroller .jxBarWrapper{float:left;height:28px;overflow:hidden;width:10000%;}.jxBarTop .jxBarControls .jxButtonContainer,.jxBarBottom .jxBarControls .jxButtonContainer{z-index:1;padding:2px 0;margin-left:-1px;}.jxBarTop .jxBarScrollLeft img.jxButtonIcon,.jxBarBottom .jxBarScrollLeft img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -80px;}.jxBarTop .jxBarScrollRight img.jxButtonIcon,.jxBarBottom .jxBarScrollR
 ight img.jxButtonIcon{background-image:url(images/emblems.png);background-position:0 -96px;}.jxBarControls{float:right;position:relative;font-size:0;line-height:0;}ul.jxToolbar,ul.jxTabBar{display:block;position:relative;float:left;clear:none;list-style-type:none;margin:0;padding:0;border:none;}li.jxToolItem{display:block;position:relative;float:left;font-size:0;line-height:0;white-space:nowrap;padding:0;margin:0;border:none;}li.jxToolItem .jxInputWrapper{white-space:nowrap;}li.jxToolItem span.jxBarSeparator{display:block;position:relative;float:left;font-size:0;line-height:0;border:0;margin:0;padding:4px;background-repeat:no-repeat;background-position:center center;}.jxBarTop li.jxToolItem span.jxBarSeparator,.jxBarBottom li.jxToolItem span.jxBarSeparator{width:8px;height:20px;background-image:url(images/toolbar_separator_h.png);}.jxBarLeft li.jxToolItem span.jxBarSeparator,.jxBarRight li.jxToolItem span.jxBarSeparator{width:20px;height:8px;background-image:url(images/toolb
 ar_separator_v.png);}.jxBarLeft ul.jxToolbar,.jxBarLeft ul.jxTabBar,.jxBarLeft li.jxToolItem,.jxBarRight ul.jxToolbar,.jxBarRight ul.jxTabBar,.jxBarRight li.jxToolItem{clear:both;}.jxToolbarAlignLeft ul{float:left;}.jxToolbarAlignRight ul{float:right;}.jxToolbarAlignCenter{text-align:center;}.jxToolbarAlignCenter ul{float:none;}.jxToolbarAlignCenter ul li{float:none;display:inline;}.jxTooltip{width:auto;height:auto;background-color:black;color:white;padding:5px;z-index:65536;}.jxTree,.jxTreeRoot{position:relative;display:block;list-style:none;margin:0;padding:0;}.jxTreeNest{list-style:none;margin:0;padding:0;background-repeat:repeat-y;background-position:left top;}li.jxTreeContainer{position:relative;display:block;margin:0;padding:0;background-repeat:no-repeat;background-position:left top;white-space:nowrap;font-size:0;line-height:0;user-select:none;-moz-user-select:none;-khtml-user-select:none;}.jxTree li.jxTreeContainer{margin-left:16px;}a.jxTreeItem{position:relative;disp
 lay:block;cursor:pointer;outline:none;overflow:hidden;background-image:url(images/tree_hover.png);background-repeat:repeat-x;background-position:left top;border:none;margin:0 1px 0 17px;padding:0 0 0 20px;z-index:0;font-family:Arial,Helvetica,sans-serif;font-size:11px;color:#000;text-decoration:none;line-height:20px;height:20px;}a.jxTreeItem:focus{border-left:1px dotted #75ADFF;border-right:1px dotted #75ADFF;margin:0 0 0 16px;background-position:left -72px;}a.jxTreeItem:hover,li.jxTreeContainer a.jxHover{border-left:1px solid #CDDFFD;border-right:1px solid #CDDFFD;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -24px;}li.jxTreeContainer a.jxSelected,li.jxTreeContainer a.jxSelected:hover,li.jxTreeContainer a.jxPressed,li.jxTreeContainer a.jxPressed:hover{border-left:1px solid #8AABFB;border-right:1px solid #8AABFB;margin:0 0 0 16px;background-color:#CDE5FF;background-position:left -48px;}li.jxDisabled a.jxTreeItem{cursor:default;}li.jxDisabled a.jxTreeIte
 m:focus,li.jxDisabled a.jxTreeItem:hover{background-position:left top;background-color:transparent;border:none;margin:0 1px 0 17px;}.jxTreeNest{background-image:url(images/tree_vert_line.png);}img.jxTreeImage,img.jxTreeIcon{position:absolute;display:inline;left:0;top:0;width:16px;height:20px;z-index:1;background-image:url(images/tree.png);background-repeat:no-repeat;border:0;margin:0;}img.jxTreeIcon{height:16px;top:2px;left:1px;}.jxTreeBranchOpen .jxTreeIcon,.jxTreeBranchLastOpen .jxTreeIcon{background-position:left -40px;}.jxTreeBranchOpen .jxTreeImage{background-position:left -100px;}.jxTreeBranchLastOpen .jxTreeImage{background-position:left -160px;}.jxTreeBranchClosed .jxTreeIcon,.jxTreeBranchLastClosed .jxTreeIcon{background-position:left -20px;}.jxTreeBranchClosed .jxTreeImage{background-position:left -80px;}.jxTreeBranchLastClosed .jxTreeImage{background-position:left -140px;}.jxTreeLeaf .jxTreeIcon,.jxTreeLeafLast .jxTreeIcon{background-position:left 0;}.jxTreeLeaf .
