[fusion-commits] r2366 - branches/fusion-2.2/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Apr 14 15:25:09 EDT 2011
Author: madair
Date: 2011-04-14 12:25:09 -0700 (Thu, 14 Apr 2011)
New Revision: 2366
   branches/fusion-2.2/lib/proj4js-combined.js
   branches/fusion-2.2/lib/proj4js-compressed.js
closes #442: add support for Google Merc WKT in projection lookup
Modified: branches/fusion-2.2/lib/proj4js-combined.js
--- branches/fusion-2.2/lib/proj4js-combined.js	2011-04-14 19:04:46 UTC (rev 2365)
+++ branches/fusion-2.2/lib/proj4js-combined.js	2011-04-14 19:25:09 UTC (rev 2366)
@@ -1,14 +1,14 @@
-  proj4js.js -- Javascript reprojection library.
-  Authors:      Mike Adair madairATdmsolutions.ca
-                Richard Greenwood richATgreenwoodmap.com
-                Didier Richard didier.richardATign.fr
-                Stephen Irons
-  License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
-                Note: This program is an almost direct port of the C library
-                Proj4.
+  proj4js.js -- Javascript reprojection library.
+  Authors:      Mike Adair madairATdmsolutions.ca
+                Richard Greenwood richATgreenwoodmap.com
+                Didier Richard didier.richardATign.fr
+                Stephen Irons
+  License:      LGPL as per: http://www.gnu.org/copyleft/lesser.html
+                Note: This program is an almost direct port of the C library
+                Proj4.
     proj4js.js
@@ -1680,6 +1680,7 @@
 Proj4js.wktProjections = {
   "Lambert Tangential Conformal Conic Projection": "lcc",
   "Mercator": "merc",
+  "Popular Visualisation Pseudo Mercator": "merc",
   "Transverse_Mercator": "tmerc",
   "Transverse Mercator": "tmerc",
   "Lambert Azimuthal Equal Area": "laea",
Modified: branches/fusion-2.2/lib/proj4js-compressed.js
--- branches/fusion-2.2/lib/proj4js-compressed.js	2011-04-14 19:04:46 UTC (rev 2365)
+++ branches/fusion-2.2/lib/proj4js-compressed.js	2011-04-14 19:25:09 UTC (rev 2366)
@@ -1,14 +1,14 @@
-                Stephen Irons
-                Proj4.
+                Stephen Irons
+                Proj4.
 Proj4js={defaultDatum:'WGS84',transform:function(source,dest,point){if(!source.readyToUse){this.reportError("Proj4js initialization for:"+source.srsCode+" not yet complete");return point;}
 if(!dest.readyToUse){this.reportError("Proj4js initialization for:"+dest.srsCode+" not yet complete");return point;}
 if((source.srsProjNumber=="900913"&&dest.datumCode!="WGS84")||(dest.srsProjNumber=="900913"&&source.datumCode!="WGS84")){var wgs84=Proj4js.WGS84;this.transform(source,wgs84,point);source=wgs84;}
@@ -97,7 +97,7 @@
 {var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_out=M_BF*(p.x-Rz_BF*p.y+Ry_BF*p.z)+Dx_BF;var y_out=M_BF*(Rz_BF*p.x+p.y-Rx_BF*p.z)+Dy_BF;var z_out=M_BF*(-Ry_BF*p.x+Rx_BF*p.y+p.z)+Dz_BF;p.x=x_out;p.y=y_out;p.z=z_out;}},geocentric_from_wgs84:function(p){if(this.datum_type==Proj4js.common.PJD_3PARAM)
 {p.x-=this.datum_params[0];p.y-=this.datum_params[1];p.z-=this.datum_params[2];}
 else if(this.datum_type==Proj4js.common.PJD_7PARAM)
-{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337229166667,"bogota":-74.
