[fusion-commits] r2265 - in trunk: . layers/Generic lib/OpenLayers templates/mapguide/standard
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Oct 28 15:22:14 EDT 2010
Author: madair
Date: 2010-10-28 12:22:14 -0700 (Thu, 28 Oct 2010)
New Revision: 2265
   trunk/fusion.cfg
   trunk/layers/Generic/Generic.js
   trunk/lib/OpenLayers/OpenLayers.js
   trunk/templates/mapguide/standard/ApplicationDefinition.xml
   trunk/templates/mapguide/standard/index.html
re #411: updating the Google layer to use v3 of Google API applied to trunk
Modified: trunk/fusion.cfg
--- trunk/fusion.cfg	2010-10-28 18:30:18 UTC (rev 2264)
+++ trunk/fusion.cfg	2010-10-28 19:22:14 UTC (rev 2265)
@@ -28,6 +28,7 @@
 OpenLayers/Layer/MapGuide.js
 OpenLayers/Layer/MapServer.js
 OpenLayers/Layer/Google.js
+OpenLayers/Layer/Google/v3.js
 OpenLayers/Layer/VirtualEarth.js
 OpenLayers/Layer/Yahoo.js
 OpenLayers/Layer/Vector.js
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js	2010-10-28 18:30:18 UTC (rev 2264)
+++ trunk/layers/Generic/Generic.js	2010-10-28 19:22:14 UTC (rev 2265)
@@ -99,26 +99,30 @@
           case 'Google':
             switch (this.mapTag.layerOptions.type) {   //Google layer types are actual objects
               case 'G_PHYSICAL_MAP':              //defined by gmap, not a string
-                this.mapTag.layerOptions.type = G_PHYSICAL_MAP;
+              case 'TERRAIN':
+                this.mapTag.layerOptions.type = google.maps.MapTypeId.TERRAIN;
                 break;
               case 'G_HYBRID_MAP':
-                this.mapTag.layerOptions.type = G_HYBRID_MAP;
+              case 'HYBRID':
+                this.mapTag.layerOptions.type = google.maps.MapTypeId.HYBRID;
                 break;
               case 'G_SATELLITE_MAP':
-                this.mapTag.layerOptions.type = G_SATELLITE_MAP;
+              case 'SATELLITE':
+                this.mapTag.layerOptions.type = google.maps.MapTypeId.SATELLITE;
                 break;
               case 'G_NORMAL_MAP':
-                this.mapTag.layerOptions.type = G_NORMAL_MAP;
+              case 'ROADMAP':
+                this.mapTag.layerOptions.type = google.maps.MapTypeId.ROADMAP;
               default:
                 // For the re-loaded Google layers
-                if(this.mapTag.layerOptions.type == G_PHYSICAL_MAP)
-                else if(this.mapTag.layerOptions.type == G_HYBRID_MAP)
-                else if(this.mapTag.layerOptions.type == G_SATELLITE_MAP)
+                if(this.mapTag.layerOptions.type == google.maps.MapTypeId.TERRAIN)
+                else if(this.mapTag.layerOptions.type == google.maps.MapTypeId.HYBRID)
+                else if(this.mapTag.layerOptions.type == google.maps.MapTypeId.SATELLITE)
                 else
                 break;
             break;
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js	2010-10-28 18:30:18 UTC (rev 2264)
+++ trunk/lib/OpenLayers/OpenLayers.js	2010-10-28 19:22:14 UTC (rev 2265)
@@ -1,95 +1,95 @@
-  OpenLayers.js -- OpenLayers Map Viewer Library
-  Copyright 2005-2010 OpenLayers Contributors, released under the Clear BSD
-  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
-  for the full text of the license.
-  Includes compressed code under the following licenses:
-  (For uncompressed versions of the code used please see the
-  OpenLayers SVN repository: <http://openlayers.org/>)
-/* Contains portions of Prototype.js:
- * Prototype JavaScript framework, version 1.4.0
- *  (c) 2005 Sam Stephenson <sam at conio.net>
- *  Prototype is freely distributable under the terms of an MIT-style license.
