[fusion-dev] fusion 1.0.5 release tomorrow
Jason Birch Jason.Birch at nanaimo.ca
Tue May 6 16:55:37 EDT 2008
I don't suppose that there's much chance of getting #56 addressed for
1.0.5?
http://trac.osgeo.org/fusion/ticket/56
If there is a way of adding LayerAttributeFilter as an optional
property, I believe that this is a relatively minor change (modify
MGBroker to accept the LAYERATTRIBUTEFILTER, modify the maptip widget to
specify a value of 5).
This will improve the usability of the Maptip widget (users don't have
to know that they need to make the layer selectable), increase
compatibility with existing MapGuide maps, and improve performance as it
prevents queries against layers that don't have tooltips defined.
Jason
-----Original Message-----
Subject: [fusion-dev] fusion 1.0.5 release tomorrow
Hi, just a quick note to let you know that Mike is fixing a few
critical bugs in 1.0.4 and will be releasing a bug fix update late
tomorrow (or early the next day) for inclusion in the next MapGuide OS
point release.
If you are interested in getting any fixes included in 1.0.5, please
get the code submitted by tomorrow.
More information about the fusion-dev mailing list
