[fusion-commits] r2313 - in trunk: layers lib widgets widgets/Maptip
    svn_fusion at osgeo.org
    Fri Jan  7 15:36:04 EST 2011
Author: madair
Date: 2011-01-07 12:36:04 -0800 (Fri, 07 Jan 2011)
New Revision: 2313
Removed:
   trunk/widgets/Maptip/Maptip.php
   trunk/layers/Layers.js
   trunk/lib/ApplicationDefinition.js
   trunk/lib/Widget.js
   trunk/widgets/Buffer.js
   trunk/widgets/BufferPanel.js
   trunk/widgets/FeatureInfo.js
   trunk/widgets/Help.js
   trunk/widgets/InvokeURL.js
   trunk/widgets/LayerManager.js
   trunk/widgets/Legend.js
   trunk/widgets/MapMetadata.js
   trunk/widgets/Maptip.js
   trunk/widgets/Measure.js
   trunk/widgets/Print.js
   trunk/widgets/Query.js
   trunk/widgets/QuickPlot.js
   trunk/widgets/SaveMap.js
   trunk/widgets/Search.js
   trunk/widgets/SelectAttribute.js
   trunk/widgets/SelectRadius.js
   trunk/widgets/SelectRadiusValue.js
   trunk/widgets/SelectWithin.js
   trunk/widgets/SelectionPanel.js
   trunk/widgets/TaskPane.js
   trunk/widgets/Theme.js
   trunk/widgets/ZoomToSelection.js
re #426: widgets can now be associated with a particular <Map> through an id attribute and a <WidgetLayerId> element in the widget's extension.
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/layers/Layers.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -92,6 +92,7 @@
         this.sMapResourceId = mapTag.resourceId ? mapTag.resourceId : '';
         this.mapInfo = mapTag.mapInfo;
         this.layerType = mapTag.type;
+        this.id = mapTag.id;
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/lib/ApplicationDefinition.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -489,6 +489,7 @@
     initialize: function(jsonNode) {
         /* TODO: type can be any supported OpenLayers type */
+        this.id = jsonNode['@id'] ? jsonNode['@id'][0] : null;
         this.type = jsonNode.Type[0];
         if (jsonNode.SingleTile) {
             var b = jsonNode.SingleTile[0].toLowerCase();
Modified: trunk/lib/Widget.js
--- trunk/lib/Widget.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/lib/Widget.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -38,6 +38,7 @@
     type: null,
     oMap: null,
+    widgetLayerId: null,   //the AppDef <Map> object associated with this widget
     enabled: false,
     mapLoadedWatcher: null,
     paramRegister: null,
@@ -75,6 +76,10 @@
         this.paramRegister = [];
+        //check to see if this widget is associated with a specific Map
+        var json = widgetTag.extension;
+        this.widgetLayerId = json.WidgetLayerId ? json.WidgetLayerId[0] : null;
         this.initializeWidget(widgetTag);
@@ -185,6 +190,25 @@
+     * accessor to get the Map object that this widget is associated with
+     * @return {object} the map
+    getMapLayer: function() {
+      if (this.widgetLayerId) {
+        var map = this.getMap();
+        for (var i=0; i<map.aMaps.length; ++i) {
+          if (map.aMaps[i].id && (map.aMaps[i].id == this.widgetLayerId) ) {
+            return map.aMaps[i];
+        Fusion.reportError("Requested widgetLayerId not found:"+this.widgetLayerId);
+        return null;
+      } else {
+        return this.getMap().aMaps[0];
      * utility method to add an OL control to the OL map object
     addControl: function(control) {
Modified: trunk/widgets/Buffer.js
--- trunk/widgets/Buffer.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Buffer.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -202,25 +202,25 @@
         var mapWidget = this.getMap();
-        var aMaps = mapWidget.getAllMaps();
-        var s = aMaps[0].arch + '/' + Fusion.getScriptLanguage() + "/Buffer." + Fusion.getScriptLanguage();
+        var widgetLayer = this.getMapLayer();
+        var s = widgetLayer.arch + '/' + Fusion.getScriptLanguage() + "/Buffer." + Fusion.getScriptLanguage();
         var params = {};
         params.parameters = 'locale='+Fusion.locale +
                             '&merge=1' +
-                            '&session='+aMaps[0].getSessionID() +
-                            '&mapname='+ aMaps[0].getMapName()+
+                            '&session='+widgetLayer.getSessionID() +