- *  For details, see the Prototype web site: http://prototype.conio.net/
-*  Contains portions of Rico <http://openrico.org/>
-*  Copyright 2005 Sabre Airline Solutions
-*  Licensed under the Apache License, Version 2.0 (the "License"); you
-*  may not use this file except in compliance with the License. You
-*  may obtain a copy of the License at
-*         http://www.apache.org/licenses/LICENSE-2.0
-*  Unless required by applicable law or agreed to in writing, software
-*  distributed under the License is distributed on an "AS IS" BASIS,
-*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-*  implied. See the License for the specific language governing
-*  permissions and limitations under the License.
- * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
- * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Contains portions of Gears <http://code.google.com/apis/gears/>
- * Copyright 2007, Google Inc.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- *  1. Redistributions of source code must retain the above copyright notice,
- *     this list of conditions and the following disclaimer.
- *  2. Redistributions in binary form must reproduce the above copyright notice,
- *     this list of conditions and the following disclaimer in the documentation
- *     and/or other materials provided with the distribution.
- *  3. Neither the name of Google Inc. nor the names of its contributors may be
- *     used to endorse or promote products derived from this software without
- *     specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
- * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
- * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
- * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
- * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * Sets up google.gears.*, which is *the only* supported way to access Gears.
- * Circumvent this file at your own risk!
- * In the future, Gears may automatically define google.gears.* without this
- * file. Gears may use these objects to transparently fix bugs and compatibility
- * issues. Applications that use the code below will continue to work seamlessly
- * when that happens.
+  OpenLayers.js -- OpenLayers Map Viewer Library
+  Copyright 2005-2010 OpenLayers Contributors, released under the Clear BSD
+  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+  for the full text of the license.
+  Includes compressed code under the following licenses:
+  (For uncompressed versions of the code used please see the
+  OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ *  (c) 2005 Sam Stephenson <sam at conio.net>
+ *  Prototype is freely distributable under the terms of an MIT-style license.
+ *  For details, see the Prototype web site: http://prototype.conio.net/
+*  Contains portions of Rico <http://openrico.org/>
+*  Copyright 2005 Sabre Airline Solutions
+*  Licensed under the Apache License, Version 2.0 (the "License"); you
+*  may not use this file except in compliance with the License. You
+*  may obtain a copy of the License at
+*         http://www.apache.org/licenses/LICENSE-2.0
+*  Unless required by applicable law or agreed to in writing, software
+*  distributed under the License is distributed on an "AS IS" BASIS,
+*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+*  implied. See the License for the specific language governing
+*  permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ *  1. Redistributions of source code must retain the above copyright notice,
+ *     this list of conditions and the following disclaimer.
+ *  2. Redistributions in binary form must reproduce the above copyright notice,
+ *     this list of conditions and the following disclaimer in the documentation
+ *     and/or other materials provided with the distribution.
+ *  3. Neither the name of Google Inc. nor the names of its contributors may be
+ *     used to endorse or promote products derived from this software without
+ *     specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
     OpenLayers/SingleFile.js
@@ -121,9 +121,19 @@
      * {String} Path to this script
     _getScriptLocation: (function() {
-        var s = document.getElementsByTagName('script');
-        var m = s[s.length-1].getAttribute("src").match(/(^|(.*?\/))(OpenLayers\.js)(\?|$)/);
-        var l = m ? m[1] : "";
+        var r = new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),
+            s = document.getElementsByTagName('script'),
+            src, m, l = "";
+        for(var i=0, len=s.length; i<len; i++) {
+            src = s[i].getAttribute('src');
+            if(src) {
+                var m = src.match(r);
+                if(m) {
+                    l = m[1];
+                    break;
         return (function() { return l; });
@@ -177,10 +187,19 @@
-            var r = new RegExp("(^|(.*?\\/))(" + scriptName + ")(\\?|$)");
-            var m = s[s.length-1].getAttribute("src").match(r);
+            var r = new RegExp("(^|(.*?\\/))(" + scriptName + ")(\\?|$)"),
+                src, m, l = "";
+                if(src) {
+                    if(m) {
+                        l = m[1];
+                        break;
@@ -3130,7 +3149,7 @@
         if ("toISOString" in Date.prototype) {
             return function(date) {
                 return date.toISOString();
         } else {
             function pad(num, len) {
                 var str = num + "";
@@ -3156,7 +3175,7 @@
                         pad(date.getUTCMilliseconds(), 3) + "Z";
                 return str;
@@ -3186,7 +3205,6 @@
             date = new Date(elapsed);
         } else {
             var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
-            var date;
             if (match && (match[1] || match[7])) { // must have at least year or time
                 var year = parseInt(match[1], 10) || 0;
                 var month = (parseInt(match[2], 10) - 1) || 0;
@@ -7646,22 +7664,6 @@
-     * Method: setExtent
-     * Set the visible part of the layer.