 jxTreeImage{background-position:left -60px;}.jxTreeLeafLast .jxTreeImage{background-position:left -120px;}a.jxTreeItem,img.jxTreeImage,img.jxTreeIcon,span.jxTreeLabel,.jxTreeItemContainer input{vertical-align:middle;}img.jxTreeImage.jxBusy{background-image:url(images/spinner_16.gif);background-position:left top;}.jxFileUploadPanel{padding:5px;}.jxUploadQueue li{display:block;position:relative;overflow:hidden;padding:2px;}.jxUploadQueue div span{display:block;}.jxUploadQueue li span.jxUploadFileName{font-size:12px;line-height:16px;padding-left:2px;}.jxUploadQueue li span.jxUploadFileDelete,.jxUploadQueue li span.jxUploadFileProgress,.jxUploadQueue li span.jxUploadFileComplete,.jxUploadQueue li span.jxUploadFileError{position:absolute;top:2px;right:2px;width:16px;height:16px;background-repeat:no-repeat;cursor:pointer;}.jxUploadQueue li span.jxUploadFileDelete{background-image:url('images/icons.png');background-position:0 -128px;}.jxUploadQueue li span.jxUploadFileProgress{back
 ground-image:url('images/spinner_16.gif');background-position:top left;}.jxUploadQueue li span.jxUploadFileComplete{background-image:url('images/icons.png');background-position:0 -48px;}.jxUploadQueue li span.jxUploadFileError{background-image:url('images/icons.png');background-position:0 -32px;}.jxUploadFileErrorTip{padding:4px 4px 4px 20px;border:2px solid #ddd;background:url("images/icons.png") no-repeat 0 -32px;color:black;width:100px;}
Modified: trunk/templates/mapguide/standard/themes/delicious/jxtheme.uncompressed.css
--- trunk/templates/mapguide/standard/themes/delicious/jxtheme.uncompressed.css	2010-11-05 15:21:19 UTC (rev 2271)
+++ trunk/templates/mapguide/standard/themes/delicious/jxtheme.uncompressed.css	2010-11-05 18:23:10 UTC (rev 2272)
@@ -669,7 +669,7 @@
     height: 16px;
  * @project         Jx
- * @revision        $Id: common.css 267 2009-03-31 20:49:16Z fred.warnock $
+ * @revision        $Id: common.css 736 2010-03-05 16:04:56Z pagameba $
  * @author          Fred Warnock (fwarnock at dmsolutions.ca)
  * @copyright       (c) 2006 DM Solutions Group Inc.
@@ -678,22 +678,99 @@
 /* COMMON STYLES */
-.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}
-.jxDisabled{opacity:0.4;-ms-filter: "Alpha(opacity=40)";}
-.jxDisabled * {-ms-filter: "Alpha(opacity=40)";}
-iframe.jxIframeShim{position:absolute;top:0px;left:0px;width:100%;height:100%;opacity:0;-ms-filter: "Alpha(opacity=0)";z-index:-1;}@CHARSET "ISO-8859-1";
+.jxClearer {
+  display: block;
+  position: relative;
+  float: none;
+  clear: both;
+  font-size: 0;
+  line-height: 0;
+  width: 0;
+  height: 0;
+  margin: 0;
+  padding: 0;
+.jxDisabled {
+  opacity: 0.4;
+  -ms-filter: "Alpha(opacity=40)";
+.jxDisabled * {
+/*  MASK STYLES  */
+.jxMask {
+  opacity: 0.5;
+  -ms-filter: "Alpha(opacity=50)";
+  background-color: #fff;
+.jxModalMask {
+  background-color: #000;
+  opacity: 0.2;
+  -ms-filter: "Alpha(opacity=20)";
+.jxEventMask {
+  background-image: url(images/a_pixel.png);
+.jxSpinner {
+  position: absolute;
+  opacity: 0.5;
+  z-index: 999;
+  background: #fff;
+/* .jxSpinnerContent { } */
+.jxSpinnerMessage {
+  text-align: center;
+  font-weight: bold;
+.jxSpinnerSmall .jxSpinnerMessage {
+  margin: 0px;
+  padding: 0px;
+  font-size: 11px;
+  line-height: 24px;
+.jxSpinnerLarge .jxSpinnerImage {
+  background: url(images/spinner_24.gif) no-repeat;
+  width: 24px;
+  height: 24px;
+  margin: 0 auto;
+.jxSpinnerSmall .jxSpinnerImage {
+  background: url(images/spinner_16.gif) no-repeat;
+  width: 16px;
+  height: 16px;
+  margin-right: 4px;
+  display: inline-block;
+  vertical-align: middle;
+/*iframe.jxIframeShim { }*/
- * Confirm dialog classes
+ * Confirm and Prompt dialog classes
-.jxConfirmQuestion {
+.jxConfirmQuestion, .jxPrompt {
     text-align: center;
     padding: 10px;
     margin-top: 10px;
