[fusion-commits] r2319 - in trunk/layers: . MapServer MapServer/php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Jan 17 15:15:35 EST 2011
Author: madair
Date: 2011-01-17 12:15:35 -0800 (Mon, 17 Jan 2011)
New Revision: 2319
   trunk/layers/Layers.js
   trunk/layers/MapServer/MapServer.js
   trunk/layers/MapServer/php/LoadMap.php
re #79: adjusting for uniqueness of lower level groups with same name but different parents
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2011-01-14 05:33:47 UTC (rev 2318)
+++ trunk/layers/Layers.js	2011-01-17 20:15:35 UTC (rev 2319)
@@ -415,7 +415,7 @@
     findGroup: function(name) {
-        return this.findGroupByAttribute('name', name);
+        return this.findGroupByAttribute('uniqueId', name);
     findGroupByAttribute: function(attribute, value) {
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js	2011-01-14 05:33:47 UTC (rev 2318)
+++ trunk/layers/MapServer/MapServer.js	2011-01-17 20:15:35 UTC (rev 2319)
@@ -272,6 +272,7 @@
             this.layerRoot.displayInLegend = true;
             this.layerRoot.expandInLegend = true;
+            o.groups.sort(function(a,b) {return a.depth-b.depth} );
             this.parseMapLayersAndGroups(o);
             var minScale = 1.0e10;
@@ -377,12 +378,11 @@
     loadScaleRanges: function() {
         var sl = Fusion.getScriptLanguage();
         var loadmapScript = 'layers/' + this.arch + '/' + sl  + '/LoadScaleRanges.' + sl;
-        var sessionid = this.getSessionID();
         var params = {'mapname': this._sMapname, "session": this.getSessionID()};
-        var options = {onSuccess: OpenLayers.Function.bind(this.scaleRangesLoaded, this),
-                       parameters:params};
+        var options = {
+          onSuccess: OpenLayers.Function.bind(this.scaleRangesLoaded, this),
+          parameters: params
         Fusion.ajaxRequest(loadmapScript, options);
@@ -503,20 +503,6 @@
-    parseLayers: function() {
-        //this.layerRoot.clear();
-        for (var i=0; i<this.aLayers.length; i++) {
-            var layer = this.aLayers[i];
-            var parent;
-            if (layer.parentGroup != '') {
-                parent = this.layerRoot.findGroup(layer.parentGroup.name);
-            } else {
-                parent = this.layerRoot;
-            parent.addLayer(layer, this.bLayersReversed);
     updateLayer: function() {   //to be fleshed out, add query file to layer if selection, call this before draw
       if (this.hasSelection()) {
           this.oLayerOL.addOptions({queryfile: this._sQueryfile});
Modified: trunk/layers/MapServer/php/LoadMap.php
--- trunk/layers/MapServer/php/LoadMap.php	2011-01-14 05:33:47 UTC (rev 2318)
+++ trunk/layers/MapServer/php/LoadMap.php	2011-01-17 20:15:35 UTC (rev 2319)
@@ -406,31 +406,40 @@
             $layerObj->minScale = min($layerObj->minScale, $aScaleRanges[$j]->minScale);
             $layerObj->maxScale = max($layerObj->maxScale, $aScaleRanges[$j]->maxScale);
-        array_push($mapObj->layers, $layerObj);
         //allow for nested groups using a "parentGroup" piece of metadata
         //nesting of groups is accomplished by using the | as a separator
         $parentStr = $layer->getMetaData('parentGroup');
-        $nestedParents = explode('|',$parentStr);
-        $parentParent = '';
-        foreach($nestedParents as $parent) {
-          //echo "testing:".$parent;
-          if (strlen($parent)>0) {
+        $nestedParents = array();
+        if (strlen($parentStr)>0) {
+          $nestedParents = explode('|',$parentStr);
+        if (strlen($layer->group)>0) {
+          array_push($nestedParents, $layer->group);
+          $layerObj->parentGroup = implode("|",$nestedParents);
+        //echo "/*";
+        //print_r($nestedParents);
+        while (count($nestedParents)>0) {
             $alreadyListed = false;
-            foreach($mapObj->groups as $pGroup){
-                if ($pGroup->groupName == $parent) {
+            $parentId = implode("|",$nestedParents);
+            $parent = array_pop($nestedParents);
+            //echo "-testing:".$parent." from:".$parentId."\n";
+            foreach($mapObj->groups as $pGroup) {
+                if ($pGroup->uniqueId == $parentId) {
                   $alreadyListed = true;
                   break;
             if (!$alreadyListed) {
-              array_push($mapObj->groups, getParentGroupObject($layer, $parent, $parentParent));
+              array_push($mapObj->groups, getGroupObject($layer, $parentId));
-          $parentParent = $parent;
+        //echo "*/";
+        array_push($mapObj->layers, $layerObj);
     $aGroups = $oMap->getAllGroupNames();
     if (is_array($aGroups)) {
       foreach($aGroups as $groupName) {
@@ -440,31 +449,32 @@
     echo var2json($mapObj);
-function getGroupObject($layer) {
+function getGroupObject($layer, $parentId) {
     $group = NULL;
-    $group->groupName = $layer->group;
+    /* parent group for nested groups */
+    $group->uniqueId =  $parentId;
+    $nestedParents = explode('|',$parentId);
+    $group->groupName = $parent;
+    $group->parentUniqueId = implode('|',$nestedParents);
+    $group->parent = $group->parentUniqueId;
+    $group->depth = count($nestedParents);
     $ll = $layer->getMetaData('groupLegendLabel');
     $group->legendLabel = $ll != '' ? $ll : $group->groupName;
-    $group->uniqueId = $group->groupName;
     $b = $layer->getMetaData('groupDisplayInLegend');
     $group->displayInLegend = ($b == 'false') ? false : true;
     $b = $layer->getMetaData('groupExpandInLegend');
     $group->expandInLegend = ($b == 'false') ? false : true;
     $group->layerGroupType = '';
-    /* parent group for nested groups */
-    $parentStr = $layer->getMetaData('parentGroup');
-    $parent = array_pop($nestedParents);
-    $group->parentUniqueId = $parent;
-    $group->parent = $parent;
     $b = $layer->getMetaData('groupVisible');
     $group->visible = ($b == 'false') ? false : true;
     $group->actuallyVisible = $layer->isVisible();
-    $group->groupParent = $layer->getMetaData('groupParent');
     return $group;
@@ -482,12 +492,11 @@
     /* maybe do some parsing of the metadata to get parents of paretns? */
+    $group->parentUniqueId = $parentGroup;
     return $group;
More information about the fusion-commits mailing list
