[fusion-commits] r2275 - trunk/text
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Nov 12 15:02:09 EST 2010
Author: madair
Date: 2010-11-12 12:02:09 -0800 (Fri, 12 Nov 2010)
New Revision: 2275
   trunk/text/en
   trunk/text/en.json
   trunk/text/fr
   trunk/text/fr.json
closes #380: set the EOL svn property
Property changes on: trunk/text/en
___________________________________________________________________
Added: svn:eol-style
   + native
Modified: trunk/text/en.json
--- trunk/text/en.json	2010-11-11 15:41:30 UTC (rev 2274)
+++ trunk/text/en.json	2010-11-12 20:02:09 UTC (rev 2275)
@@ -1,78 +1,78 @@
-Fusion.Strings.en = {
-'scriptFailed': 'failed to load script: ${script}',
-'configParseError': 'Error parsing fusion configuration file, initialization aborted',
-'configLoadError': 'Error loading fusion configuration file, initialization aborted.' +
-                  'Make sure that you have copied config_dist.json to config.json ' +
-                  'and have configured the settings for your system',
-'ajaxError': 'Exception occurred in AJAX callback.\nMessage: ${exception}\nLocation: ${filename} (${line})\nResponse: ${response}',
-'importFailed': 'failed to import stylesheet: ${url}',
-'serverNotAvailable': '<h2>Server not available. Try to reload the application. If this problem persists, please contact the administrator</h2>',
-'invalidXMLDocument': 'xml2json: invalid XML document: ${msg} : ${url}',
-'registerEventError': 'Error registering eventID, invalid (empty) eventID.',
-'appDefLoadFailed': 'failed to load: ${script}',
-'appDefParseError': 'failed to parse ApplicationDefinition',
-'widgetSetParseError': 'failed to parse the WidgetSet',
-'fusionError': 'Fusion Error: ${type}\n${message}',
-'nullExtents': 'Map.setExtents called with null extents',
-'mapLoadError': 'Failed to load requested map:\n${error}',
-'setLayersError': "setLayers failure: ${error}",
-'printTitle': 'Printable Page ',
-'noSelection': 'No Selection',
-'selectionInfo': '${features} feature(s) selected on ${layers} layer(s)',
-'attribute': 'Attribute',
-'value': 'Value',
-'taskHome': 'return to the task pane home',
-'prevTask': 'go to previous task executed',
-'nextTask': 'go to next task executed',
-'taskList': 'Task List',
-'taskPane': 'Task Pane',
-'imperial': 'Imperial',
-'metric': 'Metric',
-'deg': 'Degrees',
-'refresh': 'Refresh',
-'expandAll': 'Expand All',
-'expand': 'Expand',
-'collapseAll': 'Collapse All',
-'collapse': 'Collapse',
-'defaultMapTitle': 'Map',
-'legendTitle': 'Legend',
-'selectionPanelTitle': 'Selection',
-'ovmapTitle': 'Overview Map',
-'ovmapTitleShort': 'Overview',
-'taskPaneTitle': 'Tasks',
-'segment': 'Segment ${seg}',
-'calculating': 'calculating ...',
-'panWest': 'Pan West',
-'panEast': 'Pan East',
-'panSouth': 'Pan South',
-'panNorth': 'Pan North',
-'zoomOut': 'Zoom Out',
-'zoomIn': 'Zoom In',
-'printCancel': 'Cancel',
-'printGenerate': 'Generate',
-'zoomRect': 'Zoom Rectangle',
-'maptipLinkText': 'Click for more information',
-'redlineLayerName': 'Digitizing Layer ',
-'printShowTitle':'Show Title?',
-'printOptions'	:'Options',
-'printTitleText':'Title',
-'printShowLegend':'Show Legend?',
-'printShowNorthArrow':'Show North Arrow?',
-'quickPlotResolutionWarning':'The current settings exceed the map resolution. Zooming out or increasing the scaling will help create a more legible plot',
-'noCommercialMapLayers':'NONE',
-'googleStreet':'Google Street',
-'googleSatellite':'Google Satellite',
-'googleTerrain':'Google Terrain',
-'googleHybrid':'Google Hybrid',
-'yahooStreet':'Yahoo Street',
-'yahooSatellite':'Yahoo Satellite',
-'yahooHybrid':'Yahoo Hybrid',
-'bingStreet':'Bing Street',
-'bingSatellite':'Bing Satellite',
-'bingHybrid':'Bing Hybrid',
-'openStreetMap':'Open Street Map',
-'openStreetMapOsmarender':'Open Street Map (Osmarender)',
-'openStreetMapCycleMap':'Open Street Map (CycleMap)',
-'end': ''
+Fusion.Strings.en = {
+'scriptFailed': 'failed to load script: ${script}',
+'configParseError': 'Error parsing fusion configuration file, initialization aborted',
+'configLoadError': 'Error loading fusion configuration file, initialization aborted.' +
+                  'Make sure that you have copied config_dist.json to config.json ' +
+                  'and have configured the settings for your system',
+'ajaxError': 'Exception occurred in AJAX callback.\nMessage: ${exception}\nLocation: ${filename} (${line})\nResponse: ${response}',
+'importFailed': 'failed to import stylesheet: ${url}',