  * @project         Jx
- * @revision        $Id: dialog.css 302 2009-04-02 18:42:56Z fred.warnock $
+ * @revision        $Id: dialog.css 732 2010-03-05 14:38:36Z pagameba $
@@ -711,6 +788,9 @@
   display: block;
   z-index: 1000;
   overflow: hidden;
+  /* initial state is hidden */
+  visibility: hidden;
 .jxDialogContentContainer {
@@ -720,20 +800,6 @@
   background-color: #f0f0f0;
-.jxDialogModal {
-  /* Base setup */
-  position: absolute;
-  display: block;
-  top: 0px;
-  left: 0px;
-  width: 100%;
-  height: 100%;
-  background-color: #000;
-  opacity: .2;
-  -ms-filter: "Alpha(opacity=20)";
 .jxDialogContent {
   /* Base setup */
   display: block;
@@ -854,6 +920,14 @@
   background-position: 0px -16px;
+.jxDialogMaximize img {
+  background-position: 0px -80px;
+.jxDialogMaximized .jxDialogMaximize img {
+  background-position: 0px -96px;
 .jxDialogLoading img {
   border: 0px;
   /* the margin needs to make up the difference between it's width/height
@@ -874,15 +948,6 @@
-.jxDialogControls span.jxButtonContent,
-.jxDialogControls .jxButton:hover span.jxButtonContent,
-.jxDialogControls .jxButton:active span.jxButtonContent,
-.jxDialogControls .jxButtonActive span.jxButtonContent,
-.jxDialogControls .jxButtonActive:hover span.jxButtonContent,
-.jxDialogControls .jxButtonActive:active span.jxButtonContent,
-.jxDialogControls .jxDisabled .jxButton span.jxButtonContent,
-.jxDialogControls .jxDisabled .jxButton:hover span.jxButtonContent,
-.jxDialogControls .jxDisabled .jxButton:active span.jxButtonContent,
 .jxDialogControls .jxButton:active ,
@@ -900,16 +965,6 @@
-.jxDialogControls .jxButtonMenu span.jxButtonContent,
-.jxDialogControls .jxButtonFlyout span.jxButtonContent {
-  background-image: none;
-.jxDialogControls .jxButtonMenu span.jxButtonContent span,
-.jxDialogControls .jxButtonFlyout span.jxButtonContent span {
-  padding-right: 0px;
 /* JX TOOLBAR STYLES OVERIDES */
@@ -972,7 +1027,7 @@
 div.jxFileFake .jxButtonContainer {
-    margin-top: 6px;
+    margin-top: 2px;
     float: left;
@@ -983,12 +1038,11 @@
     filter: alpha(opacity:0);
     opacity: 0;
     z-index: 2;
-    margin-top: 3px;
+    margin-top: -5px;
     height: 35px;
-    width: 100%;
  * @project         Jx
- * @revision        $Id: form.css 615 2009-11-19 22:01:38Z fred.warnock $
+ * @revision        $Id: form.css 827 2010-04-01 14:22:49Z fred.warnock $
@@ -1017,7 +1071,6 @@
 .jxForm {
   display: block;
   position: relative;
-  overflow: hidden; /* ensures that floated elements are contained */
   font-family: Arial, Helvetica, sans-serif;
   font-size: 12px;
   line-height: 16px;
@@ -1027,7 +1080,6 @@
 .jxFieldset {
   display: block;
   position: relative;
   border: 1px solid #ccc;
   margin: 10px;
   padding: 5px;
@@ -1072,18 +1124,86 @@
   vertical-align: bottom;
+.jxInputWrapper {
+  white-space: normal;
 .jxInputText,
 .jxInputPassword,
-.jxInputTextarea {
+.jxInputTextarea,
+.jxInputCombo,
+.jxInputColor {
   margin: 0px 4px;
   padding: 4px;
   border: 1px solid #bbb;
+  /* overall width is 250px, margins+padding+border is 18px */
+  width: 232px;
   font-size: 12px;
   line-height: 16px;
   color: #000;
+.jxInputCombo,
+.jxInputColor {
+  padding: 4px 20px 4px 20px;
+  /* overall width is 250px, margins+padding+border is 50px */
+  width: 200px;
+.jxInputIconHidden .jxInputCombo {
+  /* overall width is 250px, margins+padding+border is 34px */
+  padding-left: 4px;
+  width: 216px;
+.jxInputIcon {
+  width: 16px;
+  height: 16px;
+  left: 0px;
+  top: 0px;
+  margin: 4px 4px 4px 8px;
+.jxInputContainerColor .jxInputIcon {
+  border: 1px solid #bbb;
+  width: 15px;
+  height: 15px;
+.jxInputIconHidden .jxInputIcon {
+  display: none;
+.jxInputRevealer {
+  width: 16px;
+  height: 16px;
+  right: 0px;
+  top: 0px;
+  margin: 4px 8px 4px 4px;
+  font-size: 0px;