+                            '&mapname='+ widgetLayer.getMapName()+
                             layer+distance+borderColor+fillColor;
         params.onComplete = OpenLayers.Function.bind(this.bufferCreated, this);
         Fusion.ajaxRequest(s, params);
     bufferCreated: function() {
-        var aMaps = this.getMap().getAllMaps();
-        var layer = aMaps[0].getLayerByName(this.layerName);
+        var layer = widgetLayer.getLayerByName(this.layerName);
         if (layer) {
           layer.noCache = true;
-        aMaps[0].reloadMap();
-        aMaps[0].drawMap();
+        widgetLayer.reloadMap();
+        widgetLayer.drawMap();
Modified: trunk/widgets/BufferPanel.js
--- trunk/widgets/BufferPanel.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/BufferPanel.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -95,14 +95,14 @@
         //add in other parameters to the url here
-        var mapLayers = map.getAllMaps();
         var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
         var pageElement = $(this.sTarget);
         var params = [];
         params.push('locale='+Fusion.locale);
-        params.push('session='+mapLayers[0].getSessionID());
-        params.push('mapname='+mapLayers[0].getMapName());
+        params.push('session='+widgetLayer.getSessionID());
+        params.push('mapname='+widgetLayer.getMapName());
         if (taskPaneTarget || pageElement) {
           params.push('popup=false');
         } else {
Modified: trunk/widgets/FeatureInfo.js
--- trunk/widgets/FeatureInfo.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/FeatureInfo.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -38,7 +38,7 @@
 Fusion.Widget.FeatureInfo = OpenLayers.Class(Fusion.Widget, {
     isExclusive: true,
     uiClass: Jx.Button,
-    sFeatures : 'menubar=no,location=no,resizable=no,status=no',
+    sFeatures: 'menubar=no,location=no,resizable=no,status=no',
     initializeWidget: function(widgetTag) {
@@ -51,14 +51,14 @@
         var params = [];
         params.push('LOCALE='+Fusion.locale);
-        params.push('SESSION='+mapLayers[0].getSessionID());
-        params.push('MAPNAME='+mapLayers[0].getMapName());
+        params.push('SESSION='+widgetLayer.getSessionID());
+        params.push('MAPNAME='+widgetLayer.getMapName());
           params.push('POPUP=false');
         } else {
Modified: trunk/widgets/Help.js
--- trunk/widgets/Help.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Help.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -69,7 +69,7 @@
     activate: function() {
         var url = this.baseUrl;
-        var map = this.getMap();
+        var map = this.getMapLayer();
         var params = [];
         params.push('SESSION='+map.getSessionID());
Modified: trunk/widgets/InvokeURL.js
--- trunk/widgets/InvokeURL.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/InvokeURL.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -37,7 +37,7 @@
 Fusion.Widget.InvokeURL = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
@@ -66,10 +66,11 @@
     enable: function() {
         if (this.bSelectionOnly || !map) {
             if (map && map.hasSelection()) {
-                if (map.aMaps[0]._sQueryfile) {
-                  this.additionalParameters.push('queryfile='+map.aMaps[0]._sQueryfile);
+                if (widgetLayer._sQueryfile) {
+                  this.additionalParameters.push('queryfile='+widgetLayer._sQueryfile);
                 if (this.action) {
                     this.action.setEnabled(true);
@@ -96,7 +97,7 @@
         var url = this.sBaseUrl;
         var params = [];
         params.push('session='+map.getSessionID());
Modified: trunk/widgets/LayerManager.js
--- trunk/widgets/LayerManager.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/LayerManager.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -71,7 +71,7 @@
         this.map.registerForEvent(Fusion.Event.MAP_RELOADED, OpenLayers.Function.bind(this.mapReLoaded, this));
         this.map.registerForEvent(Fusion.Event.MAP_SCALE_RANGE_LOADED, OpenLayers.Function.bind(this.scaleRangeLoaded, this));
         // update changes to the legend in this widget
