[fusion-dev] Re: Jx API Update
Paul Deschamps pdeschamps at dmsolutions.ca
Tue Sep 14 09:44:17 EDT 2010
Edi,
If you perhaps shared a link to your application we could better direct you
to where the issue is.
Cheers
Paul D.
On Tue, Sep 14, 2010 at 3:12 AM, Edi.Karadumi <edikaradumi at gmail.com> wrote:
> i have already seen the jxlib page, but that is not working with me. Do jx
> work only with fusion 2.0? I have fusion 1.1 and i have problems upgrading
> to fusion 2.0, cuz the map dont shows
> On Tue, Sep 14, 2010 at 9:04 AM, zspitzer [via OSGeo.org] <
> ml-node+5529149-131198694-182671 at n2.nabble.com<ml-node%2B5529149-131198694-182671 at n2.nabble.com>
> <ml-node%2B5529149-131198694-182671 at n2.nabble.com<ml-node%252B5529149-131198694-182671 at n2.nabble.com>
> > wrote:
> > http://www.google.com/search?q=jxlib
> > On Tue, Sep 14, 2010 at 4:57 PM, Edi.Karadumi <[hidden email]<
> http://user/SendEmail.jtp?type=node&node=5529149&i=0>>
> > wrote:
> > > where can we find documentations on how to use jx library with fusion?
> I
> > am
> > > using fusion 1.1 and i find a bit difficult to use jx components when
> > > creating custom widgets.
> > > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529138.html
> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529138.html?by-user=t
> > > Sent from the Fusion Developers mailing list archive at Nabble.com.
> > > _______________________________________________
> > > fusion-dev mailing list
> > > [hidden email] <http://user/SendEmail.jtp?type=node&node=5529149&i=1>
> > > http://lists.osgeo.org/mailman/listinfo/fusion-dev
> > Zac Spitzer
> > Solution Architect / Director
> > Ennoble Consultancy Australia
> > http://www.ennoble.com.au <http://www.ennoble.com.au?by-user=t>
> > http://zacster.blogspot.com <http://zacster.blogspot.com?by-user=t>
> > +61 405 847 168
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=5529149&i=2>
> >  View message @
> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529149.html
> > To unsubscribe from Jx API Update, click here<
> http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=2062075&code=ZWRpa2FyYWR1bWlAZ21haWwuY29tfDIwNjIwNzV8LTE4NTQwODgxMTM=
> http://osgeo-org.1803224.n2.nabble.com/Jx-API-Update-tp2062075p5529167.html
> fusion-dev at lists.osgeo.org
    Paul Deschamps
    Applications Specialist
    DM Solutions Group Inc.
    Office: (613) 565-5056 x28
    http://www.dmsolutions.ca
    http://research.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20100914/b0dc56b0/attachment.html
More information about the fusion-dev mailing list