+  line-height: 0px;
+img.jxInputRevealerIcon {
+  background-image: url(images/emblems.png);
+  background-position: right -16px;
+  background-repeat: no-repeat;
+.jxInputRevealer .jxButtonContainer,
+.jxInputRevealer .jxButton {
+  padding: 0px;
+  margin: 0px;
+  border: 0px;
+  background-color: transparent;
+  background-image: none;
 .jxInputSelect {
   margin: 0px 4px;
   padding: 3px 4px 3px 1px;
@@ -1094,13 +1214,6 @@
   color: #000;
-.jxInputText:focus,
-.jxInputPassword:focus,
-.jxInputTextarea:focus,
-.jxInputSelect:focus {
-  border: 1px solid #000;
 .jxInputRadio,
 .jxInputCheck {
   margin: 5px;
@@ -1110,6 +1223,15 @@
   color: #000;
+.jxInputText:focus,
+.jxInputPassword:focus,
+.jxInputTextarea:focus,
+.jxInputSelect:focus,
+.jxInputCombo:focus,
+.jxInputColor:focus {
+  border: 1px solid #000;
 .jxInputContainer .jxButtonContainer {
   padding: 0px;
   margin: 0px 4px;
@@ -1144,7 +1266,9 @@
-.jxFieldError .jxInputSelect {
+.jxFieldError .jxInputSelect,
+.jxFieldError .jxInputCombo,
+.jxFieldError .jxInputColor {
   background-color: #FBE3E4;
   color: #8a1f11;
   border-color: #FBC2C4;
@@ -1153,7 +1277,9 @@
-.jxFieldSuccess .jxInputSelect {
+.jxFieldSuccess .jxInputSelect,
+.jxFieldSuccess .jxInputCombo,
+.jxFieldSuccess .jxInputColor {
   background-color: #E6EFC2;
   color: #264409;
   border-color: #C6D880;
@@ -1162,14 +1288,18 @@
 .jxFieldError .jxInputText:focus,
-.jxFieldError .jxInputSelect:focus {
+.jxFieldError .jxInputSelect:focus,
+.jxFieldError .jxInputCombo:focus,
+.jxFieldError .jxInputColor:focus {
   border-color: #8a1f11;
-.jxFieldSuccess .jxInputSelect:focus {
+.jxFieldSuccess .jxInputSelect:focus,
+.jxFieldSuccess .jxInputCombo:focus,
+.jxFieldSuccess .jxInputColor:focus {
   border-color: #264409;
@@ -1307,6 +1437,7 @@
 form.jxForm span.jxFormInlineblock {
   display: block;
+  white-space: nowrap;
 /* Inline-Block Label */
@@ -1338,9 +1469,22 @@
   width: auto;
+/** Jx.Grid Overrides **/
+.jxGridCellContent .jxInputContainer,
+.jxGridCellContent .jxInputRadio,
+.jxGridCellContent .jxInputCheck {
+  display: inline;
+  border: none;
+  margin: 0px;
+  padding: 0px;
+  font-size: 0px;
+  line-height: 0px;
+  color: #000;
  * @project         Jx
- * @revision        $Id: grid.css 572 2009-10-29 05:53:36Z jonlb at comcast.net $
+ * @revision        $Id: grid.css 796 2010-03-26 19:56:43Z pagameba $
@@ -1361,21 +1505,15 @@
 .jxGridTable {
+    width: 100%;
     position: relative;
     table-layout: fixed;
     border-collapse: collapse;
     border-style: none;
     cursor: default;
-    font-family: Arial, Verdana, sans-serif;
-    font-size: 11px;
-    font-weight: normal;
-.jxGridHeader {
-    width: 100%;
 .jxGridTableBody {
     position: relative;
@@ -1383,33 +1521,8 @@
     border-style: none;
    /* width: 100%;*/
     cursor: default;
-    font-size: 11px;
-.jxGridColHeadHide {
-    height: 0px;
-    line-height: 0px;
-    font-size: 0px;
-    background-color: #fff;
-    white-space: normal;
-.jxGridColHeadHide p, .jxGridRowHeadHide p {
-    font-size: 0px;
-    line-height: 0px;
-    height: 0px;
-    margin: 0px;
-    padding: 0px;
-.jxGridRowHeadHide {
-    width: 0px;
 .jxGridCell {
     border-top: 0px solid #d8d8d8;
     border-right: 1px solid #d8d8d8;
@@ -1423,9 +1536,15 @@
     display: -moz-inline-box;
     overflow: hidden;
-    padding-left: 3px;
-    padding-right: 3px;
+    padding: 0px 3px;
     overflow: hidden;
+    font-family: Arial, Verdana, sans-serif;
+    font-size: 11px;
+    font-weight: normal;
+    line-height: 16px;
     /* can change this to normal */
     cursor: cell;
@@ -1433,9 +1552,24 @@
     text-overflow: ellipsis;
+.jxGridColHead .jxGridCellContent {
+    padding: 0px 3px;
+    color: #333;
+    height: 100%;
+.jxGridRowHead .jxGridCellContent {
+  color: #333;
 /* Normal Styles */
