[fusion-dev] RE: Replacing the Redline widget
Mars Wu mars.wu at autodesk.com
Wed Aug 31 22:55:40 EDT 2011
Hi Jackie,
I saw your submission for replacing the widget. Just to confirm: has everything been done for the new widget?
Thanks,
Mars
-----Original Message-----
From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, June 21, 2011 5:19 PM
To: fusion-dev at lists.osgeo.org
Subject: [fusion-dev] RE: Replacing the Redline widget
Sure no problem. It's mostly done, just lacks the required localization.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Replacing-the-Redline-widget-tp6494549p6499201.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
fusion-dev mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