 080916666667,"madrid":-3.687938888889,"rome":12.452333333333,"bern":7.439583333333,"jakarta":106.807719444444,"ferro":-17.666666666667,"brussels":4.367975,"stockholm":18.058277777778,"athens":23.7163375,"oslo":10.722916666667};Proj4js.Ellipsoid={"MERIT":{a:6378137.0,rf:298.257,ellipseName:"MERIT 1983"},"SGS85":{a:6378136.0,rf:298.257,ellipseName:"Soviet Geodetic System 85"},"GRS80":{a:6378137.0,rf:298.257222101,ellipseName:"GRS 1980(IUGG, 1980)"},"IAU76":{a:6378140.0,rf:298.257,ellipseName:"IAU 1976"},"airy":{a:6377563.396,b:6356256.910,ellipseName:"Airy 1830"},"APL4.":{a:6378137,rf:298.25,ellipseName:"Appl. Physics. 1965"},"NWL9D":{a:6378145.0,rf:298.25,ellipseName:"Naval Weapons Lab., 1965"},"mod_airy":{a:6377340.189,b:6356034.446,ellipseName:"Modified Airy"},"andrae":{a:6377104.43,rf:300.0,ellipseName:"Andrae 1876 (Den., Iclnd.)"},"aust_SA":{a:6378160.0,rf:298.25,ellipseName:"Australian Natl & S. Amer. 1969"},"GRS67":{a:6378160.0,rf:298.2471674270,ellipseName:"GRS 67(IUGG
  1967)"},"bessel":{a:6377397.155,rf:299.1528128,ellipseName:"Bessel 1841"},"bess_nam":{a:6377483.865,rf:299.1528128,ellipseName:"Bessel 1841 (Namibia)"},"clrk66":{a:6378206.4,b:6356583.8,ellipseName:"Clarke 1866"},"clrk80":{a:6378249.145,rf:293.4663,ellipseName:"Clarke 1880 mod."},"CPM":{a:6375738.7,rf:334.29,ellipseName:"Comm. des Poids et Mesures 1799"},"delmbr":{a:6376428.0,rf:311.5,ellipseName:"Delambre 1810 (Belgium)"},"engelis":{a:6378136.05,rf:298.2566,ellipseName:"Engelis 1985"},"evrst30":{a:6377276.345,rf:300.8017,ellipseName:"Everest 1830"},"evrst48":{a:6377304.063,rf:300.8017,ellipseName:"Everest 1948"},"evrst56":{a:6377301.243,rf:300.8017,ellipseName:"Everest 1956"},"evrst69":{a:6377295.664,rf:300.8017,ellipseName:"Everest 1969"},"evrstSS":{a:6377298.556,rf:300.8017,ellipseName:"Everest (Sabah & Sarawak)"},"fschr60":{a:6378166.0,rf:298.3,ellipseName:"Fischer (Mercury Datum) 1960"},"fschr60m":{a:6378155.0,rf:298.3,ellipseName:"Fischer 1960"},"fschr68":{a:6378150.0
 ,rf:298.3,ellipseName:"Fischer 1968"},"helmert":{a:6378200.0,rf:298.3,ellipseName:"Helmert 1906"},"hough":{a:6378270.0,rf:297.0,ellipseName:"Hough"},"intl":{a:6378388.0,rf:297.0,ellipseName:"International 1909 (Hayford)"},"kaula":{a:6378163.0,rf:298.24,ellipseName:"Kaula 1961"},"lerch":{a:6378139.0,rf:298.257,ellipseName:"Lerch 1979"},"mprts":{a:6397300.0,rf:191.0,ellipseName:"Maupertius 1738"},"new_intl":{a:6378157.5,b:6356772.2,ellipseName:"New International 1967"},"plessis":{a:6376523.0,rf:6355863.0,ellipseName:"Plessis 1817 (France)"},"krass":{a:6378245.0,rf:298.3,ellipseName:"Krassovsky, 1942"},"SEasia":{a:6378155.0,b:6356773.3205,ellipseName:"Southeast Asia"},"walbeck":{a:6376896.0,b:6355834.8467,ellipseName:"Walbeck"},"WGS60":{a:6378165.0,rf:298.3,ellipseName:"WGS 60"},"WGS66":{a:6378145.0,rf:298.25,ellipseName:"WGS 66"},"WGS72":{a:6378135.0,rf:298.26,ellipseName:"WGS 72"},"WGS84":{a:6378137.0,rf:298.257223563,ellipseName:"WGS 84"},"sphere":{a:6370997.0,b:6370997.0,el
 lipseName:"Normal Sphere (r=6370997)"}};Proj4js.Datum={"WGS84":{towgs84:"0,0,0",ellipse:"WGS84",datumName:"WGS84"},"GGRS87":{towgs84:"-199.87,74.79,246.62",ellipse:"GRS80",datumName:"Greek_Geodetic_Reference_System_1987"},"NAD83":{towgs84:"0,0,0",ellipse:"GRS80",datumName:"North_American_Datum_1983"},"NAD27":{nadgrids:"@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat",ellipse:"clrk66",datumName:"North_American_Datum_1927"},"potsdam":{towgs84:"606.0,23.0,413.0",ellipse:"bessel",datumName:"Potsdam Rauenberg 1950 DHDN"},"carthage":{towgs84:"-263.0,6.0,431.0",ellipse:"clark80",datumName:"Carthage 1934 Tunisia"},"hermannskogel":{towgs84:"653.0,-212.0,449.0",ellipse:"bessel",datumName:"Hermannskogel"},"ire65":{towgs84:"482.530,-130.596,564.557,-1.042,-0.214,-0.631,8.15",ellipse:"mod_airy",datumName:"Ireland 1965"},"nzgd49":{towgs84:"59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993",ellipse:"intl",datumName:"New Zealand Geodetic Datum 1949"},"OSGB36":{towgs84:"446.448,-125.157,542.060,0.1502,0.2