 .jxGridColHead {
+    height: 100%;
     border-bottom: 1px solid #d8d8d8;
@@ -1446,12 +1580,11 @@
     background-repeat: repeat-x;
     text-align: center;
-    font-weight: bold;
-    color: #333;
     cursor: default;
+    padding: 0px;
+    overflow: hidden;
 .jxGridRowHead {
@@ -1465,8 +1598,6 @@
     background-repeat: repeat-y;
     text-align: center;
-    color: #333;
     cursor: default;
     overflow: hidden;
@@ -1499,11 +1630,13 @@
     background-color: #f7f7f7;
-.jxGridRowSelected td {
+.jxGridRowSelected td,
+.jxGridRowSelected th {
-td.jxGridCellSelected {
+td.jxGridCellSelected,
+th.jxGridCellSelected {
     background-color: #ebebeb;
@@ -1523,36 +1656,35 @@
     background-color: #e5f1ff;
-.jxGridRowPrelight td {
+.jxGridRowPrelight td,
+.jxGridRowPrelight th {
-td.jxGridCellPrelight {
+td.jxGridCellPrelight,
+th.jxGridCellPrelight {
   background-color: #cce3ff;
-/* Sort styles */
-.jxColSortable {
-    padding-right: 20px;
-.jxGridCell.jxColSortable {
-    padding-right: 0;
-.jxColSortable span {
+.jxGridHeader .jxColSortable img {
+    vertical-align: top;
+    width: 16px;
+    height: 16px;
     background-image: url('images/emblems.png');
     background-position: right top;
+.jxGridHeader .jxColSortable .jxGridCellContent {
+  margin-right: -16px; /* recenter the column heading text */
-.jxGridColumnSortedAsc span {
-    background-position: right -160px;
+.jxGridHeader .jxGridColumnSortedAsc img {
+    background-position: right -162px;
-.jxGridColumnSortedDesc span {
-    background-position: right -16px;
+.jxGridHeader .jxGridColumnSortedDesc img {
+    background-position: right -18px;
@@ -1571,13 +1703,46 @@
     cursor: col-resize;
+.jxColSortable .jxGridColumnResize {
+  right: 8px;
 .jxGridRowResize {
     left: 0px;
     bottom: 0px;
     height: 4px;
     width: 100%;
     cursor: row-resize;
+/* Editor Styles */
+.jxGridEditorPopup {
+  min-width: 130px;
+  margin: 3px;
+  font-size: 10px;
+  box-shadow: 2px 2px 5px #888; /* i really like the boxshadow */
+  -moz-box-shadow : 2px 2px 5px #888;
+  -webkit-box-shadow : 2px 2px 5px #888;
+  border-radius: 5px;
+  -moz-border-radius: 5px;
+  -webkit-border-radius: 5px;
+  background-color: #dddddd;
+  border: 1px solid #999999;
+.jxGridEditorPopupInnerWrapper {
+  height: 100%;
+  width: 100%;
 }.jxListView {
+  position:relative;
+  display: block;
+  list-style: none;
+  margin: 0px;
+  padding: 0px;
 .jxListView .jxListItemContainer {
@@ -1946,19 +2111,20 @@
     padding: 6px 26px 6px 10px;
-.jxNoticeError .jxNoticeItem {   background-color: #FBE3E4; color: #8a1f11; border-color: #FBC2C4; background-image: url(images/notice_error.png);}
+.jxNoticeError .jxNoticeItem { background-color: #FBE3E4; color: #8a1f11; border-color: #FBC2C4; background-image: url(images/notice_error.png);}
 .jxNoticeWarning .jxNoticeItem { background-color: #FFF6BF; color: #514721; border-color: #FFD324; background-image: url(images/notice_warning.png);}
 .jxNoticeSuccess .jxNoticeItem { background-color: #E6EFC2; color: #264409; border-color: #C6D880; background-image: url(images/notice_success.png);}
+.jxNoticeInformation .jxNoticeItem { background-color: #F8F8F8; color: #666666; border-color: #CCCCCC; background-image: url(images/notice.png);}
-.jxNoticeError .jxNotice {   color: #8a1f11; padding-left: 28px; }
+.jxNoticeError .jxNotice { color: #8a1f11; padding-left: 28px; }
 .jxNoticeWarning .jxNotice { color: #514721; padding-left: 28px; }
 .jxNoticeSuccess .jxNotice { color: #264409; padding-left: 28px; }
-.jxNoticeInfo .jxNotice { padding-left: 28px; }
+.jxNoticeInformation .jxNotice { color: #666666; padding-left: 28px; }
-.jxNoticeError .jxNoticeIcon {   background-position: 0px -32px; }
+.jxNoticeError .jxNoticeIcon { background-position: 0px -32px; }
 .jxNoticeWarning .jxNoticeIcon { background-position: 0px -16px; }
