[fusion-dev] Custom Printing Widget Issue
Kori Maleski kori.maleski at gmail.com
Wed Mar 24 14:29:39 EDT 2010
Hi Mike,
Fixed the issue.  I had the OpenLayers.Map object inheriting the
maxResolution of the Fusion Map object.  (I just set the new map options to
that of the parent by default).
Somehow this let the map correctly render in the html preview page but fail
in the PDF rendering.
I will post the widget if I get a chance.
Cheers,
Kori Maleski
On Tue, Mar 23, 2010 at 12:18 PM, Kori Maleski <kori.maleski at gmail.com>wrote:
> Thanks Mike,
> I am trying to find out if it is some issue with Adobe or Primo print to
> pdf software.
> It doesn't make sense that the Google layer prints but the MapGuide fails.
> A head scratcher.
> I will post code if I cannot resolve
> Cheers,
> Kori Maleski
> On Tue, Mar 23, 2010 at 11:55 AM, Mike Adair <madair at dmsolutions.ca>wrote:
>> I checked the MapGuide Layer hierarchy in OpenLayers and I couldn't find a
>> tile size restriction anywhere.
>> Mike
>> Kori Maleski wrote:
>>> Hi all,
>>> I am developing a custom printing widget that prints the MapGuide map
>>> with a
>>> Commercial overlay such as Google to all ANSI paper sizes.  To do this I
>>> am
>>> using an OpenLayers.Map object to display a print preview.
>>> The widget and code is sound (I think) - working as expected but:
>>> When printing to PDF, the MapGuide layer does not print when the
>>> OpenLayers.Layer.MapGuide tileSize width is greater than 1000px.
>>> So 11x17 portrait w 792px h 1224px MapGuide Layer displays in the preview
>>> and
>>> prints to PDF 17x22 portrait w 1224px h 1584px MapGuide Layer displays in
>>> the preview and
>>> fails to appear in the PDF
>>> The Google layer does print to the PDF with no issue no matter what ANSI
>>> size is used.
>>> Is there some kind of MapGuide tileSize constraint for the
>>> OpenLayers.Layer.MapGuide?  Or does anyone have an idea or suggestion of
>>> what may be wrong?  I set the tileSize.w and tileSize.h to the layer
>>> before
>>> rendering.
>>> I don't have a plotter to test if the Print Preview actually prints to
>>> printer with/or without the same issue.
>>> Hence why I need this to go to PDF.
>>> Any pointers would be most welcome.
>>> Cheers,
>>> Kori Maleski
>>  Michael Adair
>>  Senior Software Architect
>>  DM Solutions Group Inc.
>>  Office: (613) 565-5056 x26
>>  http://www.dmsolutions.ca
>>  http://research.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20100324/7c5d6e5c/attachment.html
More information about the fusion-dev mailing list