+'serverNotAvailable': '<h2>Server not available. Try to reload the application. If this problem persists, please contact the administrator</h2>',
+'invalidXMLDocument': 'xml2json: invalid XML document: ${msg} : ${url}',
+'registerEventError': 'Error registering eventID, invalid (empty) eventID.',
+'appDefLoadFailed': 'failed to load: ${script}',
+'appDefParseError': 'failed to parse ApplicationDefinition',
+'widgetSetParseError': 'failed to parse the WidgetSet',
+'fusionError': 'Fusion Error: ${type}\n${message}',
+'nullExtents': 'Map.setExtents called with null extents',
+'mapLoadError': 'Failed to load requested map:\n${error}',
+'setLayersError': "setLayers failure: ${error}",
+'printTitle': 'Printable Page ',
+'noSelection': 'No Selection',
+'selectionInfo': '${features} feature(s) selected on ${layers} layer(s)',
+'attribute': 'Attribute',
+'value': 'Value',
+'taskHome': 'return to the task pane home',
+'prevTask': 'go to previous task executed',
+'nextTask': 'go to next task executed',
+'taskList': 'Task List',
+'taskPane': 'Task Pane',
+'imperial': 'Imperial',
+'metric': 'Metric',
+'deg': 'Degrees',
+'refresh': 'Refresh',
+'expandAll': 'Expand All',
+'expand': 'Expand',
+'collapseAll': 'Collapse All',
+'collapse': 'Collapse',
+'defaultMapTitle': 'Map',
+'legendTitle': 'Legend',
+'selectionPanelTitle': 'Selection',
+'ovmapTitle': 'Overview Map',
+'ovmapTitleShort': 'Overview',
+'taskPaneTitle': 'Tasks',
+'segment': 'Segment ${seg}',
+'calculating': 'calculating ...',
+'panWest': 'Pan West',
+'panEast': 'Pan East',
+'panSouth': 'Pan South',
+'panNorth': 'Pan North',
+'zoomOut': 'Zoom Out',
+'zoomIn': 'Zoom In',
+'printCancel': 'Cancel',
+'printGenerate': 'Generate',
+'zoomRect': 'Zoom Rectangle',
+'maptipLinkText': 'Click for more information',
+'redlineLayerName': 'Digitizing Layer ',
+'printShowTitle':'Show Title?',
+'printOptions'	:'Options',
+'printTitleText':'Title',
+'printShowLegend':'Show Legend?',
+'printShowNorthArrow':'Show North Arrow?',
+'quickPlotResolutionWarning':'The current settings exceed the map resolution. Zooming out or increasing the scaling will help create a more legible plot',
+'noCommercialMapLayers':'NONE',
+'googleStreet':'Google Street',
+'googleSatellite':'Google Satellite',
+'googleTerrain':'Google Terrain',
+'googleHybrid':'Google Hybrid',
+'yahooStreet':'Yahoo Street',
+'yahooSatellite':'Yahoo Satellite',
+'yahooHybrid':'Yahoo Hybrid',
+'bingStreet':'Bing Street',
+'bingSatellite':'Bing Satellite',
+'bingHybrid':'Bing Hybrid',
+'openStreetMap':'Open Street Map',
+'openStreetMapOsmarender':'Open Street Map (Osmarender)',
+'openStreetMapCycleMap':'Open Street Map (CycleMap)',
+'end': ''
Property changes on: trunk/text/en.json
   + native
Modified: trunk/text/fr
--- trunk/text/fr	2010-11-11 15:41:30 UTC (rev 2274)
+++ trunk/text/fr	2010-11-12 20:02:09 UTC (rev 2275)
@@ -1,350 +1,350 @@
-# Web surround localized strings
-# English language
-# Important: This file must be saved with UTF-8 encoding
-# General
-# Fonts - the 6 following entries are mandatory
- at fontWindows        = Arial
- at fontsizeWindows    = 8pt
- at fontLinux          = Arial
- at fontsizeLinux      = 8pt
- at fontMacintosh      = Arial
- at fontsizeMacintosh  = 8pt
-# Distances
-DISTANCEMILES       = Miles
-DISTANCEKILOMETERS  = Kilometers
-DISTANCEFEET        = Feet
-DISTANCEMETERS      = Meters
-# Fill Patterns/Values
-FILLSOLID           = Solid
-FILLNET             = Net
-FILLLINE            = Line
-FILLLINE45          = Line_45
-FILLLINE90          = Line_90
-FILLLINE135         = Line_135
-FILLSQUARE          = Square
-FILLBOX             = Box
-FILLCROSS           = Cross
-FILLDASH            = Dash
-FILLDOLMIT          = Dolmit
-FILLHEX             = Hex
-FILLSACNCR          = Sacncr
-FILLSTEEL           = Steel
-# Transparency
-TRANSPARENT         = transparent
-# Line Styles/Values
-LINESOLID           = Solid
-LINEDASH            = Dash
-LINEDOT             = Dot
-LINEDASHDOT         = DashDot
-LINEDASHDOTDOT      = DashDotDot
-LINERAIL            = Rail
-LINEBORDER          = Border
-LINEDIVIDE          = Divide
-LINEFENCELINE       = FenceLine
-# Buttons
-BUTTONOK            = OK
-BUTTONDONE          = Done
-BUTTONCANCEL        = Cancel
-BUTTONREFRESH       = Refresh
-BUTTONCLOSE         = Close
-BUTTONCLEAR         = Clear
-BUTTONSAVE          = Save
-# Colors
-COLORRED            = Red
-COLORGREEN          = Green
-COLORBLUE           = Blue
-# BufferReport
-BUFFERREPORTTITLE               = Create Buffer
-BUFFERREPORTCREATED             = %s has been created.