 .jxNoticeSuccess .jxNoticeIcon { background-position: 0px -48px; }
-.jxNoticeInfo .jxNoticeIcon {    background-position: 0px -64px; }
+.jxNoticeInformation .jxNoticeIcon { background-position: 0px -64px; }
 .jxNoticeClose {
     position: absolute;
@@ -1972,7 +2138,7 @@
  * @project         Jx
- * @revision        $Id: panel.css 302 2009-04-02 18:42:56Z fred.warnock $
+ * @revision        $Id: panel.css 716 2010-03-02 16:07:19Z fred.warnock $
@@ -2134,15 +2300,6 @@
-.jxPanelControls span.jxButtonContent,
-.jxPanelControls .jxButton:hover span.jxButtonContent,
-.jxPanelControls .jxButton:active span.jxButtonContent,
-.jxPanelControls .jxButtonActive span.jxButtonContent,
-.jxPanelControls .jxButtonActive:hover span.jxButtonContent,
-.jxPanelControls .jxButtonActive:active span.jxButtonContent,
-.jxPanelControls .jxDisabled .jxButton span.jxButtonContent,
-.jxPanelControls .jxDisabled .jxButton:hover span.jxButtonContent,
-.jxPanelControls .jxDisabled .jxButton:active span.jxButtonContent,
 .jxPanelControls .jxButton:active ,
@@ -2159,16 +2316,7 @@
-.jxPanelControls .jxButtonMenu span.jxButtonContent,
-.jxPanelControls .jxButtonFlyout span.jxButtonContent {
-.jxPanelControls .jxButtonMenu span.jxButtonContent span,
-.jxPanelControls .jxButtonFlyout span.jxButtonContent span {
@@ -2203,55 +2351,174 @@
   margin: 0px;
   padding: 0px;
   border: none;
-}@CHARSET "ISO-8859-1";
  * progress bar classes
 .jxProgressBar-container {
+    display: block;
     width: 100%;
-    display: block;
-    clear: both;
 .jxProgressBar-message {
+    display: block;
     color: black;
+    font-family: Arial, Helvetica, sans-serif;
+    font-size: 12px;
+    line-height: 20px;
-.jxProgressBar-container .jxProgressBar {
+.jxProgressBar {
+    display: block;
     width: 100%;
-    clear: both;
-    border-top: none;
+    height: 20px;
+    border: none;
+    margin: 0px;
+    padding: 0px;
-.jxProgressBar-container .jxProgressBar .jxProgressBar-outline {
-    border: 1px solid #336600;
+.jxProgressBar-outline {
     position: absolute;
+    display: block;
     top: 0px;
     left: 0px;
     z-index: 10;
+    height: 20px;
+    border-left: 1px solid #cbc8c8;
+    border-right: 1px solid #cbc8c8;
+    background-image: url(images/progressbar.png);
+    background-position: 0px -140px;
+    width: 100%;
-.jxProgressBar-container .jxProgressBar .jxProgressBar-fill {
-    background-color: #99cc66;
+.jxProgressBar-fill {
     position: absolute;
-    top: 1px;
-    left: 1px;
+    display: block;
+    top: 0px;
+    left: 0px;
     z-index: 20;
+    height: 20px;
+    border: none;
+    background-position: 0px 0px;
-.jxProgressBar-container .jxProgressBar .jxProgressBar-text {
-    color: #336600;
-    margin: 0px;
-    padding: 2px;
+.jxProgressStarting .jxProgressBar-fill {
+    border: none;
+.jxProgressWorking .jxProgressBar-fill {
+    border-left: 1px solid #49afe8;
+.jxProgressFinished .jxProgressBar-fill {
+    border-right: 1px solid #49afe8;
+.jxProgressBar-text {
     position: absolute;
-    top: 1px;
+    display: block;
+    overflow: visible;
+    top: 0px;
     left: 1px;
     width: auto;
+    height: 20px;
     z-index: 30;
     border: none;
+    margin: 0px;
+    padding: 0px 0px 0px 4px;
+    font-size: 12px;
+.jxHasVerticalScrollbar,
+.jxHasHorizontalScrollbar {
+    overflow: hidden;
+.jxScrollbarChildWrapper {
+    overflow: hidden;
+.jxHasVerticalScrollbar {
+    padding-right: 25px;
+.jxHasVerticalScrollbar .jxScrollbarContainer {
+    right: 0;
+    top: 0;
+    width: 20px;
+    height: 100%;
+    border: none;
+    border-left: 1px solid black;
+.jxHasVerticalScrollbar .jxScrollLeft,
+.jxHasVerticalScrollbar .jxScrollRight {
+    width: 20px;
+    height: 20px;
+    display: block;
+    background-color: blue;