-        this.map.aMaps[0].registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerChanged,this));
+        this.getMapLayer().registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerChanged,this));
     scaleRangeLoaded: function() {
@@ -82,7 +82,7 @@
     layerChanged: function(eventId, layer) {
-        this.updateLayer(this.map.aMaps[0]);
+        this.updateLayer(this.getMapLayer());
         this.updateSessionMapFile();
     mapReLoaded: function(){
@@ -335,14 +335,11 @@
   updateSessionMapFile: function(){
    // console.log("updateSessionMapFile");
-    // get map
-    var aMaps = map.getAllMaps();
-    var currentMap = aMaps[0];
-    var sessionId = aMaps[0].getSessionID();
+    var sessionId = widgetLayer.getSessionID();
     // get all layers
-    var oLayers = currentMap.aLayers;
+    var oLayers = widgetLayer.aLayers;
     var aLayerNames = [];
     var visibleLayers = [];
     for(var i=0;i<oLayers.length;i++){
@@ -353,13 +350,12 @@
     // prepare ajax req
-    var params =  '&session='+sessionId+'&mapname='+ this.getMap().getMapName()+'&visLayers='+visibleLayers+'&layers='+aLayerNames;
+    var params =  '&session='+sessionId+'&mapname='+ widgetLayer.getMapName()+'&visLayers='+visibleLayers+'&layers='+aLayerNames;
     var options = {parameters: params};
     // fire the request no need to return
-    var m = this.getMap().aMaps[0];
-    var url = 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/updateSessionMapFile." + Fusion.getScriptLanguage()
-    Fusion.ajaxRequest(  url, options);
+    var url = 'layers/' + widgetLayer.arch + '/' + Fusion.getScriptLanguage() + "/updateSessionMapFile." + Fusion.getScriptLanguage()
+    Fusion.ajaxRequest(url, options);
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Legend.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -381,7 +381,7 @@
     mapLoaded: function() {
         this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
-        var baseLayer = this.getMap().aMaps[0];
+        var baseLayer = this.oLegend.getMapLayer();
         baseLayer.registerForEvent(Fusion.Event.MAP_LAYER_ORDER_CHANGED, OpenLayers.Function.bind(this.mapRefresh, this));
         this.layerRoot = this.getMap().layerRoot;
         //this.renderLegend();
@@ -393,7 +393,7 @@
     mapRefresh: function() {
         baseLayer.parseLayers();
@@ -411,7 +411,7 @@
         this.clear();
         if (this.showRootFolder) {
-            this.oRoot.setLabel(this.getMap().getMapTitle());
+            this.oRoot.setLabel(this.oLegend.getMapLayer().getMapTitle());
         var startGroup = this.layerRoot;
         if (!this.showMapFolder) {
Modified: trunk/widgets/MapMetadata.js
--- trunk/widgets/MapMetadata.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/MapMetadata.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -62,7 +62,8 @@
     showMetadata: function() {
-      var metadata = this.getMap().getMetadata(this.metadataId);
+      var metadataLayer = this.getMapLayer();
+      var metadata = metadataLayer.getMetadata(this.metadataId);
       if (metadata) {
         //this.domObj.appendChild(metadata);
         if (this.content == 'markup') {
Deleted: trunk/widgets/Maptip/Maptip.php
--- trunk/widgets/Maptip/Maptip.php	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Maptip/Maptip.php	2011-01-07 20:36:04 UTC (rev 2313)
@@ -1,358 +0,0 @@
- * Fusion.Widget.Maptip2
- * $Id: $
- * Portions copyright (c) 2007, DM Solutions Group Inc.
- * Portions copyright (c) 2008, ENPLAN
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Class: Fusion.Widget.Maptip
- * Displays tooltips over the map when the mouse is hovered for some
- * time.  On the MapGuide platform, you must configure tooltips for
- * each layer using Studio or Web Studio by editing the LayerDefinition
- * Settings and specifying an expression for the tooltip. MapServer users
- * can instead specify which attribute fields in the layer are to be used
- * for the maptip text and optional hyperlink.
- * Delay (optional)
- * This is the delay, in milliseconds, that the user must keep the mouse
- * in the same position in order for the maptip to appear.  The default,
- * if not specified, is 350 milliseconds.