-BUFFERREPORTUPDATED             = %s has been updated.
-BUFFERREPORTFEATURESSINGULAR    = %s buffer feature was created.
-BUFFERREPORTFEATURESPLURAL      = %s buffer features were created.
-BUFFERREPORTWARNINGSINGULAR     = <b>Warning:</b> %s layer was excluded from buffer computation because its coordinate system is incompatible with the coordinate system of the map, or because it has no coordinate system at all
-BUFFERREPORTWARNINGPLURAL       = <b>Warning:</b> %s layers were excluded from buffer computation because their coordinate systems are incompatible with the coordinate system of the map, or because they have no coordinate system at all
-BUFFERREPORTERRORTITLE          = Buffer Error
-# Buffer
-BUFFERCLASSDESCR                = Feature class for buffer layer
-BUFFERSCHEMADESCR               = Temporary buffer schema
-BUFFERDIFFARBXY                 = Cannot compute a unique buffer around features with different 'Arbitrary X-Y' coordinate systems. Please uncheck the option 'Merge buffer areas' or select only one layer
-# BufferUI
-BUFFERTITLE                     = Create a Buffer
-BUFFERSUBTITLE                  = &nbsp;Buffer settings
-BUFFERINFOTEXT                  = Select features on the image.
-BUFFERDISTANCE                  = Distance around features:
-BUFFERLAYERS                    = Layers to include in the buffer:
-BUFFERNOLAYER                   = <No layer selected>
-BUFFERNAME                      = Name for the resulting buffer layer:
-BUFFERNAMETEXT                  = Buffer 1
-BUFFERMERGE                     = Merge buffer areas
-BUFFERFILLSTYLE                 = &nbsp;Fill style
-BUFFERFILLPATTERN               = Fill pattern:
-BUFFERFOREGROUNDCOLOR           = Foreground color:
-BUFFERTRANSPARENCY              = Transparency:
-BUFFERBACKGROUNDCOLOR           = Background color:
-BUFFERBORDERSTYLE               = &nbsp;Border style
-BUFFERBORDERLINEPATTERN         = Line pattern:
-BUFFERBORDERLINECOLOR           = Line color:
-BUFFERBORDERLINETHICKNESS       = Line thickness:
-BUFFERHELP                      = <li><p align="left">Results of the buffer are put into a new layer above the top feature layer. This buffer layer has the name you enter here.</li><li><p align="left">To create multiple buffer layers, use different buffer names.</li><li><p align="left">To hide buffer layers, turn them off.</li><li><p align="left">Buffer layers are temporary and are removed when you close the viewer.</li>
-BUFFERERRORZERODISTANCE         = Please enter a nonzero distance.
-BUFFERERRORNOLAYERNAME          = Please enter a layer name.
-BUFFERERRORNEGATIVETHICKNESS    = Please enter positive or null thickness.
-BUFFERERRORNOSELECTION          = Please select feature(s) to calculate a buffer around.
-# ColorPicker
-COLORPICKERDLGTITLE             = Select a color
-COLORPICKERTITLE                = Color palette
-COLORPICKERSUBTITLE             = Specify a color
-COLORPICKER100TRANSPARENCY      = 100%% transparency
-COLORPICKERHEXFORMAT            = Hex format
-# MeasureUI
-MEASUREDISTANCETITLE    = Measure Distance
-MEASUREAREATITLE        = Measure Area
-MEASUREBOTHTITLE        = Measure Distance And Area
-MEASUREINFO             = Click a start and end point.
-RESUME                  = Resume
-STOP                    = Stop
-CLEAR                   = Clear
-MILES                   = Miles
-KILOMETERS              = Kilometers
-MEASUREHELP             = <li>To measure multiple distances, continue clicking new points.</li><li>To finish, click &quot;Stop&quot;.</li><li>You can pan or zoom and continue measuring by clicking &quot;Resume&quot;.</li><li>To start over, click &quot;Clear&quot;.</li>
-SEGMENT                 = Segment
-TOTAL                   = Total
-LENGTH                  = Length
-TOTALLENGTH             = Total Length
-TOTALAREA               = Total Area
-MEASUREERROR            = Measure Error
-# Measure
-MEASUREFEATURECLASS     = Feature class for measure layer
-MEASURESCHEMADESCR      = Temporary measure schema
-MEASUREPARTIAL          = Partial
-MEASURETOTAL            = total
-MEASURELAYER            = Measure
-# FeatureInfoUI
-FEATUREINFOTITLE        = Feature Information
-FEATUREINFOSUBTITLE     = Select a Layer
-FEATUREINFOLAYER        = Layer:
-FEATUREINFOSELECTFEATURE= Select Features:
-FEATUREINFODIGITIZE     = Digitize:
-FEATUREINFOPOINT        = Point
-FEATUREINFORECTANGLE    = Rectangle
-FEATUREINFOPOLYGON      = Polygon
-FEATUREINFOTOTAL        = Total:
-FEATUREINFONOSELECTED   = no features selected.
-FEATUREINFOERROR        = Error
-FEATUREINFOFETCHINFO    = fetching feature info ...