-     * Resolution has probably changed, so we nullify the resolution
-     * cache (this.resolution), then redraw.
-     * Parameters:
-     * extent - {<OpenLayers.Bounds>}
-    setExtent: function(extent) {
-        this.extent = extent.clone();
-        this.resolution = null;
-        this.redraw();
      * Method: setSize
      * Sets the size of the drawing surface.
@@ -29202,14 +29204,14 @@
     callbacks: null,
-     * Property: displaySystem
+     * APIProperty: displaySystem
      * {String} Display system for output measurements.  Supported values
      *     are 'english', 'metric', and 'geographic'.  Default is 'metric'.
     displaySystem: 'metric',
-     * Property: geodesic
+     * APIProperty: geodesic
      * {Boolean} Calculate geodesic metrics instead of planar metrics.  This
      *     requires that geometries can be transformed into Geographic/WGS84
      *     (if that is not already the map projection).  Default is false.
@@ -29217,7 +29219,7 @@
     geodesic: false,
-     * Property: displaySystemUnits
+     * APIProperty: displaySystemUnits
      * {Object} Units for various measurement systems.  Values are arrays
      *     of unit abbreviations (from OpenLayers.INCHES_PER_UNIT) in decreasing
      *     order of length.
@@ -33814,6 +33816,430 @@
+    OpenLayers/Layer/Google/v3.js
+/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Layer/Google.js
+ * Constant: OpenLayers.Layer.Google.v3
+ * Mixin providing functionality specific to the Google Maps API v3. Note that
+ * this layer configures the google.maps.map object with the "disableDefaultUI"
+ * option set to true. Using UI controls that the Google Maps API provides is
+ * not supported by the OpenLayers API.
+OpenLayers.Layer.Google.v3 = {
+     * Constant: DEFAULTS
+     * {Object} It is not recommended to change the properties set here. Note
+     * that Google.v3 layers only work when sphericalMercator is set to true.
+     * (code)
+     *     maxExtent: new OpenLayers.Bounds(
+     *         -128 * 156543.0339,
+     *         128 * 156543.0339,
+     *     sphericalMercator: true,
+     *     maxResolution: 156543.0339,
+     *     units: "m",
+     *     projection: "EPSG:900913"
+     * (end)
+    DEFAULTS: {
+        maxExtent: new OpenLayers.Bounds(
+            -128 * 156543.0339,
+            128 * 156543.0339,
+            128 * 156543.0339
+        sphericalMercator: true,
+        maxResolution: 156543.0339,
+        units: "m",
+        projection: "EPSG:900913"
+     * Method: loadMapObject
+     * Load the GMap and register appropriate event listeners. If we can't
+     *     load GMap2, then display a warning message.
+    loadMapObject:function() {
+        if (!this.type) {
+            this.type = google.maps.MapTypeId.ROADMAP;
+        var mapObject;
+        var cache = OpenLayers.Layer.Google.cache[this.map.id];
+        if (cache) {
+            // there are already Google layers added to this map
+            mapObject = cache.mapObject;
+            // increment the layer count
+            ++cache.count;
+        } else {
+            // this is the first Google layer for this map
+            var container = this.map.viewPortDiv;
+            var div = document.createElement("div");
+            div.id = this.map.id + "_GMapContainer";
+            div.style.position = "absolute";
+            div.style.width = "100%";
+            div.style.height = "100%";
+            container.appendChild(div);
+            // create GMap and shuffle elements
+            var center = this.map.getCenter();
+            mapObject = new google.maps.Map(div, {
+                center: center ?