- * Layer
- * -MapGuide(optional, multiple): This is the name of a layer from the MapDefinition
- *  to get the tooltip from.  If no Layer elements are specified, then all layers
- *  will be queried and the top-most one will be displayed.  Multiple Layer
- *  tags can be added, allowing tooltips to come from different layers.
- * -Mapserver(required): This is the name of a layer from the MapFile whose attributes
- * will be used to populate the maptip text. Mapserver only supports a single layer.
- * If more than one layer is specified, only the first will be used.
- * Textfield (required for MapServer only)
- * Field to use for the maptip text for MapServer-based Fusion installs.
- * Since this is not specified server-side, as in MapGuide, it must be
- * declared here.
- * Linkfield (optional for MapServer only)
- * Field to use for the maptip hyperlink target URL on MapServer fusion installs.
- * As with Textfield above, it must be declared here if needed.
-Fusion.Widget.Maptip2 = OpenLayers.Class(Fusion.Widget, {
-        oCurrentPosition: null,
-        oMapTipPosition: null,
-        nTimer: null,
-        delay: null,
-        aLayers: null,
-        bOverTip: false,
-        textField: null,
-        linkField: null,
-        customURL: null,
-        sWinFeatures : 'menubar=no,location=no,resizable=no,status=no',
-        initializeWidget: function(widgetTag){
-           // console.log("maptipStarted");
-           // Object.inheritFrom(this, Fusion.Widget.prototype, [widgetTag, true]);
-            var json = widgetTag.extension;
-            this.sTarget = json.Target ? json.Target[0] : "MaptipWindow";
-            if (json.WinFeatures) {
-            this.sWinFeatures = json.WinFeatures[0];
-            this.delay = json.Delay ? parseInt(json.Delay[0]) : 350;
-            this.nTolerance = json.Tolerance ? parseInt(json.Tolerance[0]) : 2;
-            this.aLayers = [];
-            if (json.Layer) {
-                for (var i=0; i<json.Layer.length; i++) {
-                    this.aLayers.push(json.Layer[i]);
-            this.customURL =  json.CustomURL;
-            this.textField = json.TextField;
-            this.linkField = json.Linkfield;
-            //prepare the container div for the maptips
-            Fusion.addWidgetStyleSheet(widgetTag.location + 'Maptip/Maptip.css');
-            if (this.domObj) {
-            this.domObj.parentNode.removeChild(this.domObj);
-            } else {
-            this.domObj = document.createElement('div');
-            this.domObj.className = 'maptipContainer';
-            this.domObj.style.display = 'none';
-            this.domObj.style.top = '0px';
-            this.domObj.style.left = '0px';
-            //create an iframe to stick behind the maptip to prevent clicks being passed through to the map
-            this.iframe = document.createElement('iframe');
-            this.iframe.className = 'maptipShim';
-            this.iframe.scrolling = 'no';
-            this.iframe.frameborder = 0;
-            OpenLayers.Event.observe(this.domObj, 'mouseover', OpenLayers.Function.bind(this.mouseOverTip, this));
-            OpenLayers.Event.observe(this.domObj, 'mouseout', OpenLayers.Function.bind(this.mouseOutTip, this));
-            var oDomElem =  this.getMap().getDomObj();
-            document.getElementsByTagName('BODY')[0].appendChild(this.domObj);
-            this.getMap().observeEvent('mousemove', OpenLayers.Function.bind(this.mouseMove, this));
-            this.getMap().observeEvent('mouseout', OpenLayers.Function.bind(this.mouseOut, this));
-        mouseOut: function(e) {
-        //console.log('maptip mouseOut');
-            if (this.nTimer) {
-                window.clearTimeout(this.nTimer);
-                if (!this.nHideTimer) {
-                    /*console.log('mouseOut: set hide timer');*/
-                    this.nHideTimer = window.setTimeout(this.hideMaptip.bind(this), 250);
-        mouseMove: function(e) {
-        //console.log('map tip mouseMove');
-            var Map = map.aMaps[0];
-            if (this.bOverTip) {
-                return;
-            var p = this.getMap().getEventPosition(e);
-            this.oCurrentPosition = p;
-            this.oMapTipPosition = {x:e.xy.x, y:e.xy.y};
-            if (this.oCurrentPosition) {
-                this.nTimer = null;
-            //Bind to the appropriate function for the platform
