[fusion-commits] r2553 - trunk/widgets/QuickPlot
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jul 24 00:12:18 PDT 2012
Author: liuar
Date: 2012-07-24 00:12:18 -0700 (Tue, 24 Jul 2012)
New Revision: 2553
   trunk/widgets/QuickPlot/GeneratePicture.php
   trunk/widgets/QuickPlot/PlotAsPDF.php
On behalf of Ted Yang.
fix the wrong query parameter "print_size", and in GeneratePicture.php, use new parameter to calculate the image size
Modified: trunk/widgets/QuickPlot/GeneratePicture.php
--- trunk/widgets/QuickPlot/GeneratePicture.php	2012-07-20 06:37:49 UTC (rev 2552)
+++ trunk/widgets/QuickPlot/GeneratePicture.php	2012-07-24 07:12:18 UTC (rev 2553)
@@ -12,13 +12,13 @@
     $scaleDenominator = 0;
     $captureBox;
     $normalizedCapture;
+    $printSize_pixel;
     $printSize;
-    $paperSize;
     try
         GetParameters();
-        GenerateMap($printSize);
+        GenerateMap($printSize_pixel);
     catch (MgException $e) {
         $msg = "last error";
@@ -37,7 +37,7 @@
     function GetParameters()
-        global $sessionID, $mapName, $printDpi, $rotation, $paperSize, $captureBox, $printSize, $scaleDenominator, $normalizedCapture;
+        global $sessionID, $mapName, $printDpi, $rotation, $printSize, $printSize_pixel, $captureBox, $scaleDenominator, $normalizedCapture;
         $args = $_GET;
         if ($_SERVER["REQUEST_METHOD"] == "POST")
@@ -52,10 +52,9 @@
         $scaleDenominator = intval($args["scale_denominator"]);
-        $array       = explode(",", $args["paper_size"]);
-        $paperSize   = new Size(ParseLocaleDouble($array[0]), ParseLocaleDouble($array[1]));
-        $printSize   = new Size($paperSize->width / 25.4 * $printDpi, $paperSize->height / 25.4 * $printDpi);
+        $array       = explode(",", $args["print_size"]);
+        $printSize   = new Size(ParseLocaleDouble($array[0]), ParseLocaleDouble($array[1]));
+        $printSize_pixel   = new Size($printSize->width / 25.4 * $printDpi, $printSize->height / 25.4 * $printDpi);
         $array       = explode(",", $args["box"]);
         $captureBox  = CreatePolygon($array);
@@ -83,10 +82,9 @@
         return $captureBox;
-    function GenerateMap($size)
+    function GenerateMap($size)//print_size
         global $sessionID, $mapName, $captureBox, $printSize, $normalizedCapture, $rotation, $scaleDenominator, $printDpi;
         $userInfo         = new MgUserInformation($sessionID);
         $siteConnection   = new MgSiteConnection();
         $siteConnection->Open($userInfo);
@@ -97,7 +95,7 @@
         $map->Open($resourceService, $mapName);
         $selection        = new MgSelection($map);
         // Calculate the generated picture size
         $envelope         = $captureBox->Envelope();
         $normalizedE      = $normalizedCapture->Envelope();
@@ -105,7 +103,7 @@
         $size2            = new Size($normalizedE->getWidth(), $normalizedE->getHeight());
         $toSize           = new Size($size1->width / $size2->width * $size->width, $size1->height / $size2->height * $size->height);
         $center           = $captureBox->GetCentroid()->GetCoordinate();
         $map->SetDisplayDpi($printDpi);
         $colorString = $map->GetBackgroundColor();
         // The returned color string is in AARRGGBB format. But the constructor of MgColor needs a string in RRGGBBAA format
@@ -121,9 +119,10 @@
                                                 $color,
                                                 "PNG",
                                                 false);
         $tempImage = sys_get_temp_dir() . DIRECTORY_SEPARATOR . "mgo" . uniqid();
         $mgReader->ToFile($tempImage);
         $image = imagecreatefrompng($tempImage);
         unlink($tempImage);
@@ -141,12 +140,12 @@
         header ("Content-type: image/png");
         imagepng($croppedImg);
-        imagedestroy($croppedImg);
+        imagedestroy($croppedImg);
     function DrawNorthArrow($map)
-        global $paperSize, $rotation;
+        global $printSize, $rotation;
         // Load the north arrow image which has a 300 dpi resolution
         $na         = imagecreatefrompng("./north_arrow.png");
@@ -162,7 +161,7 @@
         $mapWidth   = imagesx($map);
         $mapHeight  = imagesy($map);
         // Get the logical resolution of map
-        $resolution = $mapWidth * 25.4 / $paperSize->width;
+        $resolution = $mapWidth * 25.4 / $printSize->width;
         // On printed paper, north arrow is located at the right bottom corner with 6 MM margin
         $naRes      = 300;
         $naMargin   = 12;
Modified: trunk/widgets/QuickPlot/PlotAsPDF.php
--- trunk/widgets/QuickPlot/PlotAsPDF.php	2012-07-20 06:37:49 UTC (rev 2552)
+++ trunk/widgets/QuickPlot/PlotAsPDF.php	2012-07-24 07:12:18 UTC (rev 2553)
@@ -74,7 +74,7 @@
     // Construct the querysting which can be used to generate the Map image
-    $query_string = "session_id=".$_POST['sessionId']."&map_name=".$_POST['mapName']."&paper_size=".$_POST['printSize'].
+    $query_string = "session_id=".$_POST['sessionId']."&map_name=".$_POST['mapName']."&print_size=".$_POST['printSize'].
                     "&print_dpi=".$_POST['dpi']."&box=".$_POST['box']."&normalized_box=".$_POST['normalizedBox'].
                     "&scale_denominator=".$_POST['scaleDenominator']."&rotation=".$_POST['rotation'];
More information about the fusion-commits mailing list