-FEATUREINFOFEATURESEL   = features selected
-FEATUREINFOAREA         = Area:
-FEATUREINFOAREAUNDEFINE = areaIdx undefined
-FEATUREINFONOINFO       = no layer info
-FEATUREINFONOFEATUREIN  = no features in selected layer.
-# QueryUI
-QUERYTITLE              = Query Features
-QUERYSELECTLAYER        = Select a Layer
-QUERYLAYER              = Layer:
-QUERYPROPERTYFILTER     = Property Filter
-QUERYPROPERTY           = Property:
-QUERYOPERATOR           = Operator:
-QUERYVALUE              = Value:
-QUERYSPATIALFILTER      = Spatial Filter
-QUERYDIGITIZE           = Digitize:
-QUERYRECTANGLE          = Rectangle
-QUERYPOLYGON            = Polygon
-QUERYCLEAR              = Clear
-QUERYOUTPUT             = Output
-QUERYOUTPUTPROPERTY     = Output property:
-QUERYEXECUTE            = Execute
-QUERYMAXRESULT          = Max results:
-QUERYRESULTS            = Results
-QUERYSCALE              = Scale:
-QUERYZOOM               = Zoom
-QUERYSELECT             = Select
-QUERYERROR              = Error
-QUERYEQUALTO            = Equal to
-QUERYNOTEQUALTO         = Not equal to
-QUERYGREATTHAN          = Greater than
-QUERYGREATTHANEQUAL     = Greater than or equal to
-QUERYLESSTHAN           = Less than
-QUERYLESSTHANEQUAL      = Less than or equal to
-QUERYBEGIN              = Begins with
-QUERYCONTAINS           = Contains
-# Theme UI
-THEMETITLE              = Theme Layer
-THEMESELECTLAYER        = Select a Layer
-THEMELAYER              = Layer:
-THEMENAME               = Theme Name:
-THEMECONDITIONS         = Define Conditions
-THEMEPROPERTY           = Property:
-THEMEMIN                = Min:
-THEMEMAX                = Max:
-THEMEDISTRIBUTION       = Distribution:
-THEMERULE               = # of Rules:
-THEMESCALERANGE         = Scale Range
-THEMESTYLERAMP          = Style Ramp
-THEMEFILLTRANS          = Fill Transparency:
-THEMEFILLCOLOR          = Fill Color:
-THEMEFROM               = From:
-THEMETO                 = To:
-THEMEBORDERCOLOR        = Border Color:
-THEMEAPPLY              = Apply
-THEMEERROR              = Error
-THEMEINDIVIDUAL         = Individual
-THEMEEQUAL              = Equal
-THEMESTANDARD           = Standard Deviation
-THEMEQUANTILE           = Quantile
-THEMEJENKS              = Jenks (Natural Breaks)
-# Redline UI
-REDLINEOPTIONS          = Digitizing Options
-REDLINESELECTLAYER      = Select Layer:
-REDLINENEW              = New
-REDLINERENAME           = Rename
-REDLINEREMOVE           = Remove
-REDLINEDRAW             = Draw:
-REDLINEPOINT            = Point
-REDLINELINE             = Line
-REDLINERECTANGLE        = Rectangle
-REDLINEPOLYGON          = Polygon
-REDLINESAVE             = Save
-REDLINEUPLOAD           = Upload
-REDLINEFEATURES         = Features
-# HtmlViewerAbout
-HTMLABOUTTITLE          = About %s
-HTMLABOUTTITLEBAR       = MapGuide Viewer
-HTMLABOUTSERVERTITLE    = MapGuide Server
-HTMLABOUTVIEWERTITLE    = MapGuide Viewer
-HTMLABOUTSERVERVERSION  = %s (Version %s)
-HTMLABOUTVIEWERVERSION  = %s (Version %s)
-HTMLABOUTTEXT           = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL").  A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright &copy; 2007 Autodesk, Inc.<br><br>
-HTMLABOUTLICENSE        = license file
-HTMLABOUTLICENSEFILE    = license_en.htm
-# LegendUI
-LEGENDLISTSEPARATOR     = ,
-# PrintablePageUi
-PRINTTITLE              = Get Printable Page
-PRINTELEMENTS           = Select the elements to include in the print layout.
-PRINTPAGETITLE          = Page title:
-PRINTLEGEND             = Legend
-PRINTNORTHARROW         = North arrow
-PRINTCREATEPAGE         = Create Page
-# PropertyCtrl
-PROPERTIESNONE          = None Selected
-PROPERTIESNAME          = Name
-PROPERTIESVALUE         = Value
-PROPERTIESITEMSEL       = Items selected: {0}
-# Search
-SEARCHDLGTITLE          = Search features
-SEARCHTITLE             = Search results
-SEARCHERROR             = Search error
-SEARCHREPORT            = Search report
-SEARCHLAYERNOTFOUND     = Layer {0} not found!
-SEARCHNOMULTIPROP       = Multi-properties identity not supported yet
-SEARCHTYYPENOTSUP       = Identity property type not supported yet ({0})
-SEARCHNOMATCHES         = No matches.
-# SearchPrompt
-SEARCHPROMPTFIND        = Find
-# SelectWithinUi
-SELECTWITHINTITLE       = Select Within
-SELECTWITHINAREAS       = Select areas on the image.
