[fusion-commits] r2522 - in sandbox/adsk/2.4j: lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Jan 18 21:32:07 EST 2012
Author: hubu
Date: 2012-01-18 18:32:07 -0800 (Wed, 18 Jan 2012)
New Revision: 2522
   sandbox/adsk/2.4j/lib/Widget.js
   sandbox/adsk/2.4j/widgets/BufferPanel.js
   sandbox/adsk/2.4j/widgets/FeatureInfo.js
   sandbox/adsk/2.4j/widgets/Help.js
   sandbox/adsk/2.4j/widgets/InvokeURL.js
   sandbox/adsk/2.4j/widgets/Measure.js
   sandbox/adsk/2.4j/widgets/Query.js
   sandbox/adsk/2.4j/widgets/QuickPlot.js
   sandbox/adsk/2.4j/widgets/Redline.js
   sandbox/adsk/2.4j/widgets/SelectWithin.js
   sandbox/adsk/2.4j/widgets/TaskPane.js
   sandbox/adsk/2.4j/widgets/Theme.js
on behalf of libr(Bruce li)
integrate from revision 2521 of trunk
Modified: sandbox/adsk/2.4j/lib/Widget.js
--- sandbox/adsk/2.4j/lib/Widget.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/lib/Widget.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -158,7 +158,7 @@
     shouldActivateWith: function(widget) {
-        return false;
+        return true;
Modified: sandbox/adsk/2.4j/widgets/BufferPanel.js
--- sandbox/adsk/2.4j/widgets/BufferPanel.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/BufferPanel.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -118,7 +118,10 @@
         url += params.join('&');
         if ( taskPaneTarget ) {
-            taskPaneTarget.setContent(url);
+            if(!taskPaneTarget.isSameWithLast(url))
+                taskPaneTarget.setContent(url);
         } else {
             if ( pageElement ) {
                 pageElement.src = url;
Modified: sandbox/adsk/2.4j/widgets/FeatureInfo.js
--- sandbox/adsk/2.4j/widgets/FeatureInfo.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/FeatureInfo.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -72,7 +72,10 @@
         } else {
Modified: sandbox/adsk/2.4j/widgets/Help.js
--- sandbox/adsk/2.4j/widgets/Help.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/Help.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -84,7 +84,10 @@
         /* check to see if this is going into a task pane */
         var taskPaneTarget = Fusion.getWidgetById(this.target);
         } else {
             /* check to see if it is going into a frame in the page */
             var pageElement = $(this.target);
Modified: sandbox/adsk/2.4j/widgets/InvokeURL.js
--- sandbox/adsk/2.4j/widgets/InvokeURL.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/InvokeURL.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -112,7 +112,10 @@
         var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
         } else {
             var pageElement = $(this.sTarget);
Modified: sandbox/adsk/2.4j/widgets/Measure.js
--- sandbox/adsk/2.4j/widgets/Measure.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/Measure.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -468,7 +468,10 @@
             var outputWin = window;
                 outputWin = taskPaneTarget.iframe.contentWindow;
             } else {
                 outputWin = window.open(url, this.sTarget, this.sWinFeatures);
Modified: sandbox/adsk/2.4j/widgets/Query.js
--- sandbox/adsk/2.4j/widgets/Query.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/Query.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -72,7 +72,10 @@
         } else {
Modified: sandbox/adsk/2.4j/widgets/QuickPlot.js
--- sandbox/adsk/2.4j/widgets/QuickPlot.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/QuickPlot.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -156,7 +156,10 @@
         if (taskPaneTarget)
         else
Modified: sandbox/adsk/2.4j/widgets/Redline.js
--- sandbox/adsk/2.4j/widgets/Redline.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/Redline.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -114,7 +114,10 @@
         } else {
             outputWin = window.open(url, this.widget.sTarget, this.widget.sWinFeatures);
Modified: sandbox/adsk/2.4j/widgets/SelectWithin.js
--- sandbox/adsk/2.4j/widgets/SelectWithin.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/SelectWithin.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -111,7 +111,10 @@
         } else {
Modified: sandbox/adsk/2.4j/widgets/TaskPane.js
--- sandbox/adsk/2.4j/widgets/TaskPane.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/TaskPane.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -161,13 +161,8 @@
         this.setContent(url);
-    setContent: function(url) {
-        Fusion.triggerEvent(Fusion.Event.TASK_PANE_LOADED);
-        if (this.nCurrentTask < this.aExecutedTasks.length-1) {
-            //this.aExecutedTasks.splice(this.nCurrentTask, this.aExecutedTasks.length - this.nCurrentTask);
+    addCommonParams:function(url){
         //add in some common parameters if they aren't supplied already
         var baseUrl = url.split("?");
         var params = OpenLayers.Util.getParameters(url);
@@ -182,7 +177,17 @@
           params["mapname"] = widgetLayer.getMapName();
         var newUrl = baseUrl[0] + "?" + OpenLayers.Util.getParameterString(params);
+        return newUrl;
+    isSameWithLast:function(url){
+        return this.aExecutedTasks[this.aExecutedTasks.length-1] == this.addCommonParams(url) ;
+    setContent: function(url) {
+        Fusion.triggerEvent(Fusion.Event.TASK_PANE_LOADED);
+        var newUrl = this.addCommonParams(url);
         this.aExecutedTasks.push(newUrl);
         ++this.nCurrentTask;
         this.loadFrame(newUrl);
Modified: sandbox/adsk/2.4j/widgets/Theme.js
--- sandbox/adsk/2.4j/widgets/Theme.js	2012-01-19 02:04:27 UTC (rev 2521)
+++ sandbox/adsk/2.4j/widgets/Theme.js	2012-01-19 02:32:07 UTC (rev 2522)
@@ -71,7 +71,10 @@
         } else {
More information about the fusion-commits mailing list
