[fusion-commits] r2670 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Mar 22 08:33:22 PDT 2013
Author: jng
Date: 2013-03-22 08:33:22 -0700 (Fri, 22 Mar 2013)
New Revision: 2670
   trunk/widgets/Buffer.js
   trunk/widgets/BufferPanel.js
   trunk/widgets/FeatureInfo.js
   trunk/widgets/Measure.js
   trunk/widgets/Query.js
   trunk/widgets/Redline.js
   trunk/widgets/Theme.js
#550: Turn off exclusion flag, turning these widgets effectively into glorified InvokeURL widgets (which they are)
Modified: trunk/widgets/Buffer.js
--- trunk/widgets/Buffer.js	2013-03-22 14:52:09 UTC (rev 2669)
+++ trunk/widgets/Buffer.js	2013-03-22 15:33:22 UTC (rev 2670)
@@ -38,7 +38,7 @@
 Fusion.Widget.Buffer = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
-    isExclusive: true,
+    isExclusive: false,
     layerName: null,
     layerNameInput: null,
     bufferDistance: null,
Modified: trunk/widgets/BufferPanel.js
--- trunk/widgets/BufferPanel.js	2013-03-22 14:52:09 UTC (rev 2669)
+++ trunk/widgets/BufferPanel.js	2013-03-22 15:33:22 UTC (rev 2670)
@@ -41,7 +41,7 @@
 Fusion.Widget.BufferPanel = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
     sFeatures : 'menubar=no,location=no,resizable=no,status=no',
     initializeWidget: function(widgetTag) {
         var json = widgetTag.extension;
Modified: trunk/widgets/FeatureInfo.js
--- trunk/widgets/FeatureInfo.js	2013-03-22 14:52:09 UTC (rev 2669)
+++ trunk/widgets/FeatureInfo.js	2013-03-22 15:33:22 UTC (rev 2670)
@@ -39,7 +39,7 @@
 Fusion.Widget.FeatureInfo = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
     sFeatures: 'menubar=no,location=no,resizable=no,status=no',
     oTarget: null,
Modified: trunk/widgets/Measure.js
--- trunk/widgets/Measure.js	2013-03-22 14:52:09 UTC (rev 2669)
+++ trunk/widgets/Measure.js	2013-03-22 15:33:22 UTC (rev 2670)
@@ -41,7 +41,7 @@
 Fusion.Event.MEASURE_COMPLETE = Fusion.Event.lastEventId++;
 Fusion.Widget.Measure = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
     //distance of each segment
Modified: trunk/widgets/Query.js
--- trunk/widgets/Query.js	2013-03-22 14:52:09 UTC (rev 2669)
+++ trunk/widgets/Query.js	2013-03-22 15:33:22 UTC (rev 2670)
@@ -40,7 +40,7 @@
 Fusion.Widget.Query = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
Modified: trunk/widgets/Redline.js
--- trunk/widgets/Redline.js	2013-03-22 14:52:09 UTC (rev 2669)
+++ trunk/widgets/Redline.js	2013-03-22 15:33:22 UTC (rev 2670)
@@ -36,7 +36,7 @@
 *  - <Fusion.Widget>
 Fusion.Widget.Redline = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
     // Fusion map widget
Modified: trunk/widgets/Theme.js
--- trunk/widgets/Theme.js	2013-03-22 14:52:09 UTC (rev 2669)
+++ trunk/widgets/Theme.js	2013-03-22 15:33:22 UTC (rev 2670)
@@ -39,7 +39,7 @@
 Fusion.Widget.Theme = OpenLayers.Class(Fusion.Widget, {
     uiClass: Jx.Button,
More information about the fusion-commits mailing list
