[fusion-commits] r2543 - in trunk: layers/MapGuide/php widgets/FeatureInfo/classes
svn_fusion at osgeo.org svn_fusion at osgeo.org
Sat Jul 7 04:51:06 PDT 2012
Author: jng
Date: 2012-07-07 04:51:06 -0700 (Sat, 07 Jul 2012)
New Revision: 2543
   trunk/layers/MapGuide/php/Utilities.php
   trunk/widgets/FeatureInfo/classes/featureinfo.php
#528: Fix Feature Info widget:
 - Only show visible and selectable layers in the layer list
 - Fix PHP notice that scrambles return json if (display_errors = On)
Modified: trunk/layers/MapGuide/php/Utilities.php
--- trunk/layers/MapGuide/php/Utilities.php	2012-06-28 20:07:38 UTC (rev 2542)
+++ trunk/layers/MapGuide/php/Utilities.php	2012-07-07 11:51:06 UTC (rev 2543)
@@ -788,15 +788,15 @@
     array_push($properties->$layerName->metadatanames, 'area');
     array_push($properties->$layerName->metadatanames, 'length');
-    //NOTE: PHP will complain about _SESSION being undefined when display_errors = On with full verbosity
-    //messing up any JSON response in the process!
-    $mappings = $_SESSION['property_mappings'][$layerObj->GetObjectId()];
-    foreach((array)$mappings as $name => $value)
-        $propType = $featureReader->GetPropertyType($name);
-        array_push($properties->$layerName->propertynames, $name);
-        array_push($properties->$layerName->propertyvalues, $value);
-        array_push($properties->$layerName->propertytypes, $propType);
+    if (isset($_SESSION)) {
+        $mappings = $_SESSION['property_mappings'][$layerObj->GetObjectId()];
+        foreach((array)$mappings as $name => $value)
+            $propType = $featureReader->GetPropertyType($name);
+            array_push($properties->$layerName->propertynames, $name);
+            array_push($properties->$layerName->propertyvalues, $value);
+            array_push($properties->$layerName->propertytypes, $propType);
     $srsTarget = null;
Modified: trunk/widgets/FeatureInfo/classes/featureinfo.php
--- trunk/widgets/FeatureInfo/classes/featureinfo.php	2012-06-28 20:07:38 UTC (rev 2542)
+++ trunk/widgets/FeatureInfo/classes/featureinfo.php	2012-07-07 11:51:06 UTC (rev 2543)
@@ -48,7 +48,7 @@
             //TODO: Exclude Raster and Drawing Layers???
-            if((substr($layer->GetName(), 0, 1) != "_") && (substr(strtoupper($layer->GetFeatureSourceId()), 0, 7) != "SESSION"))
+            if((substr($layer->GetName(), 0, 1) != "_") && (substr(strtoupper($layer->GetFeatureSourceId()), 0, 7) != "SESSION") && ($layer->IsVisible()) && $layer->GetSelectable())
                 $layerNames[$layer->GetName()] = $layer->GetLegendLabel();
More information about the fusion-commits mailing list
