[fusion-dev] Help Me Base Layers
Lucas Lessa landradelessa at gmail.com
Thu Jul 30 16:38:37 EDT 2009
Hi all,
I'm from Brazil.
Dear Friends,
I've a map with normal layers and one base layer. When I use a basic layout
everything works fine, but using Fusion flexible Layout I can't turn off a
base layer and it's always over the other layers.
Does anyone have an idea? How I change this Drawing order?
Can you send for me one example?
This example
http://squamish2010.ca/mapguide2010/contaminants/main_fusion.php will be
very good.
I'm using mapguide enterprise 2010 supervised by autodesk.
Best regards,
Lucas Lessa
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20090730/ced53c4c/attachment.html
More information about the fusion-dev mailing list