-SELECTWITHINRESTRICTION = Restrict results to selected layers:
-SELECTWITHINTEXT        = <li>If you continue to select areas on the image, click &quot;Refresh&quot; to update the layer list.</li><li>To finish and select all features within the highlighted areas, click &quot;Done&quot;.</li><li>To start over, click &quot;Clear&quot;.</li>
-# Error/Report
-REPORTTITLE             = Report
-# Legend UI
-REFRESH                 = Refresh
-EXPANDALL               = Expand
-COLLAPSEALL             = Collapse All
-DISPLAYALLINGROUP       = Display All in Group
-HIDEALLINGROUP          = Hide All in Group
-SHOWLONGTHEME           = Show Long Theme
-# Task Bar
-TASKS                   = Tasks
-# Viewer Options
-OPTIONSTITLE            = Viewer Options
-OPTIONSINFOTEXT         = Select viewing options for status bar and tool tips.
-OPTIONSDISTANCE         = Display distances in
-OPTIONSMETRIC           = Metric (Kilometers, Meters)
-OPTIONSUSENGLISH        = US/English (Miles, Feet)
-OPTIONSPOSITION         = Display cursor position in
-OPTIONSLATLON           = Latitude, Longitude (Degrees)
-OPTIONSMAPUNITS         = Map Coordinate System (X,Y)
-# AJAX Viewer
-VIEWERLAYERS            = Layers
-VIEWERPROPS             = Properties
-VIEWERPANNORTH          = Pan North
-VIEWERPANWEST           = Pan West
-VIEWERPANSOUTH          = Pan South
-VIEWERPANEAST           = Pan East
-VIEWERZOOMIN            = Zoom In
-VIEWERZOOMOUT           = Zoom Out
-VIEWERMOVESLIDER        = Drag to move slider
-VIEWERDRAGZOOM          = Drag to zoom
-ENDSEL                  = CTRL + click to end
-ENDSELSAFARI            = SHIFT + click to end
-DECIMALSEPARATOR        = .
-THOUSANDSEPARATOR       = ,
-# Main Frame
-NEEDLOGIN               = You must enter a valid login ID and password to access this site
-ALREADYINMEASURE        = Only one measure command is allowed in a web layout
-ACCESSDENIED            = Access Denied
-LATLONCURPOS            = Lat: {0}, Lon: {1}
-MAPUNITSCURPOS          = X: {0}, Y: {1}
-FEATURESSELECTED        = {0} features selected
-FEATURESELECTED         = {0} feature selected
-MI                      = mi
-FT                      = ft
-IN                      = in
-KM                      = km
-MT                      = m
-CM                      = cm
-DIGALREADYRUNNING       = Cannot execute measure: A digitization command is in progress.
-MEASALREADYRUNNING      = Cannot execute digitization: A measure is in progress.
-# Localized Icon Files
-# Quick Plot UI
-QUICKPLOT_HEADER        = Quick Plot
-QUICKPLOT_TITLE         = Title
-QUICKPLOT_SUBTITLE      = Sub title
-QUICKPLOT_PAPER_SIZE    = Paper size
-QUICKPLOT_SCALING       = Scaling
-QUICKPLOT_DPI           = Print DPI
-QUICKPLOT_GENERATE      = Generate
-QUICKPLOT_ADVANCED_OPTIONS = Advanced options
-QUICKPLOT_PRINT         = Print
-QUICKPLOT_CANCEL        = Cancel
-QUICKPLOT_PREVIEW_ERROR = The application resources required to generate the plot exceed the settings defined by the administrator
-QUICKPLOT_RESOLUTION_WARNING = The current settings exceed the map resolution. Zooming out or increasing the scaling will help create a more legible plot
-QUICKPLOT_SCALE_LABEL   = Scale
+# Web surround localized strings
+# English language
+# Important: This file must be saved with UTF-8 encoding
+# General
+# Fonts - the 6 following entries are mandatory
+ at fontWindows        = Arial
+ at fontsizeWindows    = 8pt
+ at fontLinux          = Arial
+ at fontsizeLinux      = 8pt
+ at fontMacintosh      = Arial
+ at fontsizeMacintosh  = 8pt
+# Distances
+DISTANCEMILES       = Miles
+DISTANCEKILOMETERS  = Kilometers
+DISTANCEFEET        = Feet
+DISTANCEMETERS      = Meters
+# Fill Patterns/Values
+FILLSOLID           = Solid
+FILLNET             = Net
+FILLLINE            = Line
+FILLLINE45          = Line_45
+FILLLINE90          = Line_90
+FILLLINE135         = Line_135
+FILLSQUARE          = Square
+FILLBOX             = Box
+FILLCROSS           = Cross
+FILLDASH            = Dash
+FILLDOLMIT          = Dolmit
+FILLHEX             = Hex
+FILLSACNCR          = Sacncr
+FILLSTEEL           = Steel
+# Transparency
+TRANSPARENT         = transparent
+# Line Styles/Values
+LINESOLID           = Solid
+LINEDASH            = Dash
+LINEDOT             = Dot
+LINEDASHDOT         = DashDot
+LINEDASHDOTDOT      = DashDotDot
+LINERAIL            = Rail
+LINEBORDER          = Border
+LINEDIVIDE          = Divide
+LINEFENCELINE       = FenceLine
+# Buttons
+BUTTONOK            = OK
+BUTTONDONE          = Done
+BUTTONCANCEL        = Cancel
+BUTTONREFRESH       = Refresh
+BUTTONCLOSE         = Close
+BUTTONCLEAR         = Clear
+BUTTONSAVE          = Save
+# Colors
+COLORRED            = Red
+COLORGREEN          = Green
+COLORBLUE           = Blue
+# BufferReport
+BUFFERREPORTTITLE               = Create Buffer
+BUFFERREPORTCREATED             = %s has been created.