 470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.wktProjections={"Lambert Tangential Conformal Conic Projection":"lcc","Mercator":"merc","Transverse_Mercator":"tmerc","Transverse Mercator":"tmerc","Lambert Azimuthal Equal Area":"laea","Universal Transverse Mercator System":"utm"};Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
+{var Dx_BF=this.datum_params[0];var Dy_BF=this.datum_params[1];var Dz_BF=this.datum_params[2];var Rx_BF=this.datum_params[3];var Ry_BF=this.datum_params[4];var Rz_BF=this.datum_params[5];var M_BF=this.datum_params[6];var x_tmp=(p.x-Dx_BF)/M_BF;var y_tmp=(p.y-Dy_BF)/M_BF;var z_tmp=(p.z-Dz_BF)/M_BF;p.x=x_tmp+Rz_BF*y_tmp-Ry_BF*z_tmp;p.y=-Rz_BF*x_tmp+y_tmp+Rx_BF*z_tmp;p.z=Ry_BF*x_tmp-Rx_BF*y_tmp+z_tmp;}}});Proj4js.Point=Proj4js.Class({initialize:function(x,y,z){if(typeof x=='object'){this.x=x[0];this.y=x[1];this.z=x[2]||0.0;}else if(typeof x=='string'){var coords=x.split(',');this.x=parseFloat(coords[0]);this.y=parseFloat(coords[1]);this.z=parseFloat(coords[2])||0.0;}else{this.x=x;this.y=y;this.z=z||0.0;}},clone:function(){return new Proj4js.Point(this.x,this.y,this.z);},toString:function(){return("x="+this.x+",y="+this.y);},toShortString:function(){return(this.x+", "+this.y);}});Proj4js.PrimeMeridian={"greenwich":0.0,"lisbon":-9.131906111111,"paris":2.337229166667,"bogota":-74.
 470,0.8421,-20.4894",ellipse:"airy",datumName:"Airy 1830"}};Proj4js.WGS84=new Proj4js.Proj('WGS84');Proj4js.Datum['OSB36']=Proj4js.Datum['OSGB36'];Proj4js.wktProjections={"Lambert Tangential Conformal Conic Projection":"lcc","Mercator":"merc","Popular Visualisation Pseudo Mercator": "merc","Transverse_Mercator":"tmerc","Transverse Mercator":"tmerc","Lambert Azimuthal Equal Area":"laea","Universal Transverse Mercator System":"utm"};Proj4js.Proj.aea={init:function(){if(Math.abs(this.lat1+this.lat2)<Proj4js.common.EPSLN){Proj4js.reportError("aeaInitEqualLatitudes");return;}
 this.temp=this.b/this.a;this.es=1.0-Math.pow(this.temp,2);this.e3=Math.sqrt(this.es);this.sin_po=Math.sin(this.lat1);this.cos_po=Math.cos(this.lat1);this.t1=this.sin_po;this.con=this.sin_po;this.ms1=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs1=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat2);this.cos_po=Math.cos(this.lat2);this.t2=this.sin_po;this.ms2=Proj4js.common.msfnz(this.e3,this.sin_po,this.cos_po);this.qs2=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);this.sin_po=Math.sin(this.lat0);this.cos_po=Math.cos(this.lat0);this.t3=this.sin_po;this.qs0=Proj4js.common.qsfnz(this.e3,this.sin_po,this.cos_po);if(Math.abs(this.lat1-this.lat2)>Proj4js.common.EPSLN){this.ns0=(this.ms1*this.ms1-this.ms2*this.ms2)/(this.qs2-this.qs1);}else{this.ns0=this.con;}
 this.c=this.ms1*this.ms1+this.ns0*this.qs1;this.rh=this.a*Math.sqrt(this.c-this.ns0*this.qs0)/this.ns0;},forward:function(p){var lon=p.x;var lat=p.y;this.sin_phi=Math.sin(lat);this.cos_phi=Math.cos(lat);var qs=Proj4js.common.qsfnz(this.e3,this.sin_phi,this.cos_phi);var rh1=this.a*Math.sqrt(this.c-this.ns0*qs)/this.ns0;var theta=this.ns0*Proj4js.common.adjust_lon(lon-this.long0);var x=rh1*Math.sin(theta)+this.x0;var y=this.rh-rh1*Math.cos(theta)+this.y0;p.x=x;p.y=y;return p;},inverse:function(p){var rh1,qs,con,theta,lon,lat;p.x-=this.x0;p.y=this.rh-p.y+this.y0;if(this.ns0>=0){rh1=Math.sqrt(p.x*p.x+p.y*p.y);con=1.0;}else{rh1=-Math.sqrt(p.x*p.x+p.y*p.y);con=-1.0;}
 theta=0.0;if(rh1!=0.0){theta=Math.atan2(con*p.x,con*p.y);}
More information about the fusion-commits mailing list