+                    new google.maps.LatLng(center.lat, center.lon) :
+                    new google.maps.LatLng(0, 0),
+                zoom: this.map.getZoom() || 0,
+                mapTypeId: this.type,
+                disableDefaultUI: true,
+                keyboardShortcuts: false,
+                draggable: false,
+                disableDoubleClickZoom: true,
+                scrollwheel: false,
+                streetViewControl: false
+            // cache elements for use by any other google layers added to
+            // this same map
+            cache = {
+                mapObject: mapObject,
+                count: 1
+            OpenLayers.Layer.Google.cache[this.map.id] = cache;
+            this.repositionListener = google.maps.event.addListenerOnce(
+                mapObject,
+                "center_changed",
+                OpenLayers.Function.bind(this.repositionMapElements, this)
+        this.mapObject = mapObject;
+        this.setGMapVisibility(this.visibility);
+     * Method: repositionMapElements
+     * Waits until powered by and terms of use elements are available and then
+     * moves them so they are clickable.
+    repositionMapElements: function() {
+        // This is the first time any Google layer in this mapObject has been
+        // made visible.  The mapObject needs to know the container size.
+        google.maps.event.trigger(this.mapObject, "resize");
+        var div = this.mapObject.getDiv().firstChild;
+        if (!div || div.childNodes.length < 3) {
+            this.repositionTimer = window.setTimeout(
+                OpenLayers.Function.bind(this.repositionMapElements, this),
+                250
+            return false;
+        // move the ToS and branding stuff up to the container div
+        var termsOfUse = div.lastChild;
+        container.appendChild(termsOfUse);
+        termsOfUse.style.zIndex = "1100";
+        termsOfUse.style.bottom = "";
+        termsOfUse.className = "olLayerGoogleCopyright olLayerGoogleV3";
+        termsOfUse.style.display = "";
+        cache.termsOfUse = termsOfUse;
+        var poweredBy = div.lastChild;
+        container.appendChild(poweredBy);
+        poweredBy.style.zIndex = "1100";
+        poweredBy.style.bottom = "";
+        poweredBy.className = "olLayerGooglePoweredBy olLayerGoogleV3 gmnoprint";
+        poweredBy.style.display = "";
+        cache.poweredBy = poweredBy;
+     * APIMethod: onMapResize
+    onMapResize: function() {
+        if (this.visibility) {
+        } else {
+            if (!this._resized) {
+                var layer = this;
+                google.maps.event.addListenerOnce(this.mapObject, "tilesloaded", function() {
+                    delete layer._resized;
+                    google.maps.event.trigger(layer.mapObject, "resize");
+                    layer.moveTo(layer.map.getCenter(), layer.map.getZoom());
+            this._resized = true;
+     * Method: setGMapVisibility
+     * Display the GMap container and associated elements.
+     * Parameters:
+     * visible - {Boolean} Display the GMap elements.
+    setGMapVisibility: function(visible) {
+        if (cache) {
+            var type = this.type;
+            var layers = this.map.layers;
+            var layer;
+            for (var i=layers.length-1; i>=0; --i) {
+                layer = layers[i];
+                if (layer instanceof OpenLayers.Layer.Google &&
+                            layer.visibility === true && layer.inRange === true) {
+                    type = layer.type;
+                    visible = true;
+                    break;
+            var container = this.mapObject.getDiv();
+            if (visible === true) {
+                this.mapObject.setMapTypeId(type);
+                container.style.left = "";
+                if (cache.termsOfUse && cache.termsOfUse.style) {
+                    cache.termsOfUse.style.left = "";
+                    cache.termsOfUse.style.display = "";
+                    cache.poweredBy.style.display = "";
+                cache.displayed = this.id;
+            } else {
+                delete cache.displayed;
+                container.style.left = "-9999px";
+                    cache.termsOfUse.style.display = "none";
+                    // move ToU far to the left in addition to setting
+                    // display to "none", because at the end of the GMap
+                    // load sequence, display: none will be unset and ToU
+                    // would be visible after loading a map with a google
+                    // layer that is initially hidden.
