[fusion-dev] RE: FeatureReader not being closed in MapGuide Query.php?
Mike Adair madair at dmsolutions.ca
Mon Mar 23 16:43:52 EDT 2009
Yes a ticket would be good to keep track.  I thought we found all those
but it appears not...
Mike
Jason Birch wrote:
> Should I be entering tickets for these?  I didn't expect to find so many that I had questions about.
> Another in:
>  trunk/widgets/SelectWithin/SelectWithin.php
> On line 109, it appears that an MgFeatureReader called $featureReader is opened but not closed.
> Jason
> -----Original Message-----
> From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: March-23-09 1:23 PM
> To: fusion-dev at lists.osgeo.org
> Subject: [fusion-dev] RE: FeatureReader not being closed in MapGuide Query.php?
> Similarly...
> It looks to me that in the file
>   trunk/widgets/Search/Search.php
> The MgFeatureReader called $features is only closed in the exception handling logic, not in the normal code stream.
> Jason
> From: Jason Birch
> Sent: March-23-09 1:14 PM
> Subject: [fusion-dev] FeatureReader not being closed in MapGuide Query.php?
> Could someone check my logic on this one please?
> I believe that for:
>   trunk/layers/MapGuide/php/Query.php
> There is an MgFeatureReader being opened on line 199 which is being closed on line 268.
> However, on line 261, I believe that a second MgFeatureReader is being opened using the same variable name without closing the initial MgFeatureReader first, and that this second reader is never closed.
> Thoughts?  Time for an eye exam?
> Thanks,
> Jason
> fusion-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-dev mailing list
