[fusion-dev] A defect in ViewOptions widget?
Michael Adair
madair at dmsolutions.ca
Fri Aug 5 09:30:02 EDT 2011
Arthur,
I assume you are referring to http://trac.osgeo.org/fusion/ticket/467, I
had a quick look at that last week and my guess is that the WKT coming
back for the pseudo-mercator is incorrect or not being parsed correctly
but I haven't got further than that yet.
Mike
On 05/08/2011 4:22 AM, Arthur Liu wrote:
> Hi experts,
> I meet a strange problem on commercial layer based map, and I think
> this might be a defect in ViewOptions widget. I would like to know if
> there's anyone else who ever met similar issues before.
> The map I used is defined in Google Mercator(EPSG:900913) and it
> works fine when I use the default unit(meter) ViewOptions.
> However, when I change the unit to "degree" in ViewOptions, the
> displayed value from the CursorPosition is not correct anymore.
> The expected value should be (-119.9707, 40.0646), but the value I get
> is (-120.7833,44.0925). The longitude value is acceptable while the
> latitude value is far from the correct value.
> In ViewOptions widget, it simply does an unit conversion regardless
> which coordinate system is being used. It just times
> 0.000009044(degrees per meter pre-defined in fusion.js) based on my
> original position value to get the result. I have little experience
> about coordinate system, but it seems that EPSG:900913 is flatter than
> other WGS84 coordinate systems. Is it the cause of this issue? Is it
> needed for ViewOptions to enhance its function?
> Regards,
> Arthur
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20110805/3bac8048/attachment.html
More information about the fusion-dev
