[fusion-dev] Defects and branch for MapGuide 2.2
Trevor Wekel trevor_wekel at otxsystems.com
Thu Jul 8 07:58:01 EDT 2010
Hi Mike,
I was hoping to create a build of MapGuide from "release" branches next week.  We have already branched the MapGuide vault for MapGuide 2.2 and I would like to switch the external references to CS-Map and Fusion to "release" branches before running the build.  Are we ready to create the Fusion v2.2 branch from trunk?  The current batch of submissions looks ok to me.
Thanks Mike,
Trevor
-----Original Message-----
Sent: June 24, 2010 4:38 PM
To: 'Mike Adair'
Cc: fusion-dev at lists.osgeo.org
Subject: RE: [fusion-dev] Defects and branch for MapGuide 2.2
Yep.  That sounds perfect.  I think the RFC89 changes have already been submitted to trunk.
Thanks Mike!
Trevor
Sent: June 24, 2010 11:18 AM
To: Trevor Wekel
Subject: Re: [fusion-dev] Defects and branch for MapGuide 2.2
So because of this and the of RFC89, it means that at some point Fusion
will not be backward compatible with MGOS before v2.2.  I discussed this
with Paul and we propose the following release schedule for Fusion:
- v2.0 finish up and finalize this release; other than regressions, I
would like have any outstanding projection issues resolved for this release
- we skip v2.1 just so that the version numbers are in synch for MGOS2.2
- just for this release
- v2.2 a new branch from trunk to be released along with MGOS2.2 with
changes for RFC89 and the GetSiteVersion changes (and any other issues
identified as important) - this is not backward compatible with MGOS < 2.2
- v2.3 will be the merge of the Jx3 branch back to trunk
Comments?
Mike
On 6/22/2010 1:40 PM, Trevor Wekel wrote:
> Ok.  Thanks Mike.
> I also have another patch to replace the call with MgServerAdmin.GetInformationProperties with a call to MgServerAdmin.GetSiteVersion.  I will open an enhancement for it as well.  GetInformationProperties was recently mutexed to fix another defect.  As a side effect, the multiuser performance for LoadMap.php dropped.  GetSiteVersion does not require the mutex and is significantly faster.
> Regards,
> Trevor
> From: Mike Adair [mailto:madair at dmsolutions.ca]
> Sent: June 22, 2010 10:32 AM
> To: Trevor Wekel
> Trevor,
> Both of those involve correcting the projection support so I'd like to
> get those into the 2.0 release, and I hope to have some time free up
> this week to look at them and finalizing the 2.0 release.  The Fusion
> 2.0 branch will likely be your best bet for including in MGOS2.2 since
> once that is released we will be working on the 2.1 which will include
> updates to the OL and Jx libraries and may introduce other issues.
> Mike
> Trevor Wekel wrote:
>> Hello list,
>> Has there been any further discussion on how to resolve
>> http://trac.osgeo.org/fusion/ticket/394
>> http://trac.osgeo.org/fusion/ticket/395
>> They are basically the same issue with Arbitrary XY coordinate
>> systems.  If an appropriate fix is too far out, can I request a Fusion
>> branch for MapGuide Open Source 2.2?
>> Regards,
>> Trevor
>> fusion-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
    Michael Adair
    Senior Software Architect
    DM Solutions Group Inc.
    Office: (613) 565-5056 x26
    http://www.dmsolutions.ca
    http://research.dmsolutions.ca
More information about the fusion-dev mailing list
