[fusion-commits] r2423 - in sandbox/adsk/2.3r: layers/MapGuide lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Aug 23 03:03:38 EDT 2011
Author: liuar
Date: 2011-08-23 00:03:38 -0700 (Tue, 23 Aug 2011)
New Revision: 2423
   sandbox/adsk/2.3r/layers/MapGuide/MapGuide.js
   sandbox/adsk/2.3r/lib/MGBroker.js
Port to adsk2.3 branch
Fix ticket http://trac.osgeo.org/fusion/ticket/473
query() ignores the options.filter parameter
Modified: sandbox/adsk/2.3r/layers/MapGuide/MapGuide.js
--- sandbox/adsk/2.3r/layers/MapGuide/MapGuide.js	2011-08-22 05:50:22 UTC (rev 2422)
+++ sandbox/adsk/2.3r/layers/MapGuide/MapGuide.js	2011-08-23 07:03:38 UTC (rev 2423)
@@ -1003,12 +1003,17 @@
             maxFeatures = -1;
+        if(options.filter == null)
+            options.filter = '';
         var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.getSessionID(),
        this._sMapname,
        options.geometry,
        maxFeatures,
        persist,
        options.selectionType || this.selectionType,
+        options.filter,
        options.layers,
        layerAttributeFilter);
         var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeFeatureInfo, this) : OpenLayers.Function.bind(this.processFeatureInfo, this);
@@ -1080,6 +1085,7 @@
         var maxFeatures = 1;
         var persist = 0;
         var selection = 'INTERSECTS';
+        var filter = '';
         var layerNames = '';
         var layerAttributeFilter = 3;
         var sep = '';
@@ -1090,7 +1096,7 @@
         var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.mapWidget.getSessionID(),
                                                             this._sMapname,
                                                             sGeometry,
-                                                            maxFeatures, persist, selection, layerNames,
+                                                            maxFeatures, persist, selection, filter, layerNames,
         var callback = OpenLayers.Function.bind(this.crtlClickDisplay, this);
         Fusion.oBroker.dispatchRequest(r, OpenLayers.Function.bind(Fusion.xml2json, this, callback));
@@ -1202,6 +1208,7 @@
         var persist = 0;
+        var filter = '';
         // only select visible layers with maptips defined (1+4)
         var layerAttributeFilter = 5;
         //TODO: possibly make the layer names configurable?
@@ -1209,7 +1216,7 @@
                                         this._sMapname,
                                         sGeometry,
Modified: sandbox/adsk/2.3r/lib/MGBroker.js
--- sandbox/adsk/2.3r/lib/MGBroker.js	2011-08-22 05:50:22 UTC (rev 2422)
+++ sandbox/adsk/2.3r/lib/MGBroker.js	2011-08-23 07:03:38 UTC (rev 2423)
@@ -567,13 +567,14 @@
      * @param maxFeatures {integer} number of maximum results (-1 to indicate no maximum)
      * @param selectionPersist {boolean} save the selection (valid values are 0 and 1)
      * @param selectionVariant {String} indicates the spatial operation. Valid values are 'INTERSECTS', ...
+     * @param featureFilter {String} filter crieteria to be applied for selection.
      * @param layerNames {String} comma separated list of layer names to include in the query
      * @param layerAttributeFilter {integer} bitmask determining layer selection behaviour (1=visible layers,
      *          2=selectable layers, 4=layers with tooltips)
      * @return {Object} an instance of Fusion.Lib.MGRequest.MGQueryMapFeatures
-    initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, layerNames, layerAttributeFilter )
+    initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, featureFilter, layerNames, layerAttributeFilter )
         this.initializeRequest();
         this.setParams( {
@@ -584,6 +585,7 @@
             maxFeatures: maxFeatures,
             persist: persist,
             selectionVariant: selectionVariant,
+            featureFilter: featureFilter,
             layerNames: layerNames,
             layerAttributeFilter: layerAttributeFilter
More information about the fusion-commits mailing list
