[fusion-dev] RE: [fusion-users] MapServer Legend Icons
Paul Spencer pspencer at dmsolutions.ca
Fri Nov 6 09:46:18 EST 2009
Tim,
there never seems like enough time for stuff like this :)  The coding
standard, such as it is, is a mix of current best practices and is not
entirely consistent.  All contributions will be well received but we
provide some (hopefully constructive) criticism.  The thing I like
about svn is changes can always be backed out if necessary so I always
encourage folks to commit what they have and then we can all test/
review.
Cheers
Paul
On 2009-11-06, at 9:33 AM, Nolte, Tim wrote:
> Thanks Paul for the welcome and the advice for getting a MapGuide
> install setup for testing. I'm really looking forward to
> contributing to
> the project. I was on the site looking for guidelines and didn't find
> anything. You do have some pages up but there is not content yet. Does
> anyone have any recommendations or best practices that I should be
> aware
> of? I just want to make sure that I meet any standards that have been
> set and that my contributions are received well. Thanks.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS:    616-706-2438
> Fax:    616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
> Paul Deschamps
> Sent: Thursday, November 05, 2009 7:27 PM
> To: Nolte, Tim
> Cc: Paul Spencer; fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] MapServer Legend Icons
> Hi Tim,
> Welcome to the project. If your interested you can also download a
> live
> cd of MapGuide Open source. (http://mapguide.osgeo.org/node/127) and
> run
> it in vmware. If your interested. It's a nice way to see how fusion
> works with both platforms and it will help to make sure that when you
> fix an issue on one platform that it doesn't expose an issue on the
> other so it's a good idea to have setup anyhow.
> Cheers
> Paul D (Not Paul S) :)
> On Thu, Nov 5, 2009 at 4:33 PM, Nolte, Tim
> <Tim.Nolte at ipcswirelessinc.com> wrote:
> 	Paul,
> 	Excellent! Thank you very much. I've making some good head way
> on the
> 	whole Legend issue, especially when using multiple maps within a
> map
> 	group. I'm going to switch over to a single map in the map group
> and see
> 	what results I get also. I'm happy to be able to submit changes
> to the
> 	MapServer side of the project. I hope that my work will help
> others that
> 	are already using MapServer adopt Fusion as their framework of
> choice.
> 	- Tim
> 	iPCS Wireless, Inc.
> 	Kentwood, MI 49512
> 	PCS:    616-706-2438
> 	Fax:    616-554-6484
> 	From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> 	Sent: Thursday, November 05, 2009 3:46 PM
> 	To: Nolte, Tim
> 	Cc: fusion-users at lists.osgeo.org
> 	Hi Tim,
> 	the project is not dead but I don't know how many folks are
> using it
> 	right now.  I know that MapGuide is actively using it and the
> Autodesk
> 	team there is actively finding and fixing bugs related to the
> MapGuide
> 	support.  DM Solutions is also actively using and developing the
> 	framework and the MapServer support.
> 	I have added you as a committer, welcome aboard!
> 	Cheers
> 	Paul
> 	On 2009-11-05, at 3:03 PM, Nolte, Tim wrote:
> 	> Is this forum and/or project dead? How many people are
> actually using
> 	> this or developing for it?
> 	> Well, on a good note I finally got a somewhat working solution
> by
> 	> basically forgetting about trying to rely on $_SESSION and
> basically
> 	> copied a bunch of the LoadMap code that sets up the Scale
> Ranges
> 	> over to
> 	> the LoadScaleRanges script. I also changed the script to also
> not rely
> 	> on the $_SESSION to tell it what mapfile it is supposed to use
> and
> 	> basically copied the code in LoadMap that sets up the SESSION
> based
> 	> map.
> 	> There is still the issue of the Legend being sorted backwards,
> the
> 	> Legend icons not all updating properly when zooming in, as
> well as an
> 	> issue with the map layers not being stacked in the right
> order. I'm
> 	> plugging away at this. It would be really nice if no one else
> is
> 	> really
> 	> working on MapServer specific development that I could start
> 	> submitting
> 	> to the SVN or somehow my changes could get approved to be
> taken into
> 	> the
> 	> project. I'll hate to have to use a diff utility every time
> there is
> 	> an
> 	> update and have to fix my code so that things still work.
> Thanks to
> 	> anyone that is actually reading this, if there is anyone out
> there.
> 	> - Tim
> 	> iPCS Wireless, Inc.
> 	> Kentwood, MI 49512
> 	> PCS:    616-706-2438
> 	> Fax:    616-554-6484
> 	> From: fusion-users-bounces at lists.osgeo.org
> 	> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of
> Nolte, Tim
> 	> Sent: Wednesday, November 04, 2009 4:08 PM
> 	> To: Paul Spencer
> 	> Subject: RE: [fusion-users] MapServer Legend Icons
> 	> Paul,
> 	> I attempted this, however what I found was that the way the
> loading
> 	> process happens it is not enough to just stick the scale
> ranges into
> 	> the
> 	> PHP $_SESSION. I'm finding that all of the individual maps in
> many
> 	> cases
> 	> don't yet exist in the SESSION when the corresponding
> 	> LoadScaleRanges is
> 	> called. Do you have any thoughts on how Fusion could be
> changed to
> 	> only
> 	> call LoadScaleRanges 1 time after all of the LoadMap calls
> have
> 	> finished? I think this could be the fix. The only other option
> I see
> 	> is
> 	> that the whole scale ranges creation process needs to be
> duplicated in
> 	> LoadScaleRanges script. I'm not sure but perhaps this
> functionality
> 	> needs to be added to the Utilities script?
