[fusion-dev] Custom widget problem
Zak James zjames at dmsolutions.ca
Wed Oct 7 13:44:08 EDT 2009
You will need to make some changes to get custom widgets working with
the latest version. Your best bet is to take a look at one of the
included widgets to see what has changed between releases.
The biggest difference is that Jx elements have been renamed so Jx* is
now Jx.* - those references need to be changed in your code. Also, you
need to supply a uiClass property somewhere in your class.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
http://research.dmsolutions.ca
On 2009-10-06, at 4:56 PM, web wrote:
> Hi everybody,
> I have a widget that works with the previous version of mapguide,
> but with the last beta version an error occurs when the site is
> loading:
> Fusion Error:
> WARNING: Exception occurred in AJAX callback.
> widget.paramRegister is undefined
> Location: undefined (49896))
> in FusionSF.js
> It seems to be a problem of initialization of my widget, do I need
> to change something to my widget so that it can work with the beta
> version of mapguide?
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