+BUFFERREPORTUPDATED             = %s has been updated.
+BUFFERREPORTFEATURESSINGULAR    = %s buffer feature was created.
+BUFFERREPORTFEATURESPLURAL      = %s buffer features were created.
+BUFFERREPORTWARNINGSINGULAR     = <b>Warning:</b> %s layer was excluded from buffer computation because its coordinate system is incompatible with the coordinate system of the map, or because it has no coordinate system at all
+BUFFERREPORTWARNINGPLURAL       = <b>Warning:</b> %s layers were excluded from buffer computation because their coordinate systems are incompatible with the coordinate system of the map, or because they have no coordinate system at all
+BUFFERREPORTERRORTITLE          = Buffer Error
+# Buffer
+BUFFERCLASSDESCR                = Feature class for buffer layer
+BUFFERSCHEMADESCR               = Temporary buffer schema
+BUFFERDIFFARBXY                 = Cannot compute a unique buffer around features with different 'Arbitrary X-Y' coordinate systems. Please uncheck the option 'Merge buffer areas' or select only one layer
+# BufferUI
+BUFFERTITLE                     = Create a Buffer
+BUFFERSUBTITLE                  = &nbsp;Buffer settings
+BUFFERINFOTEXT                  = Select features on the image.
+BUFFERDISTANCE                  = Distance around features:
+BUFFERLAYERS                    = Layers to include in the buffer:
+BUFFERNOLAYER                   = <No layer selected>
+BUFFERNAME                      = Name for the resulting buffer layer:
+BUFFERNAMETEXT                  = Buffer 1
+BUFFERMERGE                     = Merge buffer areas
+BUFFERFILLSTYLE                 = &nbsp;Fill style
+BUFFERFILLPATTERN               = Fill pattern:
+BUFFERFOREGROUNDCOLOR           = Foreground color:
+BUFFERTRANSPARENCY              = Transparency:
+BUFFERBACKGROUNDCOLOR           = Background color:
+BUFFERBORDERSTYLE               = &nbsp;Border style
+BUFFERBORDERLINEPATTERN         = Line pattern:
+BUFFERBORDERLINECOLOR           = Line color:
+BUFFERBORDERLINETHICKNESS       = Line thickness:
+BUFFERHELP                      = <li><p align="left">Results of the buffer are put into a new layer above the top feature layer. This buffer layer has the name you enter here.</li><li><p align="left">To create multiple buffer layers, use different buffer names.</li><li><p align="left">To hide buffer layers, turn them off.</li><li><p align="left">Buffer layers are temporary and are removed when you close the viewer.</li>
+BUFFERERRORZERODISTANCE         = Please enter a nonzero distance.
+BUFFERERRORNOLAYERNAME          = Please enter a layer name.
+BUFFERERRORNEGATIVETHICKNESS    = Please enter positive or null thickness.
+BUFFERERRORNOSELECTION          = Please select feature(s) to calculate a buffer around.
+# ColorPicker
+COLORPICKERDLGTITLE             = Select a color
+COLORPICKERTITLE                = Color palette
+COLORPICKERSUBTITLE             = Specify a color
+COLORPICKER100TRANSPARENCY      = 100%% transparency
+COLORPICKERHEXFORMAT            = Hex format
+# MeasureUI
+MEASUREDISTANCETITLE    = Measure Distance
+MEASUREAREATITLE        = Measure Area
+MEASUREBOTHTITLE        = Measure Distance And Area
+MEASUREINFO             = Click a start and end point.
+RESUME                  = Resume
+STOP                    = Stop
+CLEAR                   = Clear
+MILES                   = Miles
+KILOMETERS              = Kilometers
+MEASUREHELP             = <li>To measure multiple distances, continue clicking new points.</li><li>To finish, click &quot;Stop&quot;.</li><li>You can pan or zoom and continue measuring by clicking &quot;Resume&quot;.</li><li>To start over, click &quot;Clear&quot;.</li>
+SEGMENT                 = Segment
+TOTAL                   = Total
+LENGTH                  = Length
+TOTALLENGTH             = Total Length
+TOTALAREA               = Total Area
+MEASUREERROR            = Measure Error
+# Measure
+MEASUREFEATURECLASS     = Feature class for measure layer
+MEASURESCHEMADESCR      = Temporary measure schema
+MEASUREPARTIAL          = Partial
+MEASURETOTAL            = total
+MEASURELAYER            = Measure
+# FeatureInfoUI
+FEATUREINFOTITLE        = Feature Information
+FEATUREINFOSUBTITLE     = Select a Layer
+FEATUREINFOLAYER        = Layer:
+FEATUREINFOSELECTFEATURE= Select Features:
+FEATUREINFODIGITIZE     = Digitize:
+FEATUREINFOPOINT        = Point
+FEATUREINFORECTANGLE    = Rectangle
+FEATUREINFOPOLYGON      = Polygon
+FEATUREINFOTOTAL        = Total:
+FEATUREINFONOSELECTED   = no features selected.
+FEATUREINFOERROR        = Error
+FEATUREINFOFETCHINFO    = fetching feature info ...
