[fusion-commits] r2400 - in trunk: . lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jun 14 04:16:06 EDT 2011
Author: liuar
Date: 2011-06-14 01:16:06 -0700 (Tue, 14 Jun 2011)
New Revision: 2400
Added:
   trunk/lib/IE9patch.js
   trunk/build.xml
   trunk/lib/fusion.js
Temporary workaround for IE9 compatibility issue. I will revert this changelist after this issue get fixed in JxLib/Mootools
Modified: trunk/build.xml
--- trunk/build.xml	2011-06-03 18:56:58 UTC (rev 2399)
+++ trunk/build.xml	2011-06-14 08:16:06 UTC (rev 2400)
@@ -213,8 +213,9 @@
                   files=" SingleFile.js
                           fusion.js
                           proj4js-compressed.js
+                          IE9patch.js
                           OpenLayers/OpenLayers.js
-						  OLpatch.js
+                          OLpatch.js
                           jxlib.uncompressed.js
                           Error.js
                           EventMgr.js
Added: trunk/lib/IE9patch.js
--- trunk/lib/IE9patch.js	                        (rev 0)
+++ trunk/lib/IE9patch.js	2011-06-14 08:16:06 UTC (rev 2400)
@@ -0,0 +1,24 @@
+document.newElement = function(tag, props) {
+    var createdElement;
+    if (Browser.Engine.trident && props){
+        ['name', 'type', 'checked'].each(function(attribute){
+            if (!props[attribute]) return;
+            tag += ' ' + attribute + '="' + props[attribute] + '"';
+            if (attribute != 'checked') delete props[attribute];
+        var replaceTag = '<' + tag +'>';
+        try {
+            createdElement = this.createElement(replaceTag);
+        catch (e) {
+            createdElement = this.createElement(tag);
+    else {
+    return document.id(this.createElement(tag)).set(props);
\ No newline at end of file
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js	2011-06-03 18:56:58 UTC (rev 2399)
+++ trunk/lib/fusion.js	2011-06-14 08:16:06 UTC (rev 2400)
@@ -1400,6 +1400,7 @@
         var coreScripts = ['lib/OpenLayers/OpenLayers.js',
                             'lib/OLpatch.js',
                             'lib/jxLib/jxlib.uncompressed.js',
+                            'lib/IE9patch.js',
                             'lib/Proj4js/proj4js-compressed.js',
                             'lib/EventMgr.js',
                             'lib/Error.js',
More information about the fusion-commits mailing list