-            var showMaptip = this.showMaptip.bind(this)
-            this.nTimer = window.setTimeout(showMaptip, this.delay);
-            //Event.stop(e);
-        showMaptipMG: function(r) {
-            //Gets the maptip data on MapGuide
-            console.log('showMaptip');
-            if (map == null) {
-            return;
-            var oBroker = Fusion.oBroker;
-            var x = this.oCurrentPosition.x;
-            var y = this.oCurrentPosition.y;
-            var min = map.pixToGeo(x-this.nTolerance, y-this.nTolerance);
-            var max = map.pixToGeo(x+this.nTolerance, y+this.nTolerance);
-            //this can fail if no map is loaded
-            if (!min) {
-                return;
-            var sGeometry = 'POLYGON(('+ min.x + ' ' +  min.y + ', ' +  min.x + ' ' +  max.y + ', ' + max.x + ' ' +  max.y + ', ' + max.x + ' ' +  min.y + ', ' + min.x + ' ' +  min.y + '))';
-            var maxFeatures = 1;
-            var persist = 0;
-            var selection = 'INTERSECTS';
-            // only select visible layers with maptips defined (1+4)
-            var layerAttributeFilter = 5;
-            var maps = this.getMap().getAllMaps();
-            //TODO: possibly make the layer names configurable?
-            var layerNames = this.aLayers.toString();
-            var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(maps[0].getSessionID(),
-                                            maps[0]._sMapname,
-                                            sGeometry,
-                                            maxFeatures, persist, selection, layerNames,
-                                            layerAttributeFilter);
-            oBroker.dispatchRequest(r, this.parseMGXML.bind(this));
-        parseMGXML: function(r) {
-            //Parses the XML returned by MG and passes the text & link values to the
-            //mtDisplay function
-            if (r) {
-                var d = new DomNode(r);
-                var t = d.getNodeText('Tooltip');
-                var h = d.getNodeText('Hyperlink');
-                var mtDisplayFunc = this.mtDisplay.bind(this);
-                mtDisplayFunc(t,h);
-        showMaptip: function(r) {
-            var pos = this.getMap().pixToGeo(this.oCurrentPosition.x, this.oCurrentPosition.y);
-            //console.log(pos);
-            var options = {};
-            var dfGeoTolerance = this.getMap().pixToGeoMeasure(this.nTolerance);
-            var minx = pos.x-dfGeoTolerance;
-            var miny = pos.y-dfGeoTolerance;
-            var maxx = pos.x+dfGeoTolerance;
-            var maxy = pos.y+dfGeoTolerance;
-            options.geometry = 'POLYGON(('+ minx + ' ' + miny + ', ' + minx + ' ' + maxy + ', ' + maxx + ' ' + maxy + ', ' + maxx + ' ' + miny + ', ' + minx + ' ' + miny + '))';
-            options.selectionType = "INTERSECTS";
-            if (this.bActiveOnly) {
-                var layer = this.getMap().getActiveLayer();
-                if (layer) {
-                    options.layers = layer.layerName;
-                } else {
-                    return;
-            var Map = this.getMap().aMaps[0];
-            var bPersistant = options.persistent || true;
-            var zoomTo = options.zoomTo ?  true : false;
-            var loadmapScript = '/layers/'+Map.arch + '/php/maptip.php';
-            var params = {
-                'mapname': Map._sMapname,
-                'session': Map.getSessionID(),
-                'spatialfilter': options.geometry || '',
-                'maxfeatures': options.maxFeatures || 0, //zero means select all features
-                'variant': 'intersects',
-                'layer': this.aLayers[0] || '',
-                'textfield': this.textField || '',
-                'customURL': this.customURL || ''
-            var ajaxOptions = {
-                onSuccess: function(response){
-                        eval("rjson=" + response.responseText);
-                        mtDisplayFunc(rjson.mapTipText,rjson.mapTipLink);
-                        parameters: params};
-            Fusion.ajaxRequest(loadmapScript, ajaxOptions);
-        mtDisplay: function(t,h) {
-            //console.log("t:" + t);
-            //console.log("h:" + h);
-            if (t !="") {
-                this.domObj.innerHTML = ' ';
-                var contentDiv = document.createElement('div');