+.jxHasVerticalScrollbar .jxSliderContainer {
+    height: 100%;
+    width: 20px;
+    border: none;
+    padding-bottom: 25px;
+.jxHasHorizontalScrollbar .jxScrollbarContainer {
+    bottom: 0;
+    left: 0;
+    height: 20px;
+    width: 100%;
+    border: none;
+    border-top: 1px solid black;
+.jxHasHorizontalScrollbar .jxScrollLeft,
+.jxHasHorizontalScrollbar .jxScrollRight {
+    width: 20px;
+    height: 20px;
+    display: block;
+.jxHasHorizontalScrollbar .jxScrollLeft {
+    float: left;
+    float: right;
+.jxHasHorizontalScrollbar .jxSlider {
+    float: left;
+.jxHasHorizontalScrollbar .jxSliderContainer {
+    height: 20px;
+    width: 100%;
+    border: none;
+.jxHasVerticalScrollbar .jxSliderKnob,
+.jxHasHorizontalScrollbar .jxSliderKnob {
+    width: 20px;
+    height: 20px;
+    background-color: black;
+    cursor: pointer;
@@ -2364,7 +2631,7 @@
   background-color: #aaa;
  * @project         Jx
- * @revision        $Id: tab.css 615 2009-11-19 22:01:38Z fred.warnock $
+ * @revision        $Id: tab.css 875 2010-04-24 06:10:53Z fred.warnock $
@@ -2382,8 +2649,7 @@
      the position need to be explicitly set, as well as the width and height. */
   /* Base setup */
   position: relative;
-  display: -moz-inline-box;
-  display: inline-block;
+  display: block;
   overflow: hidden;
   width: 200px;
@@ -2393,7 +2659,7 @@
-.jxTabSetContainer  .jxToolbarContainer {
+.jxTabSetContainer  .jxBarContainer {
   /* Base setup */
   z-index: auto;
@@ -2519,18 +2785,29 @@
 /* HORIZONTALTAB BAR - TOP and BOTTOM TABS */
-.jxBarTop div.jxTabContainer,
-.jxBarBottom div.jxTabContainer {
+.jxTabBarTop .jxBarWrapper,
+.jxTabBarBottom .jxBarWrapper {
+  padding-left: 2px;
+.jxBarTop span.jxTabContainer,
+.jxBarBottom span.jxTabContainer {
   /* Base setup */
+  margin-right: -1px;
+  padding: 2px 0px;
 .jxBarTop a.jxTab,
-.jxBarTop span.jxTabContent {
+.jxBarTop span.jxTabContent,
+.jxTabBarTop .jxBarControls a.jxButton,
+.jxTabBarTop .jxBarControls span.jxButtonContent{
   background-image: url(images/tab_top.png);
-.jxBarBottom span.jxTabContent {
+.jxBarBottom span.jxTabContent,
+.jxTabBarBottom .jxBarControls a.jxButton,
+.jxTabBarBottom .jxBarControls span.jxButtonContent {
   background-image: url(images/tab_bottom.png);
@@ -2690,11 +2967,19 @@
 /* VERTICAL TAB BAR - LEFT and RIGHT */
+.jxTabBarLeft .jxBarWrapper,
+.jxTabBarRight .jxBarWrapper {
+  padding-top: 2px;
 .jxBarRight span.jxTabContainer {
   /* Base setup */
+  margin-bottom: -1px;
+  padding: 0px 2px;
 .jxBarLeft a.jxTab,
 .jxBarLeft span.jxTabContent {
   background-image: url(images/tab_left.png);
@@ -2843,7 +3128,7 @@
  * @project         Jx
- * @revision        $Id: toolbar.css 289 2009-04-01 18:09:24Z pagameba $
+ * @revision        $Id: toolbar.css 912 2010-05-21 21:33:08Z pagameba $
@@ -2916,26 +3201,29 @@
   background-position: left 0px;
 .jxBarBottom .jxBarScroller {
-  /* much bigger than its container */
-  width: 10000%;
+  float: left;
+  height: 28px;
   overflow: hidden;
+  z-index: 0;
-.jxBarTop .jxBarScrollLeft,
-.jxBarBottom .jxBarScrollLeft {
-  top: 0px;
-  left: 0px;
+.jxBarTop .jxBarScroller .jxBarWrapper,
+.jxBarBottom .jxBarScroller .jxBarWrapper {
+  float: left;
+  height: 28px;
+  overflow: hidden;
+  width: 10000%;
-.jxBarTop .jxBarScrollRight,
-.jxBarBottom .jxBarScrollRight {
-  top: 0px;
-  right: 0px;
+.jxBarTop .jxBarControls .jxButtonContainer,
+.jxBarBottom .jxBarControls .jxButtonContainer {
+  /* float: right; */
+  z-index: 1;
+  padding: 2px 0px;
+  margin-left: -1px;
@@ -2950,6 +3238,13 @@
+.jxBarControls {
+    float: right;
+    font-size: 0px;
+    line-height: 0px;
 /* The jx toolbar and tabbar are both built out of a UL
    The margins/padding are flattened out, and the list markers are hidden
    UL's are floated left so multiple toolbars can be in the samae row.