+                    cache.termsOfUse.style.left = "-9999px";
+                    cache.poweredBy.style.display = "none";
+     * Method: getMapContainer
+     * Returns:
+     * {DOMElement} the GMap container's div
+    getMapContainer: function() {
+        return this.mapObject.getDiv();
+  // TRANSLATION: MapObject Bounds <-> OpenLayers.Bounds
+     * APIMethod: getMapObjectBoundsFromOLBounds
+     * Parameters:
+     * olBounds - {<OpenLayers.Bounds>}
+     * Returns:
+     * {Object} A MapObject Bounds, translated from olBounds
+     *          Returns null if null value is passed in
+    getMapObjectBoundsFromOLBounds: function(olBounds) {
+        var moBounds = null;
+        if (olBounds != null) {
+            var sw = this.sphericalMercator ?
+              this.inverseMercator(olBounds.bottom, olBounds.left) :
+              new OpenLayers.LonLat(olBounds.bottom, olBounds.left);
+            var ne = this.sphericalMercator ?
+              this.inverseMercator(olBounds.top, olBounds.right) :
+              new OpenLayers.LonLat(olBounds.top, olBounds.right);
+            moBounds = new google.maps.LatLngBounds(
+                new google.maps.LatLng(sw.lat, sw.lon),
+                new google.maps.LatLng(ne.lat, ne.lon)
+        return moBounds;
+     *   MapObject Interface Controls   *
+  // LonLat - Pixel Translation
+     * APIMethod: getMapObjectLonLatFromMapObjectPixel
+     * Parameters:
+     * moPixel - {Object} MapObject Pixel format
+     * Returns:
+     * {Object} MapObject LonLat translated from MapObject Pixel
+    getMapObjectLonLatFromMapObjectPixel: function(moPixel) {
+        var size = this.map.getSize();
+        var lon = this.getLongitudeFromMapObjectLonLat(this.mapObject.center);
+        var lat = this.getLatitudeFromMapObjectLonLat(this.mapObject.center);
+        var res = this.map.getResolution();
+        var delta_x = moPixel.x - (size.w / 2);
+        var delta_y = moPixel.y - (size.h / 2);
+        var lonlat = new OpenLayers.LonLat(
+            lon + delta_x * res,
+            lat - delta_y * res
+        if (this.wrapDateLine) {
+            lonlat = lonlat.wrapDateLine(this.maxExtent);
+        return this.getMapObjectLonLatFromLonLat(lonlat.lon, lonlat.lat);
+     * APIMethod: getMapObjectPixelFromMapObjectLonLat
+     * Parameters:
+     * moLonLat - {Object} MapObject LonLat format
+     * Returns:
+     * {Object} MapObject Pixel transtlated from MapObject LonLat
+    getMapObjectPixelFromMapObjectLonLat: function(moLonLat) {
+        var lon = this.getLongitudeFromMapObjectLonLat(moLonLat);
+        var lat = this.getLatitudeFromMapObjectLonLat(moLonLat);
+        var extent = this.map.getExtent();
+        var px = new OpenLayers.Pixel(
+            (1/res * (lon - extent.left)),
+            (1/res * (extent.top - lat))
+        return this.getMapObjectPixelFromXY(px.x, px.y);
+     * APIMethod: setMapObjectCenter
+     * Set the mapObject to the specified center and zoom
+     * Parameters:
+     * center - {Object} MapObject LonLat format
+     * zoom - {int} MapObject zoom format
+    setMapObjectCenter: function(center, zoom) {
+        this.mapObject.setOptions({
+            center: center,
+            zoom: zoom
+  // Bounds
+     * APIMethod: getMapObjectZoomFromMapObjectBounds
+     * Parameters:
+     * moBounds - {Object} MapObject Bounds format
+     * Returns:
+     * {Object} MapObject Zoom for specified MapObject Bounds
+    getMapObjectZoomFromMapObjectBounds: function(moBounds) {
+        return this.mapObject.getBoundsZoomLevel(moBounds);
+     *       MapObject Primitives       *
+  // LonLat
+     * APIMethod: getMapObjectLonLatFromLonLat
+     * Parameters:
+     * lon - {Float}
+     * lat - {Float}
+     * Returns:
+     * {Object} MapObject LonLat built from lon and lat params
+    getMapObjectLonLatFromLonLat: function(lon, lat) {
+        var gLatLng;
+        if(this.sphericalMercator) {
+            var lonlat = this.inverseMercator(lon, lat);
+            gLatLng = new google.maps.LatLng(lonlat.lat, lonlat.lon);
+        } else {
+            gLatLng = new google.maps.LatLng(lat, lon);
+        return gLatLng;
+  // Pixel
+     * APIMethod: getMapObjectPixelFromXY
+     * Parameters:
+     * x - {Integer}
+     * y - {Integer}
+     * Returns:
+     * {Object} MapObject Pixel from x and y parameters
+    getMapObjectPixelFromXY: function(x, y) {
+        return new google.maps.Point(x, y);
+     * APIMethod: destroy
+     * Clean up this layer.
