[fusion-dev] RE: [fusion-users] v2.0.0 release candidate available
Berdel, Brian brian.berdel at mcmtrans.com
Fri Mar 26 08:35:24 EDT 2010
I have confirmed that the issue with selecting the root map, and it not turning the map back on after has it been turned off Still exists with the Standard template / Appdef / Sheboygan dataset.  So that does not appear to be package dependent:
Line: 1038  mapguide.js
Error: 'this.oLayerOL2' is null or not an object
However the other error does not occur on the tiled Sheboygan example, but that is also not a raster dataset.  I am using a MrSID dataset...
'LegendLabel' is null or not an object in legend.js (Line 9 in createTreeItem) and the variable style is coming in as null.
I will also update the ticket with this information.
Thanks,
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444 x 260
www.mcmtrans.com<http://www.mcmtrans.com>
Sent: Thursday, March 25, 2010 10:09 PM
To: Berdel, Brian
Cc: Mike Adair; fusion-dev at lists.osgeo.org; fusion-users
Subject: Re: [fusion-dev] RE: [fusion-users] v2.0.0 release candidate available
On 1.1, I recently saw a similar (but probably not same) problem when I had a map with an invisible layer at the root of the legend tree.  Also had problems when the legend label _was_ blank in the MapDefinition, and when I had layers with undefined min or max scales.  I think.  Didn't spend the time putting together a reproducible test case because 1.1 is so old and I had workarounds.
I wouldn't be surprised if this was hard to troubleshoot without a package (data/layers/map/appdef) that demonstrates the problem.
On 25 March 2010 12:57, Berdel, Brian wrote:
No problem
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20100326/f53ccbf9/attachment-0001.html
More information about the fusion-dev mailing list