-                contentDiv.className = 'maptipContent';
-                this.domObj.appendChild(contentDiv);
-                var empty = true;
-                this.bIsVisible = true;
-                if (t != '') {
-                    t = t.replace(/\\n/g, "<br>");
-                    if (h != '') {
-                    var linkDiv = document.createElement('div');
-                    var a = document.createElement('a');
-                    a.innerHTML = t;
-                    a.href = 'javascript:void(0)';
-                    a.url = h;
-                    a.onclick = this.openLink.bindAsEventListener(a);
-                    linkDiv.appendChild(a);
-                    contentDiv.appendChild(linkDiv);
-                    empty = false;
-                    } else {
-                        contentDiv.innerHTML = t;
-                        empty = false;
-                if (!empty) {
-                    this.domObj.style.visibility = 'hidden';
-                    this.domObj.style.display = 'block';
-                    var size = Element.getCoordinates(this.domObj);
-                    // 5 pixels offset added to clear the div from the mouse
-                    var mapOffsetX = this.getMap()._oDomObj.offsets[0];
-                    var mapOffsetY= this.getMap()._oDomObj.offsets[1];
-                    this.domObj.style.top = (this.oCurrentPosition.y  ) + 'px';
-                    this.domObj.style.left = (this.oCurrentPosition.x )+ 'px';
-                    if (!window.opera) {
-                        contentDiv.appendChild(this.iframe);
-                        var size = Element.getContentBoxSize(this.domObj);
-                        this.iframe.style.width = size.width + "px";
-                        this.iframe.style.height = size.height + "px";
-                    this.domObj.style.visibility = 'visible';
-                //console.log("maptip visible");
-                } else {
-                    this.hideMaptip();
-            } else {
-                this.bIsVisible = false;
-        hideMaptip: function() {
-            //console.log('hideMaptip');
-            this.hideTimer = window.setTimeout(this._hide.bind(this),10);
-        _hide: function() {
-           //console.log('maptip _hide');
-            this.hideTimer = null;
-            //this.oMapTipPosition = null;
-        mouseOverTip: function() {
-           //console.log('mouseOverTip');
-            window.clearTimeout(this.nHideTimer);
-            this.nHideTimer = null;
-            this.bOverTip = true;
-        mouseOutTip: function() {
-           //console.log('mouseOutTip');
-            this.bOverTip = false;
-        openLink : function(evt) {
-            var url = this.url;
-            var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
-            if ( taskPaneTarget ) {
-                taskPaneTarget.setContent(url);
-            } else {
-                var pageElement = $(this.sTarget);
-                if ( pageElement ) {
-                    pageElement.src = url;
-                } else {
-                    window.open(url, this.sTarget, this.sWinFeatures);
-            OpenLayers.Event.stop(evt, true);
-            return false;
Modified: trunk/widgets/Maptip.js
--- trunk/widgets/Maptip.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Maptip.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -180,7 +180,7 @@
     showMaptip: function() {
-        this.getMap().getMapTip(this);
+        this.getMapLayer().getMapTip(this);
         this.mapTipFired = true;
Modified: trunk/widgets/Measure.js
--- trunk/widgets/Measure.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Measure.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -493,13 +493,13 @@
     remoteMeasureSegment: function(marker, from, to, geom) {
-        var s = 'layers/' + aMaps[0].arch + '/' + Fusion.getScriptLanguage() + "/Measure." + Fusion.getScriptLanguage();
+        var s = 'layers/' + widgetLayer.arch + '/' + Fusion.getScriptLanguage() + "/Measure." + Fusion.getScriptLanguage();
         var fromGeo = mapWidget.pixToGeo(from.x, from.y);
         var toGeo = mapWidget.pixToGeo(to.x, to.y);
         var options = {
             parameters: {
-                'session': aMaps[0].getSessionID(),
+                'session': widgetLayer.getSessionID(),
                 'locale': Fusion.locale,