+    destroy: function() {
+        if (this.repositionListener) {
+            google.maps.event.removeListener(this.repositionListener);
+        if (this.repositionTimer) {
+            window.clearTimeout(this.repositionTimer);
+        OpenLayers.Layer.Google.prototype.destroy.apply(this, arguments);
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml	2010-10-28 18:30:18 UTC (rev 2264)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml	2010-10-28 19:22:14 UTC (rev 2265)
@@ -102,6 +102,58 @@
         </Extension>
       </Map>
     </MapGroup>
+    <MapGroup id="bing">
+      <InitialView>
+          <MinX>-9774168</MinX>
+          <MinY>5415995</MinY>
+          <MaxX>-9754637</MaxX>
+          <MaxY>5434757</MaxY>
+      </InitialView>
+      <Map>
+        <Type>VirtualEarth</Type>
+        <Extension>
+          <ResourceId>ve</ResourceId>
+        </Extension>
+      </Map>
+      <Map xsi:type="MapGuideLayerType">
+        <Type>MapGuide</Type>
+        <SingleTile>true</SingleTile>
+        <Extension>
+          <ResourceId>Library://Samples/Sheboygan/Maps/SheboyganMercator.MapDefinition</ResourceId>
+          <Options>
+             <isBaseLayer>false</isBaseLayer>
+             <useOverlay>true</useOverlay>
+             <projection>EPSG:900913</projection>
+          </Options>
+        </Extension>
+      </Map>
+    </MapGroup>
+    <MapGroup id="google2">
+      <InitialView>
+      </InitialView>
+      <Map>
+        <Type>Google</Type>
+        <Extension>
+          <ResourceId>google</ResourceId>
+        </Extension>
+      </Map>
+        <Extension>
+          <Options>
+          </Options>
+        </Extension>
+      </Map>
+    </MapGroup>
     <MapGroup id="google" xsi:type="MapType">
       <Map xsi:type="WMSLayerType">
         <Type>Google</Type>
Modified: trunk/templates/mapguide/standard/index.html
--- trunk/templates/mapguide/standard/index.html	2010-10-28 18:30:18 UTC (rev 2264)
+++ trunk/templates/mapguide/standard/index.html	2010-10-28 19:22:14 UTC (rev 2265)
@@ -3,6 +3,10 @@
 <html>
 <head>
 <title>Sample Fusion Application</title>
+<!-- uncomment for Google layers -->
+<!-- script type="text/javascript" src='http://maps.google.com/maps/api/js?sensor=false'></script-->
+<!-- uncomment for Bing layers -->
+<!-- script src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1'></script-->
 <!-- change the source of the following tag to point to your fusion installation -->
 <script type="text/javascript" src="../../../lib/fusion.js"></script>
 <link rel="stylesheet" href="themes/delicious/jxtheme.css" type="text/css" media="screen" charset="utf-8">
@@ -75,9 +79,9 @@
     var pm = new Jx.PanelSet({parent:'PanelPane', panels:[p1, p2, p3]});
     Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, function() {
-        $('thePage').resize({forceResize: true});
         $('thePage').style.visibility = 'visible';
         mainPanel.layoutContent();
+        $('thePage').resize({forceResize: true});
     Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
     Fusion.initialize();
More information about the fusion-commits mailing list