@@ -2970,6 +3265,7 @@
   display: block;
   position: relative;
   float: left;
+  clear: none;
   list-style-type: none;
   margin: 0px;  /* margins don't seem to work properly in IE */
@@ -2992,12 +3288,18 @@
   float: left;
   font-size: 0px;
   line-height: 0px;
   padding: 0px;
   border: none;
+/* inputs in toolbars wrap in IE */
+li.jxToolItem .jxInputWrapper {
 /* Seperator height should match that of button images
    and the margins+padding+border should add up to the same total too. */
@@ -3044,8 +3346,28 @@
   /* Base setup */
   clear: both;
+/* Aligning options */
+.jxToolbarAlignLeft ul {
+    float: left;
+.jxToolbarAlignRight ul {
+    float: right;
+.jxToolbarAlignCenter {
+.jxToolbarAlignCenter ul {
+    float: none;
+.jxToolbarAlignCenter ul li {
+    float: none;
+    display: inline;
  * Tooltip classes
 .jxTooltip {
@@ -3059,7 +3381,7 @@
  * @project         Jx
- * @revision        $Id: tree.css 602 2009-11-10 19:41:36Z pagameba $
+ * @revision        $Id: tree.css 755 2010-03-15 03:09:37Z jonlb at comcast.net $
@@ -3259,25 +3581,30 @@
-/* FileUploadPanel */
+img.jxTreeImage.jxBusy {
+    background-image: url(images/spinner_16.gif);
+    background-position: left top;
+}/* FileUploadPanel */
 .jxFileUploadPanel {
     padding: 5px;
 .jxFileUploadPanel .jxInputContainer {
-    width: 300px;
+    /*width: 300px;*/
 .jxUploadQueue {
-    width: 100%;
-    margin-top: 10px;
+    /*width: 100%;*/
+    /*margin-top: 10px;*/
-.jxUploadQueue div {
+.jxUploadQueue li {
+    display: block;
     position: relative;
-    width: 95%;
-    clear: both;
-    border-top: 1px solid black;
+    overflow: hidden;
+    /*width: 95%;*/
+    /*clear: both;*/
+    /*border-top: 1px solid black;*/
     padding: 2px;
@@ -3285,43 +3612,51 @@
     display: block;
-.jxUploadQueue div span.jxUploadFileName {
-    float: left;
-    font-size: 16px;
+.jxUploadQueue li span.jxUploadFileName {
+    /*float: left;*/
+    font-size: 12px;
-.jxUploadQueue div span.jxUploadFileDelete,
-.jxUploadQueue div span.jxUploadFileProgress,
-.jxUploadQueue div span.jxUploadFileComplete,
-.jxUploadQueue div span.jxUploadFileError {
-    float: right;
+.jxUploadQueue li span.jxUploadFileDelete,
+.jxUploadQueue li span.jxUploadFileProgress,
+.jxUploadQueue li span.jxUploadFileComplete,
+.jxUploadQueue li span.jxUploadFileError {
+    /*float: right;*/
+    top: 2px;
+    right: 2px;
     width: 16px;
     height: 16px;
-    background-position: top left;
     cursor: pointer;
-.jxUploadQueue div span.jxUploadFileDelete {
-    background-image: url('images/delete.gif');
+.jxUploadQueue li span.jxUploadFileDelete {
+    background-image: url('images/icons.png');
+    background-position: 0px -128px;
-.jxUploadQueue div span.jxUploadFileProgress {
-    background-image: url('images/loading.gif');
+.jxUploadQueue li span.jxUploadFileProgress {
+    background-image: url('images/spinner_16.gif');
+    background-position: top left;
-.jxUploadQueue div span.jxUploadFileComplete {
-    background-image: url('images/green_tick.png');
+.jxUploadQueue li span.jxUploadFileComplete {
+    background-position: 0px -48px;
-    background-image: url('images/error.png');
+    background-position: 0px -32px;
 .jxUploadFileErrorTip {
-  padding: 4px 4px 4px 20px;
+  padding: 4px 4px 4px 20px;
   border: 2px solid #ddd;
-  background: url("images/error.png") no-repeat left top;
+  background: url("images/icons.png") no-repeat 0px -32px;
   color: black;
   width: 100px;
\ No newline at end of file
More information about the fusion-commits mailing list
