[fusion-commits] r2540 - sandbox/adsk/2.4j/widgets/SelectWithin
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jun 26 18:49:54 PDT 2012
Author: liuar
Date: 2012-06-26 18:49:54 -0700 (Tue, 26 Jun 2012)
New Revision: 2540
   sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithin.php
   sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithinPanel.templ
Fix Defect - SelectWithin? doesn't work with Shift+Click select
This is because SelectWithin? doesn't update the selection set in browser side.
Modified: sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithin.php
--- sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithin.php	2012-06-26 20:45:48 UTC (rev 2539)
+++ sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithin.php	2012-06-27 01:49:54 UTC (rev 2540)
@@ -100,7 +100,7 @@
                 $properties->extents->miny = $oMin->GetY();
                 $properties->extents->maxx = $oMax->GetX();
                 $properties->extents->maxy = $oMax->GetY();
-              } else { echo "/* no extents */"; }
+              } else { echo "<Message>no extents</Message>"; }
               //get properties for individual features
               $result->layers = array();
@@ -122,15 +122,15 @@
               /*save selection in the session*/
               $_SESSION['selection_array'] = $properties;
-            } else { echo "/* layers false or 0 */"; }
-          } else { echo "/* no resultsel */"; }
-        } else { echo "/* no fi */"; }
-      } else { echo "/*no multi geom*/"; }
-    } else { echo "/* no layers */"; }
+              echo str_replace("</FeatureSet>", "</FeatureSet></FeatureInformation>", str_replace("<FeatureSet", "<FeatureInformation><FeatureSet", $resultSel->ToXml()));
+            } else { echo "<Message>layers false or 0</Message>"; }
+          } else { echo "<Message>no resultsel</Message>"; }
+        } else { echo "<Message>no fi</Message>"; }
+      } else { echo "<Message>no multi geom</Message>"; }
+    } else { echo "<Message>no layers</Message>"; }
-    header('Content-type: application/json');
-    header('X-JSON: true');
-    echo var2json($result);
+    //return XML
+    header("Content-type: text/xml");
   } catch(MgException $e) {
     echo "\nException: " . $e->GetDetails();
     return;
Modified: sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithinPanel.templ
--- sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithinPanel.templ	2012-06-26 20:45:48 UTC (rev 2539)
+++ sandbox/adsk/2.4j/widgets/SelectWithin/SelectWithinPanel.templ	2012-06-27 01:49:54 UTC (rev 2540)
@@ -98,7 +98,8 @@
 function selectedSuccess(r) {
     var mapWidget = GetParent().Fusion.getMapByName(mapName);
-    mapWidget.processQueryResults(zoomTo, r);
+    var callback = GetParent().OpenLayers.Function.bind(mapWidget.processFeatureInfo, mapWidget);
+    GetParent().Fusion.xml2json(callback, r);
 function selectedError(r) {
@@ -144,7 +145,7 @@
 function GetParent()
-{debugger;
 	if(popup)
 		return opener;
 	else
More information about the fusion-commits mailing list