+FEATUREINFOFEATURESEL   = features selected
+FEATUREINFOAREA         = Area:
+FEATUREINFOAREAUNDEFINE = areaIdx undefined
+FEATUREINFONOINFO       = no layer info
+FEATUREINFONOFEATUREIN  = no features in selected layer.
+# QueryUI
+QUERYTITLE              = Query Features
+QUERYSELECTLAYER        = Select a Layer
+QUERYLAYER              = Layer:
+QUERYPROPERTYFILTER     = Property Filter
+QUERYPROPERTY           = Property:
+QUERYOPERATOR           = Operator:
+QUERYVALUE              = Value:
+QUERYSPATIALFILTER      = Spatial Filter
+QUERYDIGITIZE           = Digitize:
+QUERYRECTANGLE          = Rectangle
+QUERYPOLYGON            = Polygon
+QUERYCLEAR              = Clear
+QUERYOUTPUT             = Output
+QUERYOUTPUTPROPERTY     = Output property:
+QUERYEXECUTE            = Execute
+QUERYMAXRESULT          = Max results:
+QUERYRESULTS            = Results
+QUERYSCALE              = Scale:
+QUERYZOOM               = Zoom
+QUERYSELECT             = Select
+QUERYERROR              = Error
+QUERYEQUALTO            = Equal to
+QUERYNOTEQUALTO         = Not equal to
+QUERYGREATTHAN          = Greater than
+QUERYGREATTHANEQUAL     = Greater than or equal to
+QUERYLESSTHAN           = Less than
+QUERYLESSTHANEQUAL      = Less than or equal to
+QUERYBEGIN              = Begins with
+QUERYCONTAINS           = Contains
+# Theme UI
+THEMETITLE              = Theme Layer
+THEMESELECTLAYER        = Select a Layer
+THEMELAYER              = Layer:
+THEMENAME               = Theme Name:
+THEMECONDITIONS         = Define Conditions
+THEMEPROPERTY           = Property:
+THEMEMIN                = Min:
+THEMEMAX                = Max:
+THEMEDISTRIBUTION       = Distribution:
+THEMERULE               = # of Rules:
+THEMESCALERANGE         = Scale Range
+THEMESTYLERAMP          = Style Ramp
+THEMEFILLTRANS          = Fill Transparency:
+THEMEFILLCOLOR          = Fill Color:
+THEMEFROM               = From:
+THEMETO                 = To:
+THEMEBORDERCOLOR        = Border Color:
+THEMEAPPLY              = Apply
+THEMEERROR              = Error
+THEMEINDIVIDUAL         = Individual
+THEMEEQUAL              = Equal
+THEMESTANDARD           = Standard Deviation
+THEMEQUANTILE           = Quantile
+THEMEJENKS              = Jenks (Natural Breaks)
+# Redline UI
+REDLINEOPTIONS          = Digitizing Options
+REDLINESELECTLAYER      = Select Layer:
+REDLINENEW              = New
+REDLINERENAME           = Rename
+REDLINEREMOVE           = Remove
+REDLINEDRAW             = Draw:
+REDLINEPOINT            = Point
+REDLINELINE             = Line
+REDLINERECTANGLE        = Rectangle
+REDLINEPOLYGON          = Polygon
+REDLINESAVE             = Save
+REDLINEUPLOAD           = Upload
+REDLINEFEATURES         = Features
+# HtmlViewerAbout
+HTMLABOUTTITLE          = About %s
+HTMLABOUTTITLEBAR       = MapGuide Viewer
+HTMLABOUTSERVERTITLE    = MapGuide Server
+HTMLABOUTVIEWERTITLE    = MapGuide Viewer
+HTMLABOUTSERVERVERSION  = %s (Version %s)
+HTMLABOUTVIEWERVERSION  = %s (Version %s)
+HTMLABOUTTEXT           = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL").  A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright &copy; 2007 Autodesk, Inc.<br><br>
+HTMLABOUTLICENSE        = license file
+HTMLABOUTLICENSEFILE    = license_en.htm
+# LegendUI
+LEGENDLISTSEPARATOR     = ,
+# PrintablePageUi
+PRINTTITLE              = Get Printable Page
+PRINTELEMENTS           = Select the elements to include in the print layout.
+PRINTPAGETITLE          = Page title:
+PRINTLEGEND             = Legend
+PRINTNORTHARROW         = North arrow
+PRINTCREATEPAGE         = Create Page
+# PropertyCtrl
+PROPERTIESNONE          = None Selected
+PROPERTIESNAME          = Name
+PROPERTIESVALUE         = Value
+PROPERTIESITEMSEL       = Items selected: {0}
+# Search
+SEARCHDLGTITLE          = Search features
+SEARCHTITLE             = Search results
+SEARCHERROR             = Search error
+SEARCHREPORT            = Search report
+SEARCHLAYERNOTFOUND     = Layer {0} not found!
+SEARCHNOMULTIPROP       = Multi-properties identity not supported yet
+SEARCHTYYPENOTSUP       = Identity property type not supported yet ({0})
+SEARCHNOMATCHES         = No matches.
+# SearchPrompt
+SEARCHPROMPTFIND        = Find
+# SelectWithinUi
+SELECTWITHINTITLE       = Select Within
+SELECTWITHINAREAS       = Select areas on the image.
