[fusion-dev] Re: Adding WMS in Application Definition
Michael Adair madair at dmsolutions.ca
Tue Jul 5 09:35:08 EDT 2011
I guarantee the projection issue will be a problem for you, but I can
see a number of other issues in your XML snippet:
- it may be a MGE construct but Fusion uses <MapGroup> not <MapGroupType>
- you are trying to overlay Google street map over the WMS over the
MapGuide base layer, the Google layer is opaque so you won't see the 2
underneath and the Google (layer is tiled - singleTile=false)
Using the XML below I was able to see in Firebug that tiled WMS request
are being made but nothing is being returned because the WMS doesn't
support Google mercator.  Also note that my MapGuide map is also in
Google mercator
Mike
<MapGroup id="testMap">
<Map>
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
<ResourceId>Library://Samples/Sheboygan/Maps/SheboyganMercator.MapDefinition</ResourceId>
<SelectionAsOverlay>true</SelectionAsOverlay>
<SelectionColor>0x0000FFA0</SelectionColor>
<ImageFormat>PNG</ImageFormat>
<Options>
<isBaseLayer>false</isBaseLayer>
<userOverlay>true</userOverlay>
<projection>EPSG:900913</projection>
</Options>
</Extension>
</Map>
<Map>
<Type>WMS</Type>
<SingleTile>false</SingleTile>
<Extension>
<ResourceId>http://onearth.jpl.nasa.gov/wms.cgi?</ResourceId>
<Options>
<name>NASA</name>
</Options>
<Parameters>
<layers>global_mosaic</layers>
</Parameters>
</Extension>
</Map>
<Extension />
</MapGroup>
On 04/07/2011 4:48 PM, ggdm wrote:
> Thank for the tip but I'm afraid that's not the point since, using firebug, I
> can't see any web request to the WMS server (the div in which I should find
> it is empty).
> Still waiting for someone to test my xml and/or give suggestions to see if
> it behaves in the same way.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-WMS-in-Application-Definition-tp6514397p6547362.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