                 'mapname': mapWidget.getMapName(),
                 'x1': fromGeo.x,
Modified: trunk/widgets/Print.js
--- trunk/widgets/Print.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Print.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -168,9 +168,9 @@
         var centerY = (extents.top + extents.bottom)/ 2;
         var dpi = mainMap._nDpi;
         var scale = mainMap.getScale();
-        var maps = mainMap.getAllMaps();
-        url = url + 'MAPNAME=' + mainMap.getMapName();
-        url = url + '&SESSION=' + maps[0].getSessionID();
+        url = url + 'MAPNAME=' + widgetLayer.getMapName();
+        url = url + '&SESSION=' + widgetLayer.getSessionID();
         url = url + '&CENTERX='+centerX;
         url = url + '&CENTERY='+centerY;
         url = url + '&DPI='+dpi;
Modified: trunk/widgets/Query.js
--- trunk/widgets/Query.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Query.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -51,15 +51,14 @@
         var params = [];
         } else {
Modified: trunk/widgets/QuickPlot.js
--- trunk/widgets/QuickPlot.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/QuickPlot.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -44,15 +44,14 @@
         var params = [];
@@ -113,7 +112,7 @@
     preview: function(dialogConentLoadedCallback, printDpi)
         var capture  = this.mapCapturer.getCaptureBox();
         var normalizedCapture = this.mapCapturer.getNormalizedCapture();
         var vertices = capture.geometry.getVertices();
Modified: trunk/widgets/SaveMap.js
--- trunk/widgets/SaveMap.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/SaveMap.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -197,7 +197,7 @@
         if (this.imageWidth) {
             szWidth = '&width=' + this.imageWidth;
+        var m = this.getMapLayer();
         if(navigator.appVersion.match(/\bMSIE\b/)) {
             var url = Fusion.fusionURL + 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format.toUpperCase() + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             w = open(url, "Save", 'menubar=no,height=200,width=300');
Modified: trunk/widgets/Search.js
--- trunk/widgets/Search.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Search.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -53,15 +53,14 @@
         var params = [];
         } else {
Modified: trunk/widgets/SelectAttribute.js
--- trunk/widgets/SelectAttribute.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/SelectAttribute.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -68,7 +68,7 @@
     listLayers: function() {
         //this.layerList.empty();
         this.layerList.innerHTML = '';
-        var map = this.getMap().aMaps[0];
         this.layerList.options[this.layerList.options.length] = new Option('--select--','');
         for (var i=0; i<map.aLayers.length; ++i) {
             var layer = map.aLayers[i];
@@ -116,10 +116,10 @@
     activateLayer: function(event) {
       if (this.drawn) {
         var layer = this.layerList[this.layerList.selectedIndex].value;
-        for (var i=0; i<map.aMaps[0].aLayers.length; ++i) {
-          if (map.aMaps[0].aLayers[i].layerName == layer) {
-            map.setActiveLayer(map.aMaps[0].aLayers[i]);
+        for (var i=0; i<map.aLayers.length; ++i) {
+          if (map.aLayers[i].layerName == layer) {
+            map.setActiveLayer(map.aLayers[i]);
             break;
Modified: trunk/widgets/SelectRadius.js
--- trunk/widgets/SelectRadius.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/SelectRadius.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -114,10 +114,11 @@
         var radius = this.getMap().pixToGeoMeasure(this.defaultRadius);
         this.handler.setOptions({radius: radius});
         this.handler.activate();
-        this.getMap().setCursor(this.asCursor);
+        map.setCursor(this.asCursor);
         /*map units for tool tip*/
-        this.units = this.getMap().getAllMaps()[0].units;
-        this.getMap().supressContextMenu(true);
+        this.units = map.units;
+        map.supressContextMenu(true);
         this.triggerEvent(Fusion.Event.RADIUS_WIDGET_ACTIVATED, true);
Modified: trunk/widgets/SelectRadiusValue.js
--- trunk/widgets/SelectRadiusValue.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/SelectRadiusValue.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -50,7 +50,7 @@
