[fusion-commits] r2331 - branches/fusion-2.2/widgets/Theme/classes sandbox/adsk/2.3r/widgets/Theme/classes trunk/widgets/Theme/classes
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Jan 28 05:01:08 EST 2011
Author: liuar
Date: 2011-01-28 02:01:08 -0800 (Fri, 28 Jan 2011)
New Revision: 2331
   branches/fusion-2.2/widgets/Theme/classes/theme.php
   sandbox/adsk/2.3r/widgets/Theme/classes/theme.php
   trunk/widgets/Theme/classes/theme.php
Ticket #421
MapGuide upgraded LayerDefinition schema from 1.3.0 to 2.3.0.
So, the theme widget need to be enhanced to support the latest version of layer definition.
The new layer definition could be found at  http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Schema/LayerDefinition-2.3.0.xsd
Modified: branches/fusion-2.2/widgets/Theme/classes/theme.php
--- branches/fusion-2.2/widgets/Theme/classes/theme.php	2011-01-28 09:22:35 UTC (rev 2330)
+++ branches/fusion-2.2/widgets/Theme/classes/theme.php	2011-01-28 10:01:08 UTC (rev 2331)
@@ -274,9 +274,9 @@
         $CompositeTypeStyles = $vectorScaleRangecElement->getElementsByTagName('CompositeTypeStyle');
+        $isEnhancedStyle = ($CompositeTypeStyles->length != 0);
         // Remove any existing <CompositeTypeStyle> elements with Polygon <GeometryContext>.
-        if($CompositeTypeStyles != null)
+        if($isEnhancedStyle)
             $template = 'templates/arearuletemplate-'.$version.'-Enhanced.xml';
             $styleCount = $CompositeTypeStyles->length;
@@ -356,7 +356,7 @@
                       $areaTypeStyle->appendChild($areaNode);
                     $compositeTypeStyle = $doc->createElement('CompositeTypeStyle');
                     $compositeTypeStyle->appendChild($areaNode);
@@ -410,7 +410,7 @@
Modified: sandbox/adsk/2.3r/widgets/Theme/classes/theme.php
--- sandbox/adsk/2.3r/widgets/Theme/classes/theme.php	2011-01-28 09:22:35 UTC (rev 2330)
+++ sandbox/adsk/2.3r/widgets/Theme/classes/theme.php	2011-01-28 10:01:08 UTC (rev 2331)
@@ -274,9 +274,9 @@
@@ -356,7 +356,7 @@
@@ -410,7 +410,7 @@
Modified: trunk/widgets/Theme/classes/theme.php
--- trunk/widgets/Theme/classes/theme.php	2011-01-28 09:22:35 UTC (rev 2330)
+++ trunk/widgets/Theme/classes/theme.php	2011-01-28 10:01:08 UTC (rev 2331)
@@ -274,9 +274,9 @@
@@ -356,7 +356,7 @@
@@ -410,7 +410,7 @@
More information about the fusion-commits mailing list
