[fusion-commits] r2341 - branches/fusion-2.2/lib/OpenLayers
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Mar 8 13:34:48 EST 2011
Author: madair
Date: 2011-03-08 10:34:48 -0800 (Tue, 08 Mar 2011)
New Revision: 2341
   branches/fusion-2.2/lib/OpenLayers/OpenLayers.js
fix for OL issue #3160 - change type of argument in calculateGridLayout to OL.LonLat
Modified: branches/fusion-2.2/lib/OpenLayers/OpenLayers.js
--- branches/fusion-2.2/lib/OpenLayers/OpenLayers.js	2011-03-03 20:59:36 UTC (rev 2340)
+++ branches/fusion-2.2/lib/OpenLayers/OpenLayers.js	2011-03-08 18:34:48 UTC (rev 2341)
@@ -1,127 +1,127 @@
-  OpenLayers.js -- OpenLayers Map Viewer Library
-  Copyright 2005-2011 OpenLayers Contributors, released under the Clear BSD
-  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
-  for the full text of the license.
-  Includes compressed code under the following licenses:
-  (For uncompressed versions of the code used please see the
-  OpenLayers SVN repository: <http://openlayers.org/>)
-/* Contains portions of Prototype.js:
- * Prototype JavaScript framework, version 1.4.0
- *  (c) 2005 Sam Stephenson <sam at conio.net>
- *  Prototype is freely distributable under the terms of an MIT-style license.
- *  For details, see the Prototype web site: http://prototype.conio.net/
-*  Contains portions of Rico <http://openrico.org/>
-*  Copyright 2005 Sabre Airline Solutions
-*  Licensed under the Apache License, Version 2.0 (the "License"); you
-*  may not use this file except in compliance with the License. You
-*  may obtain a copy of the License at
-*         http://www.apache.org/licenses/LICENSE-2.0
-*  Unless required by applicable law or agreed to in writing, software
-*  distributed under the License is distributed on an "AS IS" BASIS,
-*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
-*  implied. See the License for the specific language governing
-*  permissions and limitations under the License.
- * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
- * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Contains portions of Gears <http://code.google.com/apis/gears/>
- * Copyright 2007, Google Inc.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- *  1. Redistributions of source code must retain the above copyright notice,
- *     this list of conditions and the following disclaimer.
- *  2. Redistributions in binary form must reproduce the above copyright notice,
- *     this list of conditions and the following disclaimer in the documentation
- *     and/or other materials provided with the distribution.
- *  3. Neither the name of Google Inc. nor the names of its contributors may be
- *     used to endorse or promote products derived from this software without
- *     specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
- * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
- * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
- * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
- * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * Sets up google.gears.*, which is *the only* supported way to access Gears.
- * Circumvent this file at your own risk!
- * In the future, Gears may automatically define google.gears.* without this
- * file. Gears may use these objects to transparently fix bugs and compatibility
- * issues. Applications that use the code below will continue to work seamlessly
- * when that happens.
- * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
- * Copyright (c) 2006, Yahoo! Inc.
- * All rights reserved.
- * Redistribution and use of this software in source and binary forms, with or
- * without modification, are permitted provided that the following conditions
- * are met:
- * * Redistributions of source code must retain the above copyright notice,
- * * Redistributions in binary form must reproduce the above copyright notice,
- * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
- *   specific prior written permission of Yahoo! Inc.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
+  OpenLayers.js -- OpenLayers Map Viewer Library
+  Copyright 2005-2011 OpenLayers Contributors, released under the Clear BSD
+  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+  for the full text of the license.
+  Includes compressed code under the following licenses:
+  (For uncompressed versions of the code used please see the
+  OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ *  (c) 2005 Sam Stephenson <sam at conio.net>
+ *  Prototype is freely distributable under the terms of an MIT-style license.
+ *  For details, see the Prototype web site: http://prototype.conio.net/
+*  Contains portions of Rico <http://openrico.org/>
+*  Copyright 2005 Sabre Airline Solutions
+*  Licensed under the Apache License, Version 2.0 (the "License"); you
+*  may not use this file except in compliance with the License. You
+*  may obtain a copy of the License at
+*         http://www.apache.org/licenses/LICENSE-2.0
+*  Unless required by applicable law or agreed to in writing, software
+*  distributed under the License is distributed on an "AS IS" BASIS,
+*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+*  implied. See the License for the specific language governing
+*  permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ *  1. Redistributions of source code must retain the above copyright notice,
+ *     this list of conditions and the following disclaimer.
+ *  2. Redistributions in binary form must reproduce the above copyright notice,
+ *     this list of conditions and the following disclaimer in the documentation
+ *     and/or other materials provided with the distribution.
+ *  3. Neither the name of Google Inc. nor the names of its contributors may be
+ *     used to endorse or promote products derived from this software without
+ *     specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ *   specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
     OpenLayers/SingleFile.js
@@ -39520,7 +39520,7 @@
     * sz - {<OpenLayers.Size>}
     * Returns:
-    * {DOMElement} A new DOM Image with this marker´s icon set at the
+    * {DOMElement} A new DOM Image with this marker�s icon set at the
     *         location passed-in
     draw: function(px, sz) {
@@ -40029,17 +40029,17 @@
         var tilelon = resolution * this.tileSize.w;
         var tilelat = resolution * this.tileSize.h;
-        var offsetlon = bounds.left - extent.left;
+        var offsetlon = bounds.left - extent.lon;
         var tilecol = Math.floor(offsetlon/tilelon) - this.buffer;
         var tilecolremain = offsetlon/tilelon - tilecol;
         var tileoffsetx = -tilecolremain * this.tileSize.w;
-        var tileoffsetlon = extent.left + tilecol * tilelon;
+        var tileoffsetlon = extent.lon + tilecol * tilelon;
-        var offsetlat = extent.top - bounds.top + tilelat;
+        var offsetlat = extent.lat - bounds.top + tilelat;
         var tilerow = Math.floor(offsetlat/tilelat) - this.buffer;
         var tilerowremain = tilerow - offsetlat/tilelat;
         var tileoffsety = tilerowremain * this.tileSize.h;
-        var tileoffsetlat = extent.top - tilelat*tilerow;
+        var tileoffsetlat = extent.lat - tilelat*tilerow;
         return {
           tilelon: tilelon, tilelat: tilelat,
More information about the fusion-commits mailing list