     draw: function() {
         /* put in the label */
-        var units = this.getMap().getAllMaps()[0].units;
+        var units = this.getMap().units;
         this.domLabel = document.createElement('span');
         this.domLabel.className = this.className;
         this.domLabel.innerHTML = this.label + '(' + units + ')';
Modified: trunk/widgets/SelectWithin.js
--- trunk/widgets/SelectWithin.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/SelectWithin.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -89,15 +89,14 @@
         var params = [];
         } else {
Modified: trunk/widgets/SelectionPanel.js
--- trunk/widgets/SelectionPanel.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/SelectionPanel.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -503,7 +503,7 @@
             var layerObj = this.oSelection.getLayer(i);
             var aNames = layerObj.getPropertyNames();
             //find the legend label from the Map layer objects
-            var mapLayers = this.getMap().aMaps[0].aLayers; //TODO: allow multiple maps
+            var mapLayers = this.getMapLayer().aLayers;
             var labelName = layerObj.getName();
             for (var j=0; j<mapLayers.length; ++j) {
                 if (mapLayers[j].layerName == labelName) {
Modified: trunk/widgets/TaskPane.js
--- trunk/widgets/TaskPane.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/TaskPane.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -171,15 +171,15 @@
         //add in some common parameters if they aren't supplied already
         var baseUrl = url.split("?");
         var params = OpenLayers.Util.getParameters(url);
-        var mapLayers = this.getMap().getAllMaps();
         if (!params["LOCALE"] && !params["locale"]) {
           params["locale"] = Fusion.locale;
         if (!params["SESSION"] && !params["session"]) {
-          params["session"] = mapLayers[0].getSessionID();
+          params["session"] = widgetLayer.getSessionID();
         if (!params["MAPNAME"] && !params["mapname"]) {
-          params["mapname"] = mapLayers[0].getMapName();
+          params["mapname"] = widgetLayer.getMapName();
         var newUrl = baseUrl[0] + "?" + OpenLayers.Util.getParameterString(params);
Modified: trunk/widgets/Theme.js
--- trunk/widgets/Theme.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/Theme.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -50,15 +50,14 @@
         var params = [];
         } else {
Modified: trunk/widgets/ZoomToSelection.js
--- trunk/widgets/ZoomToSelection.js	2011-01-06 16:05:51 UTC (rev 2312)
+++ trunk/widgets/ZoomToSelection.js	2011-01-07 20:36:04 UTC (rev 2313)
@@ -59,18 +59,25 @@
      * @param selection the active selection, or null if there is none
-    zoomToSelection : function(selection) {
-        var map = this.oMap.aMaps[0]; //TODO: allow selection on multple maps
-        var ll = selection[map.getMapName()].getLowerLeftCoord();
-        var ur = selection[map.getMapName()].getUpperRightCoord();
-        var zoom_size = this.zoomFactor * Math.max( Math.abs(ur.x - ll.x), Math.abs(ur.y - ll.y)) / 2;
-        var cX = (ur.x + ll.x)/2;
-        var cY = (ur.y + ll.y)/2;
-        ll.x = cX - zoom_size;
-        ur.x = cX + zoom_size;
-        ll.y = cY - zoom_size;
-        ur.y = cY + zoom_size;
-        this.getMap().setExtents(new OpenLayers.Bounds(ll.x,ll.y,ur.x,ur.y));
+    zoomToSelection: function(selection) {
+        var aMaps = this.getMap().getAllMaps();
+        var bounds = new OpenLayers.Bounds();
+        for (var i=0; i<aMaps.length; ++i) {
+          var mapName = aMaps[i].getMapName()
+          if (selection[mapName]) {
+            var ll = selection[mapName].getLowerLeftCoord();//make this an OL Pixel
+            bounds.extend(new OpenLayers.LonLat(ll.x,ll.y));
+            var ur = selection[mapName].getUpperRightCoord();
+            bounds.extend(new OpenLayers.LonLat(ur.x,ur.y));
+        var zoom_size = this.zoomFactor * Math.max( Math.abs(bounds.getWidth()), Math.abs(bounds.getHeight())) / 2;
+        var center = bounds.getCenterLonLat();
+        llx = center.lon - zoom_size;
+        urx = center.lon + zoom_size;
+        lly = center.lat - zoom_size;
+        ury = center.lat + zoom_size;
+        this.getMap().setExtents(new OpenLayers.Bounds(llx,lly,urx,ury));
More information about the fusion-commits