+SELECTWITHINRESTRICTION = Restrict results to selected layers:
+SELECTWITHINTEXT        = <li>If you continue to select areas on the image, click &quot;Refresh&quot; to update the layer list.</li><li>To finish and select all features within the highlighted areas, click &quot;Done&quot;.</li><li>To start over, click &quot;Clear&quot;.</li>
+# Error/Report
+REPORTTITLE             = Report
+# Legend UI
+REFRESH                 = Refresh
+EXPANDALL               = Expand
+COLLAPSEALL             = Collapse All
+DISPLAYALLINGROUP       = Display All in Group
+HIDEALLINGROUP          = Hide All in Group
+SHOWLONGTHEME           = Show Long Theme
+# Task Bar
+TASKS                   = Tasks
+# Viewer Options
+OPTIONSTITLE            = Viewer Options
+OPTIONSINFOTEXT         = Select viewing options for status bar and tool tips.
+OPTIONSDISTANCE         = Display distances in
+OPTIONSMETRIC           = Metric (Kilometers, Meters)
+OPTIONSUSENGLISH        = US/English (Miles, Feet)
+OPTIONSPOSITION         = Display cursor position in
+OPTIONSLATLON           = Latitude, Longitude (Degrees)
+OPTIONSMAPUNITS         = Map Coordinate System (X,Y)
+# AJAX Viewer
+VIEWERLAYERS            = Layers
+VIEWERPROPS             = Properties
+VIEWERPANNORTH          = Pan North
+VIEWERPANWEST           = Pan West
+VIEWERPANSOUTH          = Pan South
+VIEWERPANEAST           = Pan East
+VIEWERZOOMIN            = Zoom In
+VIEWERZOOMOUT           = Zoom Out
+VIEWERMOVESLIDER        = Drag to move slider
+VIEWERDRAGZOOM          = Drag to zoom
+ENDSEL                  = CTRL + click to end
+ENDSELSAFARI            = SHIFT + click to end
+DECIMALSEPARATOR        = .
+THOUSANDSEPARATOR       = ,
+# Main Frame
+NEEDLOGIN               = You must enter a valid login ID and password to access this site
+ALREADYINMEASURE        = Only one measure command is allowed in a web layout
+ACCESSDENIED            = Access Denied
+LATLONCURPOS            = Lat: {0}, Lon: {1}
+MAPUNITSCURPOS          = X: {0}, Y: {1}
+FEATURESSELECTED        = {0} features selected
+FEATURESELECTED         = {0} feature selected
+MI                      = mi
+FT                      = ft
+IN                      = in
+KM                      = km
+MT                      = m
+CM                      = cm
+DIGALREADYRUNNING       = Cannot execute measure: A digitization command is in progress.
+MEASALREADYRUNNING      = Cannot execute digitization: A measure is in progress.
+# Localized Icon Files
+# Quick Plot UI
+QUICKPLOT_HEADER        = Quick Plot
+QUICKPLOT_TITLE         = Title
+QUICKPLOT_SUBTITLE      = Sub title
+QUICKPLOT_PAPER_SIZE    = Paper size
+QUICKPLOT_SCALING       = Scaling
+QUICKPLOT_DPI           = Print DPI
+QUICKPLOT_GENERATE      = Generate
+QUICKPLOT_ADVANCED_OPTIONS = Advanced options
+QUICKPLOT_PRINT         = Print
+QUICKPLOT_CANCEL        = Cancel
+QUICKPLOT_PREVIEW_ERROR = The application resources required to generate the plot exceed the settings defined by the administrator
+QUICKPLOT_RESOLUTION_WARNING = The current settings exceed the map resolution. Zooming out or increasing the scaling will help create a more legible plot
+QUICKPLOT_SCALE_LABEL   = Scale
Property changes on: trunk/text/fr
   + native
Modified: trunk/text/fr.json
--- trunk/text/fr.json	2010-11-11 15:41:30 UTC (rev 2274)
+++ trunk/text/fr.json	2010-11-12 20:02:09 UTC (rev 2275)
@@ -1,69 +1,69 @@
-Fusion.Strings.fr = {
-'ajaxError': 'Exception occurred in AJAX callback.\n${exception}\nLocation: ${file} (${line}))',
-'noSelection': 'Aucun Sélection',
-'value': 'Value',
-'deg': 'Degrees',
-'selectionPanelTitle': 'Sélection',
-'panWest': 'Ouest',
-'panEast': 'Est',
-'panSouth': 'Sud',
-'panNorth': 'Nord',
-'zoomOut': 'Cliquer pour réduire',
-'zoomIn': 'Cliquer pour agrandir',
-'maptipLinkText': 'Cliquer pour plus d information',
-'end': ''
+Fusion.Strings.fr = {
+'ajaxError': 'Exception occurred in AJAX callback.\n${exception}\nLocation: ${file} (${line}))',
+'noSelection': 'Aucun Sélection',
+'value': 'Value',
+'deg': 'Degrees',
+'selectionPanelTitle': 'Sélection',
+'panWest': 'Ouest',
+'panEast': 'Est',
+'panSouth': 'Sud',
+'panNorth': 'Nord',
+'zoomOut': 'Cliquer pour réduire',
+'zoomIn': 'Cliquer pour agrandir',
+'maptipLinkText': 'Cliquer pour plus d information',
+'end': ''
Property changes on: trunk/text/fr.json
   + native
More information about the fusion-commits mailing list