> 	> iPCS Wireless, Inc.
> 	> Kentwood, MI 49512
> 	> PCS:    616-706-2438
> 	> Fax:    616-554-6484
> Paul
> 	> Spencer
> 	> Sent: Monday, October 26, 2009 3:07 PM
> 	> To: Nolte, Tim
> 	> Ohhhhh - light goes on - doh!  You have 6 maps in the same map
> group!
> 	> This will need a bit of work :)  We need to modify the
> scale_ranges
> 	> array in the session so that it is subdivided by map name.
> LoadMap
> 	> needs to set
> 	> $_SESSION['scale_ranges'][$mapName]
> 	> and LoadScaleRanges needs to use the same thing when
> referencing it.
> 	> Do you think you could make these changes and test?  If it
> works, I'll
> 	> file the bug and commit.  If you don't want to try first, I
> can take a
> 	> stab at it and commit but I'm not really set up to test right
> now.
> 	> Thanks Tim
> 	> Paul
> 	> On 2009-10-26, at 2:39 PM, Nolte, Tim wrote:
> 	>> What I am seeing with Firebug is that there are 6 calls to
> 	>> LoadMap.php,
> 	>> which are my 5 main maps and 1 overview map. After the 5th
> 	>> LoadMap.php
> 	>> call then the LoadScaleRanges.php calls begin, there are 5
> calls. One
> 	>> thing that I noticed also is that the MapTips are not working
> and
> 	>> what
> 	>> is being POSTed to the MapTip.php script is the wrong map for
> the
> 	>> layer
> 	>> that I've selected for MapTips. Seems like there could be a
> problem
> 	>> with
> 	>> using the SESSION if the LoadMap.php is not adding something
> to the
> 	>> SESSION to directly link the call to the LoadScaleRanges.php
> so that
> 	>> it's not pulling the wrong scale_ranges. Is there any
> debugging
> 	>> information that I can send?
> 	>> - Tim
> 	>> iPCS Wireless, Inc.
> 	>> Kentwood, MI 49512
> 	>> PCS:    616-706-2438
> 	>> Fax:    616-554-6484
> Paul
> 	>> Spencer
> 	>> Sent: Monday, October 26, 2009 11:30 AM
> 	>> To: Nolte, Tim
> 	>> Hi Tim,
> 	>> The legend icon stuff is working in another project that Paul
> 	>> Deschamps is working on, he has multiple map files and a menu
> for
> 	>> changing between them.  The legend does appear to update
> correctly
> 	>> when changing maps.
> 	>> The way it *should* work is that LoadMap.php populates a
> session
> 	>> variable 'scale_ranges' with an array of each scale range of
> each
> 	>> class of each layer.  LoadScaleRanges.php uses this array to
> get the
> 	>> class for each scale range and draw the icon at the
> appropriate scale
> 	>> for that class and then combines them all into a single
> image, and
> 	>> returns a set of CSS offset values for use by the legend - so
> each
> 	>> scale range has the same image source but different offsets.
> 	>> I suspect what is going wrong is that the scale_ranges array
> is
> 	>> somehow the wrong one.  We need to know what sequence is
> causing
> 	>> this.  Is LoadScaleRanges being called before LoadMap
> finishes?  Or
> 	>> are you programmatically changing maps while loading them or
> between
> 	>> loading and calling LoadScaleRanges?
> 	>> Cheers
> 	>> Paul
> 	>> On 2009-10-26, at 10:38 AM, Nolte, Tim wrote:
> 	>>> Last week I had posted about a problem with my legend icons
> not
> 	>>> showing
> 	>>> up. I have multiple MapServer mapfiles defined. I'm not sure
> if the
> 	>>> problem I'm having is solely related to having multiple
> mapfiles or
> 	>>> that
> 	>>> I recently updated to the latest Fusion trunk. I can say
> that the
> 	>>> problem with the legend icons is because of an error in
> 	>>> layers\MapServer\php\LoadScaleRanges.php, the section that
> it is
> 	>>> having
> 	>>> a problem with is:
> 	>>>     $oImg = $oClass->createLegendIcon($nIconWidth,
> $nIconHeight);
> 	>>> This is failing with the error:
> 	>>>     Fatal error: Call to a member function
> createLegendIcon() on a
> 	>>> non-object
> 	>>> If I change the code to make sure that '$oClass' is not NULL
> then
> 	>>> legend
> 	>>> icons do get created but they are not being created
> correctly. I'm
> 	>>> not
> 	>>> sure if this is something where I need to use a different
> built-in
> 	>>> function to use one of the default Fusion layer icons? If
> anyone has
> 	>>> any
> 	>>> ideas it would be a big help.
> 	>>> - Tim
> 	>>> iPCS Wireless, Inc.
> 	>>> Kentwood, MI 49512
> 	>>> PCS:    616-706-2438
> 	>>> Fax:    616-554-6484
> 	>>> _______________________________________________
> 	>>> fusion-users mailing list
> 	>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> 	>>   Paul Spencer
> 	>>   Chief Technology Officer
> 	>>   DM Solutions Group Inc
> 	>>   http://research.dmsolutions.ca/
> 	>    Paul Spencer
> 	   Paul Spencer
>   Paul Deschamps
>   Applications Specialist
>   DM Solutions Group Inc.
>   Office: (613) 565-5056 x28
>   pdeschamps at dmsolutions.ca
>   http://www.dmsolutions.ca
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
    Paul Spencer
More information about the fusion-dev mailing list
