[fusion-dev] RFC 1: Use OpenLayers.Class and other prototypecapabilities
Jason Birch Jason.Birch at nanaimo.ca
Thu Mar 20 17:33:08 EDT 2008
I think you've chosen the right path with this, and think that tighter
integration with OpenLayers (such that both projects benefit from
shared work) would be a good idea.  OpenLayers seems to highly value
a stable API and generic functionality so, at least under its current
direction, I personally don't see any problem with tighter integration.
I guess it's a bit late for me to say I can't comment on the
technical aspects (which I can't), but the architectural decision
seems sound :)
Jason
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Thursday, March 20, 2008 13:29
To: Jason Birch
Cc: fusion-dev at lists.osgeo.org
Subject: Re: [fusion-dev] RFC 1: Use OpenLayers.Class and other
Jason,
that is correct.  In addition, it would make it much easier to
consider moving to a different GUI framework such as ExtJS although
that is not something that we are thinking of doing.
Based on my work with OpenLayers, much of the functionality that we
would be relying on was originally copied from Prototype (or at least
inspired by Prototype) when OpenLayers removed its own dependency on
Prototype.  While I haven't done a lot outside of OpenLayers with that
framework, it is working very well for OpenLayers and the API has not
changed in a while.  There is some current work being done on the Ajax
support in OpenLayers that will make it somewhat different from the
existing Prototype API but I believe it will still work for our needs
and may in fact improve it for us too :)
There is an alternative, which is to bring the essential parts of
Prototype (or equivalent) into the Fusion namespace so that we are not
dependent on anything (for that at least).  However, this would
duplicate code and functionality and I am not keen on maintaining any
more code in Fusion than necessary.  As time goes by, I am going to be
proposing even tighter integration with OpenLayers (think
Fusion.Widget = OpenLayers.Control for instance).
An argument against tighter integration may be that we may want to
replace OpenLayers with another map management library at some point.
However, I don't see anything on the block that is going to compete
with OpenLayers at the moment and I don't feel that this is a bad move
on our part.
Cheers
Paul
On 20-Mar-08, at 4:17 PM, Jason Birch wrote:
> So...
> This RFC is basically removing Fusion's explicit dependencies on
> Prototype, so that Jx is free to move to a different framework without
> disrupting Fusion?
> If so, sounds reasonable to me.
> Are these components in OpenLayers stable/enshrined enough that
> switching to that implementation will not incur the same risk of
> disruption?
> Jason
> From: fusion-dev-bounces at lists.osgeo.org
> [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
> Sent: Thursday, March 20, 2008 12:49
> To: fusion-dev at lists.osgeo.org
> Subject: [fusion-dev] RFC 1: Use OpenLayers.Class and other
> I realize that we don't have a PSC yet, however I would like to start
> working as if we did have one and use the current membership of the
> dev mailing list to discuss major changes to Fusion.  We will be
> working to formalize a PSC as we grow the community around Fusion.  In
> the mean time, I have a major change that I would like to get
> community consensus on.
> If you are interested, please see the following RFC and comment on
> this list.
> http://trac.osgeo.org/fusion/wiki/FusionRfc1
> Cheers
> Paul
> __________________________________________
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://www.dmsolutions.ca/
> fusion-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
    Paul Spencer
More information about the fusion-dev mailing list
